T-Roc R ACC Problems
Vdub
C?ID=57533
I have a 2019 T-Roc R here in the shop at the moment for walnutblasting.
The owner also mentioned a problem with the ACC, he said he wrapped the VW Logo darker and from that moment the ACC didnt work quite well anymore.
He removed the wrap but that didnt change the problems with the ACC.
You can use the ACC as long as you don't get any car in front of you, immediatly when the car see's one in front of you and starts to brake/slow down, the ACC says Failed/Error.
In the 01-Engine it has the fault code U0416 refering to a fault in the ABS/ESP but that module doesn't have any faults stored(BUT it looks like an ABS problem because when its starts braking the ACC gets an error).
The other fault, but in the ACC is "fault_tsk_irrev_fail".
I can clear the faults, the ACC works again after a few km's and a engine restart.
I will post a complete Autoscan tomorrow.
Vdub
C?ID=57533
Here is the complete scan with the 2 fault codes that appeared during the drive.
Sunday,05,October,2025,12:49:54:16149
VCDS Version: 25.3.2.0 (x64)  HEX-NET CB: 0.4672.4
Dealer/Shop Name: VAG Performance Center
Workshop Code: 052 99293 000001
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 2B 3C 42 44 4B 52 5F
          69 6D 75 A5 A9 BB BC CA D6 D7
VIN: WVGZZZA1ZLV055399   Mileage: 44044km-27367miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DNUE)       Labels:. 06K-907-425-V1.clb
   Part No SW: 81A 906 259 A    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0002
   Revision: --H13---    CVN: 8DD961FF
   Coding: 092540122476050B3004
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TFS02081A906259A 001002
   ROD: EV_ECM20TFS02081A906259A.rod
   VCID: 2A18F5F24DC03CCBAD-807E
   VINID: 9E65EAAAA441A9C9801450C9244794DEE9
17170 - Implausible Data Received from ESP Control Module
          U0416 00 [00100100] - -
                    Mileage: 44042 km
                    Date: 2025.10.04
                    Time: 15:12:54
                    Engine speed: 1809.75 /min
                    Vehicle speed: 95 km/h
                    Coolant temperature: 86 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 13.359 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
   Part No SW: 0GC 300 013 Q    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2403
   Revision: 00H06V09    CVN: DE6FE191
   ROD: EV_TCMDQ381061.rod
   VCID: 3228ED926510740B15-8066
   No subsystems:
   Part No SW: 5Q0 614 517 ES    HW: 5Q0 614 517 BP
   Component: ESC           H35 0190
   Revision: 00000000    Serial number: 62869000000024
   Coding: 46FA6B7D50252471477A070962CC6862D60A24E2E0461671384250F8D2A84B0B0040052352522424EC35351919323200
   Shop #: WSC 46131 006 1048576
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 06406142B91838ABE9-8052
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0531612215 Dataset Number: V03935301VA 0001
   Coding: 132C0C0723
   ROD: EV_KessyHellaMQBAB_VW27.rod
   VCID: 45C2A64EC49EF3B3A0-8010
   Part No SW: 5G0 907 044 FD    HW: 5G0 907 044 FD
   Component: Climatronic   H04 2201
   Revision: 00001K10
   Coding: 060200242001100D1105000000101032
   ASAM Dataset: EV_ACClimaBHBVW37X 006150
   ROD: EV_ACClimaBHBVW37X_006_VW27.rod
   VCID: 6E9039E2B1A810EB31-803A
   Air quality sensor:
   Part No SW: 5Q0 937 084 DG    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H40 0312
   Serial number: 01001928505162 Dataset Number: V03935302B  0001
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW27.rod
   VCID: 004C775A9B3C169BD3-8054
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: SAY19M10D12H11M33S07
   Coding: 0018DD
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY19270230J
   Component: Sirene, DWA  005  0314
   Serial number: 00000000000047750767
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03  0170
   Serial number: 0100201020190C100229
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058419295 Dataset Number: V03935306ND 0001
   Coding: 0471555911
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 50EC871A0BDC261B03-8004
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Dataset Number: V03935314EN 0001
   Coding: 320467CA5CFF8748949C810580408700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 43C6B856CAAACD838E-8016
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 171
                    Mileage: 44032 km
                    Date: 2025.10.04
                    Time: 00:07:28
                    Voltage terminal 15: 12.4 V
                    Control Module temperature: 27 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.09 m/s²
                    Adaptive distance regulation: status: ACC_irreversible error
   Serial number: 07101941350386 Dataset Number: V03935300TX 0001
   ROD: EV_DRCONTITEMIC_VW27.rod
   VCID: 383CDFBA836C9E5B2B-806C
   Part No SW: 3Q0 959 655 CS    HW: 3Q0 959 655 CS
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z7PL99B5$ Dataset Number: V03935296K  0001
   Coding: 88CCC0C0000000005C5400CF000840000065
   ROD: EV_AirbaVW21TS6VW48X_VW27.rod
   VCID: 116A421EC0566F134C-8044
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1040
   Serial number: 2GA857705B0290T00762
   Coding: 80000D
   Right seat belt tensioner:
   Component: BeltPretRevFR  106 1040
   Serial number: 2GA857706B0291T00333
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 909 19
   Serial number: 35700000000E6D5CEF3B
   Subsystem 4 - Part No SW: -----------    HW: 454 001 909 19
   Serial number: 358000000009E539FF33
   Subsystem 5 - Part No SW: -----------    HW: 454 802 009 19
   Serial number: 351003FD4B819000000U
   Subsystem 6 - Part No SW: -----------    HW: 454 802 009 19
   Serial number: 35200BB97B919000000Z
   Subsystem 7 - Part No SW: -----------    HW: 454 800 210 19
   Serial number: 35500F14B0A1A000000M
   Part No SW: 17A 920 790 B    HW: 17A 920 790 B
   Component: KOMBI         503 4188
   Coding: 05AC0018FF8C00080188630B5001000000000706
   ASAM Dataset: EV_DashBoardVDDMQBA0 001041
   ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
   VCID: 260001C259D818AB89-8072
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000279962 Dataset Number: V03935301GP 0001
   Coding: 030500346F085900FB13A27C9A0F00010001070000000000000000000000
   GVL: 01C63C1008000600C0CC80008000CC0010000000000200000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 70AC279AAB9C061B23-8024
   Generator:
   Component: 4-01-13-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001867760029343
   Coding: 2DFFFF
   Serial number: 3486232805
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00016.09.19 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_004_VW27.rod
   VCID: 4CD4936AE7F402FB7F-8018
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000292023005
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 312AE29E60164F136C-8064
Address 3C: Lane Change (J1086)       Labels:| 2Qx-907-686-V1.clb
   Part No SW: 2Q0 907 686 A    HW: 2Q0 907 686 A
   Component: HRE3_Kl15_Mst H05 0052
   Serial number: 00000530965607  Dataset Number: V03935297EL 0001
   Coding: 60014500
   ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
   ROD: EV_HREntryHellaGen3Kl15_001_VW27.rod
   Subsystem 1 - Part No SW: 2Q0 907 685 A    HW: 2Q0 907 685 A
   Component: HRE3_Kl15_Slv  H05 0052
   Serial number: 00000530592149
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000393171531  Dataset Number: V03935300JY 0001
   Coding: 003B1A20D000028000001000
   VCID: 4DD29E6E1CEE0BF368-8018
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000034953362
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Dataset Number: V03935312TA 0001
   Coding: 951F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C34C3AAB754B27BCF-8068
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 10101911603485 Dataset Number: V03935304ZR 0001
   Coding: 000000070900204A07100900000000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 373EDC868E72912322-8062
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000392804494  Dataset Number: V03935300JZ 0001
   Coding: 003B1820DE00028000001000
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000034908596
   Coding: 190000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0879
   Serial number:                Dataset Number: V03935311FY 0001
   Coding: 02720601BE0000004111010100880A231F0507F4012004008E
   ROD: EV_MUStd4CDELP_VW27.rod
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H61 8214
   Serial number: VWZ6ZHW2922515
   Subsystem 2 - Part No SW: V03 959 821 FM    HW: -----------
   Component: ECE DL1 24/25  --- 2210
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0530193359 Dataset Number: V03935298KQ 0001
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 40CCB75ADBBCD69B93-8014
   Part No SW: 5Q0 959 107 R    HW: 5Q0 959 107 H
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C737-6331-8 Dataset Number: V03935301SX 0001
   Coding: 1C88
   VCID: 47DEAC46FE92E1A352-8012
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------    Dataset Number: V03935298KU 0001
   Coding: 02720601EA42380D3F1CBE020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW27.rod
   VCID: 3D32CEAEAC4EBB73F8-8068
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 09101915P20141 Dataset Number: V03935310NX 0001
   Coding: 0002070600000401002213558150A90098000E20002000
   ROD: EV_MFKBoschMQBB_002.rod
   Part No SW: 2GA 907 159     HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0002
   Serial number: 191002203129
   ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
   VCID: 79BA1ABEF8E6475394-802C
   Dataset Number: V03935280ME 0001
   Coding: 608040727602
   VCID: 75A2168ED4FE2333F0-8020
   Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
   Component: LED1L         H07 0009
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
   VCID: 02487D529530048BC5-8056
   Component: LED1R         H07 0009
End----------(Elapsed Time: 02:07, VBatt start/end: 12.0V/12.1V)-----------
------------------------------2 Faults Found-------------------------------
mathi9020010
C?ID=573263
Go erase the error and drive some miles.
Vdub
C?ID=57533
Ofcourse i did that already twice, like i wrote, if i drive on ACC and don't see a car in front it drives fine for 1000miles..
In the last scan i drove quit fast to catch up a car, the ACC was on 3 stripes distance/150m and sees the car and starts to slow down and immediatly disables with this error.
Westbury, UK
Has the wrap left a layer of contamination on the radar cover or even materially changed the cover by chemically reacting with the cover?
Anything that changes the way that the radar signal passes through the cover will affect the apparent return reflection and hence the apparent presence and/or distance of objects in front. I would not be at all surprised if the only cure is a new radar.
RGH0
Australia
C?ID=433612
remove the badge so the radar has nothing in front of it and see if that solves the problem ?
Vdub
C?ID=57533
I can check that, but the logo does look clean, the wrap only sat on it for a day. Why should it need a new radar? It's mounted 10cm behind the logo..
I will check if that is even possible.
I've cleared fault-codes and took the car to the grocerystore for a drive, it drove on ACC 30kmh behind a car that didn't slow down, AS for the moment the leader of the pack came to a crossing and slightly drove slower my car brakes/did the same and bang, there was the ACC-fault again. It won't turn on anymore until you restart the car.
I'll take it back to the shop tomorrow and will post a new scan of the faultcodes.
TTT
C?ID=547002
If I come behind you, and scream the best I can 10 cm from your ear, do you think I have a fair chance to mess up your hearing hair?
With electronics and radar waves and antennas, might be the same.
Vdub
C?ID=57533
If a wrap kills the radar than every leaf, dirt or snow will kill dozens of radars.. i dont think the radar can't handle that.
Ive seen way more VAG-cars(owners) that tried to wrap or stick a black logo on top of it.
The ACC did malfunction while attached but after removal it was OK again.
TTT
C?ID=547002
A leaf is not an metallic reflective foil. I don’t have solid evidence to say wrap killed the radar, but this is the storyline: acc good, foil on, acc bad. End of it, right?
downtime
Finland
C?ID=280813
Recalibrate the radar
Vdub
C?ID=57533
Ive found a few small leftovers of wrap on the logo, peeled them off, same result.
The ride was almost the same, only when it approached the car in front off me it highlighted in BEG RED BRAKE NOW!! and then it got the ACC Fault again.
I set 50kmh on ACC and drove 43kmh behind it when it did that.
For the Golf 7.5 for example i have that script to set the ACC on zero degrees, does somebody already made that possible for this gen(2q0??) of ACC?
Monday,06,October,2025,08:13:22:16149
VCDS Version: 25.9.0.0 (x64)  HEX-NET CB: 0.4672.4
Data version: 20250915 DS372.0
VIN: WVGZZZA1ZLV055399   Mileage: 44049km-27370miles
   VCID: 2A18F5F24DC03CC93D-807E
                    Mileage: 44045 km
                    Date: 2025.10.05
                    Time: 16:09:10
                    Engine speed: 1087.00 /min
                    Vehicle speed: 39 km/h
                    Coolant temperature: 36 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 14.433 V
                    Drivetrain coordinator: brake fault status-ESP system malfunction: No
Readiness: 0010 0000
   VCID: 3228ED926510740985-8066
   No subsystems:
   VCID: 06406142B91838A979-8052
   Coding: 132C0C0723
   VCID: 45C2A64EC49EF3B130-8010
   Revision: 00001K10
   VCID: 6E9039E2B1A810E9A1-803A
   Air quality sensor:
   ROD: EV_BCMBOSCH_020_VW26.rod
   VCID: 004C775A9B3C169943-8054
   Coding: 0018DD
   Coding: 0471555911
   VCID: 50EC871A0BDC261993-8004
   VCID: 43C6B856CAAACD811E-8016
2068 - Databus
                    Reset counter: 171
                    Mileage: 44045 km
                    Date: 2025.10.05
                    Time: 16:09:10
                    Voltage terminal 15: 14.8 V
                    Control Module temperature: 25 °C
                    Vehicle speed: 4.71 m/s
                    Longitudinal acceleration: -0.44 m/s²
                    Adaptive distance regulation: status: ACC_activ_controlled
   VCID: 383CDFBA836C9E59BB-806C
   VCID: 116A421EC0566F11DC-8044
   Coding: 80000D
   Coding: 80000D
   VCID: 260001C259D818A919-8072
   VCID: 70AC279AAB9C0619B3-8024
   Generator:
   Coding: 2DFFFF
   Coding: 0001
   VCID: 4CD4936AE7F402F9EF-8018
   VCID: 312AE29E60164F11FC-8064
   Coding: 60014500
   VCID: 4DD29E6E1CEE0BF1F8-8018
   Coding: 951F0000
   VCID: 3C34C3AAB754B2795F-8068
   VCID: 373EDC868E729121B2-8062
   Coding: 190000
   VCID: 40CCB75ADBBCD69903-8014
   Coding: 1C88
   VCID: 47DEAC46FE92E1A1C2-8012
   VCID: 3D32CEAEAC4EBB7168-8068
   VCID: 79BA1ABEF8E6475104-802C
   VCID: 75A2168ED4FE233160-8020
   VCID: 02487D529530048955-8056
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW27.rod
End----------(Elapsed Time: 02:06, VBatt start/end: 12.1V/12.1V)-----------
downtime
Finland
C?ID=280813
I think that radar has guided function to start dynamic calibration. No need to manually change the angles. Of course needs ODIS for the guided functions. With VCDS you need to set angles to zero and run the reset personalisation settings basic setting
Vdub
C?ID=57533
Ive rewrote the script(found the new values for 2Q0) for setting the anglevalues of the 2Q0 ACC Radar to 0,00 so now it should dynamicly adjust the acc-allignment.
downtime
Finland
C?ID=280813
Yes. Take it for a drive
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
TSK (drivetrain coordinator) irreversible failure is the ECU telling the ACC radar that it can't carry out acceleration (speed up/slow down) commands from the radar, and won't recover from that state until the car is shut off and restarted. The ACC is just reporting that fact. Think of it like "Function Restriction due to Faults in Other Modules".
I have some experience pissing off the TSK, so I can tell you this has nothing to do with calibration. The ECU will have gone into that state because of the implausible data from ESP fault, which it obviously has to coordinate with to accomplish negative acceleration requests. Sadly the freeze-frame doesn't really say why.
The car does have follow-to-stop ACC from the factory, but I suspect further modifications. PartsLink24 expects this car to have ACC SW 2Q0 907 561 C from the factory, with a potential supersession of SW 2Q0 907 561 M. If you Google for that, you'll see images showing that HW 572 B is valid (it can run SW 561 C) but SW 572 R isn't expected for this car. Someone has flashed it or replaced it.
The TSK can be faulted by the radar asking the car to do something it's not equipped or configured for. Consider everything involved with ACC as potentially tampered-with. Software, coding, parameterization for the radar, ECU, and ESP are all on the table.
Vdub
C?ID=57533
The TSK is indeed a shitty faul-code to track, i had also several TSK solved with weird solutions..
This car is from another Garage/Workshop-owner(after i did walnutblasting for him) and he said that it happened after the Dark Foil over the logo.
I will connect ODIS tomorow and will do an Online Factory coding-check and let know what the outcome is.
The ACC stops working when it slows down, weird is that the fault is related to ESP but in the ABS/ESP module there isnt any fault stored.
Maybe ODIS wil translate the fault-code in something else..
NEtech
Denmark
C?ID=56995
Is it possible that is connected with some change odis has made on [03-ABS] at some point?
Post measurement map from [13].
Vdub
C?ID=57533
Customers says nobody touched it only the foil-guy to wrap the logo. He also didnt have any other workshop on his car than his own workshop and the tuner had tuned the car.
I know the tuner very well as iam part of the interior.
I wil post the Measurements map from 13 tomorrow.
RGH0
Australia
C?ID=433612
So now we discover after many posts that the car has been tuned ! Who knows what they did to screwup / upset the ACC system.
