Tuesday,30,September,2025,14:53:34:07708
VCDS Version: 25.9.0.0 (x64) HEX-NET2 CB: 0.4672.5
Data version: 20250915 DS372.0
VIN: TMBKV0NX5TY009766 License Plate:
Chassis Type: NX-SK38 PA* (5QS)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 23 2B 32 42 44 47 4B 52
5F 69 6C 6D 75 82 A5 BB BC CA D6 D7 DE 8107 8109 810A 810B 810C 811E 811F
8120 8121 C002 C003
VIN: TMBKV0NX5TY009766 Mileage: 294km-182miles
CA-Sunroof -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
8107-Antenna -- Status: OK 0000
8109-Close Rge Radar 1 -- Status: OK 0000
810A-Close Rge Radar 2 -- Status: OK 0000
810B-Close Rge Radar 3 -- Status: Malfunction 0010
810C-Close Rge Radar 4 -- Status: Malfunction 0010
Address 01: Engine (J623-DNPD) Labels:. 06K-907-425-V1.clb
Part No SW: 5WA 906 264 HW: 06K 907 425 AA
Component: R4 2.0l TFS H80 0002
Dataset Number: 06Q909102DD 0001 CVN: 79CFB21C39CB07FD
Coding: 0C25403223740D0B30080000001000000000000000000000
ASAM Dataset: EV_ECM20TFS0205WA906264 001005
ROD: EV_ECM20TFS0205WA906264.rod
VCID: 0842EB8B62B2DA8AEF3-805C-R SFD+SFD2
VINID: 91D49B9807A8164A400091C6186286B53B
43491 - Communication Authentication
U3035 00 [00100000] - Invalid Signal
[Communication Authentication Signal Invalid Data]
Reset counter: 38
Mileage: 264 km
Date: 2025.09.28
Time: 15:27:24
Engine speed: 0.00 /min
Vehicle speed: 255 km/h
Coolant temperature: 55 °C
Intake air temperature: 31 °C
Voltage terminal 30: 12.285 V
FAC_TPS_1_SAE: 16.8627454 %
FUP_H_SAE: 10370 kPa
MAP_MES_SAE: 101 kPa
Engine status: Stop
TAA: 13.500 °C
T_AST_SAE: 28 s
Oxygen sensor 1 bank 1: voltage raw value O2 signal: 1.992 V
20692 - Accelerator Pedal
U013C 00 [00100000] - No Communications
Reset counter: 34
Mileage: 15 km
Coolant temperature: 58 °C
Intake air temperature: 48 °C
Voltage terminal 30: 11.953 V
Unlearning counter according OBD: 34
Accelerator pedal position: 0.00 %
20693 - Accelerator Pedal
Reset counter: 34
Mileage: 15 km
46877 - Implausible Data Received from Body Control Module (Central Electric)
U0422 00 [00100000] - -
[Invalid Data Received From Body Control Module]
Reset counter: 34
Mileage: 23 km
Date: 2025.09.27
Time: 09:59:43
Coolant temperature: 95 °C
Intake air temperature: 49 °C
Voltage terminal 30: 12.382 V
FUP_H_SAE: 15540 kPa
MAP_MES_SAE: 100 kPa
Engine status: Stop
TAA: 14.352 °C
T_AST_SAE: 32 s
Oxygen sensor 1 bank 1: voltage raw value O2 signal: 2.041 V
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0GC 906 557 PS HW: 0GC 300 028
Component: GSG DQ381 H06 0860
CVN: D6E89A0E
ASAM Dataset: EV_TCMDQ381064 001012
ROD: EV_TCMDQ381064.rod
VCID: 1D6CAADFDD302F22AC5-8048-R SFD
Parking lock:
Subsystem 1 - Part No SW: 5WA 907 484 A HW: 5WA 907 484
Component: ZSB_SB_AUTO H03 1092
Serial number: 00000000000091933142
Selector lever:
Subsystem 2 - Part No SW: 5E8 713 059 HW: 5E8 713 059
Component: ZSB_SB_mono H01 0011
Serial number: 25 181 0438 R 02U1B8
MTF pump:
Subsystem 3 - Part No SW: 0GC 927 373 M HW: 0GC 927 373 M
Component: SMOP DQ381 H04 0001
Serial number: C7458810700007752664
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5WA 614 517 DS HW: 5WA 614 517 BS
Component: ESC H31 0337
Serial number: 61785000007729 Dataset Number: V03935472DV 0001 CVN: 2262F09E4B4798CD
Coding: 5508556CA4CA399C4103A59C9EB701C50ACF952249A000
ASAM Dataset: EV_Brake1ESCMQB37WUNECE 006026
ROD: EV_Brake1ESCMQB37WUNECE_004.rod
VCID: 1C6AA7DBC62A262A5BB-8048-R SFD+SFD2
8730 - Implausible Data Received from Parking Assist Control Module A
U045A 00 [00100000] - -
[CCan_PARKEN_01_Counter]
Reset counter: 38
Mileage: 264 km
Date: 2025.09.28
Time: 16:38:05
Vehlicle_speed: 0.0 km/h
Resolution Mileage: 824 m
Voltage_value_KL.30_ESC_V: 12.0 V
Wake up EPB: not active
Wake up CAN: not active
Postrun_activ: not active
Comparison_pressure_sensor: completed successfully
Comparison_longitudinal_accleration: completed successfully
Comparison_transverse_accleration: not completed successfully
Comparison_yaw_rate_sensor: not completed successfully
LWS_comparison: not completed successfully
Internal_failure_code: 00 D5
00 02 00 00 04 8C 10 08 80 00 00 00 8A 12 00 40 30 00 21 00 04
1981 - Function Restricted due to Insufficient Voltage
U1400 00 [00101000] - -
[Uv_related_fail_replace]
Fault Frequency: 16
Mileage: 13 km
Date: 2025.09.22
Time: 08:58:11
Resolution Mileage: 528 m
Voltage_value_KL.30_ESC_V: 9.2 V
Internal_failure_code: 01 F1
00 E0 00 00 04 8C 10 08 80 00 00 00 80 1B 00 40 32 00 21 00 04
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 AD HW: 5WA 959 436 N
Component: Kessy IOBOX 122 0771
Serial number: --------------- Dataset Number: V03935417A 0001
ASAM Dataset: EV_Kessy37w 005030
ROD: EV_Kessy37w_005_SK38.rod
VCID: 167EB5F338067C7A6DF-8042-R
Address 08: Auto HVAC (J979) Labels: Redir Fail!
Part No SW: 3WA 907 007 F HW: 3WA 907 007
Component: Climatronic H01 5089
Serial number: 212052519163960 Dataset Number: V03935480LL 0001
Coding: 201100240011020010101010101111110000132110200000000000000000
ASAM Dataset: EV_ACClimaBHBE3ADV 002062
ROD: N/A
VCID: 48C22B8B22321A8A2F3-801C-R SFD+SFD2
Subsystem 1 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00001280625100621505
Subsystem 2 - Part No SW: 5E3 907 049 B HW: 5E3 907 049 B
Component: E265KlimaHeck H03 0201
Serial number: 06051501850797
No ASAM data for: "EV_ACClimaBHBE3ADV" (SK38)
1048833 - ROD - Unknown Error Code
- 00 [00100000]
Reset counter: 37
Mileage: 151 km
Date: 2025.09.27
Time: 15:57:20
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5WA 937 086 CF HW: 5WA 937 086 BL
Component: BCM37w_H238 0517
Serial number: BXJ53F180725940 Dataset Number: V03935479FD 0001
ASAM Dataset: EV_BCMwBL 005001
ROD: N/A
VCID: 1760B8F73F0C4572769-8042-R SFD+SFD2
Subsystem 1 - Part No SW: 5E8 955 119 A HW: 5E8 955 119 A Labels: 5QX-955-119-V1.CLB
Component: J400FRWISCH 067 0084
Serial number: 900J53F0402515300832
Subsystem 2 - Part No SW: 85E 955 555 B HW: 85E 955 555
Component: G397_RLFSS H09 0011
Serial number: 40098317X85E955555B0
Subsystem 3 - Part No SW: 5LC 941 501 HW: 5LC 941 501
Component: E1-LTM H02 0002
Serial number: 94111YEV00092
Subsystem 4 - Part No SW: 5E3 925 200 L HW: 5E3 925 200
Component: DiETa H05 0004
Serial number: 01557YFM000RO
Subsystem 5 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000006579039
Subsystem 6 - Part No SW: 5Q0 951 172 C HW: 5Q0 951 172 C
Component: Sensor, DWA 006 0501
Serial number: 0000000000000Q3ACNB8
Subsystem 8 - Part No SW: 5Q1 953 507 GF HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000011072504400900
Subsystem 9 - Part No SW: 57L 962 243 B HW: 57L 962 243 B
Component: GEB.F.Heckoef H02 0014
Serial number: 00000000000652937026
Subsystem 10 - Part No SW: 5E3 945 207 B HW: 5E3 945 207 B
Component: SHL_li1 H01 0305
Serial number: AP5R01250425FT061043
Subsystem 11 - Part No SW: 5E7 945 307 B HW: 5E7 945 307 B
Component: SHL_li2 H01 0305
Serial number: AP5R03150425FT060845
Subsystem 12 - Part No SW: 5E3 945 208 B HW: 5E3 945 208 B
Component: SHL_re1 H01 0305
Serial number: AP5R02220425FT090887
Subsystem 13 - Part No SW: 5E7 945 308 E HW: 5E7 945 308 E
Component: SHL_re2 H01 0305
Serial number: AP5R04110525FT060116
No ASAM data for: "EV_BCMwBL" (SK38)
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5QS 919 300 C HW: 5QS 919 300
Component: IPA 12ch high H01 0337
Serial number: 000023042595570 Dataset Number: V03935464WW 0001
Coding: 8318126111
ASAM Dataset: EV_EPHBO3CVW3360000 001014
ROD: EV_EPHBO3CVW3360000.rod
VCID: 52F609E3D46EA05A417-8006-R
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 1N3 907 567 E HW: 1N3 907 819 A
Component: ACC Bosch MQB H03 0550
Dataset Number: V03935474CW 0001
Coding: 0E8920EF4071404410020000000040C0000020008004000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW412 002017
ROD: EV_FRONTRADARBOSCHVW412_001.rod
VCID: 39245E4F69D87302A0D-806C-R SFD+SFD2
0322 - Databus
U1122 00 [00101100] - Implausible Message
[FAULT_SWA_MODE_SYSTEM_NOT_AVAILABLE]
Mileage: 15 km
Date: 2025.09.26
Time: 12:39:23
Outside temperature: 15.00 °C
Control Module temperature: 57 °C
Voltage terminal 30: 11.4 V
Vehicle speed: -0.00 m/s
Longitudinal acceleration: -0.00 m/s²
Adaptive distance regulation: status: initialized
kilometer reading: 15 km
Monitoring_debug_information: 00 00 00 00 00 00 00 00
Event_Id: 02 36
1416 - Databus
U1122 00 [00101110] - Implausible Message
[FAULT_VMM_INCONSISTENCY_AWV_PCF]
Mileage: 294 km
Date: 2025.09.30
Time: 13:42:42
Control Module temperature: 25 °C
Voltage terminal 30: 11.8 V
kilometer reading: 294 km
Event_Id: 02 55
1842 - Databus
U1122 00 [00101000] - Implausible Message
[FAULT_RB_MFK_BLINDNESS_ODACC]
Mileage: 292 km
Date: 2025.09.29
Time: 08:22:21
Outside temperature: 7.00 °C
Control Module temperature: 15 °C
Voltage terminal 30: 14.6 V
Vehicle speed: 9.30 m/s
Longitudinal acceleration: -1.49 m/s²
Adaptive distance regulation: status: Readiness
kilometer reading: 292 km
Event_Id: 02 05
1884 - Databus
[FAULT_RB_MFK_BLINDNESS_OD_PED]
Mileage: 292 km
Date: 2025.09.29
Time: 08:22:21
Event_Id: 02 06
1885 - Databus
[FAULT_RB_MFK_BLINDNESS_LDA]
Mileage: 292 km
Date: 2025.09.29
Time: 08:22:21
Event_Id: 02 04
2260 - Databus
[FAULT_RB_IMU_TIMESTAMP_NOT_PLAUSIBLE]
Mileage: 264 km
Date: 2025.09.28
Time: 15:49:50
Outside temperature: 16.00 °C
Control Module temperature: 34 °C
Voltage terminal 30: 11.9 V
kilometer reading: 264 km
Event_Id: 01 FE
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 3WA 907 376 E HW: 3WA 907 376 E
Component: DAEMPFUNGS-SG H10 0508
Serial number: 2C7752680805032 Dataset Number: V03935382TF 0001
ASAM Dataset: EV_DCC3CONTITEMIC 003014
ROD: EV_DCC3CONTITEMIC_002_VW38.rod
VCID: 50F203EBDA62D24A773-8004-R
Address 15: Airbags (J234) Labels:| 5QS-959-655.clb
Part No SW: 5QS 959 655 P HW: 5QS 959 655 P
Component: AirbagVW50 010 0250
Serial number: 000000003C0TNRD Dataset Number: V03935465EX 0001
Coding: 98FC008000C0C000000000000000000051540000A1540000C000F680009300A7
ASAM Dataset: EV_AirbaVW50SMEVW49X 001062
ROD: EV_AirbaVW50SMEVW49X.rod
VCID: 70B2A36B7A22F24A573-8024-R SFD+SFD2
Left seat belt tensioner:
Subsystem 1 - Part No SW: 85E 980 945 E HW: 85E 980 945 E
Component: BeltPretRevFL 007 0640
Serial number: 30062500170622000000
Right seat belt tensioner:
Subsystem 2 - Part No SW: 85E 980 946 E HW: 85E 980 946 E
Component: BeltPretRevFR 007 0640
Serial number: 30062500170871000000
Subsystem 3 - Part No SW: ----------- HW: 480 000 904 19
Serial number: 35700005868922590440
Subsystem 4 - Part No SW: ----------- HW: 480 001 106 19
Serial number: 35800007B6852DF85A10
Subsystem 5 - Part No SW: ----------- HW: 480 051 B06 19
Component: SideSensor_Dr 000 0149
Serial number: 3510000AAE5882C50520
Subsystem 6 - Part No SW: ----------- HW: 480 051 B06 19
Component: SideSensor_Pr 000 0149
Serial number: 3520000A6E5D5A1807C0
Subsystem 7 - Part No SW: ----------- HW: 480 050 A06 19
Component: FrontSensor_D 000 014A
Serial number: 3550000C8E40A38DC740
Address 17: Instruments (J285) Labels: None-SRI2
Part No SW: 5E3 920 770 F HW: 5E3 920 770 F
Component: KOMBI 501 3360
Dataset Number: V03935469DT 0001
Coding: 242401407B9C06400184620B20000B081030040000
ASAM Dataset: EV_DashBoardVDDMQB37W 006052
ROD: EV_DashBoardVDDMQB37W_003_SK38.rod
VCID: 2C0A771B968AD6AA2BB-8078-R SFD
8667138 - ROD - Unknown Error Code
- 00 [00001000]
Fault Frequency: 11
Reset counter: 43
Mileage: 13 km
Date: 2025.09.22
Time: 11:26:59
Part No SW: 5QS 907 530 F HW: 5QS 907 530
Component: GW MQB 23 005 2095
Serial number: SMERBG170725007 Dataset Number: V03935474V 0001
Coding: 000000000000000000000000000000000000000000000300030000000000000000000000000000000000000000000000
GVL: 3D48080002E8C08C804080C2CC00104004406002007C00000200000000000044
ASAM Dataset: EV_GatewMQBwBL 001027
ROD: EV_GatewMQBwBL_SK49.rod
VCID: 57E0F8F7FF8C8572B69-8002 SFD+SFD2
Generator:
Component: 5-00-18-01-03
Subsystem 2 - Part No SW: 5QS 915 181 HW: 5QS 915 181
Component: J367-BDMHella H01 2362
Serial number: 8364006606
Subsystem 3 - Part No SW: 5E3 919 719 AE HW: 5E3 919 719 AE
Component: E221__MFL-PR6 H02 0110
Serial number: PR6-0440061066254971
Subsystem 4 - Part No SW: 5E3 959 542 BD HW: 5E3 959 542 BD
Component: KLR 089 0029
Serial number: 3144797AA25181468404
8397575 - Energy Network Status
B1CB3 F0 [00101000] - Faulty
[NVEM_power_network_status_incorrect]
Fault Frequency: 9
Reset counter: 39
Mileage: 23 km
Date: 2025.09.27
Time: 09:57:21
Reason: 24
8397579 - 12V Battery
U183C 00 [00101000] - Discharged
[12V_battery_empty]
Reset counter: 36
Mileage: 15 km
Date: 2025.09.26
Time: 14:13:30
Specified voltage: 10.6 V
Generator actual voltage: 11.7 V
Voltage difference generator battery: 0.0 V
Generator speed: 0 /min
Generator chip temperature: 40 °C
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 AH HW: 3Q0 909 059 D
Component: EBKV H10 0563
Serial number: BPA085050625018 Dataset Number: V03935448GN 0001
Coding: 5003C5009600007BEFBDF7DE000049922449922400
ASAM Dataset: EV_BrakeBoostVW37WUNECE 013005
ROD: EV_BrakeBoostVW37WUNECE_013.rod
VCID: 167EB5F338067C7A6DF-8042-R SFD+SFD2
Address 2B: Steer. Col. Lock (J764) Labels:. 3WA-905-861.clb
Part No SW: 3WA 905 861 A HW: 3WA 905 861
Component: ELV-MQB_UNECE H05 0071
Serial number: 25000170347002- Dataset Number: V03935360RB 0001
Coding: 8820000000000000
Shop #: WSC 31000 074 00384
ASAM Dataset: EV_ELVMarqUNECE 004001
ROD: N/A
VCID: 49C42E8F3938E38230D-801C-R SFD+SFD2
No ASAM data for: "EV_ELVMarqUNECE" (SK38)
Address 32: Differential Locks (J647) Labels:* None
Part No SW: 5WA 907 554 Q HW: 5WA 525 130
Component: Quersperre H66 3020
Serial number: 000016.05.25000 Dataset Number: V03935343VH 0001
Coding: 0201
ASAM Dataset: EV_VAQMQB37WPA 001001
ROD: EV_VAQMQB37WPA.rod
VCID: 5CEAE7DB86AA662A9BB-8008-R
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 3WA 959 593 A HW: 3WA 959 593
Component: TSG FS 001 0222
Serial number: Y3007YFJ00JD1 Dataset Number: V03935462PC 0001
Coding: 003C9820D001008102003030
ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
ROD: N/A
VCID: 54FA0FFBEE7AAE6A53B-8000-R SFD+SFD2
No ASAM data for: "EV_DCU4DriveSideMAXHKLO" (SK38)
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V2.clb
Part No SW: 3WA 907 145 E HW: 3WA 907 145
Component: BASGEN1MQB37 504 1122
Serial number: 03995440 Dataset Number: V03935468VV 0001
Coding: 00000000000000010001020101000100000001010101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
ROD: EV_SteerAssisBASGEN1MQB37_017.rod
VCID: 4AC611833C3EE89A397-801E-R SFD+SFD2
Part No SW: 3G0 035 466 K HW: 3G0 035 466 K
Component: AMPeth16CDoIP H10 4052
Serial number: A1130V00016570 Dataset Number: V03935466VY 0001
Coding: 33800000000000000000000000000000000000000000000000
ASAM Dataset: EV_AMPEthMQB37w 001005
ROD: EV_AMPEthMQB37w_SK38.rod
VCID: 2D0C7A1FAD90DFA23C5-8078-R SFD
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5QS 907 338 E HW: 5QS 907 338 B
Component: FCM Baseline 019 4010
Serial number: 780542040025174 Dataset Number: V03935472BP 0001
Coding: 00000000090001CE06002F11020003000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiWBL 001008
ROD: EV_MultiModulContiWBL.rod
VCID: 5CEAE7DB86AA662A9BB-8008-R SFD
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 3WA 959 592 A HW: 3WA 959 592
Component: TSG BFS 001 0222
Serial number: YG007YAR0304A Dataset Number: V03935462PE 0001
ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
ROD: N/A
VCID: 53F80CE7EB74A9524A1-8006-R SFD+SFD2
No ASAM data for: "EV_DCU4PasseSideMAXHKLO" (SK38)
Part No SW: 57H 035 816 C HW: 57H 035 816
Component: MU-O-ND-EU H11 2768
Serial number: WG8LGM080725004 Dataset Number: V03935466YK 0001
Coding: 33825008000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 002001
ROD: EV_MUOIMQB37w_002_SK38.rod
VCID: 2E0E7D13A096A4BA05F-807A-R SFD+SFD2
Subsystem 1 - Part No SW: 5LA 919 606 B HW: 5LA 919 606 B
Component: ABT_W_13 H24 0266
Serial number: BHB00115072504780329
Subsystem 2 - Part No: V03 959 822 LE
Component: EUR 2025/26 3129
4112 - Release / Enable Active
B184C 00 [00001000] - -
[Unlock_protection_of_vehicle_diagnosis_active]
Reset counter: 8
Mileage: 12 km
Date: 2025.09.20
Time: 02:45:58
Address 69: Trailer (J345) Labels:. 5H0-907-383.clb
Part No SW: 5H2 907 383 E HW: 5H2 907 383
Component: Anhaenger H12 0207
Serial number: 000000000006672 Dataset Number: V03935436NL 0001
Coding: 0100000202001200
ASAM Dataset: EV_TrailFunctG3MPFMHella 001012
ROD: N/A
VCID: 32366963B4AE805A617-8066-R SFD+SFD2
No ASAM data for: "EV_TrailFunctG3MPFMHella" (SK38)
Address 6C: Back-up Cam. (J772) Labels:| 5WA-980-556.clb
Part No SW: 5WA 980 556 G HW: 5WA 980 556 C
Component: RV eCompact H52 0604
Serial number: FCLK20070725010 Dataset Number: V03935440HT 0001
Coding: 0303C10423140000
ASAM Dataset: EV_CamSysRVCeCFicosBL 003010
ROD: EV_CamSysRVCeCFicosBL.rod
VCID: 55FCF2FFE580B762A45-8000-R
Part No SW: 5WC 959 107 C HW: 5WC 959 107 B
Component: HDSG-Modul H08 0444
Revision: -------- Serial number: A2-C767-1162-1 Dataset Number: V03935420SH 0001
Coding: 3988
ASAM Dataset: EV_DeckLidCONTIAU536 001009
ROD: EV_DeckLidCONTIAU536_VW38.rod
VCID: 51F406EFD168DB4278D-8004-R
Address 75: Telematics (J949) Labels: None
Part No SW: 571 035 284 D HW: 571 035 284
Component: OCUMQBW2023_H H09 0668
Serial number: 0000000506VIBB9 Dataset Number: V03935465GG 0001
Coding: 03010601000000211000010012002607101112111012100000
ASAM Dataset: EV_OCUMWB2023 001072
ROD: N/A
No ASAM data for: "EV_OCUMWB2023" (SK38)
7253 - ROD - Unknown Error Code
- 00 [00101110]
Fault Frequency: 29
Mileage: 12 km
Date: 2025.09.20
Time: 11:56:16
1586 - ROD - Unknown Error Code
- 00 [01100100]
Reset counter: 39
Address 82: Head Up Display (J898) Labels:| 5H1-919-608.clb
Part No SW: 5E8 919 608 C HW: 5E8 919 608 C
Component: HeadupDisplay H02 2449
Coding: 5700E000
ASAM Dataset: EV_HUDMQBwBL 002013
ROD: EV_HUDMQBwBL_002.rod
VCID: 363E557358C69C7A4DF-8062-R SFD+SFD2
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 3WA 907 217 D HW: 3WA 907 217
Component: MFK120_MQB H18 1543
Dataset Number: V03935480MA 0001
Coding: 0206000000000000000000BB7940E00500000000006680000000FE00000038FFC3F24074C000000000800000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_MFK120MAGNAMQBWB 005004
ROD: EV_MFK120MAGNAMQBWB_001.rod
1049685 - Front Camera for Driver Assist Systems
C12B3 FD [00100000] - View Temporarily Restricted
[temp_blindness_detected_lda_impairment]
Mileage: 292 km
Date: 2025.09.29
Time: 08:22:50
1049858 - ROD - Unknown Error Code
- 00 [00100000]
Mileage: 292 km
Date: 2025.09.29
Time: 08:22:22
1049859 - ROD - Unknown Error Code
- 00 [00100000]
Mileage: 292 km
Date: 2025.09.29
Time: 08:22:22
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 3WA 959 595 A HW: 3WA 959 595
Component: TSG HFS 001 0222
Serial number: Y2007YF8007P6 Dataset Number: V03935462PG 0001
Coding: 000880200101008100003020
ASAM Dataset: EV_DCU4RearDriveMAXHKLO 001016
ROD: N/A
VCID: 56FEF5F3F886BC7AADF-8002-R SFD+SFD2
No ASAM data for: "EV_DCU4RearDriveMAXHKLO" (SK38)
Address BC: Door Rear Pass (J389) Labels: None
Part No SW: 3WA 959 594 A HW: 3WA 959 594
Component: TSG HBFS 001 0222
Serial number: Y2007YF900FB2 Dataset Number: V03935462PF 0001
ASAM Dataset: EV_DCU4RearPasseMAXHKLO 001016
ROD: N/A
VCID: 55FCF2FFE580B762A45-8000-R SFD+SFD2
No ASAM data for: "EV_DCU4RearPasseMAXHKLO" (SK38)
Part No SW: 4K8 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 010 0010
Dataset Number: V03935432GL 0001
Coding: 708040638202
Shop #: WSC 31000 074 00677
ROD: EV_SunRoofCONTIAU736_SK38.rod
VCID: 7DAC8A5F3D708F22CC5-8028-R
Part No SW: 992 941 572 AH HW: 992 941 572 A
Component: LED1L H25 9204
ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
ROD: EV_LLPGen3LKEBODPO68X_002_SK38.rod
VCID: 6984CE0F59F8038210D-803C-R
Component: LED1R H25 9204
ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
ROD: EV_LLPGen3RKEBODPO68X_002_SK38.rod
140304 - Bulb for DRL and Parking Light
C123A FA [00101000] - Function Restriction due to Over-Temp
[positionlight / daytimerunning light - high temperature dimming]
Reset counter: 29
Mileage: 159 km
Date: 2025.09.27
Time: 17:01:50
Address DE: Charger 1 for mobile dev (J0000) Labels: None
Part No SW: 3P0 035 502 C HW: 3P0 035 502
Component: COUPLING BOX 004 0311
Serial number: 325000000000053 Dataset Number: V03935425HL 0001
Coding: 400040
ASAM Dataset: EV_DualCouplBoxSK336 001006
ROD: N/A
VCID: 251C823FF560E7E2F45-8070-R SFD+SFD2
No ASAM data for: "EV_DualCouplBoxSK336" (SK38)
Address 8107: Antenna (J666) Labels:* None
Part No SW: 5QS 035 741 A HW: 5QS 035 741
Component: TrxModulHigh H05 0610
Dataset Number: V03935436GN 0001
Coding: 03380601010100010001010101000000010000
ASAM Dataset: EV_TrxMLGEMQBWBL 001026
ROD: EV_TrxMLGEMQBWBL.rod
VCID: 4ECE1D93C056C4BA65F-801A-R SFD+SFD2
Address 8109: Close Rge Radar 1 (J1088) Labels: None
Part No SW: 3WA 907 541 F HW: 95C 907 541
Component: Nanoradar 1 H08 0161
Serial number: 14520077152095 Dataset Number: V03935468TB 0001
Coding: 5A955E1529C405000000
ASAM Dataset: EV_NR1HELLAVW38X 002116
ROD: N/A
VCID: 4BC814873344F192021-801E-R SFD+SFD2
No ASAM data for: "EV_NR1HELLAVW38X" (SK38)
Address 810A: Close Rge Radar 2 (J1089) Labels: None
Component: Nanoradar 2 H08 0161
Serial number: 14520076965795 Dataset Number: V03935468TC 0001
ASAM Dataset: EV_NR2HELLAVW38X 002116
ROD: N/A
No ASAM data for: "EV_NR2HELLAVW38X" (SK38)
Address 810B: Close Rge Radar 3 (J770) Labels: None
Part No SW: 3WA 907 670 F HW: 95C 907 550
Component: Nanoradar 3 H09 0161
Serial number: 10140112619075 Dataset Number: V03935468TD 0001
Coding: 5A565E1529C405000000
ASAM Dataset: EV_NR3HELLAVW38X 002116
ROD: N/A
No ASAM data for: "EV_NR3HELLAVW38X" (SK38)
12582983 - ROD - Unknown Error Code
- 00 [00101110]
Fault Frequency: 101
Address 810C: Close Rge Radar 4 (J769) Labels: None
Component: Nanoradar 4 H09 0161
Serial number: 10140112612150 Dataset Number: V03935468TE 0001
Coding: 9A696E1631C40F000000
ASAM Dataset: EV_NR4HELLAVW38X 002116
ROD: N/A
No ASAM data for: "EV_NR4HELLAVW38X" (SK38)
- 00 [00101110]
15859837 - ROD - Unknown Error Code
- 00 [00101110]
Fault Frequency: 14
Mileage: 294 km
Date: 2025.09.30
Time: 13:51:02
Address 811E: Burglary Protection FL (J518) Labels: 5WA-962-133.clb
Part No SW: 5WA 962 133 G HW: 5WA 962 133 E
Component: Kessy RSAD 122 0770
ASAM Dataset: EV_RSADVL37w 004018
ROD: EV_RSADHR37w_004_VW38.rod
VCID: 4CCA179B364AF6AA0BB-8018-R
Address 811F: Burglary Protection FR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADVR37w 004018
Address 8120: Burglary Protection RL (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHL37w 004018
ROD: EV_RSADHL37w_004_VW38.rod
Address 8121: Burglary Protection RR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHR37w 004018
End----------(Elapsed Time: 02:27, VBatt start/end: 14.3V/14.4V)-----------
