Need some help with my Touareg V10
Jonathan1977
South Africa
C?ID=589658
My 2005 V10 TDI Touareg has been standing since last year, A bunch of XMas tree lights on the dash and I loose my digital display. I want to be sure what is causing the issues before I start throwing parts at it as it can become an expensive excercise. Im going to attach the last scan I done , not really sure what to make of it.
Friday,04,October,2024,15:08:50:37818
VIN: WVGZZZ7LZ6D014293   License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ6D014293   Mileage: 176510km-109678miles
   Part No SW: 070 906 016 AA    HW: 028 101 148 1
   Component: V10 5,0L EDCG000AGMª6189
   Coding: 0010575
   Shop #: WSC 31414 000 00000
   VCID: 4FFFA0127BC417D2961-5160
   VINID: 9E65EAAAA1DCA865000440890CEFF16FD9
18253 - Please check DTC Memory of Steering Electronics (J527)
            P1845 - 000 -  - Intermittent
                    RPM: 651 /min
                    Torque: 150.1 Nm
                    Voltage: 13.53 V
                    Bin. Bits: 00001111
                    Bin. Bits: 00000000
                    Bin. Bits: 00001111
Readiness: 0 0 X X X
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No: 09D 927 750 BM
   Component: AL 750 6A           0592
   Coding: 0012328
   VCID: 7AA921C690C6627A11F-5160
01045 - Tiptronic Switch (F189)
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   VCID: 3D23EADAC168954274D-5160
   Part No SW: 3D0 909 137     HW: 5WK 470 22
   Component: 05 Kessy            6700
   Revision: 67005514    Serial number: VWZ3Z0E3369500
   Coding: 0147688
   VCID: 64957FBE0242848ADB3-5160
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77AF38F2A3D47F126E1-5160
Address 08: Auto HVAC        Labels: 7L6-907-044.clb
   Part No: 7L6 907 044 L
   Component: CLIMAtronic 2+2     4018
   Subsystem 1 - Part No: 7L6 907 049 D
   Component: CLIMAtronic FOND    0400
00711 - Left Footwell Flap Positioning Motor (V108)
00445 - Loss of Refrigerant
                    Temperature: 82.0°C
                    RPM: 608 /min
                    Absolute Pres.: 5.0 bar
                    Load: 94.0 %
                    Temperature: 18.0°C
                    Temperature: 22.0°C
                    Temperature: 56.0°C
02597 - Rear Left Upper Body Vent Motor (V315)
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3001
   Coding: 0111868
   VCID: 47CF883293B4CF92DE1-5160
8 Faults Found:
00967 - Left Turn Signals
01494 - Bulb for Parking Lamps; Left (M1)
01495 - Bulb for High-Beams; Left (M30)
02196 - Fuse for Control Module for Power Supply to Vehicle Battery (S287)
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG000AGSª6189
   Coding: 0010575
18315 - Engine Databus
            P1907 - 000 - ECU<->ECU Communications Fault - Intermittent
                    Torque: 426.6 Nm
                    Voltage: 7.14 V
                    Bin. Bits: 00001111
                    Torque: 221.2 Nm
                    Torque: 0.0 Nm
                    Torque: 426.6 Nm
                    Voltage: 7.14 V
                    Bin. Bits: 00001111
                    Torque: 221.2 Nm
                    Torque: 0.0 Nm
16482 - Intake Air Temperature Sensor 2 (G299)
            P0098 - 000 - Signal too Low - Intermittent
                    Torque: 442.4 Nm
                    Voltage: 11.48 V
                    Temperature: 130.5°C
                    Temperature: 11.7°C
                    Temperature: 14.4°C
16626 - Manifold Pressure / Boost Sensor 2 (G447)
            P0242 - 000 - Signal too High - Intermittent
                    Torque: 442.4 Nm
                    Voltage: 11.55 V
                    Bin. Bits: 00001111
                    Absolute Pres.: 173.4 mbar
                    Absolute Pres.: 2590.8 mbar
19792 - Control Module 2 for Turbocharger(s)
            P3336 - 000 - Missing Message(s) - Intermittent
                    Torque: 442.4 Nm
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Absolute Pres.: 2182.8 mbar
18156 - Transmission Control Unit
            P1748 - 000 - Programming Error - Intermittent
                    Torque: 331.8 Nm
                    Voltage: 11.70 V
                    Bin. Bits: 00001100
                    Torque: 221.2 Nm
                    Torque: 0.0 Nm
   Part No: 3D0 909 601 E
   Component: 0B Airbag 8.4E+ H10 0951
   Coding: 0012354
   VCID: 251322BA49F83D820CD-5160
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000032
   VCID: 40DD932EB69AF8AA1FB-5160
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 881 B
   Component: KOMBIINSTRUMENT RB8 3135
   Coding: 0007721
   Shop #: WSC 05147 996 88872
   VCID: 372FF8F2E354BF12AE1-5160
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 819 008 C
   Component: Standheizung E1MAC
   Coding: 0000030
   VCID: 3631F5F6E45E461AB57-5160
01177 - Engine Control Unit
   Part No: 6N0 909 901
   Coding: 0000006
   Shop #: WSC 52110 004 1048576
   VCID: 70BD03EEC6BA282AAFB-5160
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F5FD0D28BE44752261-5160
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   Shop #: WSC 01657 996 62726
Address 46: Central Conv.        Labels: 7L0-959-933.clb
   Part No: 7L0 959 933 K
   Component: 34 HSG              4105
   Coding: 0000081
   VCID: 44D59F3EA282E48A3B3-4B14
   Subsystem 1 - Part No: 7L0 959 701 L
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 L
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 D
   Component: Tuersteuergeraet HR 0201
   Subsystem 5 - Part No: 7L0 907 719
   Subsystem 6 - Part No: 7L6 951 171
   Component: B  Innenraumsensor  0020
Address 47: Sound System        Labels:
   VCID: 55F3527A5C086D025CD-5160
   Note: Excessive Comm Errors
Address 55: Headlight Range        Labels: 7L6-907-357.lbl
   Part No SW: 7L6 907 357     HW: 7L6 907 357
   Component: AFS-Steuergeraet    X016
   Revision:   H09       Serial number:
   Coding: 0000009
   Shop #: WSC 63354 003 1048576
   VCID: 78AD3BCEAECA706A67B-5160
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X017
   Coding: 00000034
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000034
02071 - Local Databus
                    Fault Status: 00101110
                    Reset counter: 123
02233 - Left Headlight Power Output Stage (J667)
                    Reset counter: 150
02234 - Right Headlight Power Output Stage (J668)
                    Reset counter: 150
                    Reset counter: 123
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 L
   Component: Front Wiper         4027
   Coding: 0000855
   Shop #: WSC 31414 000 376832
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00208933
   Shop #: WSC 31414
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 392BFECAD540A962585-5160
00437 - Rear Right Inner Parking Aid Sensor (G335)
            014 - Defective
00436 - Rear Left Inner Parking Aid Sensor (G334)
            014 - Defective
Address 77: Telephone        Labels: Redir Fail!
   Part No SW: 7L6 035 729 F    HW: 7L6 035 729 F
   Component: FSE_275x        H18 0020
   Revision: 00000001    Serial number: 00000000253650
   Coding: 0000211
02503 - Output Wire to Radio
                    Reset counter: 12
                    Time Indication: 15
End----------(Elapsed Time: 08:55, VBatt start/end: 12.1V/12.1V)-----------
Thank you in advance for any light you can shed on this issue.
Jef
HQ
That is what I find to be a bit exciting... and we've things like this before:
edit... this also may be helpful:
Jonathan1977
South Africa
C?ID=589658
Thanx for the info, Looks like I have to rip up some carpet and look for rotten wires
Jonathan1977
South Africa
C?ID=589658
Hi All
So no new on my side, I took the advice from the above post but I still do not see a problem in that area, I checked all the joints everything looks sound. No corrossion noted. Wires look sound in that area. Im keeping the vehicle on a trickle charge, as I note the batteries seen to run down if I dont. The vehicle still starts up with all its faults, what I do notice is the voltmeter on the dash drops almost immediately to under 6 volts after starting.
Whoa! That warrants further investigation.
Check with YouTube on how to test a alternator (you'll need a DVOM) volt meter . I think yours is on its way out or even completely gone!
Your scan voltage looks good however: End----------(Elapsed Time: 08:55, VBatt start/end: 12.1V/12.1V)----------- Was the engine running?
You may have a parasitic draw (shorted wiring) somewhere ; see youtube also for testing for this as well. There are several methods.
Jonathan1977
South Africa
C?ID=589658
I tend to agree with you, I was hoping that it was something else more simpler to fix. On the trickle charger it went up to 12.1V on the terminals. As soon as the car starts it runs a constant 8.6V , Switching the lights on it goes down to 8.1V.
So I guess thats it confirmed ! I just didnt want to believe it in the first place as its a complete bugger to remove the alternator on these v10 engines. Nevermind the price to replace it. Thanx for everyones help.
Where / how are you measuring this?
Jonathan1977
South Africa
C?ID=589658
This I measure at the positive and negative terminals inside the engine compartment, The one battery is under the seat and the other is in the boot under the spare wheel, I have a basic multimeter that I use.
Even if the alternator was shot, batteries in good condition that have been recently charged should maintain a higher voltage than that. However, even if the batteries are shot, the alternator should raise the voltage higher than that once the engine is running.
I'm wondering if you have a bad connection somewhere? At the alternator? At the batteries? At whatever leads to those terminals?
Check voltage in other places as well with the engine running. At the alternator. At the each of the batteries. Use VCDS to see what some of your control modules think the Terminal 30 voltage is.
Jonathan1977
South Africa
C?ID=589658
Hi Again peeps
So before starting I het 12.1V at the front battery, The rear shows 12.4V
I started the vehicle and measured the front battery whilst idling , at first it was around 9.4V and after a while 9.1V. The rear battery went to 12.3V. I run a fresh scan with the car idling. Here it is..... any thoughts?
 Tuesday,14,October,2025,13:14:56:37818
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.5
VIN: WVGZZZ7LZ6D014293   License Plate: CFG44111
Mileage: 180590km-112213mi   Repair Order: 12345
VIN: WVGZZZ7LZ6D014293   Mileage: 180590km-112213miles
   Coding: 0010575
   VCID: 4FFFA0127BC417D2479-5160
            P1845 - 000 -
                    RPM: 714 /min
                    Torque: 102.7 Nm
                    Voltage: 11.02 V
                    Bin. Bits: 00001111
                    Bin. Bits: 00000000
                    Bin. Bits: 00001111
18057 - Powertrain Data Bus
            P1649 - 000 - Missing Message from ABS Controller - Intermittent
                    RPM: 693 /min
                    Torque: 71.1 Nm
                    Voltage: 11.02 V
                    Bin. Bits: 00001111
                    Torque: 395.0 Nm
                    Bin. Bits: 00000000
18009 - Relay for Supply Voltage Terminal 30 (J317)
            P1601 - 000 - Implausible Signal
                    Torque: -489.8 Nm
                    Voltage: 12.54 V
                    Bin. Bits: 00000000
                    Bin. Bits:        0
                    (no units): 0.0
   Coding: 0012328
   VCID: 7AA921C690C6627AC07-5160
00364 - Terminal 15 Slave
   Coding: 0022786
   VCID: 3D23EADAC1689542A55-5160
   Coding: 0147688
   VCID: 64957FBE0242848A0AB-5160
00184 - Control Circuit for Engine Start/Stop Switch
00955 - Key 1
00087 - Terminal 30 for Starting Relevant Consumers
   VCID: 77AF38F2A3D47F12BF9-5160
                    Temperature: 99.0°C
                    RPM: 608 /min
                    Absolute Pres.: 6.0 bar
                    Load: 99.0 %
                    Temperature: 28.0°C
                    Temperature: 32.0°C
                    Load: 7.2 %
                    Temperature: 71.0°C
02600 - Rear Right Temperature Flap Motor (V314)
   Component:                     3001
   Coding: 0111868
   VCID: 47CF883293B4CF920F9-5160
00070 - Starting Battery Voltage
   Coding: 0010575
                    RPM: 693 /min
                    Torque: 71.1 Nm
                    Voltage: 11.10 V
                    Bin. Bits: 00001111
                    Torque: 395.0 Nm
                    Bin. Bits: 00000000
   Coding: 0012354
   VCID: 251322BA49F83D82DD5-5160
            002 - Lower Limit Exceeded - MIL ON
   Coding: 0000032
   VCID: 40DD932EB69AF8AACE3-5160
   Coding: 0007721
   VCID: 372FF8F2E354BF127F9-5160
   Coding: 0000030
   VCID: 3631F5F6E45E461A64F-5160
   Coding: 0000006
   VCID: 70BD03EEC6BA282A7E3-5160
   VCID: 7F5FD0D28BE44752F79-5160
   Coding: 0015521
01598 - Drive Battery Voltage
   Coding: 0000081
   VCID: 44D59F3EA282E48AEAB-4B0C
7 Faults Found:
01830 - Bulbs for Fog-Lamps; Rear
   VCID: 55F3527A5C086D028D5-5160
   Coding: 0000009
   VCID: 78AD3BCEAECA706AB63-5160
   Coding: 00000034
   Coding: 00000034
                    Fault Status: 11100010
                    Reset counter: 146
                    Reset counter: 146
                    Reset counter: 146
                    Reset counter: 146
                    Reset counter: 146
                    Reset counter: 161
   Coding: 0000855
   Coding: 00208933
   Shop #: WSC 31414
   VCID: 392BFECAD540A96289D-5160
            014 - Defective
            014 - Defective
   Coding: 0000211
                    Reset counter: 12
                    Time Indication: 15
End-----(Elapsed Time: 09:02, VBatt start/end: 9.3V/9.5V. VIgn 9.5V)-------
------------------------------56 Faults Found------------------------------
Awaiting your replies.
Westbury, UK
Sounds to me like the front battery isn't getting charged from the alternator.
Guitarman
C?ID=56603
I wonder if the rubber drive coupling for the alternator (it's gear driven engine with no drive belts) has stripped and the alternator is not charging at all. Or if poor battery connections are causing the terminal 30 codes.
That's a huge discrepancy. Is there a relay that separates the batteries?
