- Sep 27, 2025
- 4
- 2
- Bracebridge, ON, Canada
- C?ID=630036
Hi my name is Markus. Below is the read out, first a brief summary of one problem I am trying to solve.
I am working with my sons on a 2008 VW Rabbit for a homeschooling project. This is my first time posting in a forum. I am a bit at a dead end and not sure what my next move is. Here is the problem, (or rather the symptom). The rear passenger window and door lock do not function. I have taken the entire rear door apart. I have replaced the window motor (J389). With the help of ChatGTP it seems the problem is, the central control module (J393) is not communicating with the window control module (J389) The door window motor has good ground, and is getting power. All six wires coming from the door connector going to the B pillar have continuity. I have checked the orange connector at J393 and there are two wires which showing low voltage (which according to chatgtp is likely the problem.) These two wires are twisted, and both have a separate pin in the connector. One is at around 7 volts, and the other around 4 volts. apparently they should be around 12V.
According to chat gtp pin 9 at the door connector (j389) should be the lin wire and should connect to Pin 7 at the central control module connector. I can't tell where pin #7 is. And I am not sure which of the 2 wires with low voltage is the correct lin wire going back to the door. Also as there are only 6 wires coming from J389 and only six pins receiving those wires with continuity on the inside of Pillar B. So the problem should be between the b pillar and the comfort module J393. Or is the problem further up the chain in the can gateway?
Any thoughts? Here now is the readout and some helpful pictures:
I can't seem to post pictures.
I would really appreciate some help.
respectfully,
Markus Koehler
Monday,29,September,2025,11:00:14:54093
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.5
VIN: WVWCA71KX8W256450 License Plate:
Mileage: 236120km-146718mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWCA71KX8W256450 Mileage: 236120km-146718miles
46-Central Conv. -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BK HW: 07K 906 032 Q
Component: 2,5l R5/4V G 1568
Revision: 1NH01--- Serial number: VWX7Z0H13NC7YZ
Coding: 0000001
Shop #: WSC 01279 785 00200
VCID: 73B403D277B81C42831-8026
VINID: 9E69D344705BA089C214610500850C59DA
001672 - ECM Power Relay Load Circuit
P0688 - 002 - Open Circuit - Intermittent
Mileage: 234224 km
Time: 09:55:24
RPM: 691 /min
Load: 33.7 %
Temperature: 54.0 C
Temperature: -32.0 C
Absolute Pres.: 1010.0 mbar
Voltage: 0.000 V
001669 - ECM Power Relay Control Circuit
P0685 - 004 - Open Circuit - Intermittent
Mileage: 234224 km
Time: 09:55:24
RPM: 313 /min
Load: 46.3 %
Temperature: 54.0 C
Voltage: 0.127 V
008825 - Leak in Air Intake System
P2279 - 008 - - Intermittent
Fault Status: 00111000
Mileage: 234229 km
Time: 00:46:44
RPM: 843 /min
Load: 16.1 %
Temperature: 90.0 C
Temperature: -26.0 C
Voltage: 13.589 V
001152 - Coolant Fan Control Circuit 1
P0480 - 004 - Electrical Malfunction - Intermittent
Mileage: 236115 km
Time: 00:00:12
RPM: 190 /min
Load: 89.4 %
Temperature: 10.0 C
Temperature: -40.0 C
Absolute Pres.: 990.0 mbar
Voltage: 10.414 V
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.clb
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3FDC9FE20B708822B79-806A
Part No SW: 1K0 820 047 HN HW: 1K0 820 047 HN
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 77AC37C263C07062BF9-8022
013 - Check DTC Memory
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007956180
Coding: 108D8F214004150047140000001400000008730B5C000100000000000000
Shop #: WSC 00000 785 00200
VCID: 6FBC0FA21B9038A2679-803A
Subsystem 1 - Component: Fehler Lin-Slave 01
00906 - Horn (H1)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 250
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.20 V
02071 - Local Databus
Reset counter: 250
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.20 V
Reset counter: 250
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.20 V
Reset counter: 250
Mileage: 236123 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.15 V
01759 - Relay for Horn
Fault Status: 01111100
Reset counter: 250
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.20 V
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 250
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.20 V
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6L AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0AHF6
Coding: 0013900
Shop #: WSC 01269 785 00200
VCID: 6C8618AE2A86C3BA42B-8038
Subsystem 1 - Serial number: 6332MSME32521161Z
Subsystem 2 - Serial number: 6342MSME3672455EI
Subsystem 3 - Serial number: 6352QSME51492913B
Subsystem 4 - Serial number: 6362QSME51443D3BM
Subsystem 5 - Serial number: 63727SME126B5F7EL
Subsystem 6 - Serial number: 63827SME12414352Q
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 051 0100
Coding: 0000022
VCID: 7F5CDFE24BF04822F79-802A
Part No SW: 1K0 920 854 T HW: 1K0 920 854 T
Revision: V0002000 Serial number: VWX7Z0H13NC7YZ
Coding: 0007303
VCID: 3C26E8EE1A66933A92B-8068
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 12
Reset counter: 250
Mileage: 236123 km
Time: 00:05:26
Reset counter: 250
Mileage: 236123 km
Time: 00:20:09
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K08207031A
Coding: E9807F060002020002
VCID: 303ECCDEC62E675A3E3-8064
Reset counter: 250
Mileage: 236123 km
Time: 00:05:28
Reset counter: 250
Mileage: 236123 km
Time: 00:05:29
01304 - Radio
Reset counter: 250
Mileage: 236123 km
Time: 00:05:32
Reset counter: 250
Mileage: 236123 km
Time: 00:20:10
Component: IMMO VDD 1212
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1219
Coding: 0001205
VCID: 382EF4FE2E5EBF1A763-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3530FDCA394C42726D5-8060
Address 46: Central Conv.
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Component: Tuer-SG 006 1203
Coding: 0001204
VCID: 3928F1FA1554A61289D-806C
Address 56: Radio
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1302
Coding: 0001168
Shop #: WSC 01279 785 1012552
Address 72: Door, Rear Right
End----------(Elapsed Time: 00:56, VBatt start/end: 14.3V/14.3V)-----------
------------------------------25 Faults Found------------------------------
respectfully,
Markus Koehler
