Any way to change the sensitivity for the Day/Night light sensor on a 2015 Q5?
greyghost
C?ID=11562
I'm looking for a way to change the sensitivity for how much light is needed to change the map display from daylight to night. When my headlights are in AUTO, the display changes when there is still a LOT of light - even just a heavy overcast.
Please post an Auto-Scan so people can see how the vehicle is equipped and configured.
Doing is is by no means a guarantee that someone will be able to answer your question, but it does greatly increase the odds.
DirtD1ver
C?ID=186223
While we are waiting on your Auto-Scan, Under [Car -> Vehicle Settings -> Automatic headlights] what is the setting set there, I think the default is early. I have it set to late on my Allroad, and even then it can come on a bit early.
greyghost
C?ID=11562
Here's the complete autoscan. I hope it helps provide some suggestions!
In response to DirtD1ver, the auto headlight setting is "Late". Is there a noticeable difference if I change it to "Early", and if so, which way does it change?
Thanks!
Wednesday,27,January,2016,07:59:10:08468
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WA1LFAFP5FA121500   License Plate: 930-DLJ
Mileage: 20540km-12762mi   Repair Order:
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
          62 6C 6D 72
VIN: WA1LFAFP5FA121500   Mileage: 20540km-12762miles
Address 01: Engine (DET-CPMB)       Labels: None
   Part No SW: 8R1 907 115 L    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0002
   Revision: ECH09---
   Coding: 6A2A0013242600062000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TFS0118R1907115L 001003
   ROD: EV_ECM20TFS0118R1907115L.rod
   VCID: 3E795BBDA156A1CE43-806A
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 8R0 927 158 AS    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H19 1003
   Revision: --H19---
   ROD: EV_TCMAL551211_AU48.rod
   VCID: 0E19CB7DD176714EF3-805A
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 151D1803
   Shop #: WSC 06335 000 00000
   VCID: 1123D001C8486EB6EE-8044
   Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
   Component: BCM2 2.0      H15 0711
   Coding: 0D854040000000000000
   VCID: 0815FD65BB122F7E39-805C
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01130320152653
   Coding: 6481208000
   VCID: 77F78E99C6EC508640-8022
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00001026266502
   Coding: 26000091863CAFE00000480300003D0D0F1C4608A2090221000008004000030100000034000000
   VCID: 78F58DA5CBF25FFE49-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 150219  H12 0050
   Coding: 01DD13
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Component: USHL4.2  H30 0030
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED13D8SK
   Coding: 303635313832383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4C9D0175E7EA035EDD-8018
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R150000K3DL
   Serial number: 6334MSME4F1B307FT
   Serial number: 6344MSME4F4B525AU
   Serial number: 6352QSME204E077EP
   Serial number: 6362QSME0953484CN
   Serial number: 63732SME4B53185E7
   Serial number: 63832SME4B53585A8
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862OCH000N6
   Coding: 000017
   VCID: 48953D65FB92EF7EF9-801C
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 981 N    HW: 8R0 920 981 N
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 036298C3G
   Coding: 8BB622000301D705020000
   Shop #: WSC 45412 001 1048576
   VCID: 458B3451CC80F21602-8010
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z153030ABC
   Coding: 80C303FF00
   VCID: 4C9D0175EFEA035EDD-8018
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000138781026
   Coding: 00581B00000000000000
   VCID: 42812F4DDDAEC52E27-8016
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0362524262
   Coding: 010211
   Shop #: WSC 06334 000 00000
   VCID: 3F8726B9A65CA8C648-806A
   Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000139793860
   Coding: 011D13205E00440004
   VCID: 4FA716791EFC3846B8-801A
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0006489433
   Coding: 100000000000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X.rod
   VCID: 458B3451C480F21602-8010
   Revision: 00002001    Serial number: 0362756578
   Coding: 0126023A20FA709584B0053200040000
   Component: GTO BF  H01 0080
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813041813006
   VCID: 2D5B6CF174302A56EA-8078
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000140225859
   VCID: 4E990B7D19F6314EB3-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 10000000514556
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7157ADBD7E8DEE7F-806E
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156C.0F8238172
   Coding: 020007010000000001
   VCID: 244D89D527FAEB1E35-8070
   Part No SW: 8R1 035 746 G    HW: 8R1 035 746 G
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 523C-0F7531943
   Coding: 160200060005A1EF55028B5E00000403140000000000000000
   VCID: 3B7F52A9BA44B4E664-806E
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  5950
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000140748138
   Coding: 010C13204000240004
   VCID: 4689335DF186F90E0B-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-JA1A1IO
   Coding: 1020010
   VCID: 346D7995571A7B9EA5-8060
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D7B5CB1A450BAD65A-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000140748392
End-------------------------(Elapsed Time: 04:03)--------------------------
DirtD1ver
C?ID=186223
there is a noticeable difference when you change it it early. if you think it comes on too early now it will change even faster when set to early.
greyghost
C?ID=11562
I have done some additional digging and came up with the following post from Germany on an A3:
(source = http://www.stemei.de/pages/coding/audi-q3-8u/regensensor-und-lichtsensor-anpassen.php)
1. Select 09 (Central Electronics)
2. coding -> function 07
3. Select RLS - 1 - 8K0 955 xxx
4. Byte 1 = light sensor correction value
5. Byte 2 = rain sensor correction value
Value range respectively: 0 to 64.
Default: 56
Recommended: 0A = 10%
This sounds very promising to me, but I don't know how to interpret the suggestions. I've gone into that and here is the picture of my current coding:
f_51168381537
If anyone can help me with the bits & bytes I'd sure appreciate it!!!!
greyghost
C?ID=11562
Sorry, wrong format - here (I hope) is the picture!
f_51169658965
greyghost
C?ID=11562
OK, that didn't seem to work right either!
This time?
f_51169658965
greyghost
C?ID=11562
One more time - thanks for your help, Andy!
iHbYMOT
NEtech
Denmark
C?ID=56995
That is not the part number for the RLFS you have in your car!
Why don't you use Long Coding helper, it documented.
greyghost
C?ID=11562
And yet again - it's really going to work this time and I apologize to everyone about my lack of posting an image skills!!!!
http://i.imgur.com/iHbYMOT.jpg
greyghost
C?ID=11562
NEtech, I know it's not what's in my car, this was info from the link I posted. What I'm trying to do is understand what I need to change/click on to accomplish this - and I'm clearly not very knowledgeable about the VCDS system!
Now we're getting somewhere. I think you might be missing the fact that you have to select the G397_RLFS from the pull-down before you can code it. The coding you're looking at is the main BCM module, not it's RLFS subsystem.
Here's a screen-shot from the manual which illustrates what I mean:
Stevvee
Sweden
C?ID=234244
Barrow the thread!
I want to do the same thing on My Audi A6 C7, has someone Done this?
DirtD1ver
C?ID=186223
So, I had some time today and checked my car, and in the 09-Cent. Elec. the drop down to 2 -- RLFS -> long coding helper -> byte 0, the dropdown only has normal, 20% earlier, 40% earlier, and 60% earlier, nothing for later.
DirtDriver: Alas, your observations are pretty-much standard
iconoclast
C?ID=115951
yes. you can change it to be more sensitive or less sensitive. i have enabled it to be more sensitive 20% more sensitive because the lights kick on usually when exiting the tunnel not entering then stay on once i am out.
i am going off the top of my head but i believe it is in 09 in the drop down section you can access RLS Regenlicht Sensor. there you will find percentage changes and adjust to suit your taste. if it is not there please let me know and i'll try to scan the car tomorrow to give better information.
epicx
Romania
C?ID=197347
I would also be interested in how to adjust the sensor to be LESS sensitive, hence the auto lights to come on LATER...
iconoclast
C?ID=115951
Just a point of clarification regarding the discussion about "early" or "late" settings of the light part of the RLS/RLHS/RLFS. Changing these settings appears to be relative to the actual threashold value that is set somewhere else in another control module - I believe.
In a mk7, this threashold value appears to be defined in a couple of adaptation channels in the BCM. For example, if the car is fitted with the high-end 5Q0 937 series BCM, the actual turn-on/turn-off threashold values can be accessed at the following channels:
For the benefit of those that aren't familiar with the term "lx", it refers to the SI unit LUX which is a measurement of quantity of light falling onto a meter-square (those in USA might be more familiar with the term candela). Channel (1) in the table establishes the turn-on threashold (I used to use 500 lx as a nominal measurement for twilight in another incarnation) and channel (2) the turn-off threashold. So I suspect that "early", or "late" is relative to the 1st (or both) of these settings - I think.
Can anyone else shed any further light (pun intended) on this hypothesis?
