- May 2, 2014
- 169
- 83
- Alexandria/fairfax county VA
- C?ID=99408
my TPMS is intermittent, and I read that I might be able to enable the indirect TPMS used in later models, vs replacing TPMS modules inside the wheels.
tried to follow this info:
http://forums.tdiclub.com/showthread.php?p=4521091#post4521091
when i get into the long coding helper, I can find the specified bit/byte, which the helper says indicates TPMS not installed.
it will not let me implement the change. when I hit "do it" a window comes up to say there is an issue. do I need an authorization code to make this change?
for reference, here is a recent scan:
Saturday,03,May,2014,16:27:05:51928
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: 3VWPL71K89M272852 License Plate:
Mileage: 193240km-120073mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
VIN: 3VWPL71K89M272852 Mileage: 193240km/120073miles
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 P HW: 03L 906 022 J
Component: R4 2,0L EDC G000AG 8681
Revision: --H01--- Serial number: VWX7Z0H72491JO
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 3FA390536EB764E6A2D-806A
001139 - Exhaust Pressure Sensor 1 (G450)
P0473 - 000 - Signal too High - Intermittent
Mileage: 192453 km
Time: 15:35:46
Pressure: 0 mbar
Pressure: 0 mbar
(no units): 0.0
Temperature: 7.2°C
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 050 D HW: 02E 927 770 AD
Component: GSG DSG 082 1402
Revision: 05108020 Serial number: 00001009261684
Shop #: WSC 04940 001 00001
VCID: 130B6CE332BF5086365-8046
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 113B600D492900FC881306E9921B0042B100
VCID: 75CF327BDC0BEEB6B81-8020
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 7CD9275F3F21BFFEC7F-8029
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000001014370
Coding: 14898F2340041500070000001C000000000873075C000120000000000000
VCID: 3245C967ADE5B98E5D3-8067
Component: Wischer 230808 021 0501
Coding: 00038805
Shop #: WSC 00066
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0382262
Coding: 0000100
VCID: 334BCC6352FFB086565-8066
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 78 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M06G1H$
Coding: 0014136
VCID: 6CF9171F4F412F7E57F-8039
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME3B0044340
Subsystem 3 - Serial number: 6342MSME3E307878M
Subsystem 4 - Serial number: 6351HSME174A4C71D
Subsystem 5 - Serial number: 6361HSME175F5826H
Subsystem 6 - Serial number: 63727SME16701603R
Subsystem 7 - Serial number: 63827SME16701021M
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0010042
VCID: 832BDCA3C2DF4006065-80D6
Part No SW: 1K0 920 974 N HW: 1K0 920 974 N
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0003000 Serial number: VWX7Z0H72491JO
Coding: 0007203
VCID: 3957FE4B70934AD69C9-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 020708F1000751
Coding: ED807F070013022002
VCID: 354FF27B5C8BAEB6781-8060
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T2EKX03
VCID: FDDFAA5BA43B36F6701-80A8
Component: IMMO 3HL 2418
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000532488807
Coding: 0001205
VCID: 6FC300137E57D46672D-803A
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A75D1078535F14EE53-807F
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139007885283281B0904058FB0880F0488DC00
VCID: 8429DFBFC7D1473E3FF-80D1
00332 - Control Circuit for Tank Flap
Fault Status: 00100111
Reset counter: 160
Fault Frequency: 9
Reset counter: 159
Mileage: 192892 km
Time: 09:31:29
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000552988807
Coding: 0001204
VCID: 70C1036F6369CB9E6B7-8025
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2224675
Coding: 0010400
VCID: 29772E0B8033FA56EC9-807C
00003 - Control Module
014 - Defective
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003360131
Coding: 0001168
VCID: 76CD3577010DE5AEB1B-8023
Component: RDK 0450
Coding: 0100101
Fault Status: 00110100
Reset counter: 154
Mileage: 192751 km
Time: 23:00:18
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003383939
Coding: 0001168
VCID: 77D3387306079CA6AAD-8022
End ---------------------------------------------------------------------
