IS IT POSSIBLE TO ACTIVATE REAR FOG LIGHT FOR US SPEC VW PHAETON 2004
RICH18
C?ID=628352
Hi I have a VW Phaeton US Spec which I need to obtain TUV inspection here in Germany. One requirement is to have the rear fog light that lights up and also is supposed to have a indicator light notifying the driver that the fog lamps are on. I have removed the US Spec headlight switch and plugged in a German one and coded it to 0000003 (no DRL function of any kind) + rear fog light installed.
It also mentioned that rear fog light controllers are not installed on NAR Phaetons. My question is what do I need to do to get the rear fog lights to work. I also have a German Spec Phaeton with German rear lights . I wonder if the controllers are built into the German rear light assemblies.
Regards Richard
Actually, it might be best to post scans from both cars.
Dave I will do this tomorrow never uploaded yet will figure it out
RICH18
C?ID=628352
Regards Richard
RICH18
C?ID=628352
Wednesday,08,October,2025,13:37:32:44133
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.5
Dealer/Shop Name: THE GREASE MONKEY
VIN: WVWAF63DX48008943   License Plate:
Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
          34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
VIN: WVWAF63DX48008943   Mileage: 304660km-189306miles
Address 01: Engine        Labels: 4D0-907-560-BGH.lbl
   Part No SW: 4D0 907 560 CS    HW: 8E0 907 560
   Component: 4.2L V8/5V      G   0040
   Coding: 0007873
   Shop #: WSC 33804 142 87002
   VCID: 79AB3D12E5C39492C9D-5160
   VINID: 9E69D15860D4A042000082440C9B207D09
Readiness: 0110 1101
   Part No SW: 09L 927 760 A    HW: GS1 904 1
   Component: AG6 09L 4,2L V8     0901
   Coding: 0001102
   VCID: 3533F122895BB0F26D5-5160
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 R
   Component: ESP 5.7 allrad  H33 0043
   Coding: 0008376
   Shop #: WSC 44580 000 00000
   VCID: 313BC5327D339CD231D-5160
   Part No SW: 3D0 909 137 E    HW: 5WK 485 09
   Component: G1 Kessy            6840
   Revision: 68406620    Serial number: VWZ3Z0C7109082
   Coding: 0137452
   Shop #: WSC 33804 142 97064
   VCID: 290B2D5255E3E412F9D-5160
Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
   Part No: 3D0 959 759 B
   Component: Sitzmemory D1 BF    1520
   Coding: 0000003
   Shop #: WSC 01065 000 00000
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3D0 035 008 Q
   Component:    ZAB COCKPIT      0223
   Coding: 0500345
   Shop #: WSC 06490 444 58963
   VCID: 280D28564EE9DD1AE63-5160
7 Faults Found:
00857 - CD Changer Unit (R41)
            003 - Mechanical Failure
00823 - Line-Output; Front Left
00859 - Line-Output; Front Right
00385 - Positive Output Audio Channel for Speech/Telephone
00386 - Negative Output Audio Channel for Speech/Telephone
00856 - Radio Antenna
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 G
   Component: Climatronic D1      1132
   Coding: 0000002
   VCID: 22193A7E28D5374AB87-5160
            014 - Defective
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 G
   Component: STG.Bordnetz        5001
   Coding: 0000003
   VCID: 2E01DE4E6C0D832A2CF-5160
00968 - Right Turn Signals
01498 - Bulb for Parking Lamps; Right (M3)
   Part No: 3D0 909 601 D
   Component: 0A Airbag 8.4E+ H07 0934
   Coding: 0012353
   VCID: 24153C6632C1397ACAB-5160
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 E
   Coding: 0000232
   VCID: 2F3FC34A6B078A22279-5160
Address 17: Instruments        Labels: 3D0-920-INS-V1.lbl
   Part No: 3D0 920 981 A
   Component: KOMBIINSTRUMENT RB4 0321
   Coding: 0007221
   Shop #: WSC 33804 142 84454
   VCID: 2513216239FBC072DD5-5160
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70BD0036B6B9D5DA7E3-5160
Address 28: HVAC, Rear        Labels: 3D0-919-158.lbl
   Part No: 3D0 919 158 F
   Component: Klima-Bedienteil D1 0117
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  X012
   Coding: 0000001
   VCID: 6691666E847D0B6A14F-518C
Address 34: Level Control        Labels: 3D0-907-553-V1.clb
   Part No: 3D0 907 553 B
   Component: LUFTFDR.-CDC- 3C1V0 1101
   Coding: 0017700
   VCID: 2611266E44FDCB6AD4F-5160
01598 - Drive Battery Voltage
Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
   Part No: 3D0 959 760 B
   Component: Sitzmemory D1 F     1520
   Coding: 0000004
   VCID: 2D03D942610BF832155-5160
Address 37: Navigation        Labels: 3D0-919-887.lbl
   Part No: 3D0 919 887 A
   Component:    NAVIGATION       0147
   Coding: 0400000
   VCID: 3239CA3E7835A7CA487-5160
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 C
   Component: Dachmodul           0708
   Coding: 0000043
   VCID: 23173F7A37CF3E42B31-5160
00220 - Connection to Sunroof
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  X012
   Coding: 0000001
   VCID: 678F6B6A837712622F9-5180
Address 46: Central Conv.        Labels: 3D0-959-933.clb
   Part No: 3D0 959 933 E
   Component: 6P HSG              3211
   Coding: 0000040
   VCID: 3239CA3E7835A7CA487-4AF8
   Subsystem 1 - Part No: 3D1 959 701 E
   Component: Tuersteuergeraet FS 0104
   Subsystem 2 - Part No: 3D1 959 702 E
   Component: Tuersteuergeraet BF 0104
   Subsystem 3 - Part No: 3D0 959 703 E
   Component: Tuersteuergeraet HL 0104
   Subsystem 4 - Part No: 3D0 959 704 E
   Component: Tuersteuergeraet HR 0104
   Subsystem 5 - Part No: 3D0 909 610 B
   Component: 3I HDSG             2320
   Subsystem 6 - Part No: 7L0 907 719
00984 - Left Tail Light (M4)
            009 - Open or Short to Ground
00253 - Taillight Assembly - Rear Right
   Part No: 3D0 035 466
   Component: 12K-AUDIOVERST      0115
   VCID: 5F9F738A5B275AA2D79-5160
00871 - Bass Speaker Front Right (R23)
00421 - Rear Left DSP Midrange Speaker (R105)
Address 65: Tire Pressure        Labels: None
   Part No: 3D0 907 273 C
   Component: Reifendruckueberw.  0021
   Coding: 0011204
   Shop #: WSC 44580 136 08015
Address 66: Seat, Rear        Labels: None
   Part No: 3D0 959 860 B
   Component: Sitzmemory D1 H     1513
   Coding: 0000001
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V1.clb
   Part No: 3D1 955 119
   Component: Front Wiper         2005
   VCID: 6691666E847D0B6A14F-5160
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 B
   Component: Batteriemanagement  2600
Address 75: Telematics        Labels: 3D0-035-617.lbl
   Part No SW: 3D0 035 617     HW: 3D0 035 617
   Component: Telematik NAR1      0101
   Coding: 0061860
   Shop #: WSC 06490 444 01052
   VCID: 5DE34982512B48B2C55-5160
Address 76: Park Assist        Labels: None
   Part No: 3D0 919 283 C
   Component: 03 Einparkhilfe     0807
   VCID: 2A09D25E50E5EF0AF07-5160
End----(Elapsed Time: 07:22, VBatt start/end: 11.2V/10.5V. VIgn 0.0V)------
------------------------------24 Faults Found------------------------------
RICH18
C?ID=628352
GERMAN SPEC
Wednesday,08,October,2025,14:23:23:44133
VIN: WVWZZZ3DZ48007644   License Plate:
VIN: WVWZZZ3DZ48007644   Mileage: 202280km-125690miles
   Part No SW: 4D0 907 560 CQ    HW: 8E0 907 560
   Component: 4.2L V8/5V      A   0040
   Coding: 0011873
   VCID: 77AF3B2AD3D782E2BF9-5160
   VINID: 9E69EAAAA0D4A84200007184100DA8C8FA
18032 - MIL Request Signal Active (Check TCM for errors too!)
            P1624 - 008 -
18010 - Power Supply Terminal 30
            P1602 - 002 - Voltage too Low
18104 - Powertrain Data Bus
            P1696 - 002 - Implausible Message from Steering Column Controller - Intermittent
   Part No SW: 09L 927 760 B    HW: GS1 904 1
   Component: AG6 09L 4,2L V8     1004
   Coding: 0000101
   VCID: 3631F62E945DBBEA64F-5160
18161 - Tiptronic Switch (F189)
            P1753 - 000 - Implausible Signal - Intermittent
                    (no units): 0.0
                    (no units): 110.0
                    Temperature: 51.0°C
                    T.B. Angle: 0.0°
                    Voltage: 12.00 V
17119 - Gear 5
            P0735 - 000 - Incorrect Ratio
                    (no units): 0.0
                    (no units): 110.0
                    Temperature: 51.0°C
                    T.B. Angle: 0.0°
                    Voltage: 12.00 V
17113 - Gear 6
            P0729 - 000 - Incorrect Gear Ratio
                    (no units): 0.0
                    (no units): 110.0
                    Temperature: 51.0°C
                    T.B. Angle: 0.0°
                    Voltage: 12.00 V
   Coding: 0008376
   Part No SW: 3D0 909 135 L    HW: 5WK 470 22
   Component:    Kessy            6400
   Coding: 0147688
   Shop #: WSC 31414 000 00000
9 Faults Found:
00184 - Control Circuit for Engine Start/Stop Switch
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
00183 - Interior Access/Start Authorization Antenna 1 (R138)
00087 - Terminal 30 for Starting Relevant Consumers
   Coding: 0000003
   Part No: 3D0 035 007 PX
   Coding: 0500735
   Shop #: WSC 47058 141 11678
   VCID: 7EA12E0EFCEDB3AAFCF-5160
00384 - Optical Databus
   Part No: 3D0 907 040 F
   Coding: 0000001
   VCID: 211B35722DD32C52A1D-5160
00712 - Right Footwell Flap Positioning Motor (V109)
            014 - Defective
00023 - Motor for Warm-Air Flap; Center Console Rear Left (V202)
            014 - Defective
00716 - Air recirculation Flap Positioning Motor (V113)
            014 - Defective
00057 - Right B-pillar/Footwell Shut-Off Flap Motor (V211)
            014 - Defective
00785 - Temp Sensor in Instrument Panel (G56)
   Coding: 0000003
   Shop #: WSC 42706 124 82102
Address 13: Auto Dist. Reg        Labels: Redir Fail!
   Part No: 3D0 907 567 H
   Component: AC101 V8  6HP194 09 0338
   Coding: 0001451
51560 - Unknown Error Code
            Unknown - 008 -  - Intermittent
                    Count: 63
00272 - Function Disabled due to Electromagnetic Interference
            012 - Electrical Fault in Circuit - Intermittent - MIL ON
                    Count: 27
00472 - Control Module for Brake Boost (J539)
            013 - Check DTC Memory
51561 - Unknown Error Code
            Unknown - 012 -  - Intermittent
   Component: 0C Airbag 8.4E+ H07 0935
   Coding: 0012355
   Part No: 3D0 953 549 B
   Component: Lenksäulenmodul     3301
   Coding: 0000022
   VCID: 2C05D4465A11F13A02B-5160
00003 - Control Module
            014 - Defective
   Part No: 3D0 920 881 Q
   Component: KOMBIINSTRUMENT RB4 0421
   Coding: 0007111
   Shop #: WSC 47058 141 61973
   VCID: 3435CC268221A9FA5AB-5160
14 Faults Found:
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
Address 18: Aux. Heat        Labels: 3D0-815-005.clb
   Part No: 3D0 815 005 P
   Component: Standheizung        2415
            014 - Defective
01415 - Recirculating Pump (V55)
   Coding: 0000006
21 Faults Found:
00461 - Control Module for Seat Memory; Passenger (J521)
00462 - Control Module for Seat Memory; Rear (J522)
00478 - Control Module; Display & Input; Comfort CAN; Rear (J524)
00908 - Control Module for Wiper Motor
01308 - Control Module for Roof Electronics (J528)
01327 - Control Module for Parking Aid (J446)
01335 - Drivers Seat/Mirror Position Control Module (J543)
Address 23: Brake Booster        Labels: None
   Part No: 3D0 907 563 C
   Component: BREMSBOOSTER        4310
   Part No: 3D0 919 158 G
   Coding: 0000001
   VCID: 6691666E847D0B6A14F-512A
   Coding: 0015500
01487 - System Function Test
            015 - Cannot Be Tested at this Time - Intermittent
   Coding: 0000004
   Coding: 0000019
   Shop #: WSC 47058 141 60934
00926 - Terminal 30
   Coding: 0000001
   VCID: 678F6B6A837712622F9-5140
   Component: 15 HSG              3212
   Coding: 0000040
   VCID: 3239CA3E7835A7CA487-4B14
9 Faults Found:
00485 - Drivers Outside Door Handle Central Locking Button (E369)
00318 - Supply Voltage for Rear Lid Control Module
Address 57: TV Tuner        Labels: 3D0-919-146.lbl
   Part No: 3D0 919 146
   Component: TV Tuner        H07 1205
   Coding: 0000010
   VCID: 65936162797B00721D5-5160
   Coding: 0011324
   Shop #: WSC 01942 161 11844
01477 - System Switched Off
   Component: Sitzmemory D1 H     1501
   Coding: 0000001
   Component: 01 Einparkhilfe     0807
Address 77: Telephone        Labels: None
   Part No: 3D0 035 704 D
   Component: Telefon             8110
   VCID: 1E610E8E1CAD13AA9CF-5160
01522 - Handset for Telephone (R37)
01524 - Antenna for Telephone
End----(Elapsed Time: 06:54, VBatt start/end: 13.9V/13.7V. VIgn 0.0V)------
-----------------------------104 Faults Found------------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
First hit of a web search:
Michael aka. PanEuropean as well as others in the community have done a really good job documenting all sorts of modifications on Phaetons.
RICH18
C?ID=628352
Sebastian thankyou very much for your help !!!
RICH18
C?ID=628352
I may have time to Swap the lamps out today and code 17 to EU I have already fitted a EU switch. Everybody involved helping me here I'm very grateful !!!
RICH18
C?ID=628352
UPDATE !!!
I fitted the German spec lights and EU headlight switch used VCDS to code with the help from Chat GBT. The end result is it works expect instead of a rear fog symbol on the instrument cluster it lights up a TPMS Icon . I hope the TUV guy passes it . Also the RH Fog light don't light up minimum requirement is LH rear must work so I'm not going to trouble shoot it. code 0007111 for channel 17 appeared to work.
Thanks for all your support
Richard
