Passat B8, a lot of errorcodes and missing messages
FormerMazda
Sweden
C?ID=602370
Hi!
So I'm one year deep into owning a 2015 passat now, and I've just recently bought my own HEX-V2 after borrowing a friends old VCDS adapter a few times.
The car doesn't really have any problem that shows other than in periods the front assist stops working, and therefore the cruise control works only in limiter mode. (which sucks)
This is a bit annoying since I always use cruise control. I could live without the adaptive cruise, but not live with being limited to speed limiter.
So I started checking this out, and was led into calibration of the radar as probable cause, but I couldn´t figure out how to initiate a calibration.
But I did also see a lot of other errors, many stating missing messages and such. So I abandoned my tries of calibration and just cleared all codes.
And now everything started working again!
And from then I have found it can work for months, and if it starts glitching a clear of codes "fixes" it again.
So now I'm thinking that maybe a misbehaving module or connection or something is causing problems that makes the more sensitive systems to go into safe mode and shuts down?
Attached is a scan with codes that have occurred in just 260km's. (sorry for it being in swedish, I can redo a scan in english if you want)
Am I on the wrong track of maybe a glitching module or bad connection that may cause this?
Also, in the car menu, under driver assists, there´s a option for traffic-sign assistant. But I'm 99,9% sure I don't have a camera for that.
There is a slight chance I have coded that, since I have read about it, but now I can't find where do de-program it..
/Anders
onsdag,08,Oktober,2025,19:27:31:59669
VCDS -- Windows-baserad VAG/VAS-emulator Tändningen Windows 11 x64
VCDS version: AER 25.3.1.1  HEX-V2 CB: 0.4671.5
Dataversion: 20250429 DS365.0
www.vcds.se
VIN: WVWZZZ3CZFE446200   Reg.nr:
Mätarställning: 204229km   Rep.order: Front assist fail
Chassityp: 3C-VW48 (5Q0)
Skanna: 01 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 5F 69 6C
VIN: WVWZZZ3CZFE446200   Mätarställning: 204229km
01-Motor -- Status: Felfunktion 0010
03-Bromselektronik -- Status: OK 0000
05-Behör.kontroll -- Status: Felfunktion 0010
08-Klimatanläggning -- Status: OK 0000
09-Elektron. elcentral -- Status: Felfunktion 0010
10-park/styr-hjälp -- Status: Felfunktion 0010
13-Distansreglering -- Status: Felfunktion 0010
15-Krockkuddar -- Status: OK 0000
16-Rattelektronik -- Status: OK 0000
17-Instrument -- Status: OK 0000
18-Extra/p-värmare -- Status: OK 0000
19-CAN Gateway -- Status: Felfunktion 0010
2B-Styraxellås -- Status: OK 0000
42-Dörrel. förare -- Status: OK 0000
44-Styrservo -- Status: OK 0000
52-Dörrelektr. pass. -- Status: OK 0000
5F-Information Elektr. -- Status: OK 0000
69-Släpvagn -- Status: Felfunktion 0010
6C-Back-kamera -- Status: Felfunktion 0010
Adress 01: Motor (J623-CRLB)       Labels:. AER\04L-907-309-V1.clb
   Artikelnr SW: 04L 906 026 ES    HW: 04L 907 309 R
   Komponent: R4 2.0l TDI   H21 1989
   Revision: B5H21---    CVN: 7FCF0AFE
   Kodning: 0119001A04541D083000
   Verkstad #: WSC 61354 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
   ROD: EV_ECM20TDI01104L906026FK.rod
   VCID: 7F5CDB11B773EDA2F60-802A
   VINID: 9E69EAAAA0D3A9654410608000BAEBA8D6
1 fel funnet:
4865 - Styrdon för registrering av släpvagnsdrift (J345)
          U1003 00 [00100000] - ingen kommunikation
          [Towing recognition control moduleNo Communication]
          Intermittent fel - Ej bekräftad - Testad efter att minnet rensats
             frysta data:
                    Felprioritet: 6
                    Felfrekvens: 17
                    Mätarställning: 204184 km
                    Datum: 2025.10.08
                    Tid: 16:19:25
                    Motorvarvtal: 1397.50 /min
                    Normerat lastvärde: 70.2 %
                    Körhastighet: 69 km/h
                    Kylvätsketemperatur: 89 °C
                    Insugningslufttemperatur: 57 °C
                    Omgivningens lufttryck: 990 mbar
                    Spänning klämma 30: 13.040 V
                    Felfördröjningsräknare enligt OBD: 39
                    Begränsning: gaspedal: 0.0 Nm
                    CAN Status - motorstyrdon-Bits 0-7: 0
                    Automatisk hastighetsreglering: status-Bits 0-7: 3
                    CAN Status - växellådans styrdon-Bits 0-7: 0
                    CAN Status - bromsstyrdon 1-Bits 0-7: 0
                    CAN Status - bromsstyrdon 2-Bits 0-7: 0
                    Ilagd växel-Bits 0-7: 5
Adress 03: Bromselektronik (J104)       Labels: AER\5Q0-907-379-IPB-V1.clb
   Artikelnr SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Komponent: ESC           H42 0625
   Revision: 00000000    Serienummer: 63534000002771
   Kodning: 0FEC6A8F34240B720779060041C349F0562CD0E0608292F11460F078C002
   Verkstad #: WSC 131071 1023 2097151
   VCID: 7EA22615B079E4AAFD6-802A
Ingen felkod funnen.
Adress 05: Behör.kontroll (J518)       Labels:| AER\5Q0-959-435.clb
   Artikelnr SW: 3Q0 959 435     HW: 3Q0 959 435
   Komponent: VWKESSYMQB    023 0522
   Revision: 00023000    Serienummer: 0356834008 Dataset Nummer: V03935214PR 0001
   Kodning: 000F0F0603
   Verkstad #: WSC 05311 115 00314
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   VCID: 77AC33319F43D5E2BE0-8022
   Styrdon för öppning av bakluckan:
2 Funna fel:
133124 - Databuss meddelande saknas
          U1121 00 [00001000] - -
          [Message Klemmen_status_01 missing]
          Intermittent fel - Bekräftad - Testad efter att minnet rensats
             frysta data:
                    Felprioritet: 6
                    Felfrekvens: 1
                    Reset-räknare: 128
                    Mätarställning: 204195 km
                    Datum: 2025.10.08
                    Tid: 16:27:57
12718085 - Databuss meddelande saknas
          [Message ESP_21 missing]
             frysta data:
                    Felprioritet: 6
                    Felfrekvens: 5
                    Reset-räknare: 128
                    Mätarställning: 204192 km
                    Datum: 2025.10.08
                    Tid: 16:25:12
Adress 08: Klimatanläggning (J255)       Labels:| AER\5G0-907-044.clb
   Artikelnr SW: 5G0 907 044 AK    HW: 5G0 907 044 AK
   Komponent: Climatronic   H03 1001
   Revision: 00001K10
   Kodning: 12020104204401012015500200101802
   Verkstad #: WSC 00015 115 00001
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 70BE082DFA2D82DA7FA-8024
   Styrdon för friskluftsfläkt (fram):
   Givare för kylvätsketryck/-temperatur:
   Sensor för luftkvalitet:
   Givare för luftfuktighet: utvändigt:
Adress 09: Elektron. elcentral (J519)       Labels:| AER\5Q0-937-08X-HV1.clb
   Artikelnr SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Komponent: BCM PQ37BOSCH 028 0146
   Revision: --------    Serienummer: 86580301150371 Dataset Nummer: V03935211SE 0001
   Kodning: 00030866C24102F70BA44084B11C07081C80000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DA02119BD7FFFB2E4C-8028
   styrdon för torkarmotor:
   Subsystem 1 - Artikelnr SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: AER\5QX-955-119-V1.CLB
   Komponent: WWS    141213  042 0607
   Serienummer:         141219080011
   Kodning: 0E4DDD
   regn- och ljussensor:
   Subsystem 2 - Artikelnr SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: AER\5Q0-955-547.CLB
   Komponent: RLHS  037 0059
   Serienummer: S5Y15M01D03H16M45S01
   Kodning: 00A8EE
   ljusreglage:
   Subsystem 3 - Artikelnr SW: 3G0 941 633 A    HW: 3G0 941 633 A
   Komponent: E1 - LDS MQB  H01 0032
   Serienummer: 28 10 2014  00000304
   sensor för stöldlarm:
   Subsystem 4 - Artikelnr SW: 5Q0 951 172     HW: 5Q0 951 172
   Komponent: Sensor, DWA  005 0315
   Serienummer: 000000000ZY1434413L7
   larmsiren:
   Subsystem 5 - Artikelnr SW: 5Q0 951 605     HW: 5Q0 951 605
   Komponent: Sirene, DWA  004 0311
   Serienummer: 00000000000061366947
   Givare för luftfuktighet: invändigt:
1 fel funnet:
529173 - Databuss meddelande saknas
             frysta data:
                    Felprioritet: 6
                    Felfrekvens: 44
                    Reset-räknare: 128
                    Mätarställning: 204185 km
                    Datum: 2025.10.08
                    Tid: 16:20:25
                    Status klämma 15: på
                    Status klämma 50: av
                    CAN-Bus_aktiv: på
                    Status Bremslichtschalter (HW): av
                    Status Bremslichtschalter (CAN): av
                    av: Inte aktiverad
                    Parkeringsljus: Inte aktiverad
                    automatisk ljusstyrning: aktiverad
                    Halvljus: Inte aktiverad
                    Positionsljus vänster: Inte aktiverad
                    Positionsljus höger: Inte aktiverad
                    last_wakeup: gültiges Funktelegramm
                    spänning: 12.8 V
                    Utetemperatur: 13.5 °C
Adress 10: park/styr-hjälp (J446)       Labels:| AER\5Q0-919-294.clb
   Artikelnr SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
   Komponent: PARKHILFE 8K  H03 0053
   Revision: --------    Serienummer: 39311500202669 Dataset Nummer: V03935214SK 0001
   Kodning: 0071151101
   Verkstad #: WSC 05311 115 00094
   VCID: 40DE98ED8A0D525ACFA-8014
2 Funna fel:
1079044 - Givare för parkeringshjälp; vänster bak; mitten
          B1077 04 [00001000] - Internt system-fel
             frysta data:
                    Felprioritet: 3
                    Felfrekvens: 1
                    Reset-räknare: 127
                    Mätarställning: 204168 km
                    Datum: 2025.10.08
                    Tid: 16:03:25
13632273 - Databuss meddelande saknas
          [Steuergerät für Anhängererkennung-J345 - Gateway_72.Anhaenger_01_alt - kein Signal/keine Kommunikation]
             frysta data:
                    Felprioritet: 6
                    Felfrekvens: 27
                    Reset-räknare: 128
                    Datum: 2025.10.08
                    Tid: 16:20:24
Adress 13: Distansreglering (J428)       Labels:| AER\3Q0-907-572.clb
   Artikelnr SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Komponent: ACC BOSCH MQB H04 0126
   Dataset Nummer: V03935207UY
   Kodning: 2A40600910FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3334C721CBBBF9C2428-8066
2 Funna fel:
0937 - Databuss mottaget felvärde
          U1123 00 [00001000] - -
          [FAULT_TRAILOR_OBSOLETE_DATA]
             frysta data:
                    Felprioritet: 6
                    Felfrekvens: 22
                    Reset-räknare: 128
                    Mätarställning: 204188 km
                    Datum: 2025.10.08
                    Tid: 16:22:22
                    Styrdonstemperatur: 28 °C
                    Spänning klämma 15: 12.9 V
                    Velocity_vehicle_reference: 21.76 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.03 m/s²
2068 - Databuss mottaget felvärde
          [FAULT_TSK_IRREV_FAIL]
             frysta data:
                    Felprioritet: 6
                    Felfrekvens: 2
                    Reset-räknare: 128
                    Datum: 2025.10.08
                    Tid: 16:19:25
                    Spänning klämma 15: 12.8 V
                    Velocity_vehicle_reference: 18.91 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.09 m/s²
                    Status_ACC_System: ACC_activ_controlled
Adress 15: Krockkuddar (J234)       Labels:| AER\5Q0-959-655.clb
   Artikelnr SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Komponent: Airbag VW20   012 0195
   Revision: --------    Serienummer: 003R1PT1HE4Z Dataset Nummer: 3G0003V____ 0028
   Kodning: 88CCC000008000005C5400CC000800000065
   Verkstad #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 01585DE9C1879B52804-8054
   Bältessträckare vänster:
   Subsystem 1 - Artikelnr SW: 4M0 980 945 A    HW: 4M0 980 945 A
   Komponent: BeltPretRevFL  106 1032
   Serienummer: 3G1857705E0006P00482
   Kodning: 80000A
   Bältessträckare höger:
   Subsystem 2 - Artikelnr SW: 4M0 980 946 A    HW: 4M0 980 946 A
   Komponent: BeltPretRevFR  106 1032
   Serienummer: 3G1857706E0010P00855
   Kodning: 80000A
   krocksensor för sidoairbag på förarsidan:
   Subsystem 3 - Artikelnr SW: -----------    HW: 454 002 112 14
   Komponent: SideSensor_Df  008 0887
   Serienummer: 3576U00000029050021R
   Kodning: 2D2D2D
   krocksensor för sidoairbag på passagerarsidan:
   Subsystem 4 - Artikelnr SW: -----------    HW: 454 002 012 14
   Komponent: SideSensor_Pf  008 0887
   Serienummer: 3586U000000E2D600214
   Kodning: 2D2D2D
   krocksensor för sidoairbag bak på förarsidan:
   Subsystem 5 - Artikelnr SW: -----------    HW: 454 801 812 14
   Komponent: SideSensor_Dr  111 0148
   Serienummer: 3516R60E46305000000.
   Kodning: 2D2D2D
   Krocksensor för sidoairbag bak: passagerarsidan:
   Subsystem 6 - Artikelnr SW: -----------    HW: 454 801 712 14
   Komponent: SideSensor_Pr  111 0148
   Serienummer: 3526R16DA65050000003
   Kodning: 2D2D2D
   krocksensor för airbag fram på förarsidan:
   Subsystem 7 - Artikelnr SW: -----------    HW: 454 801 612 14
   Komponent: FrontSensor_D  114 0149
   Serienummer: 3556V683A49050000009
   Kodning: 2D2D2D
Adress 16: Rattelektronik (J524)       Labels:| AER\5Q0-953-549.clb
   Artikelnr SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Komponent: Lenks.Modul   075 0175
   Revision: FF032032    Serienummer: 20141217400608
   Kodning: 0400
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D20E119FDFF3FB2A4C-8068
Adress 17: Instrument (J285)       Labels:| AER\5G0-920-XXX-17.clb-SRI3
   Artikelnr SW: 3G0 920 741     HW: 3G0 920 741
   Komponent: KOMBI         209 4311
   Kodning: 07A509102780000800887A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   VCID: 61987D6921C73B52E04-8034
Adress 18: Extra/p-värmare (J364)       Labels:| AER\5Q0-963-272.clb
   Artikelnr SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
   Komponent: STH-MQB       006 0069
   Kodning: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   VCID: 3632FE35D8C9ECEA656-8062
   Fjärrkontroll parkeringsvärmare:
   Subsystem 1 - Artikelnr SW: 5Q0 963 513     HW: 5Q0 963 513
   Komponent: R149 T91-LIN  003 0301
   Serienummer: 00000000000001059252
Adress 19: CAN Gateway (J533)       Labels:| AER\5Q0-907-530-V1.clb
   Artikelnr SW: 5Q0 907 530 AC    HW: 5Q0 907 530 M
   Komponent: GW MQB High   212 2203
   Revision: --------    Serienummer: 18121410800790 Dataset Nummer: V03935212LV 0001
   Kodning: 030300344F017300EF00025C080F00010001070000000000000000000000
   GVL: 01543C0000000600C00C80000006480000000000000000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72BA0225F421B0CA89E-8026
   Generator:
   Styrdon för multifunktionsratt:
   Subsystem 2 - Artikelnr SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: AER\3C8-959-537.CLB
   Komponent: E221__MFL-DC1  H16 0040
   Serienummer: 27140003121630064511
   Kodning: 2CFFFF
   Styrdon för batteriövervakning:
   Subsystem 3 - Artikelnr SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Komponent: J367-BDMHella  H04 8050
   Serienummer: 8559435403
   Analog klocka:
   Subsystem 4 - Artikelnr SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Komponent: Analoguhr  209 2002
1 fel funnet:
131655 - Styrdon för registrering av släpvagnsdrift (J345)
          U1003 00 [00001000] - ingen kommunikation
          [Timeout Knoten 0x47 / 69 - Steuergerät für Anhängererkennung]
             frysta data:
                    Felprioritet: 2
                    Felfrekvens: 7
                    Reset-räknare: 128
                    Datum: 2025.10.08
                    Tid: 16:28:04
                    Försörjningsspänning klämma 30: 12.9 V
                    Klämma 15: på
Adress 2B: Styraxellås (J764)       Labels:| AER\1EA-905-861.clb
   Artikelnr SW: 3Q0 905 861     HW: 3Q0 905 861
   Komponent: ELV-MQBB      H05 0031
   Serienummer: 14000316072011
   Kodning: 0000000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71B80D29F1278BD2704-8024
Adress 42: Dörrel. förare (J386)       Labels:| AER\5QX-959-X93-42.clb
   Artikelnr SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Komponent: TSG FS        020 0028
   Serienummer: 201214BLJ15027 Dataset Nummer: 3G0222v____ 0017
   Kodning: 00350A208000028000001000
   VCID: 42DA92E58401404AD9E-8016
   Dörrstyrdon förarsidan bak:
   Subsystem 1 - Artikelnr SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: AER\5QX-959-81X-V1.CLB
   Komponent: Fond FHSG DRV  007 0002
   Serienummer: 00000000000000643358
   Kodning: 010000
Adress 44: Styrservo (J500)       Labels:| AER\5Q0-909-143.clb
   Artikelnr SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Komponent: MQB_PP_APA    203 2033
   Revision: 00000000    Serienummer: 0000116844 Dataset Nummer: 3G0074V____ 0131
   Kodning: 01000010005000
   Verkstad #: WSC 00015 115 00314
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3B24EF01E3EB31829A8-806E
Adress 52: Dörrelektr. pass. (J387)       Labels:| AER\5QX-959-X92-52.clb
   Artikelnr SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Komponent: TSG BFS       020 0028
   Serienummer: 171214BLH05876 Dataset Nummer: 3G0157v____ 0019
   Kodning: 003500208000028000001000
   VCID: 41D89DE981075B52C04-8014
   Dörrstyrdon passagerarsidan bak:
   Subsystem 1 - Artikelnr SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: AER\5QX-959-81X-V1.CLB
   Komponent: Fond FHSG PSG  007 0002
   Serienummer: 00000000000000641118
   Kodning: 090000
Adress 5F: Information Elektr. (J794)       Labels:| AER\5G0-035-MIB-STD2.clb
   Artikelnr SW: 3Q0 035 864     HW: 3Q0 035 864
   Komponent: MU-S-N-ER     H10 0138
   Serienummer: VWZAZ2P4676099 Dataset Nummer: V03935236TK 0001
   Kodning: 02840201FF00000011110001000808031F0100C401200100CC
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 6E821655E019942A6D6-803A
   Indikerings- och manöverenhet 1 för informationselektronik:
   Subsystem 1 - Artikelnr SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Komponent: ABT_Std-2_Nav  H42 1017
   Serienummer: VWZ8Z9RD800Q1C
   Bildataskylt:
   Subsystem 2 - Artikelnr SW: V03 959 821 FP    HW: -----------
   Komponent: ECE DL3 24/25  --- 2210
   Serienummer: --------------------
Adress 69: Släpvagn (J345)       Labels:| AER\5Q0-907-383.clb
   Artikelnr SW: 5Q0 907 383 D    HW: 5Q0 907 383 D
   Komponent: Anhaenger     H14 0137
   Revision: 8A001001    Serienummer: 0356709323 Dataset Nummer: 0G0124v____ 0014
   Kodning: 0100000202000000
   VCID: 382EF00DD2DD1A9A77A-806C
1 fel funnet:
342030 - Databuss komfort
          U0010 00 [00001000] - defekt
          [Convenience data bus - faulty]
             frysta data:
                    Felprioritet: 6
                    Felfrekvens: 73
                    Reset-räknare: 128
                    Datum: 2025.10.08
                    Tid: 16:19:24
Adress 6C: Back-kamera (J772)       Labels:| AER\5Q0-980-556.clb
   Artikelnr SW: 5Q0 980 556     HW: 5Q0 980 556
   Komponent: RVC Compact   H07 0100
   Dataset Nummer: V03935206JJ 0001
   Kodning: 0184020143002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_005.rod
1 fel funnet:
13705483 - Databuss meddelande saknas
          [Oldbit-monitoring Gateway_72.Anhaenger_01_alt]
             frysta data:
                    Felprioritet: 6
                    Felfrekvens: 26
                    Reset-räknare: 128
                    Datum: 2025.10.08
                    Tid: 16:20:25
                    CAN-Kommunikation
Slut--------(Förfluten tid: 02:07, Vbatt start/stopp: 14.7V/14.8V)---------
-------------------------------11 Funna fel--------------------------------
downtime
Finland
C?ID=280813
Can you please do the autoscan with english version of VCDS. There are probably quite less swedish speaking here than english speaking :)
Nothing to with radar itself your problems. Check your trailer wiring, most of the errors are pointing towards your trailer electrics. That will drop out ACC as well when it goes into fault.
FormerMazda
Sweden
C?ID=602370
Thanks for the reply! :)
I will do a re-scan in english, but I've just cleared all errorcodes so I'll give it a few kilometers to accumulate.
But I suspect there's already a lot of them.
I too am suspecting the trailer module/wiring. But I can't say why and don't want to plant a seed so to speak.
So maybe I'll start by checking around that.
I do a lot of towing and haven't seen the lights on my trailers glitch, but of course I'm not staring at my trailer lights all the time.
downtime
Finland
C?ID=280813
Our climate is pretty similar Finland and Sweden and there's a lot of salt on the roads during winters. The socket for the trailer is in a such place that it sucks all the crap from the road. I'm pretty sure the issue is there. It's probably full of water and in worst case it has burned the trailer module. Or has burned the fuse for it and that's why it does not recognize it at all
FormerMazda
Sweden
C?ID=602370
I will check it out, but last time i towed was like a month ago, and it worked just fine then.
That being said, it can still be some creeping voltages och whatnot.
And yes, we all hate salt. :)
FormerMazda
Sweden
C?ID=602370
I just did a scan with the english version of VCDS, but there were not many codes yet, and the codes this time from the trailer module was actually correct, a crappy trailer with lot of bulbs broken..
But here's the scan, although i suppose I should wait for some more codes to accumulate.
Saturday,11,October,2025,17:11:35:59669
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.5
VIN: WVWZZZ3CZFE446200   License Plate:
Mileage: 204379km-126995mi   Repair Order: english
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 5F 69 6C
VIN: WVWZZZ3CZFE446200   Mileage: 204379km-126995miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ES    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H21 1989
   Coding: 0119001A04541D083000
   Shop #: WSC 61354 001 1048576
   VCID: 7F5CDB11B773EDA2F79-802A
17159 - Databus
          U1123 00 [00100000] - Received Error Message
                    Mileage: 204379 km
                    Date: 2025.10.11
                    Time: 14:54:35
                    Engine speed: 980.50 /min
                    Normed load value: 45.9 %
                    Coolant temperature: 91  C
                    Intake air temperature: 61  C
                    Voltage terminal 30: 14.620 V
                    Engine status: COENG_RUNNING
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 63534000002771
   Coding: 0FEC6A8F34240B720779060041C349F0562CD0E0608292F11460F078C002
   VCID: 7EA22615B079E4AAFCF-802A
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0356834008 Dataset Number: V03935214PR 0001
   Coding: 000F0F0603
   Shop #: WSC 05311 115 00314
   VCID: 77AC33319F43D5E2BF9-8022
   Part No SW: 5G0 907 044 AK    HW: 5G0 907 044 AK
   Revision: 00001K10
   Coding: 12020104204401012015500200101802
   Shop #: WSC 00015 115 00001
   VCID: 70BE082DFA2D82DA7E3-8024
   Air quality sensor:
   Humidity sensor: exterior:
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86580301150371 Dataset Number: V03935211SE 0001
   Coding: 00030866C24102F70BA44084B11C07081C80000000000000000000000000
   VCID: 7DA02119BD7FFFB2E55-8028
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    141213  042 0607
   Serial number:         141219080011
   Component: RLHS  037 0059
   Serial number: S5Y15M01D03H16M45S01
   Coding: 00A8EE
   Subsystem 3 - Part No SW: 3G0 941 633 A    HW: 3G0 941 633 A
   Serial number: 28 10 2014  00000304
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY1434413L7
   Serial number: 00000000000061366947
   Humidity sensor: interior:
   Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0053
   Revision: --------    Serial number: 39311500202669 Dataset Number: V03935214SK 0001
   Coding: 0071151101
   Shop #: WSC 05311 115 00094
   VCID: 40DE98ED8A0D525ACE3-8014
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0126
   Dataset Number: V03935207UY
   Coding: 2A40600910FFC428949C804C
   VCID: 3334C721CBBBF9C2431-8066
0935 - Databus
          [FAULT_TRAILOR_LIGHT_DEFECTIVE]
                    Reset counter: 134
                    Mileage: 204379 km
                    Date: 2025.10.11
                    Time: 14:54:36
                    Control Module temperature: 32  C
                    Voltage terminal 15: 14.6 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s
2068 - Databus
                    Reset counter: 134
                    Mileage: 204379 km
                    Date: 2025.10.11
                    Time: 14:54:36
                    Voltage terminal 15: 14.5 V
   Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R1PT1HE4Z Dataset Number: 3G0003V____ 0028
   Coding: 88CCC000008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   VCID: 01585DE9C1879B5281D-8054
   Left seat belt tensioner:
   Serial number: 3G1857705E0006P00482
   Coding: 80000A
   Right seat belt tensioner:
   Serial number: 3G1857706E0010P00855
   Coding: 80000A
   Subsystem 3 - Part No SW: -----------    HW: 454 002 112 14
   Serial number: 3576U00000029050021R
   Subsystem 4 - Part No SW: -----------    HW: 454 002 012 14
   Serial number: 3586U000000E2D600214
   Subsystem 5 - Part No SW: -----------    HW: 454 801 812 14
   Serial number: 3516R60E46305000000.
   Subsystem 6 - Part No SW: -----------    HW: 454 801 712 14
   Serial number: 3526R16DA65050000003
   Subsystem 7 - Part No SW: -----------    HW: 454 801 612 14
   Serial number: 3556V683A49050000009
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141217400608
   Coding: 0400
   VCID: 3D20E119FDFF3FB2A55-8068
   Part No SW: 3G0 920 741     HW: 3G0 920 741
   Component: KOMBI         209 4311
   Coding: 07A509102780000800887A001000000000000000
   VCID: 61987D6921C73B52E1D-8034
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
   Component: STH-MQB       006 0069
   Coding: 9309
   VCID: 3632FE35D8C9ECEA64F-8062
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001059252
   Revision: --------    Serial number: 18121410800790 Dataset Number: V03935212LV 0001
   Coding: 030300344F017300EF00025C080F00010001070000000000000000000000
   VCID: 72BA0225F421B0CA887-8026
   Generator:
   Component: E221__MFL-DC1  H16 0040
   Serial number: 27140003121630064511
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 8559435403
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: 14000316072011
   Coding: 0000000000000000
   VCID: 71B80D29F1278BD271D-8024
   Serial number: 201214BLJ15027 Dataset Number: 3G0222v____ 0017
   Coding: 00350A208000028000001000
   VCID: 42DA92E58401404AD87-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000643358
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000116844 Dataset Number: 3G0074V____ 0131
   Coding: 01000010005000
   Shop #: WSC 00015 115 00314
   VCID: 3B24EF01E3EB31829B1-806E
   Serial number: 171214BLH05876 Dataset Number: 3G0157v____ 0019
   Coding: 003500208000028000001000
   VCID: 41D89DE981075B52C1D-8014
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000641118
   Coding: 090000
   Part No SW: 3Q0 035 864     HW: 3Q0 035 864
   Component: MU-S-N-ER     H10 0138
   Serial number: VWZAZ2P4676099 Dataset Number: V03935236TK 0001
   Coding: 02840201FF00000011110001000808031F0100C401200100CC
   VCID: 6E821655E019942A6CF-803A
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H42 1017
   Serial number: VWZ8Z9RD800Q1C
   Subsystem 2 - Part No SW: V03 959 821 FP    HW: -----------
   Component: ECE DL3 24/25  --- 2210
   Part No SW: 5Q0 907 383 D    HW: 5Q0 907 383 D
   Component: Anhaenger     H14 0137
   Revision: 8A001001    Serial number: 0356709323 Dataset Number: 0G0124v____ 0014
   Coding: 0100000202000000
   VCID: 382EF00DD2DD1A9A763-806C
655882 - Bulb for Brake Light on Trailer
          C10F3 15 [00001000] - Open or Short to Plus
                    Reset counter: 134
                    Mileage: 204379 km
                    Date: 2025.10.11
                    Time: 14:54:35
656650 - Bulb for Right Turn Signal on Trailer
          C10F6 15 [00001000] - Open or Short to Plus
                    Reset counter: 134
                    Mileage: 204375 km
                    Date: 2025.10.11
                    Time: 14:49:26
656906 - Bulb for Left Turn Signal on Trailer
          C10F7 15 [00001000] - Open or Short to Plus
                    Reset counter: 134
                    Mileage: 204375 km
                    Date: 2025.10.11
                    Time: 14:49:26
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Dataset Number: V03935206JJ 0001
   Coding: 0184020143002017000040
End----------(Elapsed Time: 02:07, VBatt start/end: 14.8V/14.7V)-----------
------------------------------6 Faults Found-------------------------------
FormerMazda
Sweden
C?ID=602370
Here we go, I just had fault again, causing front assist to get scared. :)
Pasted below is a new scan, and once again I was towing the crappy trailer, but also my mint condition caravan.
Both of which were working just fine, except for crappy trailers obviosly broken bulbs..
And I didn't get the front assist fail when towing, that was just when i drove to work.
But it seems like the trailer module is acting up?
Also, as I wrote in my first post:
"Also, in the car menu, under driver assists, there´s a option for traffic-sign assistant. But I'm 99,9% sure I don't have a camera for that.
There is a slight chance I have coded that, since I have read about it, but now I can't find where do de-program it.."
I don't know if this maybe causes issues?
Thursday,16,October,2025,18:51:06:59669
Mileage: 204542km-127096mi   Repair Order: Fail frontass
VIN: WVWZZZ3CZFE446200   Mileage: 204542km-127096miles
4865 - No Communication with Towing System Control Module (J345)
          U1003 00 [00100000] - -
                    Mileage: 204497 km
                    Date: 2025.10.16
                    Time: 06:25:37
                    Engine speed: 1175.00 /min
                    Normed load value: 74.5 %
                    Vehicle speed: 58 km/h
                    Coolant temperature: 63  C
                    Intake air temperature: 42  C
                    Voltage terminal 30: 14.680 V
                    Cruise Control System (CCS): status-Bits 0-7: 3
                    selected gear-Bits 0-7: 5
32871 - Databus
          [IPB_BUS: Gateway_72 / BCM1_Rueckfahrlicht_Schalter invalid]
                    Reset counter: 139
                    Mileage: 204501 km
                    Date: 2025.10.16
                    Time: 06:29:14
   Coding: 000F0F0603
12718085 - Databus
                    Reset counter: 139
                    Mileage: 204500 km
                    Date: 2025.10.16
                    Time: 06:28:03
   Revision: 00001K10
   Air quality sensor:
   Coding: 00A8EE
529173 - Databus
                    Fault Frequency: 17
                    Reset counter: 139
                    Mileage: 204497 km
                    Date: 2025.10.16
                    Time: 06:25:32
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: g ltiges Funktelegramm
                    Voltage: 14.4 V
                    Outside temperature: 6.0  C
   Coding: 0071151101
13632273 - Databus
          [Steuerger t f r Anh ngererkennung-J345 - Gateway_72.Anhaenger_01_alt - kein Signal/keine Kommunikation]
                    Fault Frequency: 22
                    Reset counter: 139
                    Mileage: 204497 km
                    Date: 2025.10.16
                    Time: 06:25:37
0937 - Databus
          [FAULT_TRAILER_OBSOLETE_DATA]
                    Fault Frequency: 15
                    Reset counter: 139
                    Mileage: 204498 km
                    Date: 2025.10.16
                    Time: 06:26:10
                    Control Module temperature: 21  C
                    Velocity_vehicle_reference: 12.25 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.35 m/s
2068 - Databus
                    Reset counter: 139
                    Mileage: 204497 km
                    Date: 2025.10.16
                    Time: 06:25:37
                    Voltage terminal 15: 14.4 V
                    Velocity_vehicle_reference: 15.95 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.06 m/s
   Coding: 80000A
   Coding: 80000A
   Coding: 0400
   Coding: 9309
   Generator:
   Coding: 2CFFFF
   Analog clock:
131655 - No Communication with Towing System Control Module (J345)
          U1003 00 [00001000] - -
          [Timeout Knoten 0x47 / 69 - Steuerger t f r Anh ngererkennung]
                    Reset counter: 139
                    Mileage: 204498 km
                    Date: 2025.10.16
                    Time: 06:26:22
                    Terminal 30 power supply: 14.5 V
                    Terminal 15: On
   Coding: 090000
342030 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0010 00 [00001000] - Malfunction
                    Fault Frequency: 17
                    Reset counter: 139
                    Mileage: 204497 km
                    Date: 2025.10.16
                    Time: 06:25:37
          C10F7 15 [00001001] - Open or Short to Plus
                    Reset counter: 94
                    Mileage: 204379 km
                    Date: 2025.10.12
                    Time: 15:17:40
13705483 - Databus
                    Fault Frequency: 22
                    Reset counter: 139
                    Mileage: 204497 km
                    Date: 2025.10.16
                    Time: 06:25:38
                    CAN communication
End----------(Elapsed Time: 02:07, VBatt start/end: 14.7V/13.3V)-----------
------------------------------11 Faults Found------------------------------
Vdub
C?ID=57533
You dont have the A5 camera in the car, so better is to code the TrafficSR out.
Then you have to check the 69 Trailer module on water damage or so(behind left trim/panel in trunk), in the last scan it has a lost-communication
FormerMazda
Sweden
C?ID=602370
Now it's been a month month or less since I did as suggested.
I disabled the sign-thing in the MMI and now that menu-option isn't there anymore. Since i don't have the camera as Vdub said.
I also checked the module in the trunk, although I didn't really get it out, but i did get a good look in there and did reach and re-plugged the connectors. And by visual inspection, it's looking like it's brand new. Clean, not even dusty, and not a trace of water like specs or corrosion.
And lastly i cleared all error-codes again.
Since then the ACC has been working without a glitch. Except for a backup sensor who finally gave up, but atleast that doesn't affect ACC. But i will change it, someday.
And now when i did a new scan I do actually think that my problems are solved?
Sure, there a few messages still, but as far I can see, they are legit. In example broken sensors and lights on trailers causing other errors.
But no missed messages and no communication.
Sunday,16,November,2025,19:56:32:59669
VIN:    License Plate:
Mileage: 206324km-128203mi   Repair Order:
VIN: WVWZZZ3CZFE446200   Mileage: 206324km-128203miles
17159 - Databus
                    Mileage: 205606 km
                    Date: 2025.11.01
                    Time: 13:56:12
                    Engine speed: 753.50 /min
                    Normed load value: 25.9 %
                    Coolant temperature: 72  C
                    Intake air temperature: 48  C
                    Voltage terminal 30: 14.700 V
                    Unlearning counter according OBD: 18
   Coding: 000F0F0603
   Revision: 00001K10
   Air quality sensor:
459526 - Databus
          [Feuchtesensor innen - Fehlerspeicher auslesen]
                    Reset counter: 169
                    Mileage: 205623 km
                    Date: 2025.11.03
                    Time: 06:26:59
   Coding: 00A8EE
939534 - Humidity sensor
          B1281 04 [00001000] - Internal System Fault
                    Reset counter: 169
                    Mileage: 204918 km
                    Date: 2025.10.24
                    Time: 10:10:54
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Voltage: 14.3 V
                    Outside temperature: 11.5  C
204546 - Remote key 2
          B147A 18 [00001001] - Current Too Low
                    Reset counter: 149
                    Mileage: 206284 km
                    Date: 2025.11.15
                    Time: 16:20:22
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.5 V
                    Outside temperature: -1.5  C
   Coding: 0071151101
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [00001001] - Open Circuit
                    Reset counter: 104
                    Mileage: 204602 km
                    Date: 2025.10.18
                    Time: 10:13:04
0935 - Databus
                    Reset counter: 167
                    Mileage: 205606 km
                    Date: 2025.11.01
                    Time: 13:56:12
                    Control Module temperature: 25  C
                    Voltage terminal 15: 14.7 V
2068 - Databus
                    Reset counter: 167
                    Mileage: 205606 km
                    Date: 2025.11.01
                    Time: 13:56:12
   Coding: 80000A
   Coding: 80000A
   Coding: 0400
   Coding: 9309
0036 - Fuel Level too Low
          P1250 00 [00001000] - -
                    Reset counter: 189
                    Mileage: 206278 km
                    Date: 2025.11.15
                    Time: 16:07:16
                    Parking heater: operating condition: Control mode
                    99
                    Coolant temperature of parking heater: 84  C
                    Coolant temperature: 78  C
                    Engine running status: detected
                    Fuel level: 9 l
                    Heating performance: 2440 W
   Generator:
   Coding: 2CFFFF
   Analog clock:
   Coding: 090000
   Coding: 02840201FF00000011110001000808031F0100C4012001008C
   Shop #: WSC 131071 102 209715
   Subsystem 2 - Part No SW: V03 959 823 BA    HW: -----------
   Component: ECE DL3 2026  --- 2510
                    Reset counter: 167
                    Mileage: 205606 km
                    Date: 2025.11.01
                    Time: 13:56:12
                    Reset counter: 181
                    Mileage: 206073 km
                    Date: 2025.11.09
                    Time: 14:17:37
End----------(Elapsed Time: 02:15, VBatt start/end: 14.8V/14.8V)-----------
------------------------------10 Faults Found------------------------------
FormerMazda
Sweden
C?ID=602370
Holy mothballs, batman!
I actually think I found my issue! :)
The trailer module seemed to have something to do with this, and my car had a real mental breakdown lately so I decided to take a closer look at the module.
Removing it wasn't so hard, and it was clipped together, so even inspecting the PCB was easy. Again, nothing visual to complain about at all, it could pass as a brand new one based on visual.
But, relatively new to me was the press-fit pins to the connectors on the PCB, no solder, just a tight fit in the vias. I get the point of this, but it seems like a cause for problems as well.
So I used some violence on it, tapping, bending, trying to exercise it. And now after a month of driving and then performing an auto-scan, the result was no error at all! Yaay!
(Well, except for my still to change rear parking sensor, but that is to be expected.)
Vdub
C?ID=57533
it took you very long, i've wrote that in oct 25 already..
FormerMazda
Sweden
C?ID=602370
Who's in a rush?
I did actually (mostly) check what you suggested in nov -25, as the post post after yours says. And for a ling time i didn't get any panic-attacks, but then they came back.
And now when I messed with the module again, more thoroughly this time, and "fixed" it again, I can be sure that the module is my problem. And that's why I posted again.
But if it's permanently fixed, that's another question. Time will tell. ;)
