Jetta 2014 Readiness Monitors failed inspection
ELGC
Delaware, USA
C?ID=631276
Hi everyone,
I have a 2014 VW Jetta that's currently failing the emissions test due to several monitors not being ready (see attached image). Over the past month, I've performed the recommended drive cycle multiple times, including a long trip (~250 miles this past weekend). While the EVAP monitor finally set to "Ready," the others are still incomplete.
To try and resolve this, I purchased a HEX-V2 interface after reading that you can set readiness via VCDS. However, I don’t see the option to manually set readiness in the software.
I've been trying the "Automatic Test Sequence" in VCDS. Sometimes it runs for a few minutes and then I get a timeout alarm. Other times, I get two fault codes related to the cooling fan (DTC P0691 – Fan 1 Control Circuit Low), which might be interfering with the readiness process.
Here are a few more details:
  • I’ve driven the car many miles with mixed driving conditions.
  • The readiness monitors (aside from EVAP) still won’t set.
  • VCDS does not give me the "Set Readiness" option that others have mentioned.
  • I’m including the log from the failed auto test sequence and the full auto-scan.
  • Before starting the Automatic Test Sequence I am deleting the codes
Does anyone have advice on:
  1. How to get the remaining monitors to set?
  2. Whether the fan fault (P0691) could be preventing readiness?
  3. If there’s a workaround in VCDS or something I’m missing?
Any tips to help me pass the emissions test would be greatly appreciated!
Thanks in advance!
Wednesday,08,October,2025,20:16:16:30478
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.5
VIN: 3VW  License Plate:
Mileage: 177420km-110243mi   Repair Order:
                Address 01: Engine       Labels: 06K-907-425-V2.CLB
Control Module Part Number: 06K 906 070 F    HW: 06K 907 425
  Component and/or Version: Simos12.2     H09 8052
           Software Coding: 001A0012242400170000
            Work Shop Code: WSC 00066 790 00199
              ASAM Dataset: EV_ECM18TFS02006K906070F 001012 (VW36)
                       ROD: EV_ECM18TFS02006K906070F.rod
                      VCID: 2D00D5F57D964E82155-8078
14963 - Fan 1 Control Circuit
          P0691 00 [00100110] - Short to GND
                    Mileage: 177425 km
                    Date: 2025.10.08.
                    Time: 20:13:52
                    Engine speed: 1800.00 /min
                    Normed load value: 10.6 %
                    Coolant temperature: 109  C
                    Intake air temperature: 57  C
                    Voltage terminal 30: 14.023 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 582 s
                    MAP_MES_SAE: 26 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 13.281250 %
                    FUP_H_SAE: 3800.0 kPa
Readiness: 0010 0101
Wednesday,08,October,2025,20:27:23:30478
                    Mileage: 177425 km
                    Date: 2025.10.08.
                    Time: 20:13:52
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 582 s
                    MAP_MES_SAE: 26 kPa
14971 - Fan Control Module 1
          P2D89 00 [00100110] - Supply Voltage Malfunction
                    Mileage: 177425 km
                    Date: 2025.10.08.
                    Time: 20:17:12
                    Engine speed: 727.00 /min
                    Normed load value: 6.7 %
                    Coolant temperature: 110  C
                    Intake air temperature: 64  C
                    Voltage terminal 30: 13.925 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 782 s
                    MAP_MES_SAE: 29 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.002 V
                    FAC_TPS_1_SAE: 10.937500 %
                    FUP_H_SAE: 6630.0 kPa
Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: Release 25.3.2(x64) Data version: 20250822 DS365.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Wednesday,08,October,2025,20:24:14:30478
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 56 77
VIN: 3VW Mileage: 177420km-110243miles
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
 Part No SW: 06K 906 070 F HW: 06K 907 425
 Component: Simos12.2 H09 8052
 Revision: --H09--- Serial number: 00000000000000 CVN: 788F8E62
 Shop #: WSC 00066 790 00199
 VINID: 0E69D404745A1157441050C0206B7B51D0
 Mileage: 177425 km
 Date: 2025.10.08.
 Time: 20:13:52
 Coolant temperature: 109 °C
 Intake air temperature: 57 °C
 STATE_LS_SAE[1]: CL
 T_AST_SAE: 582 s
 MAP_MES_SAE: 26 kPa
 Mileage: 177425 km
 Date: 2025.10.08.
 Time: 20:17:12
 Coolant temperature: 110 °C
Self-Diagnosis Log
Page 3
 Intake air temperature: 64 °C
 STATE_LS_SAE[1]: CL
 T_AST_SAE: 782 s
 MAP_MES_SAE: 29 kPa
------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:* 09G-927-749-V1.clb
 Part No SW: 09G 927 749 A HW: 09G 927 749 A
 Component: AISIN AG6 G3 109 2856
 CVN: 481EBFD0
 Coding: 000348
 ASAM Dataset: EV_TCMAQ250031 001004
 ROD: EV_TCMAQ250031_001.rod
 VCID: 372CF79D8FCAF4527F9-8062
No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V4.clb
 Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
 Component: ESP MK60EC1 H46 0166
 Revision: 00H46001
 Coding: A14B400C492600FF850E02E492210041A1100012
 Shop #: WSC 44637 001 1048576
 VCID: 045650518E1C6FCAAAB-8050
No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 5C0-820-047.clb
 Part No SW: 5C0 820 047 BK HW: 5C0 820 047 BK
 Component: J301 Klimaanlage 0204
 Revision: 2001001S Serial number: 00000002192173
 VCID: 6A8A1EE9807899BA307-803E
Self-Diagnosis Log
Page 4
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
 Part No SW: 5C0 937 087 J HW: 5C0 937 087 A
 Component: BCM25 JLB H3 H34 0411
 Revision: B2034001 Serial number: 08013170140025
 Coding: 7B994B1808AB0B0000302000240884D400C2502E60004000300010002000
 Shop #: WSC 00066 000 00000
 VCID: 3436C0919E3C1F4A5AB-8060
 Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
 Component: J386__TSG_FT 006 5461
 Serial number: 14102585140515083025
 Coding: 820000
 Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
 Component: J387__TSG_BT 006 5461
 Serial number: 14102584140521175637
 Coding: 820000
 Subsystem 3 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
 Component: J388__TSG_HL 006 5460
 Serial number: 14102587140520062957
 Coding: 800000
 Subsystem 4 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
 Component: J389__TSG_HR 006 5460
 Serial number: 14102586140523035235
 Coding: 800000
Self-Diagnosis Log
Page 5
 Part No SW: 5C0 959 655 AD HW: 5C0 959 655 AD
 Component: AirbagVW10 102 0912
 Serial number: 003MVD04VA3V Dataset Number: 160003v____ 0219
 Coding: 00004138
 ROD: EV_AirbaVW10SMEVW360.rod
 VCID: 74B60091DE3C5F4A9AB-8020
 Serial number: 6940000Y14000162NB0F
 Coding: 303037
 Serial number: 3572MSME731A7943ZZZ.
 Serial number: 3582MSME5B0E3E44ZZZ6
 Serial number: 3516KSME1414542CZZZM
 Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
 Serial number: 3526KSME08215C2CZZZW
 Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
 Serial number: 3556LSME5905662DZZZ/
 Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
 Serial number: 3566LSME3047352EZZZX
Self-Diagnosis Log
Page 6
 Part No SW: 5C6 920 953 B HW: 5C6 920 953 B
 Component: KOMBI H04 0809
 Coding: 270A01
 Shop #: WSC 00066 790 00123
 VCID: 2C06D8F1468C478A02B-8078
No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
 Part No SW: 6N0 909 901 HW: 5C0 937 087 A
 Component: GW-K-CAN TP20 H34 0411
 Revision: B2034001
 Coding: 102200
 VCID: 70BE0C81AAA4636A7E3-8024
No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
 Component: IMMO H04 0809
 VCID: 6A8A1EE98CF899BA307-803E
No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
 Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
 Revision: A1001003 Serial number: 7666068005
 Coding: 010100
 Shop #: WSC 00066 790 00202
 VCID: 2B04DBED430240B20B1-807E
Self-Diagnosis Log
Page 7
 Part No: 1K0 909 144 R
 Component: EPS_ZFLS Kl. 69 3501
 Revision: 00H22000
 Shop #: WSC 02069 000 90108
 VCID: 3928F1A5B55EE22289D-806C
No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
 Part No SW: 1K0 035 164 F HW: 1K0 035 164 F
 Component: LOW NAR SDARS H04 0005
 Revision: -----08S Serial number: VWZ4Z6P3800434
 Coding: 01000400020006
 VCID: 25102DD525E676C2DD5-8070
 Reset counter: 187
 Mileage: 176225 km
 Date: 2020.02.16.
 Time: 19:48:07
------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
 Part No SW: 7P6 035 730 N HW: 7P6 035 730 N
 Component: TELEFON H15 4217
 Revision: 1B001001 Serial number: 00007666134439 Dataset Number: 7P6035730N 0001
 Coding: 0A10040000010100
 Shop #: WSC 55549 001 1048576
 ASAM Dataset: EV_UHVNA 002720
 ROD: EV_UHVNA_002_VW25.rod
 VCID: 3D20E5B5ADF6DE02A55-8068
End----------(Elapsed Time: 01:03, VBatt start/end: 13.7V/13.8V)-----------
------------------------------3 Faults Found-------------------------------
Vdub
C?ID=57533
every time you delete fault codes the readiness test wil be set to failed for al sensors.
First try to fix the fan module..
Then you have to drive at least 15mins with 60mph roads, idle for traffic light etc, so a normal drive to your work for example in normal traffic.
You're not using the correct way to post your autoscans and it makes them hard to read.
Yup. Fix whatever is causing that.
PS: Please do not use the [Print] function in VCDS to post data here. The formatting it produces is intended for a sheet-fed printer, but it's much harder to read here than the native text that VCDS produces. That native text can be had using the [Copy] button in VCDS, or by opening any of the .txt files in your Logs or Scans sub-folder with Notepad and then copying the data to paste here.
ELGC
Delaware, USA
C?ID=631276
Thank you all for your answers, tomorrow I am going to troubleshoot the P0691. Sorry about the post it is my first one.... I am going to read the right way to post my autoscan.
ELGC
Delaware, USA
C?ID=631276
Hi everyone,
It’s me again. I replaced the fan this weekend, and the fault code cleared successfully. However, I’m now having trouble completing the Automatic Test in VCDS. The procedure runs through all the steps, but when it reaches the final stage — CAT Conversion Test Bank 1 — it just keeps running indefinitely. After about 10 minutes, VCDS displays TIMEOUT.
(See image below.)
Does anyone have any ideas on what could be causing this? I still have the CAT, FUEL, and O2S readiness monitors showing Not Ready. I’ve attempted the test several times with the same result. At this point, I’m not sure what else to check or whether something in the system is preventing the monitor from completing.
I’m also attaching a copy of the Auto-Scan log for reference.
Thanks in advance for any guidance or suggestions!
This is the Auto Scan, as you can see there aren't any mayor faults. Just the one for the radio I google it and it is related to the Satelite radio.
Monday,03,November,2025,20:04:02:30478
VIN: 3VWD17   License Plate:
VIN: 3VWD17   Mileage: 178200km-110728miles
Readiness: 0010 0001
   CVN: 481EBFD0
   Coding: 000348
   Revision: 00H46001
   Coding: 820000
   Coding: 820000
   Coding: 800000
   Coding: 800000
   Coding: 00004138
   Coding: 303037
   Coding: 270A01
   Revision: B2034001
   Coding: 102200
   Coding: 010100
   Revision: 00H22000
                    Reset counter: 138
                    Mileage: 177958 km
                    Date: 2020.03.26.
                    Time: 15:49:56
End----------(Elapsed Time: 01:03, VBatt start/end: 14.1V/14.0V)-----------
-------------------------------1 Fault Found-------------------------------
Thank you in advance for your help.
Vdub
C?ID=57533
drive the car for 20mins, in normal traffic, traffic-lights and highway it should go away
ELGC
Delaware, USA
C?ID=631276
Hi Vdub, I have driven for about 130miles and it did not go away. Should I take my car to a VW dealeship? or continue driving?
Thank you in advance for your answer
Vdub
C?ID=57533
which sensor doesnt pass the readiness test, IF you clear faultcodes in 01 Engine, the readiness test will reset to FAIL for all sensors, so don't erase a fault code in 01 Engine
ELGC
Delaware, USA
C?ID=631276
It passes almost all test but it is getting stuck in the final test for the CAT converter test. Even if I run that test by its own the test runs forever until VCDS displays the timeout. I havent erase any code from Engine. And I dont have any fault present
Vdub
C?ID=57533
buy a mini catalyst
buy a mini catalyst
That's not fixing the car, that's just masking the problem, and would likely be considered an illegal "emissions defeat device".
ELGC
Delaware, USA
C?ID=631276
Any advice about What can I do identify the root cause?
As you can see I don't have any active code/fault.
Thank you for following up
Vdub
C?ID=57533
yes, but if the readiness test will complete, he knows it needs a new OEM catalyst, if not he only spend 10 dollars.
You might have an air leak or lazy oxygen sensor preventing the Cat test from completing. That should flag a new DTC .... but any saved scans that you have before the readiness was cleared may add clarity.
In the meanwhile I would get the engine up to temp and immediately after driving it, pull over/park with it still at idle, connect VCDS and try all of the individual oxygen sensor Basic Settings self-tests while standing. Ideally all should pass in a timely manor and it would be ideal if all of the Oxygen sensor Readiness bits were passed as well. If that happens you can try the [*IDE00553*] Automatic test procedure again (it should go very quick as long as the engine is still running) -or- run all 4 of the Basic Settings that mention cat manually at that time.
On a different note. If you do end up at the VW dealer I believe this ECM has a newer software level (flash update from SWL 8052 to 9360 per: https://vag-flashinfo.de/site/index?partno=06K906070F) so we can try to find the TSB on that. Either that, or you can request they update the software to the latest version on that visit.
ELGC
Delaware, USA
C?ID=631276
Hi Dana,
Couple months ago I replaced the upstream sensor. Do you think I should replace the downstream?
I already did the test for the O2 sensor and all test are completed successfully but still the O2S monitor not ready, the O2 heater is already ready.
I am going to try to do the CAT again.
Thank you for your response.
OK. That might be relevant. Was the MIL on for the front Oxygen sensor due to an electrical issue or was it some other type of DTC (like lean or slow response)? If you happen to locate the exact DTC (even if that's a picture of a generic code reader) please post it.
In addition, the old one was revised back in 2020 and the newest part number is: 06K 906 262 DA Please check your receipts to see if that was the part number so we can rule out aftermarket or incorrect parts as a possible explanation.
I would not go after the rear sensor at this time unless you have DTCs for it. That one is a lot more expensive.
I don't believe the Catalytic converter test can run and pass prior to the Oxygen sensors but there's no harm in repeating all 4 the Basic Settings that mention it.
ELGC
Delaware, USA
C?ID=631276
Hi Dana,
The MIL was ON, I don't have a picture as I replaced last June. I don't remember the DTC but the MIL was ON and the car was shaking sometimes.
According to my receipts the one I bought was 06K906262N.
I was looking at rockauto and the BOSCH 17100 fits my car, I saw it is in stock at my closest autozone.
When I arrive home I am going to perform the test again. I will drive the car for about 20-30min and then I am going to perform the test.
Thank you, I appreciate your help.
ELGC
Delaware, USA
C?ID=631276
Hi Dana,
I did all test related to the O2 sensors. All test were completed ok with no issues but the O2S monitor still not ready.
I did the CAT test but it runs forever, it stars at 2100rpm and stays there, then it falls to idle rpm's and is not sending any timeout just stays there (from the beggining to this state aprox 10mins)
I performed the following tests related to the CAT:
IDE06576-Test of Cat converter for back presure Result:System OK
IDE00742 - CAT conversion test bank 1 - Result: Running forever
Then I performed the Automatic Test:
IDE00553 - Automatic Test Procedure Result: Everything passes until it reaches the last step for the CAT at this point it runs forever with no results.
IDE04794 - Automatic Test Sequence 2 - Same result as the 553
I opened some measuring values and I was wondering if I need to get any value for the Test of catalytic converter (see image below) this value is never changing it stays at zero all time, no matter which test I am running it stays at zero.
Thank you for your help.
Hmm. I get the impression that the lack of Oxygen sensor readiness is the holdup here but if all of these:
IDE00737-Oxygen sensor after catalytic converter: readiness for oper​
IDE00738-Oxygen sensor test: bank 1: delta lambda​
IDE00752-Oxygen sensor control test​
IDE00882-Test of oxygen sensor in deceleration mode​
IDE00883-Test of oxygen sensor heater in deceleration mode​
IDE00886-Test of oxygen sensor​
IDE03227-Oxygen sensor aging test: bank 1 downstream of catalytic converter​
... ran and completed I would be tempted to disconnect the battery and let it sit powered down for a while.
You will be greeted with ABS/TPMS/Steering lights after reconnecting the battery but starting the engine and turning the steering to each extreme end-stop (in each direction) followed by a short drive should sort most of it out. If the TPMS light remains make sure to check the pressures before using the button to reset it.
