Firmware update
rceddie123
DN213DG, England
C?ID=604585 +LP/SN
I recently updated to latest version of VCDS and it is now saying a firmware update is required. Even though it is recognising the adapter at test when it goes to config it is saying no dongle present. Have tried reload of software to no avail. On reverting back to v24.7 firmware update is not asked for so I can use VCDS but in this version also dongle is not being seen in config mode. Can you please advise
What is the serial number showing on the [About] screen in VCDS? If it's the one you provided when you joined the forum, that's a clone. You might want to bin that clone and try again with the legitimate HEX-V2 that also own; the one with the serial number on the product label that starts with H17- and ends in 103.
elpadreman
Kent, England
C?ID=591941
Hi,
I too am being advised that I need a firmware update.
Not sure what serial number I provided, but there is none on the Hex-V2 unit, which I bought from Gendan and believe is legit.
It appears too work on my 2005 Transporter, but not on my 2012 Passat, when the firmware update suggestion flags up.
Ive come indoors where I have wifi, but firmware update does not seem possible.
Any constructive comments and suggestions would be gratefully received.
elpadreman
Kent, England
C?ID=591941
Update.......
I just checked the procedure for firmware update and was informed no updates are available.
VCDS is Release 25.3.2.
The one you bought from Gendan should have a number on it, specifically H17-xxx010.
(The xxx represents a redaction since we don't like having people's complete serial numbers here).
Are you certain that is the HEX-V2 you are using?
As far as I can see that HEX-V2 us up-to-date for use with Release 25.3.2 of VCDS, but would need an update from the Beta firmware channel for use with the Beta version of VCDS (25.9.0).
elpadreman
Kent, England
C?ID=591941
Hi,
Thanks for the swift reply.
H17-xxx010 is correct, and it is labelled HEX-V2.
The opening page of VCDS says Release 25.3.2.
It works with my 2005 Transporter T5, but comes up with the firmware suggestion when plugged into my 2012 Passat with ignition on.
Photo attached of the message when connected to wifi indoors.
When tested via Options/Test it reads as all OK.
Would a screen grab of the message when plugged into my Passat help?
TTT
C?ID=547002
It may be plugged in, but this car does not power the obd socket. It is not the hex-v2 you need to be concerned here. I say chase fuses.
The picture you posted does not show it requesting a firmware update. It shows a lack of +12V power coming from the OBD-II socket in the car, and the interface needs that +12V power in order to communicate with the car.
I'm with @TTT. Check fuses.
elpadreman
Kent, England
C?ID=591941
Hi All,
Thanks for your comments.
Screen shot was indoors on Wi-Fi - not connected to car.
Any good.. all working this morning! Not sure why but it is. Thanks again for your help.
  • Informative
