Resolved 2006 Audi A3 8p - Fault 01036 (electrical window thermal protection) - Rear Left Door
Resolved
Keyser Söze
Seattle, WA, USA
C?ID=550760
The right rear window is not working. I ran VCDS and got a Code 01036.
There is only one other thread I found for this code. Uwe wrote: "Speculation: A bad temperature sensor/switch in that door control module."
I ran an output test for the rear door and everything worked except the window going up and down.
My car was not in use for about a month while work was being done. Battery was disconnected at times. The rear windows worked fine before this. The right rear door had the same or similar code, but that cleared on the first attempt.
I checked the wiring harness on that door looks good. I tried some tests I found online to try to resolve the issue . . . . all without success.
Is this just a bad motor/control module?
My next step is to disconnect the motor and lift the window in position (it is currently open) as a temporary solution. Will this work?
As for other codes, the car is still on jack stands with front bumper and headlights removed. This explains most of remaining codes.
Any guidance you can offer would be appreciated.
Tuesday,07,October,2025,16:14:15:58670
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
VIN: WAUKD78P96A087632   License Plate:
Mileage: 360500km-224004mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72
VIN: WAUKD78P96A087632   Mileage: 360500km-224004miles
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 GP    HW: 000 000 000 00
   Component: MOTRONIC ME7.1.1G   8192
   Revision: --H01---    Serial number: AUX7Z0E9FNH0IF
   Coding: 0000178
   Shop #: WSC 06314 000 00000
   VCID: 5F9BB1145B33CE12D79-800A
   VINID: 9D195B507220246440207183084553B2F2
Readiness: 0110 1101
   Part No SW: 02E 300 047 A    HW: 02E 927 770 AE
   Component: GSG DSG         070 1002
   Revision: 04507000    Serial number: 00000509300704
   VCID: 1675D430F489CF5A44F-8042
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 S    HW: 1K0 614 517 S
   Component: ESP 4MOTION MK60-AT 0102
   Revision: 00T12001
   Coding: 0021122
   VCID: 372B39B49343D6527F9-8062
   Part No SW: 8P0 820 043 L    HW: 8P0 820 043 L
   Component: KlimavollautomatH17 0200
   Revision: 022108      Serial number: 8P0820043L
   VCID: 353733BC894F24426D5-8060
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Component: Bordnetz-SG     H36 1201
   Revision: 00H36000    Serial number: 00000002244428
   Coding: F18C5F81C014100000181800180000000028F6135A1500
   Shop #: WSC 06314 123 08192
   VCID: 40D95268C68D91EACE3-8014
   Subsystem 1 - Part No: 8P1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00150573
   Shop #: WSC 06314
                    Fault Status: 01101100
                    Reset counter: 8
                    Mileage: 360502 km
                    Date: 2025.08.13
                    Time: 00:36:00
                    Voltage: 11.55 V
                    Reset counter: 8
                    Mileage: 360502 km
                    Date: 2025.08.13
                    Time: 00:36:00
                    Voltage: 11.55 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 8
                    Mileage: 360502 km
                    Date: 2025.08.12
                    Time: 02:56:00
                    Voltage: 13.95 V
                    Reset counter: 8
                    Mileage: 360502 km
                    Date: 2025.08.13
                    Time: 00:36:00
                    Voltage: 12.30 V
                    Reset counter: 8
                    Mileage: 360502 km
                    Date: 2025.08.12
                    Time: 02:56:00
                    Voltage: 13.95 V
                    Reset counter: 8
                    Mileage: 360502 km
                    Date: 2025.08.12
                    Time: 02:56:00
                    Voltage: 13.95 V
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 A    HW: 8P0 959 655 A
   Component:    Airbag 9.41  H12 3770
   Revision: 91H12377    Serial number: 0035W0008S2Z
   Coding: 0432605
   Subsystem 1 - Part No: 8P0 910 339
   Component: BF-Gewichtsens. 001 0020
   Subsystem 2 - Serial number: 35KCZ
   Subsystem 3 - Serial number: 0001.01.000000100000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB4024D1226Dÿ†63
   Subsystem 5 - Serial number: D1226Dÿ†6342DRB4024D4EB0Wÿ†63
   Subsystem 6 - Serial number: D4EB0Wÿ†63528RB400A085ACPÿ†63
   Subsystem 7 - Serial number: 085ACPÿ†63628RB400A0AE8D-ÿ†63
   Subsystem 8 - Serial number: 0AE8D-ÿ†63729RB400BCF088.ÿ†63
   Subsystem 9 - Serial number: CF088.ÿ†63829RB400BCF05D/ÿ
   Subsystem 10 - Serial number: CF05D/ÿ
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H34 0070
   Coding: 0012142
   VCID: 41DF576CCD8798E2C1D-8014
   Component: E0221           H07 0080
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 981 E    HW: 8P0 920 981 E
   Component: KOMBIINSTR. VDO H80 0420
   Revision: D06         Serial number: 2249ED06004783
   Coding: 0001203
   Shop #: WSC 26855 004 1048576
   VCID: 3A2D2080A051CB3A807-806E
16346 - Control Module - ROM Error
            014 - Defective
                    Fault Status: 00000011
                    Mileage: 55318 km
                    Date: 2010.08.06
                    Time: 14:54:09
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105A058707
   Coding: FF3F0340072102
   VCID: 2A0D10C050F17BBAF07-807E
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 B
   Component: HALDEX 4Motion      0107
   Coding: 0000001
   VCID: 2C0116D85A05658A02B-8078
   Revision: D06         Serial number: AUX7Z0E9FNH0IF
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX2.lbl
   Part No: 8P0 959 801 G
   Component: Tuer-SG         H03 0120
   Coding: 0000121
   VCID: 3FDB5194BB73EE12B79-806A
00120 - Outside Warning Light/Door exit Light Driver Side
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 323D08A07821337A487-8066
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 D
   Component: 02 KSG          H04 0050
   Coding: 9BD0031C2D288505488F047300
   Shop #: WSC 06314 123 12345
   VCID: 3D272B9CB17FFC02A55-8068
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
   Part No: 8P0 959 802 H
   Component: Tuer-SG         020 0090
   Coding: 0001209
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   VCID: 2809EAC84EFD49AAE63-807C
   Subsystem 1 - Part No: NOSUBSYSTEM
   Component: AFS-Modul links
   Subsystem 2 - Part No: NOSUBSYSTEM
   Component: AFS-Modul rechts
02071 - Local Databus
                    Fault Status: 11100100
                    Reset counter: 7
                    Mileage: 360504 km
                    Date: 2025.08.12
                    Time: 02:59:10
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 195 K    HW: 8P0 035 195 K
   Component: symphony II US  H52 0460
   Revision:      04S    Serial number: AUZ5Z4E6111849
   Coding: 0021205
   Shop #: WSC 130873 003 00000
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No: 8P4 959 801 D
   Component: Tuer-SG         020 0060
   Coding: 0001176
01036 - Electric Window Thermal Protection Active; Rear Left
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No: 8P4 959 802 D
   Coding: 0001176
End----------(Elapsed Time: 01:16, VBatt start/end: 13.7V/13.8V)-----------
------------------------------11 Faults Found------------------------------
Personal experience with the 2006 8P A3 I bought brand-new 20 years ago that my son still drives: Rear door controllers are problematic in them. However, we never had that particular fault code and I'm not sure where the temperature sensor is located.
Keyser Söze
Seattle, WA, USA
C?ID=550760
Thank you. It has been a great car. I got mine as a lease return with 16k miles. Turned out to be a great purchase. I will have it on the road Tomorrow and will continue searching for a solution for a short time before springing for a new controller.
Vdub
C?ID=57533
Very often its the black computermodule that is fitted in/on the window motor
Keyser Söze
Seattle, WA, USA
C?ID=550760
Vdub
C?ID=57533
Yes but not for sale as a separate item.
