skoda octavia 2013 airbag fault
raf0468
C?ID=120244
please can some one identify this fault as to where these igniters are situated on the car..
car was involved in a light collision and only seat airbag deployed which has been replaced..
thanks..
Tuesday,26,January,2016,15:34:01:29062
VCDS Version: 15.7.1.0
Data version: 20150904
VIN: TMBBG7NE0D0022877   License Plate: JIMMY 13 BAG
Mileage: 151941km-94411mi   Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: TMBBG7NE0D0022877   Mileage: 151941km-94411miles
Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5517
   Revision: 84H22---
   Coding: 01110012030501090000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L906021M_SK37.rod
   VCID: 2F689F1F766CCA46F4-807A
   Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
   Component: ESC           H75 0333
   Revision: 00000000    Serial number:
   Coding: 1A078A9120220A6E007F060701CA245851045000608024F0004B000040
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
   ROD: EV_Brake1UDSContiMK100ESP_SK37.rod
   VCID: 3A7EBE4BBD2E1FEE53-806E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5E0 820 047 D    HW: 5E0 820 047 D
   Component: AC Manuell    H02 0604
   Revision: 00001K06
   Coding: 00110104000100001000000000400000
   ASAM Dataset: EV_ACManueBHBVW37X 002017
   ROD: EV_ACManueBHBVW37X_SE37.rod
   VCID: 2340632F2AA47E2660-8076
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011307503036
   Coding: 0F0008424207005307A04082B10407080000000000000000000000000000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 4380C3AFCAE45E2600-8016
   Slave 1:
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 130307  041 0570
   Serial number:         130308230500
   Coding: 065DDD
   Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY130590GT1
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000056389806
   Part No SW: 3Q0 959 655 AB    HW: 3Q0 959 655 AB
   Component: Airbag VW20   011 0188
   Revision: --------    Serial number: 003P3P5Q5Z64
   Coding: 98CCC0000C0000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X_SK37.rod
   VCID: 7EF6725BE186F3CE2F-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 603 13
   Serial number: 3576U000000A3BB43C0J
   Subsystem 2 - Part No SW: -----------    HW: 454 001 603 13
   Serial number: 3586U000000E6B053C0H
   Subsystem 3 - Part No SW: -----------    HW: 454 801 403 13
   Serial number: 3516RB6067300000000W
   Subsystem 4 - Part No SW: -----------    HW: 454 801 403 13
   Serial number: 3526R1BAD2100000000
   Subsystem 5 - Part No SW: -----------    HW: 454 801 402 13
   Serial number: 3556V6EF8D400000000O
   Pedestrian protection crash sensor; driver side:
   Subsystem 6 - Part No SW: -----------    HW: 454 801 302 13
   Component: PedP_Sensor_D  114 0149
   Serial number: 2286V92D0F900000000B
   Pedestrian protection crash sensor; front passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 454 801 302 13
   Component: PedP_Sensor_P  114 0149
   Serial number: 2296VF8D0F900000000O
   Subsystem 8 - Part No SW: -----------    HW: 454 801 502 13
   Component: PedP_Sensor_C  114 0149
   Serial number: 2306VDE26F900000000F
9451537 - Igniter 1 for pedestrian protection
          B1038 11 [137] - Short to Ground
                    Mileage: 151941 km
                    Date: 2016.01.25
                    Time: 15:29:39
9451793 - Igniter 2 for pedestrian protection
          B1039 11 [137] - Short to Ground
                    Mileage: 151941 km
                    Date: 2016.01.25
                    Time: 15:29:39
   Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
   Revision: --------    Serial number: 08031304220567
   Coding: 0600
   ROD: EV_SMLSKLOMQB_SK37.rod
   VCID: 76E66A7BC9B6BB8E77-8022
   Part No SW: 5E0 920 950 E    HW: 5E0 920 950 E
   Component: KOMBI         129 1667
   Coding: 272402002000A60001080800040000
   ASAM Dataset: EV_DashBoardJCIMQBAB 008008
   ROD: EV_DashBoardJCIMQBAB_SK37.rod
   VCID: 285A740353829D7E35-807C
   Part No SW: 5Q0 907 530 D    HW: 5Q0 907 530 D
   Component: GW MQB Low    123 1109
   Revision: --------    Serial number: 0000434862
   Coding: 030000040B087300EF000048080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear.rod
   VCID: 326E966B655EE7AE9B-8066
   Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 9170820203
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Component: TSG FS        007 0006
   Serial number: 0000056620265
   Coding: 001000208001020100001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 55A40DF73470D0965E-8000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 01
   ROD: EV_SteerAssisMQB.rod
   VCID: 3D74B557AC0028D676-8068
   Part No SW: 5Q4 959 392     HW: 5Q4 959 392
   Component: TSG BFS       007 0006
   Serial number: 0000056627817
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 7F088F5FE68CFAC624-802A
   Part No SW: 5E0 035 820     HW: 5E0 035 820
   Component: MU-S-D-ER     038 0132
   Serial number: S5C00203130126
   Coding: 03730100FF0000001111120100A800002F0000860100010000
   ASAM Dataset: EV_MUStd4CPASE 002036
   ROD: EV_MUStd4CPASE_SK37.rod
   VCID: 5CB218D3575A01DE61-8008
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5E0 919 605     HW: 5E0 919 605
   Component: ABT_Std_Radio  H44 0020
   Serial number: SKZ8Z9N540016S
Gone But Not Forgotten
The WD in the repair manual would be a great start in identifying the parts but I imagine it is the seat belts for the drivers and passenger side pyrotechnic igniters.
Jef
HQ
:confused: That would imply boom boom bags on the outside of the vehicle for when you are running over people on the sidewalk. I can't find any wiring info for the airbag on this car, so I'm not sure what to make of this.
Short to Ground + collision = most cases, wiring harness damage.
raf0468
C?ID=120244
just an update ..(pedestrian protection igniters) were located near the hinges either side for the bonnet ..
small little pistons which when trigered ignite and lift bonnet a few inches making extra cushioning..
all sorted with new ones ...
