Hello everybody. My first post here, I tried searching for a solution but didn't find any, so apologies if this issue is already discussed in another thread. In that case, please point me to the correct place and I'll continue there.
In any case, I bought a 2017 Audi Q7 e-tron about 5 months ago. It has about 180000 km or about 115000 miles on it. There is a persistent P20EE - Scr catalyst efficiency too low error code.
So far it has been to the shop twice, the first NOx sensor has been swapped twice, ECU was updated to the latest software version, Ad-blue injector was cleaned in an ultrasonic cleaner, Ad-blue quality and amount has been verified, Ad-blue injector spray pattern and injection amount has been verified. Still the same issue remains. I have taken logs with vcds a couple of times and it looks like the ppm readings for 1st and 2nd NOx sensor are pretty much the same and the ad-blue injection isn't activated. Yesterday I did the forced particle filter regeneration. It was completed but the result was "malfunction" with three new error codes. Before the regen burn, I only got the P20EE code always about 60 miles after clearing it.
I'm fresh out of ideas to try next. Mind You, I haven't gotten the doom countdown yet. Check engine light will light up always after about 60-70 miles after clearing codes but otherwise the car seems to work just fine.
Monday,13,October,2025,18:20:28:17919
VCDS Version: Release 25.3.2 (x64) Running on Windows 10 x64
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 4M0 907 401 A HW: 059 907 309 F
Component and/or Version: 3.0TDI MD1 H23 0010
Software Coding: 2A2A403A057E050335182B00000000000000000000000000
Work Shop Code: WSC 56880 112 00000
ASAM Dataset: EV_ECM30TDI0114M0907401A 001018 (AU73)
ROD: EV_ECM30TDI0114M0907401A.rod
VCID: 270AFDF99F694BC2EF9-8072
31000 - NOx Sensor 2 Bank 1
P22A0 00 [01100000] - Signal too Small
Mileage: 184208 km
Date: 2025.10.13
Time: 07:25:34
Engine speed: 1390.50 /min
Normed load value: 74.1 %
Vehicle speed: 103 km/h
Coolant temperature: 79 °C
Intake air temperature: 6 °C
Voltage terminal 30: 11.880 V
Engine status: COENG_RUNNING
5188 - Particle Filter
P2463 00 [00100100] - Excessive Soot Accumulation
Mileage: 184291 km
Date: 2025.10.13
Time: 17:48:59
Engine speed: 974.00 /min
Normed load value: 24.7 %
Coolant temperature: 70 °C
Intake air temperature: 24 °C
Voltage terminal 30: 12.760 V
P Flt Ld fac Ash Cor: 1.0000
Particul.filter diff.pressure: 15 hPa
Exh t Adap T Oxi Cat Ds: 156.2 °C
Exh t Adap TP Flt Ds: 156.8 °C
Current operating mode_2-Bits 0-7: 0
Current operating mode_2-Bits 0-7: 2
Current operating mode_2-Bits 0-7: 1
9645 - Reductant
P20E8 00 [01100100] - Pressure too Low
Mileage: 184291 km
Date: 2025.10.13
Time: 17:42:23
Engine speed: 849.00 /min
Normed load value: 64.3 %
Coolant temperature: 68 °C
Intake air temperature: 18 °C
Voltage terminal 30: 12.640 V
Outside temperature: 8.0 °C
Pressure sensor for reducing agent: measured pressure: 70 hPa
Pump for reducing agent: speed: 2960.0 /min
Sensor for reducing agent tank temperature: temperature: 8.5 °C
Reducing agent pump: activation: 50.00 %
Sensor for reducing agent fill level: fill level height: 209 mm
Sensor 2 for temp. reducing agent: act. value: 8.0 °C
17277 - SCR NOx Catalyst Bank 1
P20EE 00 [01100000] - Efficiency too Low
Mileage: 184160 km
Date: 2025.10.11
Time: 16:02:12
Engine speed: 2269.50 /min
Vehicle speed: 67 km/h
Coolant temperature: 90 °C
Intake air temperature: 16 °C
Voltage terminal 30: 13.120 V
SCR efficiency test overall: -51.10 %
SCR error threshold of efficiency test: 20.00 %
SCR efficiency test 1: 0.000
Particle filter: unburned fuel calculated: 0.000
Mean temperature of SCR catalyst: 245.0 °C
Long-term adaptation of reduction agent dosage: 1.00
Monday,13,October,2025,18:27:47:17919
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
VIN: WAUZZZ4M2HD019939 License Plate:
Chassis Type: 4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 18 19 23 29 36 39 42 44 46 47
51 52 5F 69 6C 6D 74 81 8B 8C A5 AC BA BB BC C5 C6 CA
VIN: WAUZZZ4M2HD019939 Mileage: 184291km-114513miles
8C-HV Battery -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CVZA) Labels: Redir Fail!
Part No SW: 4M0 907 401 A HW: 059 907 309 F
Component: 3.0TDI MD1 H23 0010
Revision: C7H23--- CVN: 67C2796F674A713E8947E11D755A2113
Shop #: WSC 56880 112 00000
VINID: 9D196AAAA11D09850004924324CA0D8078
Active accelerator pedal:
Subsystem 1 - Part No SW: 4M1 723 523 HW: 4M1 723 523
Component: J1115 - FFP H17 0007
Serial number: 123456789ABCDEFGHIJK
Clutch electronics 1:
Subsystem 2 - Part No SW: 0D7 142 057 D HW: 0D7 142 057 D
Component: J1128 CCU H04 0031
Mileage: 184208 km
Date: 2025.10.13
Time: 07:25:34
Mileage: 184291 km
Date: 2025.10.13
Time: 17:48:59
9645 - Reductant
Mileage: 184291 km
Date: 2025.10.13
Time: 17:42:23
Mileage: 184160 km
Date: 2025.10.11
Time: 16:02:12
Part No SW: 4M0 927 158 M HW: 0D7 927 156 B
Component: 0D7 30TDIRdW H03 1009
Revision: --H03--- CVN: AB92E607
Coding: 100000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMALX52011 002011
ROD: EV_TCMALX52011.rod
VCID: 3E24389D60F3EA0ABCF-806A
ATF pump:
Subsystem 1 - Part No SW: 4M0 927 154 AA HW: 0D7 321 281 A
Component: V552 ATFP D.4 0000
Serial number: 00006177
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4M0 907 379 P HW: 4M0 907 379 P
Component: ESP9 Premium H09 0649
Dataset Number: 4M0909504H 0030 CVN: 9E814F6B
Coding: 2C9830B232A30A9FD1A71894188652AAF6A6D2340C4C508B18184A556F654B
Shop #: WSC 25780 001 1048576
ASAM Dataset: EV_ESP9BOSCHAU536P 011013
ROD: EV_ESP9BOSCHAU536P_AU73.rod
VCID: 44D04A750E1F80DAEAB-8010
415488 - TPMS Warning; Front Left Tire
C1055 00 [00101000] - Flat
Mileage: 183893 km
Date: 2025.10.07
Time: 07:07:44
450560 - Databus
U1123 00 [00101000] - Received Error Message
[Signal_FT_Tuer_Status_error_(3)]
Fault Frequency: 32
Mileage: 183663 km
Date: 2025.09.30
Time: 08:22:31
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M1 959 760 E HW: 4M1 959 760 E
Component: MEM-BFS 008 0031
Serial number: 00000219821937 Dataset Number: 4M0909866C 0016
Coding: 001010000000B0410000010101010000110000313100000000000000000000
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
VCID: 3B22318973E1FF229B1-806E
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4M0 820 043 AD HW: 4M0 820 043 AD
Component: Klima Zone 3 H52 0093
Coding: 661A48094544400D02220280800000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 678ABDF95FE98BC22F9-8032
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000001057464
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0005
Serial number: 2298494800PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: Klima Heck H40 0073
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0266
Dataset Number: 4M0909514P 0050
Coding: C2501942C17900CD0101061010BF8CF9130331008000000000000000E0001601004100AB32B61A
Shop #: WSC 12345 123 61029
VCID: 025C8C6D548B4EEA987-8056
Subsystem 1 - Part No SW: 4M1 955 119 A HW: 4H2 955 119 C Labels: 1KX-955-119.CLB
Component: WWS536 160728 043 0893
Serial number: 89555300401621000144
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 62269014
Coding: 02006E
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 28 06 2016 00466259
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE130061611521437
Interior Light Module:
Subsystem 5 - Part No SW: 4M0 947 135 CK HW: 4M0 947 135
Component: J528-Dachele H14 0130
Serial number: Q00192388
Subsystem 6 - Part No SW: 4M0 925 301 H HW: 4M0 925 301 H
Component: SL-Q7NF/AU736 H10 0013
Serial number: 00000000000000003668
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 4M0 907 561 D HW: 4M0 907 561
Component: LRR4 H09 0220
Dataset Number: 4M0909863L 0027
Coding: 5473FFEB58FFEC0A949C80E0
ASAM Dataset: EV_ACCBOSCHAU736 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 313E13A1A1AD057231D-8064
2135 - Databus
U1122 00 [00001000] - Implausible Message
[FAULT_DRIVER_DOOR_INVALID]
Fault Frequency: 74
Reset counter: 250
Mileage: 183663 km
Date: 2025.09.30
Time: 08:06:40
Control Module temperature: 19 °C
Voltage terminal 15: 12.1 V
2091 - Databus
[FAULT_DRIVER_DOOR_STATE_FAIL]
Fault Frequency: 74
Reset counter: 250
Mileage: 183663 km
Date: 2025.09.30
Time: 08:06:40
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4M0 959 655 HW: 4M0 959 655
Component: Airbag10.44 H70 0086
Serial number: 003L1002SUA9 Dataset Number: 4M0909602S 0001
Coding: AACCF0C00CA0000098F600F3C04C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005.rod
VCID: 78A8EE850257143AB63-802C
Subsystem 1 - Part No SW: ----------- HW: 442 060 709 16
Serial number: 3577Y00AD1FB75D2616H
Subsystem 2 - Part No SW: ----------- HW: 442 060 709 16
Serial number: 3587Y00B91FB75D3F30L
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 006 16
Serial number: 3517700A1211FA22B21
Subsystem 4 - Part No SW: ----------- HW: 442 0B1 806 16
Serial number: 3527700B5211FA16024$
Subsystem 5 - Part No SW: ----------- HW: 442 0C2 208 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500C92135002A33W
Subsystem 6 - Part No SW: ----------- HW: 442 0C2 208 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500C92135004B37/
Subsystem 7 - Part No SW: ----------- HW: 442 0C3 108 16
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500AF217248312C+
Subsystem 8 - Part No SW: ----------- HW: 442 420 712 19
Component: PedPSensor_D2 21E 0887
Serial number: I0M8U00B1341D0D1853C
Subsystem 9 - Part No SW: ----------- HW: 442 420 712 19
Component: PedPSensor_P2 21E 0887
Serial number: I0N8U00BB2DD6DE0230
Central crash sensor X/Y:
Subsystem 10 - Part No SW: ----------- HW: 410 201 708 16
Component: CentrSensorXY 1C8 0108
Serial number: I0O7800BF20D7DC3F27S
Part No SW: 4M0 907 129 JE HW: 4M0 907 129 JE
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 7CA0F295366F381AD2B-8028
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4M0 920 794 B HW: 4M0 920 794 B
Component: FHybRDW H15 0302
Coding: 040501C07C900008018669703204600000000000
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736_AU73.rod
VCID: 323C1CADA4AB3E6A487-8066
16777046 - Charger for HV Battery
U1139 00 [00001000] - No Communications
[BAP_BatteryControl_0x25 communication error bap_error_timeout heartbeat]
Reset counter: 250
Mileage: 183537 km
Date: 2025.09.26
Time: 12:23:37
Address 18: Aux. Heat (J364) Labels:| 4M0-265-105.clb
Part No SW: 4M0 265 105 E HW: 4M0 265 105 E
Component: HSG H10 0080
Dataset Number: 4M0909858D 0016
Coding: 0D0803
ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
ROD: EV_AuxilParkHeateEBEAU736.rod
VCID: 290EFBC1897D7DB2F9D-807C
Part No SW: 8W7 907 468 C HW: 8W7 907 468 C
Component: Gateway H27 2299
Revision: 4M090005 Serial number: 0584M303816917 Dataset Number: 4M0909515F 0069
Coding: 0201010100020EC08C8201000059003258520007080000000175079E00000000
GVL: 09503C0008440008D4BCC8000006C81811080000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 002060
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: 4BC2614923414FA22B1-801E
Subsystem 1 - Part No SW: 4M0 951 523 A HW: 4M0 951 523 A
Component: J453 MFL H06 0002
Serial number: 20160816192153 01891
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 0113531504
16711690 - Databus
[HVK_Service_Disconnect_BMS]
Reset counter: 248
Mileage: 184125 km
Date: 2025.10.08
Time: 18:14:11
H-V activ. restriction-Airbag control module: not active
H-V activ. restriction-Thermal management: not active
H-V activ. restriction-Engine Electronics: not active
H-V activ. restriction-Transformer for electrical drive: not active
H-V activ. restriction-Hybrid Battery Management: active
H-V activ. restriction-Control module for wireless charging: not active
H-V activ. restriction-High-voltage battery charger: not active
H-V activ. restriction-HV activation prohibited due to accident: not active
H-V activ. restriction-HV activation prohibited due to de-activation: not active
H-V activ. restriction-HV activation prohibited due to blocking: not active
H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 1: not active
H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 2: not active
Address 23: Brake Booster (J539) Labels: None
Part No SW: 4M0 909 059 E HW: 4M0 909 059
Component: J539 EBKV H11 0195
Serial number: 085430010810 Dataset Number: 4M0909524H 0001
ASAM Dataset: EV_BrakeBoostBOSCHAU736 001001
ROD: EV_BrakeBoostBOSCHAU736.rod
VCID: 363420BD48C3224A64F-8062
Brake pressure reservoir:
Subsystem 1 - Part No SW: 4M0 909 057 A HW: 4M0 909 057
Component: VX70BrakeAssi H04 0153
Serial number: 05802861050916120728
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AD HW: 4M0 907 397 D
Component: LCM_MLBevoH05 0023
Dataset Number: 4M0909519C 0009
VCID: 79AEEB81395D0D32C9D-802C
Component: MEM-FS 008 0031
Serial number: 00000219822009 Dataset Number: 4M0909856C 0018
Coding: 001813400000B0410000010101010000110000313100000000000000000000
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Dataset Number: 4M0909520C 0009
Part No SW: 4M0 959 793 E HW: 4M0 959 793 C
Component: TSG FS 009 0060
Serial number: 0000218312500 Dataset Number: 4M0909872VF 0002
Coding: 005C8B005E00000000083080
Shop #: WSC 03057 002 1048576
VCID: 40D846651A079CFACE3-8014
Part No SW: 4M0 909 144 G HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H20 0004
Serial number: 0000252749 Dataset Number: 4M0909852L 0025
Coding: B0150101010001
ASAM Dataset: EV_EPSVWBSAU736 008020
ROD: EV_EPSVWBSAU736_008.rod
VCID: 333219A95BB13762431-8066
Part No SW: 8W0 907 064 BB HW: 8W0 907 064 B
Component: BCM2 MLBevo 018 0328
Dataset Number: 4M0909501G 0060
Coding: 01741E00000000E06309A0006600D80203000000004704502F04000000040030001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 011012
ROD: EV_BCM2HellaAU736_011_AU73.rod
VCID: 7DA6FF912D753112E55-8028
65759 - Databus
Fault Frequency: 54
Reset counter: 250
Mileage: 183522 km
Date: 2025.09.25
Time: 17:23:20
Supply voltages-Terminal 30 power supply: 12.854 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.827 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.772 V
general_additional_freeze_frame-terminal_control_intern_status: 40 04 0A 12 04 38
Part No SW: 4M0 035 466 B HW: 4M1 035 466
Component: 8RF H10 0592
Serial number: 2530204535 Dataset Number: 4M0909510D 0011
Coding: 0135960B00A2AAAAAAAAAA010001
ASAM Dataset: EV_AMPMst24C1Gen2BAO 001002
ROD: EV_AMPMst24C1Gen2BAO_AU73.rod
VCID: 2B0201C983816FA20B1-807E
Address 51: Electric Drive (J841) Labels:. 4MX-907-INV-V1.clb
Part No SW: 4M1 907 080 B HW: 4M1 907 080 B
Component: A73P7828S1000 H02 0018
Revision: --H02--- CVN: 65B0CC01
Coding: 01000000000000000000
ASAM Dataset: EV_DMCM08530214M1907080B 001002
ROD: EV_DMCM08530214M2907080.rod
VCID: 2C0002D5868F689A02B-8078
Part No SW: 4M0 959 792 E HW: 4M0 959 792 C
Component: TSG BFS 009 0060
Serial number: 0000218331790 Dataset Number: 4M0909873VF 0002
VCID: 3FDA459967F9E302B79-806A
Address 5F: Information Electr. (J794) Labels:* 4M0-035-MIB-HGH2.clb
Part No SW: 4M0 035 036 D HW: 4M0 035 036 A
Component: MU-P-LN-EU 052 0678
Serial number: A788I0G7511042 Dataset Number: 4M0909545J 0034
Coding: 013796010000000053110002000A00102F001DE5017001009E
VCID: 2614F0FD986352CAD4F-8072
Subsystem 1 - Part No SW: V03 959 801 FB HW: -----------
Component: ECE 2016/2017 --- 0153
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9GJ402Z0F
Subsystem 3 - Part No SW: 4M0 919 615 H HW: 4M0 919 615 H
Component: ControlUnit_P H15 0209
Serial number: 14091600000000000617
Compact disc data bank:
Component: Gracenote2--- --- 1013
7205 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Battery management (0x25) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 249
Mileage: 183785 km
Date: 2025.10.01
Time: 12:54:59
Voltage terminal 30: 12.2 V
BAP-BAP_Function_ID: 02
Part No SW: 4M0 907 383 D HW: 4M0 907 383 B
Component: Anhaenger H20 0214
Revision: 9A001003 Serial number: 0415865414 Dataset Number: 4M0909527C 0024
Coding: 0110000202010000
Bend angle sensor for trailer:
Subsystem 1 - Part No SW: 4M0 907 811 HW: 4M0 907 811
Component: G820 KNWINSEN H18 0019
Serial number: 31571
Part No SW: 4M0 907 428 E HW: 4M0 907 428
Component: Areaview 2 H13 0315
Serial number: C854607JG003517 Dataset Number: 4M1909460G 0022
Coding: 02350601BF0FA10008404500
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
VCID: 34301AB55EBF305A5AB-8060
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 30952492200000 Dataset Number: 4M0909541G 0025
Coding: 0090
VCID: 48C85E453237A4BA063-801C
Address 74: Chassis Control (J775) Labels:* Redir Fail!
Part No SW: 4M0 907 777 G HW: 4M0 907 777 B
Component: Fahrwerk-SG H34 1213
Serial number: 2109160530 Dataset Number: 4M0909576M 0043
Coding: 98586880F8
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
VCID: 3D263F916DF5F112A55-8068
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004139075698
Coding: 303030
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M1 713 041 F HW: 4M1 713 041 F
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20160914002977
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736.rod
VCID: 2808FEC5927744BAE63-807C
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 4M0 907 541 D HW: 4M0 907 541
Component: LRR4 H10 0220
Dataset Number: 4M0909885H 0023
ASAM Dataset: EV_ACC2BOSCHAU736 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 2F3A15D9B7991382279-807A
Address 8C: HV Battery (J840) Labels: None
Part No SW: 4M0 915 233 E HW: 4M0 915 233 E
Component: BMC_PHEV_PL73 H07 0195
Dataset Number: 4M0909107VA 0001
ASAM Dataset: EV_BECM0842071 001004
ROD: EV_BECM0842071_AU49.rod
VCID: 2D060FD1BD956192155-8078
Battery interrupt switch:
Subsystem 1 - Part No SW: 4M0 915 253 E HW: 4M0 915 253 C
Component: J990 H16 0200
Cell module control module 1:
Subsystem 2 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J991 H08 0105
Cell module control module 2:
Subsystem 3 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J992 H08 0105
Cell module control module 3:
Subsystem 4 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J993 H08 0105
Cell module control module 4:
Subsystem 5 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J994 H08 0105
Cell module control module 5:
Subsystem 6 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J995 H08 0105
Cell module control module 6:
Subsystem 7 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J996 H08 0105
Cell module control module 7:
Subsystem 8 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J997 H08 0105
Cell module control module 8:
Subsystem 9 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J998 H08 0105
Cell module control module 9:
Subsystem 10 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J999 H08 0105
Cell module control module 10:
Subsystem 11 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J1000 H08 0105
Cell module control module 11:
Subsystem 12 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J1001 H08 0105
Cell module control module 12:
Subsystem 13 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J1002 H08 0105
Cell module control module 13:
Subsystem 14 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J1045 H08 0105
Cell module control module 14:
Subsystem 15 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J1046 H08 0105
40968 - High Voltage Service Disconnect
P0B37 00 [01101100] - Open Circuit
High-volt. battery mode: spec. value: Standby-mode
Mode HV battery actual value: Hybrid battery mode: emergency shutdown
H-V battery voltage: 303.70 V
Voltage in H-V system-Voltage of hybrid battery after protection: 14.20 V
Current of H-V / hybrid battery: -0.00 A
Battery temperature: Initialization
Battery charge level: 21 %
Terminal 30 power supply: 12.60 V
Voltage terminal 30C: 0.00 V
Terminal 15 status via CAN: OFF
Power reduction status: not active
Malfunction Indicator Lamp-Start request: not active
Service Disconnect: Status: not connected
Pilot line: Open
Status of voltage freedom: High voltage power off recognized
Crash signal: not active
Protection of posit. terminal of high voltage / hybrid battery: Open
Protection of neg. terminal of high voltage / hybrid battery: Open
Status pre-loader: Open
HV battery: cool. level requirement: no cooling request
Pump for HV battery coolant: specified speed value: 10.00 %
Pump for HV battery coolant: status: No malfunction
HV battery positive terminal insulation resistance-Status: Initialization
HV battery positive terminal insulation resistance: 20470 kOhm
HV battery minus terminal insulation resistance-Status: Initialization
HV battery minus terminal insulation resistance: 20470 kOhm
Entire HV system positive terminal insulation resistance-Status: Initialization
Entire HV system positive terminal insulation resistance: 20470 kOhm
Entire HV system minus terminal insulation resistance-Status: Initialization
Entire HV system minus terminal insulation resistance: 20470 kOhm
maximum voltage for battery cells-Index 1: 0
maximum voltage for battery cells-Value: 3.653 V
minimum voltage for battery cells-Index 1: 0
minimum voltage for battery cells-Value: 3.590 V
Highest measured temperature-Temperature sensor: 0
Highest measured temperature-Value: 23 °C
Lowest measured temperature-Temperature sensor: 0
Lowest measured temperature-Value: 21 °C
Air temperature of H-V / hybrid battery-Intake: -100 °C
Air temperature of H-V / hybrid battery-Exhaust: 22 °C
Maximum charge level-Index 1: 0
Maximum charge level-Value: 38 %
Minimum charge level-Index 1: 0
Minimum charge level-Value: 20 %
Dynamic limit for charge current-Limit for charge current: 0 A
Predictive limit for charge current-Limit for charge current: 0 A
Dynamic limit for discharge current-Limit for discharge current: 0 A
Predictive limit for discharge current-Limit for discharge current: 0 A
Maximum charging voltage: 34.80 V
Minimum discharge voltage: 0.00 V
Minimum dynamic charging voltage: 0.00 V
Minimum predictive charging voltage: 0.00 V
Minimum dynamic discharge voltage: 0.00 V
Minimum predictive discharge voltage: 0.00 V
40971 - High Voltage System Interlock
P0A0A 00 [01101100] - Open Circuit
Mode HV battery actual value: Initialization
H-V battery voltage: Initialization
Voltage in H-V system-Voltage of hybrid battery after protection: Initialization
Current of H-V / hybrid battery: Initialization
Service Disconnect: Status: connected
Pilot line: Open
Status of voltage freedom: Initialization
maximum voltage for battery cells-Value: 5.095 V
minimum voltage for battery cells-Value: 5.095 V
Highest measured temperature-Value: Initialization
Lowest measured temperature-Value: Initialization
Air temperature of H-V / hybrid battery-Exhaust: 26 °C
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 4M0 907 217 D HW: 4M0 907 217 A
Component: BVS H14 0042
Dataset Number: 4M0909466K 0041
Coding: 040703060000040202202385CD0000B4B0F0C010C020
ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
1123671 - Fog mode active
C118E 00 [00001000] - -
Reset counter: 243
Mileage: 183730 km
Date: 2025.10.01
Time: 06:57:58
Control Module temperature: 1 °C
Voltage terminal 15: 14.80 V
1123600 - Predictive Route Data
B1630 02 [00001000] - Signal Failure
Reset counter: 249
Mileage: 184145 km
Date: 2025.10.10
Time: 10:12:18
Control Module temperature: 9 °C
Voltage terminal 15: 12.00 V
1123601 - Predictive Route Data
Reset counter: 242
Mileage: 183665 km
Date: 2025.09.30
Time: 15:59:08
Control Module temperature: 21 °C
Voltage terminal 15: 12.10 V
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 B HW: 4M0 907 355 B
Component: SCR-Stg-G3H04 0005
Dataset Number: 4M0909571H 0003
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736.rod
VCID: 303816A5AAA70C7A3E3-8064
Address BA: Motor Mounts (J931) Labels: None
Part No SW: 4M0 907 145 C HW: 4M0 907 145 B
Component: AEMevo H09 0101
Dataset Number: 4M0909578F 0013
ASAM Dataset: EV_AEMZFAU736 006011
ROD: EV_AEMZFAU736_006.rod
VCID: 2E0408DDB0931A8A2CF-807A
Part No SW: 4M0 959 795 E HW: 4M0 959 795 C
Component: TSG HFS 009 0060
Serial number: 0000218130945 Dataset Number: 4M0909897VF 0002
Coding: 004C89000000000000083080
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 42DC4C6D140B8EEAD87-8016
Component: TSG HBFS 009 0060
Serial number: 0000218131788 Dataset Number: 4M0909896VF 0002
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address C5: Therm. mgt. (J1024) Labels:* 5GE-907-458.clb
Part No SW: 4M0 965 429 D HW: 4M0 965 429 B
Component: TME-Max H04 0021
Serial number: 0025804 Dataset Number: 4M0909476F 0014
Coding: 01
ASAM Dataset: EV_ThermContrVISAU49X 001023
ROD: EV_ThermContrVISAU49X_VW37.rod
VCID: 38282E8542D7D43A763-806C
Subsystem 1 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G395 pT-Sens1 H11 0010
Subsystem 2 - Part No SW: 12E 963 231 G HW: 12E 963 231 G
Component: J848 HV-PTC H09 0208
Serial number: LM162573003810000068
A/C compressor sub:
Subsystem 3 - Part No SW: 4M0 816 797 E HW: 4M0 816 797 E
Component: J842 EKK es33 H05 0017
Serial number: 00000000021051300430
A/C pressure/coolant temperature sensor 2:
Subsystem 4 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G826 pT-Sens2 H11 0010
A/C pressure/coolant temperature sensor 3:
Subsystem 5 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G827 pT-Sens3 H61 0006
Expansion valve 1 for refrigerant:
Subsystem 6 - Part No SW: 4M0 816 682 E HW: 4M0 816 682 E
Component: N636 EV1_KaMi H12 0102
Serial number: 00000000000150134209
Shut-off valve 2 for refrigerant:
Subsystem 7 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N640 AV2_KaMi H12 0102
Serial number: 00000000000130269662
Shut-off valve 3 for refrigerant:
Subsystem 8 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N641 AV3_KaMi H12 0102
Serial number: 00000000000130269481
Shut-off valve 4 for refrigerant:
Subsystem 9 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N642 AV4_KaMi H12 0102
Serial number: 00000000000130269666
Shut-off valve 5 for refrigerant:
Subsystem 10 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N643 AV5_KaMi H12 0102
Serial number: 00000000000130269668
60016 - Interior Pre-Conditioning
P13F1 00 [00101111] - Not Started
Mileage: 184211 km
Date: 2025.10.13
Time: 07:27:15
Expanded ambient data 1-Voltage terminal 30: 0.000 V
Expanded ambient data 1-Vehicle speed: 92 km/h
Expanded ambient data 1-System status: Drive readiness
Expanded ambient data 1-Power quota setting by energy management: 15
Expanded ambient data 1-Status of drive readiness hybrid: Hybrid driving
Expanded ambient data 1-Ambient temperature: 5.50 °C
Expanded ambient data 1-current state of low temp.circ.: 00
Expanded ambient data 1-previous state low-temp.circ.: 00
Expanded ambient data 1-Operating time in the current state of the low temp.circ.: 00
Expanded ambient data 1-current state of high-temp.circ.: 00
Expanded ambient data 1-previous state of high-temp.circ.: 00
Expanded ambient data 1-Operating time in the current state of the high temp.circ.: 00
Expanded ambient data 1-current state of battery low temp.circ.: 07
Expanded ambient data 1-previous state of battery low temp.circ.: 00
Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: E4
Expanded ambient data 1-current state of battery cold circuit: 05
Expanded ambient data 1-previous state of battery cold circuit: 00
Expanded ambient data 1-Operating time in the current state of the cold circuit: DD
Address C6: Batt. Chrg. (AX4) Labels:* 5QE-915-681.clb
Part No SW: 5QE 915 681 AA HW: 5QE 915 681 AA
Component: OBC Delta-ES H57 0721
Dataset Number: 4M0909811E 0013
Coding: 11508B207004
Shop #: WSC 37613 003 1048576
ASAM Dataset: EV_OBCTwoPhaseDT2AU736 006011
ROD: EV_OBCTwoPhaseDT2AU736.rod
VCID: 0B42A14963C10FA2EB1-805E
12583681 - Function Restricted due to Missing Message(s)
[BapErr_RetryNotSuccessful]
Reset counter: 250
Mileage: 184175 km
Date: 2025.10.13
Time: 00:00:03
Part No SW: 4M0 907 594 G HW: 4M0 907 594
Component: SAD_STG_1 013 0005
Dataset Number: 4M0909469F 0014
Coding: 4A8000053602
ROD: EV_SunRoofCONTIAU736_006_VW37.rod
VCID: 3A2C348D7CDBC62A807-806E
End----------(Elapsed Time: 03:03, VBatt start/end: 13.0V/13.0V)-----------
------------------------------19 Faults Found------------------------------
