Steering wheel heater, faulty - after retrofit
Timirey
Chisinau, Moldova
I have retrofitted a heated steering wheel into my VW Taos 2021. The retrofit works and the heating turns on, but after a couple of minutes it shuts down and throws a fault code.
Address 09: Cent. Elect.
Event code: C2803 [796675]
SAE code: B153804
Event text: Steering wheel heating, faulty (Schaltermodul Lenksäule SMLS -> Lenkradheizung defekt)
Priority: 4
Malfunction frequency: 2
Unlearning counter: 55
Odometer: 27,338 km
Date/Time: 26.09.2025 11:38:51
Heated wheel retrofit installed and working for a short time.
Proper coding/adaptations have been applied.
The error only appears after the heating runs for a couple of minutes.
Local dealership cannot find the root cause.
What could cause B153804 (“Steering wheel heating faulty”) after a few minutes of heating? Could it be related to the clockspring/slip ring, wiring, or the heater element itself? Has anyone seen this issue when retrofitting?
Slip ring: 5Q1 953 521 KR IGI
Steering wheel: 5H0 419 093 E AGD
OBDeleven vehicle history log
Date: 2025-05-08 13:46:51
    VIN: 3VVTX7B22NM017095
    Car: Volkswagen
    Year: 2022
    Body type: SUV
    Engine: DNKA  kW ( hp) l
    Mileage: 21784 km
    Backup
        01 Engine
        System description: R4 1.5l TFS
        Software number: 05E906013B
        Software version: 3308
        Hardware number: 05E907309BB
        Hardware version: H20
        Backup name: Engine
        Long coding
            412A001223641508B0000000000000000000000000000000
        Adaptations
            Production mode
                    000000
            Deactivate production mode
                    000000
            Protective function
                    Off
            Roller test bench mode, functional
                    Not activated
            Activation of start-stop function
                    active
            Open tank shut-off valve to the gasoline pressure tank
                    0 s
            Turbocharger offset correction
                Bytefield Value
                    7F7F7F7F
            Adaptation of correction angle position detection bank 1 outlet
                Error angle sensor wheel
                    56.25 °
                Error angle sensor
                    -75.78 °
            Adaptation of correction angle position detection bank 1 intake
                    21.88 °
                Error angle sensor
                    18.75 °
            Adaptation of cyl. Individual correction angle camshafts bank 1
                Correction outlet cylinder 8
                    0.00 °
                Correction outlet cylinder 7
                    0.00 °
                Correction outlet cylinder 6
                    0.00 °
                Correction outlet cylinder 5
                    0.00 °
                Correction outlet cylinder 4
                    10.94 °
                Correction outlet cylinder 3
                    11.72 °
                Correction outlet cylinder 2
                    10.16 °
                Correction outlet cylinder 1
                    10.16 °
                Correction inlet cylinder 8
                    0.00 °
                Correction inlet cylinder 7
                    0.00 °
                Correction inlet cylinder 6
                    0.00 °
                Correction inlet cylinder 5
                    0.00 °
                Correction inlet cylinder 4
                    0.00 °
                Correction inlet cylinder 3
                    -6.25 °
                Correction inlet cylinder 2
                    0.00 °
                Correction inlet cylinder 1
                    4.69 °
            Adaptation of correction angle of crankshaft position detection
                    0.00 °
                Error angle sensor
                    64.06 °
        Mileage: 21642 km
        Date: 2025-05-05 21:00:24
    Backup
        02 Transmission
        System description: AISIN 8G30/18
        Software number: 09S927158BL
        Software version: 3791
        Hardware number: 09S927158
        Hardware version: 301
        Backup name: Transmission
        Long coding
            0100000100000000000000000000000000000000
        Adaptations
                    Not activated
            Deactivation of start-stop function
                Deactivating of start stop function
                    Not activated
                Productionmode deactivate
                    000000
            Production mode
                Production Mode
                    Not activated
            Control module switch-off, switch-off time
                Knockout timer
                    20 minute
        Mileage: 21642 km
    Backup
        03 Brakes
        System description: ESC
        Software number: 5Q0614517GA
        Software version: 0114
        Hardware number: 5Q0614517BN
        Hardware version: H35
        Serial number: 51241000000431
        Backup name: Brakes
        Long coding
            86FB6A7EA0212473C7770209A2C82561560524E34045A47D1841F058D6834A0B00000523525212121035351919323200
        Adaptations
            Tire pressure monitoring display
                Warning thresholds, tire pressure monitoring system
                    Manual activation, possible
            Running manufacturer number
                    activated
            Engine drag torque control
                    activated
            Activating and deactivating all development messages
            OFFROAD
                Offroad portion electronic differential lock
            Brake system vacuum pump
                Offset
                    5
            Hydraulic brake booster
                Offset
                    8
            Brake prefill
                Brake prefill
                    activated
            Braking torque boost for distance regulation
                    3
            Brake booster
                Brake booster
                    4
            Hydraulic brake assistant
                    normal
            Electronic Stability Program
                Speed-dependent activation
                    Not activated
            Brake disk drying
                Brake disk drying
                    Weak
            Hill-start assistant
                    early
            Straight ahead brake stabilization
                    activated
            Brake pedal evaluation
                    activated
            Seat belt buckle scan
                    activated
            Dynamic starting assist
                    early
            Driver door status
                Driver door status
                    activated
            Automatic application during engine stalling
                    activated
            AUTO HOLD functionality
                    activated
            AUTO HOLD increase threshold, reduced tensioning force
                    0 %
            AUTO HOLD increase threshold, full tensioning force
                    10 %
                    Deactivating
            Developer_Function_121
                Tyre pressure control monitoring tour mode
                    Not activated
        Mileage: 21642 km
    Backup
        08 Air Conditioning
        System description: Climatronic
        Software number: 5GM907044AL
        Software version: 2601
        Hardware number: 5GM907044AL
        Hardware version: H04
        Backup name: Air Conditioning
        Long coding
            0902002420211C001000014C0015D014
        Adaptations
            Retention of driver's seat heater level
                    active for 10 minutes
            Runtime for compressor run-in basic setting
                    60 s
            Duration of compressor run in
                    60 s
            Stop release for start-stop function
                    According to function requirements
                    not active
            Analysis 6
                    Not activated
            Analysis 7
            Gear ratio of engine - A/C compressor
                    0.00
            Blower voltage for voice operation
                    Not activated
            Air quality sensor sensitivity
                    minimal
            Speed switch-off threshold for compressor run-in (engine speed)
                    1500 1/min
            Blower voltage for production routines
                    12.0 V
            Interior target temperature for production routines
                    23 °C
            Air distribution for production routines
                    No effect
            Recirculation air for production routines
                    No effect
            Production mode
                    Deactivating
                    Deactivating
            Blower logic for manual adjustment
                    Matching coding
            Ignore compressor switch-off by Engine Control Module
                    Do not ignore
            Post-heating of parking heater
                    10 min
            Retrofitting of parking heater without CAN
                    not installed
            Reset all counters
                    Not activated
            Automatic Activation of front windshield heater at MAX-Defrost
                    active
            Analysis 8
                    not active
            Window condensation exterior reduction at high humidity
                    Matching coding
            Hand heater function during cold start
                    active
            Retention of frt.pass. seat heater level
            dimming_characteristic_1
                X1
                Y1
                    0 %
                X2
                    6
                Y2
                    6 %
                X3
                    40
                Y3
                    40 %
                X4
                    60
                Y4
                    60 %
                X5
                    80
                Y5
                    80 %
                X6
                    100
                Y6
                    100 %
            dimming_characteristic_2
                X1
                Y1
                    2 %
                X2
                    10
                Y2
                    2 %
                X3
                    50
                Y3
                    10 %
                X4
                    100
                Y4
                    21 %
                X5
                    220
                Y5
                    85 %
                X6
                    253
                Y6
                    100 %
            dimming_characteristic_3
                X1
                Y1
                    3 %
                X2
                    10
                Y2
                    3 %
                X3
                    50
                Y3
                    6 %
                X4
                    100
                Y4
                    12 %
                X5
                    220
                Y5
                    100 %
                X6
                    253
                Y6
                    100 %
            dimming_characteristic_4
                X1
                Y1
                    2 %
                X2
                    10
                Y2
                    2 %
                X3
                    50
                Y3
                    5 %
                X4
                    100
                Y4
                    10 %
                X5
                    220
                Y5
                    85 %
                X6
                    253
                Y6
                    100 %
            dimming_characteristic_5
                X1
                Y1
                    2 %
                X2
                    10
                Y2
                    2 %
                X3
                    50
                Y3
                    5 %
                X4
                    100
                Y4
                    10 %
                X5
                    220
                Y5
                    85 %
                X6
                    253
                Y6
                    100 %
            CO2 compressor on-time reduction
                    Matching coding
            Cut-in behavior
                    Matching coding
            Climate modes
                    Matching coding
                Control module
                    20 min
                Data bus
                    30 min
            Knockout_timer_activation
                    Not activated
            Remote start function, activation of seat heating
                    Seat heater front
            Remote start function, activation of seat ventilation
                    Not activated
            Rem. start funct., activat.temper. of seat heating
                    15 °C
            Rem. start funct., activat.temper. of seat ventilation
                    20 °C
            Remote start function, activation stage of seat heating
            Remote start function, activation stage of seat ventilation
            Rem.start funct.,activ.temper. of windshield defrost.heat.
                    4 °C
            Remote start function, interior climate control status
                    Remote start function with fixed rated temperature active
            Target temperature of A/C - heater function via remote control
                    23.0 °C
            Filtering of interior air, store
                    Service life-dependent store
            Remote start function, windshield defogger
                    activated
            Remote start function, windshield defogger takeover
                    Not activated
            Remote start function, rear window defogger
                    activated
            Remote start function, seat climate control takeover
                    Not activated
            Remote start function, windshield defogger can be activated
                    activated
            HMI_View_Switch
                    Yes
            Sun_sensor_supplier_differentiation
                    None
        Mileage: 21642 km
        Date: 2025-05-05 21:00:25
    Backup
        09 Central Electrics
        System description: BCM MQBAB MNA
        Software number: 5Q0937085CF
        Software version: 0411
        Hardware number: 5Q0937085CF
        Hardware version: H42
        Backup name: Central Electrics
        Long coding
            000000000000000000000000000000000000000000000000000000000000
        Adaptations
            Leuchte 0 BLK VL B36
                Lasttyp 0
                    12 - Blinkleuchten
                Lampendefektbit Position 0
                    34
                Fehlerort mittleres Byte DTC-DFCC 0
                    14
                Lichtfunktion A 0
                    Blinken links Hellphase
                Lichtfunktion B 0
                    nicht aktiv
                Dimmwert AB 0
                    100
                Lichtansteuerung HD AB 0
                    always
                Lichtfunktion C 0
                    nicht aktiv
                Lichtfunktion D 0
                    nicht aktiv
                Dimmwert CD 0
                Dimming Direction CD 0
                    maximize
                Lichtfunktion E 0
                    nicht aktiv
                Lichtfunktion F 0
                    nicht aktiv
                Dimmwert EF 0
                Dimming Direction EF 0
                    maximize
                Lichtfunktion H 0
                    nicht aktiv
                Dimmwert GH 0
                Dimming Direction GH 0
                    maximize
                Lichtfunktion G 0
                    nicht aktiv
            Leuchte1BLK VRB20
                Lasttyp 1
                    12 - Blinkleuchten
                Lampendefektbitposition 1
                    3E
                Fehlerort mittleres Byte DTC-DFCC 1
                    15
                Lichtfunktion A 1
                    Blinken rechts Hellphase
                Lichtfunktion B 1
                    nicht aktiv
                Dimmwert AB 1
                    100
                Lichtansteuerung HD AB 1
                    always
                Lichtfunktion C 1
                    nicht aktiv
                Lichtfunktion D 1
                    nicht aktiv
                Dimmwert CD 1
                Dimming Direction CD 1
                    maximize
                Lichtfunktion E 1
                    nicht aktiv
                Lichtfunktion F 1
                    nicht aktiv
                Dimmwert EF 1
                Dimming Direction EF 1
                    maximize
                Lichtfunktion G 1
                    nicht aktiv
                Lichtfunktion H 1
                    nicht aktiv
                Dimmwert GH 1
                Dimming Direction GH 1
                    maximize
            Leuchte2SL VLB10
                Lasttyp 2
                    4 - LED Tagfahrlichtmodul Signal
                Lampendefektbitposition 2
                    48
                Fehlerort mittleres Byte DTC-DFCC 2
                    4A
                Lichtfunktion A 2
                    Tagfahrlicht
                Lichtfunktion B 2
                    nicht aktiv
                Dimmwert AB 2
                    100
                Lichtansteuerung HD AB 2
                    always
                Lichtfunktion C 2
                    Blinken links aktiv (beide Phasen)
                Lichtfunktion D 2
                    Nebellicht links
                Dimmwert CD 2
                Dimming Direction CD 2
                    minimize
                Lichtfunktion E 2
                    Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
                Lichtfunktion F 2
                    Parklicht links (beidseitiges Parklicht aktiviert li & re)
                Dimmwert EF 2
                    28
                Dimming Direction EF 2
                    maximize
                Lichtfunktion G 2
                    nicht aktiv
                Lichtfunktion H 2
                    nicht aktiv
                Dimmwert GH 2
                Dimming Direction GH 2
                    maximize
            Leuchte3SL VRB21
                Lasttyp 3
                Lampendefektbitposition 3
                    4C
                Fehlerort mittleres Byte DTC-DFCC 3
                    4C
                Lichtfunktion A 3
                    Tagfahrlicht
                Lichtfunktion B 3
                    nicht aktiv
                Dimmwert AB 3
                    100
                Lichtansteuerung HD AB 3
                    always
                Lichtfunktion C 3
                    Blinken rechts aktiv (beide Phasen)
                Lichtfunktion D 3
                    Nebellicht rechts
                Dimmwert CD 3
                Dimming Direction CD 3
                    minimize
                Lichtfunktion E 3
                Lichtfunktion F 3
                    Parklicht rechts
                Dimmwert EF 3
                    28
                Dimming Direction EF 3
                    maximize
                Lichtfunktion G 3
                    nicht aktiv
                Lichtfunktion H 3
                    nicht aktiv
                Dimmwert GH 3
                Dimming Direction GH 3
                    maximize
            Leuchte4TFL LB4
                Lasttyp 4
                    1 - LED Tagfahrlichtmodul Versorgung
                Lampendefektbitposition 4
                    3A
                Fehlerort mittleres Byte DTC-DFCC 4
                    49
                Lichtfunktion A 4
                    Tagfahrlicht
                Lichtfunktion B 4
                    nicht aktiv
                Dimmwert AB 4
                    127
                Lichtansteuerung HD AB 4
                    always
                Lichtfunktion C 4
                Lichtfunktion D 4
                    nicht aktiv
                Dimmwert CD 4
                Dimming Direction CD 4
                    minimize
                Lichtfunktion E 4
                Lichtfunktion F 4
                Dimmwert EF 4
                    127
                Dimming Direction EF 4
                    maximize
                Lichtfunktion G 4
                    nicht aktiv
                Lichtfunktion H 4
                    nicht aktiv
                Dimmwert GH 4
                Dimming Direction GH 4
                    maximize
            Leuchte5 TFL RB32
                Lasttyp 5
                Lampendefektbitposition 5
                    44
                Fehlerort mittleres Byte DTC-DFCC 5
                    4B
                Lichtfunktion A 5
                    Tagfahrlicht
                Lichtfunktion B 5
                    nicht aktiv
                Dimmwert AB 5
                    127
                Lichtansteuerung HD AB 5
                    always
                Lichtfunktion C 5
                Lichtfunktion D 5
                    nicht aktiv
                Dimmwert CD 5
                Dimming Direction CD 5
                    minimize
                Lichtfunktion E 5
                Lichtfunktion F 5
                    Parklicht rechts
                Dimmwert EF 5
                    127
                Dimming Direction EF 5
                    maximize
                Lichtfunktion G 5
                    nicht aktiv
                Lichtfunktion H 5
                    nicht aktiv
                Dimmwert GH 5
                Dimming Direction GH 5
                    maximize
            Leuchte6ABL LC5
                Lasttyp 6
                    5 - LED Abblendlicht
                Lampendefektbitposition 6
                    36
                Fehlerort mittleres Byte DTC-DFCC 6
                    1A
                Lichtfunktion A 6
                    Abblendlicht links
                Lichtfunktion B 6
                    Lichthupe generell
                Dimmwert AB 6
                    127
                Lichtansteuerung HD AB 6
                    always
                Lichtfunktion C 6
                    nicht aktiv
                Lichtfunktion D 6
                    nicht aktiv
                Dimmwert CD 6
                Dimming Direction CD 6
                    maximize
                Lichtfunktion E 6
                    nicht aktiv
                Lichtfunktion F 6
                    nicht aktiv
                Dimmwert EF 6
                Dimming Direction EF 6
                    maximize
                Lichtfunktion G 6
                    nicht aktiv
                Lichtfunktion H 6
                    nicht aktiv
                Dimmwert GH 6
                Dimming Direction GH 6
                    maximize
            Leuchte7ABL RB1
                Lasttyp 7
                Lampendefektbitposition 7
                    40
                Fehlerort mittleres Byte DTC-DFCC 7
                    1B
                Lichtfunktion A 7
                    Abblendlicht rechts
                Lichtfunktion B 7
                    Lichthupe generell
                Dimmwert AB 7
                    127
                Lichtansteuerung HD AB 7
                    always
                Lichtfunktion C 7
                    nicht aktiv
                Lichtfunktion D 7
                    nicht aktiv
                Dimmwert CD 7
                Dimming Direction CD 7
                    maximize
                Lichtfunktion E 7
                    nicht aktiv
                Lichtfunktion F 7
                    nicht aktiv
                Dimmwert EF 7
                Dimming Direction EF 7
                    maximize
                Lichtfunktion G 7
                    nicht aktiv
                Lichtfunktion H 7
                    nicht aktiv
                Dimmwert GH 7
                Dimming Direction GH 7
                    maximize
            Leuchte8FL LB39
                Lasttyp 8
                    6 - LED Lichtmodul
                Lampendefektbitposition 8
                    37
                Fehlerort mittleres Byte DTC-DFCC 8
                    1C
                Lichtfunktion A 8
                    Fernlicht links
                Lichtfunktion B 8
                    Lichthupe generell
                Dimmwert AB 8
                    127
                Lichtansteuerung HD AB 8
                    always
                Lichtfunktion C 8
                    nicht aktiv
                Lichtfunktion D 8
                    nicht aktiv
                Dimmwert CD 8
                Dimming Direction CD 8
                    maximize
                Lichtfunktion E 8
                    nicht aktiv
                Lichtfunktion F 8
                    nicht aktiv
                Dimmwert EF 8
                Dimming Direction EF 8
                    maximize
                Lichtfunktion G 8
                    nicht aktiv
                Lichtfunktion H 8
                    nicht aktiv
                Dimmwert GH 8
                Dimming Direction GH 8
                    maximize
            Leuchte9FL RB2
                Lasttyp 9
                    6 - LED Lichtmodul
                Lampendefektbitposition 9
                    41
                Fehlerort mittleres Byte DTC-DFCC 9
                    1D
                Lichtfunktion A 9
                    Fernlicht rechts
                Lichtfunktion B 9
                    Lichthupe generell
                Dimmwert AB 9
                    127
                Lichtansteuerung HD AB 9
                    always
                Lichtfunktion C 9
                    nicht aktiv
                Lichtfunktion D 9
                    nicht aktiv
                Dimmwert CD 9
                Dimming Direction CD 9
                    maximize
                Lichtfunktion E 9
                    nicht aktiv
                Lichtfunktion F 9
                    nicht aktiv
                Dimmwert EF 9
                Dimming Direction EF 9
                    maximize
                Lichtfunktion G 9
                    nicht aktiv
                Lichtfunktion H 9
                    nicht aktiv
                Dimmwert GH 9
                Dimming Direction GH 9
                    maximize
            Leuchte10SHUTTER LB23
                Lasttyp 10
                    2 - Shutter, Diagnosesensierung für 'LED low'
                Lampendefektbitposition 10
                    52
                Fehlerort mittleres Byte DTC-DFCC 10
                    55
                Lichtfunktion A 10
                    Abblendlicht links
                Lichtfunktion B 10
                    Fernlicht links
                Dimmwert AB 10
                    127
                Lichtansteuerung HD AB 10
                    always
                Lichtfunktion C 10
                    nicht aktiv
                Lichtfunktion D 10
                    nicht aktiv
                Dimmwert CD 10
                Dimming Direction CD 10
                    maximize
                Lichtfunktion E 10
                    nicht aktiv
                Lichtfunktion F 10
                    nicht aktiv
                Dimmwert EF 10
                Dimming Direction EF 10
                    maximize
                Lichtfunktion G 10
                    nicht aktiv
                Lichtfunktion H 10
                    nicht aktiv
                Dimmwert GH 10
                Dimming Direction GH 10
                    maximize
            Leuchte11SHUTTER RB22
                Lasttyp 11
                Lampendefektbitposition 11
                    53
                Fehlerort mittleres Byte DTC-DFCC 11
                    56
                Lichtfunktion A 11
                    Abblendlicht rechts
                Lichtfunktion B 11
                    Fernlicht rechts
                Dimmwert AB 11
                    127
                Lichtansteuerung HD AB 11
                    always
                Lichtfunktion C 11
                    nicht aktiv
                Lichtfunktion D 11
                    nicht aktiv
                Dimmwert CD 11
                Dimming Direction CD 11
                    maximize
                Lichtfunktion E 11
                    nicht aktiv
                Lichtfunktion F 11
                    nicht aktiv
                Dimmwert EF 11
                Dimming Direction EF 11
                    maximize
                Lichtfunktion G 11
                    nicht aktiv
                Lichtfunktion H 11
                    nicht aktiv
                Dimmwert GH 11
                Dimming Direction GH 11
                    maximize
            Leuchte12NL LB45
                Lasttyp 12
                    not active
                Lampendefektbitposition 12
                Fehlerort mittleres Byte DTC-DFCC 12
                Lichtfunktion A 12
                    nicht aktiv
                Lichtfunktion B 12
                    nicht aktiv
                Dimmwert AB 12
                Lichtansteuerung HD AB 12
                    always
                Lichtfunktion C 12
                    nicht aktiv
                Lichtfunktion D 12
                    nicht aktiv
                Dimmwert CD 12
                Dimming Direction CD 12
                    maximize
                Lichtfunktion E 12
                    nicht aktiv
                Lichtfunktion F 12
                    nicht aktiv
                Dimmwert EF 12
                Dimming Direction EF 12
                    maximize
                Lichtfunktion G 12
                    nicht aktiv
                Lichtfunktion H 12
                    nicht aktiv
                Dimmwert GH 12
                Dimming Direction GH 12
                    maximize
            Leuchte13NL RB5
                Lasttyp 13
                    not active
                Lampendefektbitposition 13
                Fehlerort mittleres Byte DTC-DFCC 13
                Lichtfunktion A 13
                    nicht aktiv
                Lichtfunktion B 13
                    nicht aktiv
                Dimmwert AB 13
                Lichtansteuerung HD AB 13
                    always
                Lichtfunktion C 13
                    nicht aktiv
                Lichtfunktion D 13
                    nicht aktiv
                Dimmwert CD 13
                Dimming Direction CD 13
                    maximize
                Lichtfunktion E 13
                    nicht aktiv
                Lichtfunktion F 13
                    nicht aktiv
                Dimmwert EF 13
                Dimming Direction EF 13
                    maximize
                Lichtfunktion G 13
                    nicht aktiv
                Lichtfunktion H 13
                    nicht aktiv
                Dimmwert GH 13
                Dimming Direction GH 13
                    maximize
            Leuchte 35 LED Warnblinktaster C48
                Lasttyp 15
                    41 - LED Kleinleistung
                Lampendefektbitposition 15
                Fehlerort mittleres Byte DTC-DFCC 15
                    63
                Lichtfunktion A 15
                    Warnblinktaster Suchbeleuchtung
                Lichtfunktion B 15
                    nicht aktiv
                Dimmwert AB 15
                    100
                Lichtansteuerung HD AB 15
                    always
                Lichtfunktion C 15
                    nicht aktiv
                Lichtfunktion D 15
                    nicht aktiv
                Dimmwert CD 15
                Dimming Direction CD 15
                    maximize
                Lichtfunktion E 15
                    nicht aktiv
                Lichtfunktion F 15
                    nicht aktiv
                Dimmwert EF 15
                Dimming Direction EF 15
                    maximize
                Lichtfunktion G 15
                    nicht aktiv
                Lichtfunktion H 15
                    nicht aktiv
                Dimmwert GH 15
                Dimming Direction GH 15
                    maximize
            Leuchte16BLK SLB35BLK SL KC9
                Lasttyp 16
                    37 - allgemeine LED bis 12W
                Lampendefektbitposition 16
                    1A
                Fehlerort mittleres Byte DTC-DFCC 16
                    36
                Lichtfunktion A 16
                Lichtfunktion B 16
                    nicht aktiv
                Dimmwert AB 16
                    126
                Lichtansteuerung HD AB 16
                    always
                Lichtfunktion C 16
                    nicht aktiv
                Lichtfunktion D 16
                    nicht aktiv
                Dimmwert CD 16
                    126
                Dimming Direction CD 16
                    maximize
                Lichtfunktion E 16
                    nicht aktiv
                Lichtfunktion F 16
                    nicht aktiv
                Dimmwert EF 16
                Dimming Direction EF 16
                    maximize
                Lichtfunktion G 16
                Lichtfunktion H 16
                    nicht aktiv
                Dimmwert GH 16
                    10
                Dimming Direction GH 16
                    minimize
            Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
                Lasttyp 17
                Lampendefektbitposition 17
                    A
                Fehlerort mittleres Byte DTC-DFCC 17
                    35
                Lichtfunktion A 17
                Lichtfunktion B 17
                    nicht aktiv
                Dimmwert AB 17
                    126
                Lichtansteuerung HD AB 17
                    always
                Lichtfunktion C 17
                    nicht aktiv
                Lichtfunktion D 17
                    nicht aktiv
                Dimmwert CD 17
                    126
                Dimming Direction CD 17
                    maximize
                Lichtfunktion E 17
                    nicht aktiv
                Lichtfunktion F 17
                    nicht aktiv
                Dimmwert EF 17
                Dimming Direction EF 17
                    maximize
                Lichtfunktion G 17
                Lichtfunktion H 17
                    nicht aktiv
                Dimmwert GH 17
                    10
                Dimming Direction GH 17
                    minimize
            Leuchte18BLK HLA60
                Lasttyp 18
                    38 - LED Blinkleuchten
                Lampendefektbitposition 18
                    8
                Fehlerort mittleres Byte DTC-DFCC 18
                    16
                Lichtfunktion A 18
                Lichtfunktion B 18
                    nicht aktiv
                Dimmwert AB 18
                    127
                Lichtansteuerung HD AB 18
                    always
                Lichtfunktion C 18
                    nicht aktiv
                Lichtfunktion D 18
                    nicht aktiv
                Dimmwert CD 18
                Dimming Direction CD 18
                    maximize
                Lichtfunktion E 18
                    nicht aktiv
                Lichtfunktion F 18
                    nicht aktiv
                Dimmwert EF 18
                Dimming Direction EF 18
                    maximize
                Lichtfunktion G 18
                    nicht aktiv
                Lichtfunktion H 18
                    nicht aktiv
                Dimmwert GH 18
                Dimming Direction GH 18
                    maximize
            Leuchte19BLK HRC31
                Lasttyp 19
                Lampendefektbitposition 19
                    18
                Fehlerort mittleres Byte DTC-DFCC 19
                    18
                Lichtfunktion A 19
                Lichtfunktion B 19
                    nicht aktiv
                Dimmwert AB 19
                    127
                Lichtansteuerung HD AB 19
                    always
                Lichtfunktion C 19
                    nicht aktiv
                Lichtfunktion D 19
                    nicht aktiv
                Dimmwert CD 19
                Dimming Direction CD 19
                    maximize
                Lichtfunktion E 19
                    nicht aktiv
                Lichtfunktion F 19
                    nicht aktiv
                Dimmwert EF 19
                Dimming Direction EF 19
                    maximize
                Lichtfunktion G 19
                    nicht aktiv
                Lichtfunktion H 19
                    nicht aktiv
                Dimmwert GH 19
                Dimming Direction GH 19
                    maximize
            Leuchte20BR LA71
                Lasttyp 20
                    34 - LED Bremsleuchten
                Lampendefektbitposition 20
                    9
                Fehlerort mittleres Byte DTC-DFCC 20
                    2B
                Lichtfunktion A 20
                    Bremslicht
                Lichtfunktion B 20
                    nicht aktiv
                Dimmwert AB 20
                    100
                Lichtansteuerung HD AB 20
                    always
                Lichtfunktion C 20
                    nicht aktiv
                Lichtfunktion D 20
                    nicht aktiv
                Dimmwert CD 20
                Dimming Direction CD 20
                    maximize
                Lichtfunktion E 20
                    nicht aktiv
                Lichtfunktion F 20
                    nicht aktiv
                Dimmwert EF 20
                Dimming Direction EF 20
                    maximize
                Lichtfunktion G 20
                    nicht aktiv
                Lichtfunktion H 20
                    nicht aktiv
                Dimmwert GH 20
                Dimming Direction GH 20
                    maximize
            Leuchte21BR RC8
                Lasttyp 21
                Lampendefektbitposition 21
                    19
                Fehlerort mittleres Byte DTC-DFCC 21
                    2D
                Lichtfunktion A 21
                    Bremslicht
                Lichtfunktion B 21
                    nicht aktiv
                Dimmwert AB 21
                    100
                Lichtansteuerung HD AB 21
                    always
                Lichtfunktion C 21
                    nicht aktiv
                Lichtfunktion D 21
                    nicht aktiv
                Dimmwert CD 21
                Dimming Direction CD 21
                    maximize
                Lichtfunktion E 21
                    nicht aktiv
                Lichtfunktion F 21
                    nicht aktiv
                Dimmwert EF 21
                Dimming Direction EF 21
                    maximize
                Lichtfunktion G 21
                    nicht aktiv
                Lichtfunktion H 21
                    nicht aktiv
                Dimmwert GH 21
                Dimming Direction GH 21
                    maximize
            Leuchte22BR MA57
                Lasttyp 22
                    42 - LED dritte Bremsleuchte
                Lampendefektbitposition 22
                    29
                Fehlerort mittleres Byte DTC-DFCC 22
                    2C
                Lichtfunktion A 22
                    Bremslicht
                Lichtfunktion B 22
                    nicht aktiv
                Dimmwert AB 22
                    127
                Lichtansteuerung HD AB 22
                    always
                Lichtfunktion C 22
                    nicht aktiv
                Lichtfunktion D 22
                    nicht aktiv
                Dimmwert CD 22
                Dimming Direction CD 22
                    maximize
                Lichtfunktion E 22
                    nicht aktiv
                Lichtfunktion F 22
                    nicht aktiv
                Dimmwert EF 22
                Dimming Direction EF 22
                    maximize
                Lichtfunktion G 22
                    nicht aktiv
                Lichtfunktion H 22
                    nicht aktiv
                Dimmwert GH 22
                Dimming Direction GH 22
                    maximize
            Leuchte23SL HLC10
                Lasttyp 23
                Lampendefektbitposition 23
                    10
                Fehlerort mittleres Byte DTC-DFCC 23
                    39
                Lichtfunktion A 23
                    Bremslicht
                Lichtfunktion B 23
                    nicht aktiv
                Dimmwert AB 23
                    126
                Lichtansteuerung HD AB 23
                    always
                Lichtfunktion C 23
                Lichtfunktion D 23
                    nicht aktiv
                Dimmwert CD 23
                    126
                Dimming Direction CD 23
                    maximize
                Lichtfunktion E 23
                Lichtfunktion F 23
                    nicht aktiv
                Dimmwert EF 23
                    127
                Dimming Direction EF 23
                    maximize
                Lichtfunktion G 23
                Lichtfunktion H 23
                    nicht aktiv
                Dimmwert GH 23
                    10
                Dimming Direction GH 23
                    minimize
            Leuchte24SL HRA65
                Lasttyp 24
                Lampendefektbitposition 24
                    20
                Fehlerort mittleres Byte DTC-DFCC 24
                    3A
                Lichtfunktion A 24
                    Bremslicht
                Lichtfunktion B 24
                    nicht aktiv
                Dimmwert AB 24
                    126
                Lichtansteuerung HD AB 24
                    always
                Lichtfunktion C 24
                Lichtfunktion D 24
                    nicht aktiv
                Dimmwert CD 24
                    126
                Dimming Direction CD 24
                    maximize
                Lichtfunktion E 24
                Lichtfunktion F 24
                    nicht aktiv
                Dimmwert EF 24
                    127
                Dimming Direction EF 24
                    maximize
                Lichtfunktion G 24
                Lichtfunktion H 24
                    nicht aktiv
                Dimmwert GH 24
                    10
                Dimming Direction GH 24
                    minimize
            Leuchte25KZL HA59
                Lasttyp 25
                    43 - allgemeine LED
                Lampendefektbitposition 25
                    28
                Fehlerort mittleres Byte DTC-DFCC 25
                    30
                Lichtfunktion A 25
                Lichtfunktion B 25
                    nicht aktiv
                Dimmwert AB 25
                    127
                Lichtansteuerung HD AB 25
                    always
                Lichtfunktion C 25
                    nicht aktiv
                Lichtfunktion D 25
                    Tagfahrlicht
                Dimmwert CD 25
                    100
                Dimming Direction CD 25
                    maximize
                Lichtfunktion E 25
                    nicht aktiv
                Lichtfunktion F 25
                    nicht aktiv
                Dimmwert EF 25
                Dimming Direction EF 25
                    maximize
                Lichtfunktion G 25
                    nicht aktiv
                Lichtfunktion H 25
                    nicht aktiv
                Dimmwert GH 25
                Dimming Direction GH 25
                    maximize
            Leuchte26NSL LA72
                Lasttyp 26
                    not active
                Lampendefektbitposition 26
                Fehlerort mittleres Byte DTC-DFCC 26
                Lichtfunktion A 26
                    nicht aktiv
                Lichtfunktion B 26
                    nicht aktiv
                Dimmwert AB 26
                Lichtansteuerung HD AB 26
                    always
                Lichtfunktion C 26
                    nicht aktiv
                Lichtfunktion D 26
                    nicht aktiv
                Dimmwert CD 26
                Dimming Direction CD 26
                    maximize
                Lichtfunktion E 26
                    nicht aktiv
                Lichtfunktion F 26
                    nicht aktiv
                Dimmwert EF 26
                Dimming Direction EF 26
                    maximize
                Lichtfunktion G 26
                    nicht aktiv
                Lichtfunktion H 26
                    nicht aktiv
                Dimmwert GH 26
                Dimming Direction GH 26
                    maximize
            Leuchte27NSL RC6
                Lasttyp 27
                    not active
                Lampendefektbitposition 27
                    20
                Fehlerort mittleres Byte DTC-DFCC 27
                    3A
                Lichtfunktion A 27
                    nicht aktiv
                Lichtfunktion B 27
                    nicht aktiv
                Dimmwert AB 27
                Lichtansteuerung HD AB 27
                    always
                Lichtfunktion C 27
                Lichtfunktion D 27
                    Parklicht rechts
                Dimmwert CD 27
                    10
                Dimming Direction CD 27
                    maximize
                Lichtfunktion E 27
                    nicht aktiv
                Lichtfunktion F 27
                    nicht aktiv
                Dimmwert EF 27
                Dimming Direction EF 27
                    maximize
                Lichtfunktion G 27
                    nicht aktiv
                Lichtfunktion H 27
                    nicht aktiv
                Dimmwert GH 27
                Dimming Direction GH 27
                    maximize
            Leuchte28RFL LC11
                Lasttyp 28
                    32 - allgemeine LED bis 12W
                Lampendefektbitposition 28
                    B
                Fehlerort mittleres Byte DTC-DFCC 28
                    31
                Lichtfunktion A 28
                    Rueckfahrlicht
                Lichtfunktion B 28
                    nicht aktiv
                Dimmwert AB 28
                    127
                Lichtansteuerung HD AB 28
                    always
                Lichtfunktion C 28
                    nicht aktiv
                Lichtfunktion D 28
                    nicht aktiv
                Dimmwert CD 28
                Dimming Direction CD 28
                    maximize
                Lichtfunktion E 28
                    nicht aktiv
                Lichtfunktion F 28
                    nicht aktiv
                Dimmwert EF 28
                Dimming Direction EF 28
                    maximize
                Lichtfunktion G 28
                    nicht aktiv
                Lichtfunktion H 28
                    nicht aktiv
                Dimmwert GH 28
                Dimming Direction GH 28
                    maximize
            Leuchte29RFL RA64
                Lasttyp 29
                Lampendefektbitposition 29
                    1B
                Fehlerort mittleres Byte DTC-DFCC 29
                    32
                Lichtfunktion A 29
                    Rueckfahrlicht
                Lichtfunktion B 29
                    nicht aktiv
                Dimmwert AB 29
                    127
                Lichtansteuerung HD AB 29
                    always
                Lichtfunktion C 29
                    nicht aktiv
                Lichtfunktion D 29
                    nicht aktiv
                Dimmwert CD 29
                Dimming Direction CD 29
                    maximize
                Lichtfunktion E 29
                    nicht aktiv
                Lichtfunktion F 29
                    nicht aktiv
                Dimmwert EF 29
                Dimming Direction EF 29
                    maximize
                Lichtfunktion G 29
                    nicht aktiv
                Lichtfunktion H 29
                    nicht aktiv
                Dimmwert GH 29
                Dimming Direction GH 29
                    maximize
            Leuchte30FR LC72
                Lasttyp 30
                    not active
                Lampendefektbitposition 30
                Fehlerort mittleres Byte DTC-DFCC 30
                Lichtfunktion A 30
                    nicht aktiv
                Lichtfunktion B 30
                    nicht aktiv
                Dimmwert AB 30
                Lichtansteuerung HD AB 30
                    always
                Lichtfunktion C 30
                    nicht aktiv
                Lichtfunktion D 30
                    nicht aktiv
                Dimmwert CD 30
                Dimming Direction CD 30
                    maximize
                Lichtfunktion E 30
                    nicht aktiv
                Lichtfunktion F 30
                    nicht aktiv
                Dimmwert EF 30
                Dimming Direction EF 30
                    maximize
                Lichtfunktion G 30
                    nicht aktiv
                Lichtfunktion H 30
                    nicht aktiv
                Dimmwert GH 30
                Dimming Direction GH 30
                    maximize
            Leuchte31AMBL 1C61
                Lasttyp 31
                    not active
                Lampendefektbitposition 31
                Fehlerort mittleres Byte DTC-DFCC 31
                Lichtfunktion A 31
                    nicht aktiv
                Lichtfunktion B 31
                    nicht aktiv
                Dimmwert AB 31
                Lichtansteuerung HD AB 31
                    always
                Lichtfunktion C 31
                    nicht aktiv
                Lichtfunktion D 31
                    nicht aktiv
                Dimmwert CD 31
                Dimming Direction CD 31
                    maximize
                Lichtfunktion E 31
                    nicht aktiv
                Lichtfunktion F 31
                    nicht aktiv
                Dimmwert EF 31
                Dimming Direction EF 31
                    maximize
                Lichtfunktion G 31
                    nicht aktiv
                Lichtfunktion H 31
                    nicht aktiv
                Dimmwert GH 31
                Dimming Direction GH 31
                    maximize
            Leuchte32AMBL 2C35
                Lasttyp 32
                    not active
                Lampendefektbitposition 32
                Fehlerort mittleres Byte DTC-DFCC 32
                Lichtfunktion A 32
                    nicht aktiv
                Lichtfunktion B 32
                    nicht aktiv
                Dimmwert AB 32
                Lichtansteuerung HD AB 32
                    always
                Lichtfunktion C 32
                    nicht aktiv
                Lichtfunktion D 32
                    nicht aktiv
                Dimmwert CD 32
                Dimming Direction CD 32
                    maximize
                Lichtfunktion E 32
                    nicht aktiv
                Lichtfunktion F 32
                    nicht aktiv
                Dimmwert EF 32
                Dimming Direction EF 32
                    maximize
                Lichtfunktion G 32
                    nicht aktiv
                Lichtfunktion H 32
                    nicht aktiv
                Dimmwert GH 32
                Dimming Direction GH 32
                    maximize
            Leuchte33AMBL 3C36
                Lasttyp 33
                    not active
                Lampendefektbitposition 33
                Fehlerort mittleres Byte DTC-DFCC 33
                Lichtfunktion A 33
                    nicht aktiv
                Lichtfunktion B 33
                    nicht aktiv
                Dimmwert AB 33
                Lichtansteuerung HD AB 33
                    always
                Lichtfunktion C 33
                    nicht aktiv
                Lichtfunktion D 33
                    nicht aktiv
                Dimmwert CD 33
                Dimming Direction CD 33
                    maximize
                Lichtfunktion E 33
                    nicht aktiv
                Lichtfunktion F 33
                    nicht aktiv
                Dimmwert EF 33
                Dimming Direction EF 33
                    maximize
                Lichtfunktion G 33
                    nicht aktiv
                Lichtfunktion H 33
                    nicht aktiv
                Dimmwert GH 33
                Dimming Direction GH 33
                    maximize
            Leuchte34AMBL 4C37
                Lasttyp 34
                    not active
                Lampendefektbitposition 34
                Fehlerort mittleres Byte DTC-DFCC 34
                Lichtfunktion A 34
                    nicht aktiv
                Lichtfunktion B 34
                    nicht aktiv
                Dimmwert AB 34
                Lichtansteuerung HD AB 34
                    always
                Lichtfunktion C 34
                    nicht aktiv
                Lichtfunktion D 34
                    nicht aktiv
                Dimmwert CD 34
                Dimming Direction CD 34
                    maximize
                Lichtfunktion E 34
                    nicht aktiv
                Lichtfunktion F 34
                    nicht aktiv
                Dimmwert EF 34
                Dimming Direction EF 34
                    maximize
                Lichtfunktion G 34
                    nicht aktiv
                Lichtfunktion H 34
                    nicht aktiv
                Dimmwert GH 34
                Dimming Direction GH 34
                    maximize
            HW_Verbau
                Aussentemperatursensor
                    installed
                Brake pad wear
                    not installed
                PTC Zuheizer
                    installed
                Insufficient brake fluid
                    installed
                Insufficient coolant
                    installed
                Insufficient washer fluid
                    installed
                Kontaktschalter fuer Motorhaube
                    installed
                Status Tankdeckelverriegelung
                    active
                Druckklappe
                    installed
                Ladesteckerverriegelung
                    not installed
                Signalhorn ohne KL15
                    active
                Elektrische Laderaumabdeckung
                    not installed
                Elektrische Laderaumabdeckung aktiv
                    not active
            Aussenlicht_Heck
                Bremslicht ist auch Blinklicht
                    No
                Schlusslicht mit Bremslichtfunktion
                    active
                Notbremsanzeige NBA
                    active
                Umgreifende Heckklappe
                    not installed
                Nebelschlusslicht Warngeschwindigkeit
                    0 km/h
            Static AFS light
                bei Rueckwaertsfahrt
                    both sides
                Zeitwert Einschaltzeit Abbiegelicht
                    15 min
                Vorschrift
                    Off
                Untere Geschwindigkeitsschwelle
                    0.0 km/h
                Obere Geschwindigkeitsschwelle
                    0.0 km/h
                Steering wheel angle, offset
                    0.2 °
                Unterer Lenkradwinkel
                    80 °
                Oberer Lenkradwinkel
                    120 °
                Abdimmgeschwindigkeit
                    50.0 %/s
                Maximaltemperatur
                    100.0 °C
                obere Grenztemperatur
                    95.0 °C
                untere Grenztemperatur
                    80.0 °C
            Sonderfunktionen
                Sonderfunktionen 1
                    not installed
                Sonderfunktionen
                    not enabled
                Signalprioritaet fuer Blinker
                    MFG
                Blinkerueberwachug Sonderfunktions-SG
                    not installed
            Fernlicht_assistent
                Erweiterte Fernlichtsteuerung
                    Basis
                Menuesteuerung Fernlichtassistent
                    Not present
                Fernlichtassistent Reset
                    not active
                Menuesteuerung Fernlichtassistent Werkseinstellung
                    Present
                Will Beam assistant, responsivity adjustable via BAP
                    Present
            lwr_ofs_RSw_Ah1S
                x0
                    -5.00 %
                x1
                    -5.00 %
                x2
                    -5.00 %
                x3
                    -5.00 %
                x4
                    -5.00 %
                y0
                    -5.00
                y1
                    -5.00
                y2
                    -5.00
                y3
                    -5.00
                y4
                    -5.00
            Kennlinie_sLWR_Soll
                x0
                    100.00 %
                x1
                    100.00 %
                x2
                    100.00 %
                x3
                    100.00 %
                x4
                    83.00 %
                x5
                    67.00 %
                x6
                    50.00 %
                x7
                    33.00
                x8
                    17.00 %
                x9
                    0.00 %
                y0
                    50.0 %
                y1
                    50.0 %
                y2
                    50.0 %
                y3
                    50.0 %
                y4
                    55.0 %
                y5
                    60.0 %
                y6
                    65.0 %
                y7
                    70.5 %
                y8
                    77.5 %
                y9
                    84.5 %
            Assistance light functions
                Regen Lichtsensor
                    diskret
                Feuchtesensor
                    not installed
                Assistenzfahrlicht bei Regen
                    active
                Sonnensensor
                    not installed
                LS Error Ausgabe
                    not active
                Maskierung Regenfunktion
                    not active
                Lichtsensorempfindlichkeit
                    normal
            Light sensor
                Einschaltgrenze CHO LHO
                    600 lx
                Daemmerungsgrenze, Hysterese obergrenze
                    1200 lx
                Daemmerungsgrenze Hysterese untergrenze
                    2200 lx
                Helligkeitsgrenze sehr hell
                    2000 lx
                Helligkeitsgrenze Licht  einschalten
                    1200 lx
                Helligkeitsgrenze Licht ausschalten
                    2200 lx
                Minimale Beleuchtungsstaerke
                    0 lx
                Maximale Beleuchtungsstaerke
                    6000 lx
                Minimale Ausgangsspannung
                    2000 mV
                Maximale Ausgangsspannung
                    4500 mV
                Tunnel einschalt verzoegerung
                ECE Lichteinschaltschwelle
                    2512 lx
                Helligkeitsgrenze Licht ausschalten red
                    50
                HMI Wiper Comfort Rain Sensor OFF
                    not active
                HMI Exterior light on highway
                    not active
                HMI Exterior light on rain
                    not active
                LS Error Ausgabe
                    not active
                HMI exterior light sensitivity
                    frueh
            LuB Lichtrouter Kennlinie 1
                x0
                    0.0 %
                x1
                    5.0 %
                x2
                    50.0 %
                x3
                    75.0 %
                x4
                    110.0
                x5
                    126.5
                y0
                    0.0 %
                y1
                    6.0 %
                y2
                    16.0 %
                y3
                    30.0 %
                y4
                    60.0 %
                y5
                    100.0 %
            Light configuration
                    0C3400140200640000000000000000000C3E00150400640000000000000000000448004A14006406128008091C000000044C004C140064071380080A1C000000013A004914007F06008008097F0000000144004B14007F070080080A7F0000000536001A0B0F7F0000000000000000000540001B0C0F7F0000000000000000000637001C0D0F7F0000000000000000000641001D0E0F7F000000000000000000025200550B0D7F000000000000000000025300560C0E7F0000000000000000000000000000000000000000000000000000000000000000000000000000000000
            Leuchtenkonfiguration_Aussenlich_Heck
                    2608001602007F0000000000000000002618001804007F0000000000000000002209002B1800640000000000000000002219002D1800640000000000000000002A29002C18007F0000000000000000002210003918007E08007E08007F06008A2220003A18007E08007E08007F07008A2B28003008007F001464000000000000000000000000000000000000000000000020003A000000080A0A000000000000200B003119007F000000000000000000201B003219007F000000000000000000
            Leuchtenkonfiguration_Sonstiges
                    251A003608007E00007E00000007008A250A003508007E00007E00000006008A0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000290000634C0064000000000000000000
            debug_light_function
                Adresse
                Bitmask
                Offset
                Divisor
                Polaritaet
                Aktivierung
            Interior lighting, parameter
                p t verzoegerung einstieg innenlicht
                    0.0 s
                p t verzoegerung ausstieg innenlicht
                    0.0 s
                p t verzoegerung oeffnen innenlicht
                    0.0 s
                p t verzoegerung entriegelt innenlicht
                    0.0 s
                p t verzoegerung schliessen innenlicht
                    0.0 s
                p t verzoegerung schluessel ab innenlicht
                    0.0 s
                p t verzoegerung verriegelt innenlicht
                    0.0 s
                p t verzoegerung einstieg tueren
                    0.0 s
                p t verzoegerung ausstieg tueren
                    0.0 s
                p t verzoegerung oeffnen tueren
                    0.0 s
                p t verzoegerung entriegelt tueren
                    0.0 s
                p t verzoegerung schliessen tueren
                    0.0 s
                p t verzoegerung schluessel ab tueren
                    0.0 s
                p t verzoegerung verriegelt tueren
                    0.0 s
                p t verzoegerung einstieg fussraum
                    0.0 s
                p t verzoegerung ausstieg fussraum
                    0.0 s
                p t verzoegerung oeffnen fussraum
                    0.0 s
                p t verzoegerung entriegelt fussraum
                    0.0 s
                p t verzoegerung schliessen fussraum
                    0.0 s
                p t verzoegerung schluessel ab fussraum
                    0.0 s
                p t verzoegerung verriegelt fussraum
                    0.0 s
                p t verzoegerung einstieg cockpit
                    0.0 s
                p t verzoegerung ausstieg cockpit
                    0.0 s
                p t verzoegerung oeffnen cockpit
                    0.0 s
                p t verzoegerung entriegelt cockpit
                    0.0 s
                p t verzoegerung schliessen cockpit
                    0.0 s
                p t verzoegerung schluessel ab cockpit
                    0.0 s
                p t verzoegerung verriegelt cockpit
                    0.0 s
                p t verzoegerung einstieg miko
                    0.0 s
                p t verzoegerung ausstieg miko
                    0.0 s
                p t verzoegerung oeffnen miko
                    0.0 s
                p t verzoegerung entriegelt miko
                    0.0 s
                p t verzoegerung schliessen miko
                    0.0 s
                p t verzoegerung schluessel ab miko
                    0.0 s
                p t verzoegerung verriegelt miko
                    0.0 s
                p t verzoegerung einstieg dach
                    0.0 s
                p t verzoegerung ausstieg dach
                    0.0 s
                p t verzoegerung oeffnen dach
                    0.0 s
                p t verzoegerung entriegelt dach
                    0.0 s
                p t verzoegerung schliessen dach
                    0.0 s
                p t verzoegerung schluessel ab dach
                    0.0 s
                p t verzoegerung verriegelt dach
                    0.0 s
                p helligkeit entriegelt innenlicht
                    100 %
                p helligkeit max innenlicht
                    100 %
                p helligkeit HD auf zuendung ein innenlicht
                    100 %
                p helligkeit HD auf zuendung aus innenlicht
                    100 %
                p helligkeit dieseTuer auf zuendung ein innenlicht
                    100 %
                p helligkeit andereTuer auf zuendung ein innenlicht
                    100 %
                p helligkeit Fzg geschlossen zuendung ein innenlicht
                    0 %
                p helligkeit dieseTuer auf zuendung aus innenlicht
                    100 %
                p helligkeit andereTuer auf zuendung aus innenlicht
                    100 %
                p helligkeit einausstieg innenlicht
                    100 %
                p helligkeit Fzg geschlossen zuendung aus innenlicht
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus innenlicht
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus innenlicht
                    100 %
                p helligkeit Tueren geschlossen schluessel ab innenlicht
                    100 %
                p helligkeit Fzg geschlossen schluessel ab innenlicht
                    100 %
                p adaption kundenwunsch tuer
                    1.00
                p helligkeit entriegelt tueren
                    100 %
                p helligkeit max tueren
                    100 %
                p helligkeit HD auf zuendung ein tueren
                    100 %
                p helligkeit HD auf zuendung aus tueren
                    100 %
                p helligkeit dieseTuer auf zuendung ein tueren
                    100 %
                p helligkeit andereTuer auf zuendung ein tueren
                    100 %
                p helligkeit Fzg geschlossen zuendung ein tueren
                    126 %
                p helligkeit dieseTuer auf zuendung aus tueren
                    100 %
                p helligkeit andereTuer auf zuendung aus tueren
                    100 %
                p helligkeit einausstieg tueren
                    100 %
                p helligkeit Fzg geschlossen zuendung aus tueren
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus tueren
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus tueren
                    100 %
                p helligkeit Tueren geschlossen schluessel ab tueren
                    100 %
                p helligkeit Fzg geschlossen schluessel ab tueren
                    100 %
                p adaption kundenwunsch fussraum
                    1.00
                p helligkeit entriegelt fussraum
                    100 %
                p helligkeit max fussraum
                    100 %
                p helligkeit HD auf zuendung ein fussraum
                    100 %
                p helligkeit HD auf zuendung aus fussraum
                    100 %
                p helligkeit dieseTuer auf zuendung ein fussraum
                    100 %
                p helligkeit andereTuer auf zuendung ein fussraum
                    100 %
                p helligkeit Fzg geschlossen zuendung ein fussraum
                    126 %
                p helligkeit dieseTuer auf zuendung aus fussraum
                    100 %
                p helligkeit andereTuer auf zuendung aus fussraum
                    100 %
                p helligkeit einausstieg fussraum
                    100 %
                p helligkeit Fzg geschlossen zuendung aus fussraum
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus fussraum
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus fussraum
                    100 %
                p helligkeit Tueren geschlossen schluessel ab fussraum
                    100 %
                p helligkeit Fzg geschlossen schluessel ab fussraum
                    100 %
                p adaption kundenwunsch lautsprecher
                    1.00
                p helligkeit entriegelt lautsprecher
                    100 %
                p helligkeit max lautsprecher
                    100 %
                p helligkeit HD auf zuendung ein lautsprecher
                    100 %
                p helligkeit HD auf zuendung aus lautsprecher
                    100 %
                p helligkeit dieseTuer auf zuendung ein lautsprecher
                    100 %
                p helligkeit andereTuer auf zuendung ein lautsprecher
                    100 %
                p helligkeit Fzg geschlossen zuendung ein lautsprecher
                    126 %
                p helligkeit dieseTuer auf zuendung aus lautsprecher
                    100 %
                p helligkeit andereTuer auf zuendung aus lautsprecher
                    100 %
                p helligkeit einausstieg lautsprecher
                    100 %
                p helligkeit Fzg geschlossen zuendung aus lautsprecher
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus lautsprecher
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus lautsprecher
                    100 %
                p helligkeit Tueren geschlossen schluessel ab lautsprecher
                    100 %
                p helligkeit Fzg geschlossen schluessel ab lautsprecher
                    100 %
                p adaption kundenwunsch itafel
                    1.00
                p helligkeit entriegelt itafel
                    100 %
                p helligkeit max itafel
                    100 %
                p helligkeit HD auf zuendung ein itafel
                    100 %
                p helligkeit HD auf zuendung aus itafel
                    100 %
                p helligkeit dieseTuer auf zuendung ein itafel
                    100 %
                p helligkeit andereTuer auf zuendung ein itafel
                    100 %
                p helligkeit Fzg geschlossen zuendung ein itafel
                    126 %
                p helligkeit dieseTuer auf zuendung aus itafel
                    100 %
                p helligkeit andereTuer auf zuendung aus itafel
                    100 %
                p helligkeit einausstieg itafel
                    100 %
                p helligkeit Fzg geschlossen zuendung aus itafel
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus itafel
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus itafel
                    100 %
                p helligkeit Tueren geschlossen schluessel ab itafel
                    100 %
                p helligkeit Fzg geschlossen schluessel ab itafel
                    100 %
                p adaption kundenwunsch cockpit
                    1.00
                p helligkeit entriegelt cockpit
                    100 %
                p helligkeit max cockpit
                    100 %
                p helligkeit HD auf zuendung ein cockpit
                    100 %
                p helligkeit HD auf zuendung aus cockpit
                    100 %
                p helligkeit dieseTuer auf zuendung ein cockpit
                    100 %
                p helligkeit andereTuer auf zuendung ein cockpit
                    100 %
                p helligkeit Fzg geschlossen zuendung ein cockpit
                    126 %
                p helligkeit dieseTuer auf zuendung aus cockpit
                    100 %
                p helligkeit andereTuer auf zuendung aus cockpit
                    100 %
                p helligkeit einausstieg cockpit
                    100 %
                p helligkeit Fzg geschlossen zuendung aus cockpit
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus cockpit
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus cockpit
                    100 %
                p helligkeit Tueren geschlossen schluessel ab cockpit
                    100 %
                p helligkeit Fzg geschlossen schluessel ab cockpit
                    100 %
                p adaption kundenwunsch miko
                    1.00
                p helligkeit entriegelt miko
                    100 %
                p helligkeit max miko
                    100 %
                p helligkeit HD auf zuendung ein miko
                    100 %
                p helligkeit HD auf zuendung aus miko
                    100 %
                p helligkeit dieseTuer auf zuendung ein miko
                    100 %
                p helligkeit andereTuer auf zuendung ein miko
                    100 %
                p helligkeit Fzg geschlossen zuendung ein miko
                    126 %
                p helligkeit dieseTuer auf zuendung aus miko
                    100 %
                p helligkeit andereTuer auf zuendung aus miko
                    100 %
                p helligkeit einausstieg miko
                    100 %
                p helligkeit Fzg geschlossen zuendung aus miko
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus miko
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus miko
                    100 %
                p helligkeit Tueren geschlossen schluessel ab miko
                    100 %
                p helligkeit Fzg geschlossen schluessel ab miko
                    100 %
                p adaption kundenwunsch dach
                    1.00
                p helligkeit entriegelt dach
                    100 %
                p helligkeit max dach
                    100 %
                p helligkeit HD auf zuendung ein dach
                    100 %
                p helligkeit HD auf zuendung aus dach
                    100 %
                p helligkeit dieseTuer auf zuendung ein dach
                    100 %
                p helligkeit andereTuer auf zuendung ein dach
                    100 %
                p helligkeit Fzg geschlossen zuendung ein dach
                    126 %
                p helligkeit dieseTuer auf zuendung aus dach
                    100 %
                p helligkeit andereTuer auf zuendung aus dach
                    100 %
                p helligkeit einausstieg dach
                    100 %
                p helligkeit Fzg geschlossen zuendung aus dach
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus dach
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus dach
                    100 %
                p helligkeit Tueren geschlossen schluessel ab dach
                    100 %
                p helligkeit Fzg geschlossen schluessel ab dach
                    100 %
                p adaption kundenwunsch psd
                    1.00
                p helligkeit entriegelt psd
                    100 %
                p helligkeit max psd
                    100 %
                p helligkeit HD auf zuendung ein psd
                    100 %
                p helligkeit HD auf zuendung aus psd
                    100 %
                p helligkeit dieseTuer auf zuendung ein psd
                    100 %
                p helligkeit andereTuer auf zuendung ein psd
                    100 %
                p helligkeit Fzg geschlossen zuendung ein psd
                    126 %
                p helligkeit dieseTuer auf zuendung aus psd
                    100 %
                p helligkeit andereTuer auf zuendung aus psd
                    100 %
                p helligkeit einausstieg psd
                    100 %
                p helligkeit Fzg geschlossen zuendung aus psd
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus psd
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus psd
                    100 %
                p helligkeit Tueren geschlossen schluessel ab psd
                    100 %
                p helligkeit Fzg geschlossen schluessel ab psd
                    100 %
                p dimmfaktor farbwechsel auf
                p dimmfaktor farbwechsel ab
                p farbwechsel delay
                p farbauswahl HMI
                p ambienteumfang mehrfarbig HMI
                p ambienteumfang mehrfarbig HMI 2
                p ambienteumfang mehrfarbig HMI 3
                p ambienteumfang mehrfarbig HMI 4
                p ambientelicht verbauinformation HMI
                p ambientelicht verbauinformation HMI 2
                p ambientelicht verbauinformation HMI 3
                p ambientelicht verbauinformation HMI 4
                p verzoegerung berechnen
                p t HMI verzoegerung helligkeitswerte
                    200 ms
            Ambient light color list
                Rotwert Farbe 1
                    217
                Gruenwert Farbe 1
                    221
                Blauwert Farbe 1
                    235
                Rotwert Farbe 2
                    255
                Gruenwert Farbe 2
                    172
                Blauwert Farbe 2
                    5
                Rotwert Farbe 3
                    253
                Gruenwert Farbe 3
                    108
                Blauwert Farbe 3
                    55
                Rotwert Farbe 4
                    242
                Gruenwert Farbe 4
                Blauwert Farbe 4
                    40
                Rotwert Farbe 5
                    252
                Gruenwert Farbe 5
                    116
                Blauwert Farbe 5
                    240
                Rotwert Farbe 6
                    132
                Gruenwert Farbe 6
                    76
                Blauwert Farbe 6
                    222
                Rotwert Farbe 7
                Gruenwert Farbe 7
                    102
                Blauwert Farbe 7
                    255
                Rotwert Farbe 8
                Gruenwert Farbe 8
                    192
                Blauwert Farbe 8
                    255
                Rotwert Farbe 9
                Gruenwert Farbe 9
                    204
                Blauwert Farbe 9
                Rotwert Farbe 10
                    182
                Gruenwert Farbe 10
                    255
                Blauwert Farbe 10
                    57
            ambient_lighting_lin_slaves_modules
                pa einzeladresse slave 1
                pa verbauinfo slave 1
                    not installed
                pa fehlerort slave 1
                pa einzeladresse slave 2
                pa verbauinfo slave 2
                    not installed
                pa fehlerort slave 2
                pa einzeladresse slave 3
                pa verbauinfo slave 3
                    not installed
                pa fehlerort slave 3
                pa einzeladresse slave 4
                pa verbauinfo slave 4
                    not installed
                pa fehlerort slave 4
                pa einzeladresse slave 5
                pa verbauinfo slave 5
                    not installed
                pa fehlerort slave 5
                pa einzeladresse slave 6
                pa verbauinfo slave 6
                    not installed
                pa fehlerort slave 6
                pa einzeladresse slave 7
                pa verbauinfo slave 7
                    not installed
                pa fehlerort slave 7
                pa einzeladresse slave 8
                pa verbauinfo slave8
                    not installed
                pa fehlerort slave8
                pa einzeladresse slave 9
                pa verbauinfo slave 9
                    not installed
                pa fehlerort slave 9
                pa einzeladresse slave 10
                pa verbauinfo slave 10
                    not installed
                pa fehlerort slave 10
                pa einzeladresse slave 11
                pa verbauinfo slave 11
                    not installed
                pa fehlerort slave 11
                pa einzeladresse slave :12
                pa verbauinfo slave 12
                    not installed
                pa fehlerort slave 12
                pa einzeladresse slave 13
                pa verbauinfo slave 13
                    not installed
                pa fehlerort slave 13
                pa einzeladresse slave 14
                pa verbauinfo slave 14
                    not installed
                pa fehlerort slave 14
                pa einzeladresse slave 15
                pa verbauinfo slave 15
                    not installed
                pa fehlerort slave 15
                pa einzeladresse slave 16
                pa verbauinfo slave 16
                    not installed
                pa fehlerort slave 16
                pa einzeladresse slave 17
                pa verbauinfo slave 17
                    not installed
                pa fehlerort slave 17
                pa einzeladresse slave 18
                pa verbauinfo slave 18
                    not installed
                pa fehlerort slave 18
                pa einzeladresse slave 19
                pa verbauinfo slave 19
                    not installed
                pa fehlerort slave 19
                pa einzeladresse slave 20
                pa verbauinfo slave 20
                    not installed
                pa fehlerort slave 20
            ambient_lighting_lin_slaves_groups
                pa verbauinfo gruppe 1
                    not installed
                pa lichtfunktion gruppe 1
                    Door
                pa korrekturfaktor gruppe 1
                    1.00
                pa verbauinfo gruppe 2
                    not installed
                pa lichtfunktion gruppe 2
                    I-panel
                pa korrekturfaktor gruppe 2
                    1.00
                pa verbauinfo gruppe 3
                    not installed
                pa lichtfunktion gruppe 3
                    Door
                pa korrekturfaktor gruppe 3
                    1.00
                pa verbauinfo gruppe 4
                    not installed
                pa lichtfunktion gruppe 4
                    Door
                pa korrekturfaktor gruppe 4
                    1.00
                pa verbauinfo gruppe 5
                    not installed
                pa lichtfunktion gruppe 5
                    Door
                pa korrekturfaktor gruppe 5
                    1.00
                pa verbauinfo gruppe 6
                    not installed
                pa lichtfunktion gruppe 6
                    Door
                pa korrekturfaktor gruppe 6
                    1.00
                pa verbauinfo gruppe 7
                    not installed
                pa lichtfunktion gruppe 7
                    Door
                pa korrekturfaktor gruppe 7
                    1.00
                pa verbauinfo gruppe 8
                    not installed
                pa lichtfunktion gruppe 8
                    Door
                pa korrekturfaktor gruppe 8
                    1.00
                pa verbauinfo gruppe 9
                    not installed
                pa lichtfunktion gruppe 9
                    Door
                pa korrekturfaktor gruppe 9
                    1.00
                pa verbauinfo gruppe 10
                    not installed
                pa lichtfunktion gruppe 10
                    Door
                pa korrekturfaktor gruppe 10
                    1.00
                pa verbauinfo gruppe 11
                    not installed
                pa lichtfunktion gruppe 11
                    Door
                pa korrekturfaktor gruppe 11
                    1.00
                pa verbauinfo gruppe 12
                    not installed
                pa lichtfunktion gruppe 12
                    Door
                pa korrekturfaktor gruppe 12
                    1.00
                pa verbauinfo gruppe 13
                    not installed
                pa lichtfunktion gruppe 13
                    Door
                pa korrekturfaktor gruppe 13
                    1.00
                pa verbauinfo gruppe 14
                    not installed
                pa lichtfunktion gruppe 14
                    Door
                pa korrekturfaktor gruppe 14
                    1.00
                pa verbauinfo gruppe 15
                    not installed
                pa lichtfunktion gruppe 15
                    Door
                pa korrekturfaktor gruppe 15
                    1.00
            Suchbeleuchtung_Tasterdimmung
                tasterdimmung x0
                    0 ms
                tasterdimmung x1
                    2000 ms
                tasterdimmung x2
                    3000 ms
                tasterdimmung x3
                    4000 ms
                tasterdimmung x4
                    5100 ms
                tasterdimmung y0
                    1.0 %
                tasterdimmung y1
                    5.0
                tasterdimmung y2
                    15.0
                tasterdimmung y3
                    40.0
                tasterdimmung y4
                    100.0
            Suchbeleuchtung_Hochdimmen
                x0
                    0 ms
                x1
                    200 ms
                x2
                    400 ms
                x3
                    600 ms
                x4
                    800 ms
                x5
                    1000 ms
                x6
                    1200 ms
                x7
                    1400 ms
                x8
                    1600 ms
                x9
                    1800 ms
                x10
                    2000 ms
                y0
                    0.0 %
                y1
                    1.0 %
                y2
                    3.0 %
                y3
                    5.0 %
                y4
                    11.0 %
                y5
                    22.0 %
                y6
                    40.0 %
                y7
                    80.0 %
                y8
                    95.0 %
                y9
                    100.0 %
                y10
                    100.0 %
            Suchbeleuchtung_Abdimmen
                x0
                    0 ms
                x1
                    200 ms
                x2
                    400 ms
                x3
                    600 ms
                x4
                    800 ms
                x5
                    1000 ms
                x6
                    1200 ms
                x7
                    1400 ms
                x8
                    1600 ms
                x9
                    1800 ms
                x10
                    2000 ms
                y0
                    100.0 %
                y1
                    100.0 %
                y2
                    95.0 %
                y3
                    80.0 %
                y4
                    40.0 %
                y5
                    20.0 %
                y6
                    10.0 %
                y7
                    5.0 %
                y8
                    3.0 %
                y9
                    1.0 %
                y10
                    0.0 %
            Suchbeleuchtung_Fotosensor
                x0
                x1
                    50
                x2
                    100
                x3
                    200
                x4
                    253
                x5
                x6
                x7
                x8
                x9
                x10
                y0
                    0 lx
                y1
                    50 lx
                y2
                    100 lx
                y3
                    200
                y4
                    500
                y5
                y6
                    0 lx
                y7
                    0 lx
                y8
                    0 lx
                y9
                    0 lx
                y10
                    0 lx
            Suchbeleuchtung_KL 58xs min
                x0
                    0 lx
                x1
                    8 lx
                x2
                    50 lx
                x3
                    500 lx
                y0
                    6.0
                y1
                    6.0
                y2
                    100.0
                y3
                    100.0
            Suchbeleuchtung_KL 58xs max
                x0
                    0 lx
                x1
                    8 lx
                x2
                    50 lx
                x3
                    500 lx
                y0
                    100.0
                y1
                    100.0
                y2
                    100.0
                y3
                    100.0
            Suchbeleuchtung_KL_58xt min
                x0
                    0 lx
                x1
                    8 lx
                x2
                    50 lx
                x3
                    500 lx
                y0
                    6.0
                y1
                    6.0
                y2
                    100.0
                y3
                    100.0
            Suchbeleuchtung_KL_58xt_max
                x0
                    0 lx
                x1
                    8 lx
                x2
                    50 lx
                x3
                    500 lx
                y0
                    100.0
                y1
                    100.0
                y2
                    100.0
                y3
                    100.0
            Suchbeleuchtung_KL_58xd_min
                x0
                    0 lx
                x1
                    8 lx
                x2
                    220 lx
                x3
                    300 lx
                x4
                    500 lx
                y0
                    6.0
                y1
                    6.0
                y2
                    100.0
                y3
                    100.0
                y4
                    100.0
            Suchbeleuchtung_KL_58xd_max
                x0
                    0 lx
                x1
                    8 lx
                x2
                    200 lx
                x3
                    300 lx
                x4
                    500 lx
                y0
                    16.0
                y1
                    16.0
                y2
                    100.0
                y3
                    100.0
                y4
                    100.0
            Suchbeleuchtung_KL_58xd_log_Bus
                x0
                    0.0 %
                x1
                    6.0 %
                x2
                    16.0 %
                x3
                    30.0 %
                x4
                    60.0 %
                x5
                    100.0 %
                y0
                    10
                y1
                    10
                y2
                    100
                y3
                    150
                y4
                    220
                y5
                    253
            Dimmunt_KL_58xs_PWM
                x0
                    0.0 %
                x1
                    50.0 %
                x2
                    100.0 %
                y0
                    0.0 %
                y1
                    50.0 %
                y2
                    100.0 %
            Suchbeleuchtung_KL_58xt_PWM
                x0
                    0.0 %
                x1
                    50.0 %
                x2
                    100.0 %
                y0
                    0.0 %
                y1
                    50.0 %
                y2
                    100.0 %
            Suchbeleuchtung_KL_58xd_PWM
                x0
                x1
                    10
                x2
                    50
                x3
                    100
                x4
                    220
                x5
                    253
                y0
                    2.0 %
                y1
                    2.0 %
                y2
                    6.0 %
                y3
                    10.0 %
                y4
                    80.0 %
                y5
                    100.0 %
            Suchbeleuchtung_58_xs_Bus_Kennlinie
                x0
                    0.0 lx
                x1
                    8.0 lx
                x2
                    50.0 lx
                x3
                    80.0 lx
                x4
                    100.0 lx
                y0
                    6.0
                y1
                    6.0
                y2
                    20.0
                y3
                    50.0
                y4
                    100.0
            Suchbeleuchtung_58xt_Bus_Kennlinie
                x0
                    0.0 lx
                x1
                    8.0 lx
                x2
                    50.0 lx
                x3
                    80.0 lx
                x4
                    100.0 lx
                y0
                    6.0
                y1
                    6.0
                y2
                    20.0
                y3
                    50.0
                y4
                    100.0
            Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie
                x0
                    0 lx
                x1
                    10 lx
                x2
                    100 lx
                x3
                    500 lx
                x4
                    800 lx
                x5
                    1020 lx
                y0
                y1
                    20
                y2
                    86
                y3
                    180
                y4
                    300
                y5
                    500
            ZV allgemein
                Notschliessfunktion
                    active
                Funkfrequenz
                    315MHz
                Funk bei Klemme 15 ein
                    active
                ZV ohne Safe Funktion
                    installed
                Deaktivierung SAFE ueber DWA Deaktivierungstaster
                    active
                Entsafen mit autorisierte Klemme 15 Ein
                    active
                Bewusstes Safe mit 2. Betaetigung der FFB
                    not active
                Lock Unlock Taster direkt
                    not installed
                Lock Unlock Toggle Taster
                    not installed
                ZV Tuerentriegelung
                    Einzeltuerentriegelung
                Menuesteuerung Tuerentriegelung
                    active
                LS Taster Togglefunktion
                    not active
                Deaktivierung Laderaumschliessung extern
                    not active
                Nutzfahrzeug Schliessung
                    not active
                Wiederverriegelung Laderaum
                    Freigabe Softtouch
                Tankschloss
                    unidirectional
            ZV Türkonfiguration
                Viertuerer
                    Yes
                Fond Schloss
                    2-Motorenschloesser
                Schlosstyp NAR
                    Yes
                Schiebetueren Crafter
                    not installed
                Schiebetuerschloss direkt BCM
                    Driver side
                Schiebetuer Kontaktmodul Fahrerseite
                    not installed
                Schiebetuer Kontaktmodul Beifahrerseite
                    not installed
                Schiebetuer links
                    No
                Schiebetuer rechts
                    No
                Schliessung der Schiebetuer bei geoeffneter Tankklappe
                    not active
                HFT Invertierung Drehfallensignal
                    nicht invertiert
            ZV Heck
                Tausch Tank Hecktreiberausgang
                    No
                ZV Heck Schlosstyp
                    1- oder 2-Rasten-Hecksteller
                Heckschloss mit Vorraste
                    Yes
                Heckschloss Steuerung
                    Kontaktsteuerung
                Entriegelungwunsch verzoegert waehrend Zuziehvorgang
                    not active
                Heckdeckelentriegelung HDF Innentaster
                    not installed
                ZV entriegelt auch Heckdeckel
                    active
                Direkter Auswurf des Heckdeckels
                    not active
                Heckfreigabe Ohne Verzoegerung
                    active
                ZV Heck nur direkt auswerfen
                    not active
                Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster
                    not active
                Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt
                    not active
                Mindestbetaetigung HDF Innentaster
                    0.0 s
                Heckoeffnung ueber 2 Bedienhandlungen
                    active
            ZV Autolock
                Automatisches Verriegeln bei Geschwindigkeit
                    active
                automatisches Entriegeln
                    active
                Autounlock NAR
                    active
                Autolock Autounlock wirkt auf Heck
                    active
                Geschwindigkeitsabhaengige Tankdeckelverriegelung
                    not active
                Menuesteuerung ZV Autolock-Unlock
                    not active
            Schiebedach
                SAD Richtung Komfortoeffnen
                    tilting
                SAD Komfort schliessen
                    active
                SAD Komfort oeffnen
                    active
                Schiebedachmodul MD 1
                    installed
                Schiebedachmodul MD 3
                    not installed
                Schiebedachmodul MD Rollo
                    installed
                Verortung Schiebedachmodule
                    CAN
            Spiegelverstellung
                Spiegelabsenkung bei Rueckwaertsfahrt
                    not active
                Spiegelverstellung Synchron
                    not active
                Menuesteuerung Spiegelabsenkung
                    not active
                Funk Spiegelanklappen
                    not active
                Funk Spiegelanklappung Modus
                    by convenience operation via remote control key
                Menuesteuerung synchrone Spiegelverstellung
                    not active
                Menuesteuerung Funk Spiegel anklappen
                    not active
                Profilfunktion fuer Anklappung der Aussenspiegel
                    not active
                Signalisierung Spiegelanklappung
                    not active
                Spiegelanklappen bei Wiederverriegelung
                    not active
            ZV Crash
                Heckdeckel-Bedienstellen nachCrash temporaer sperren
                    active
                ZV-Entriegelung nach Seitencrash
                    active
                SAD PreCrash Konturschliessen
                    not active
            After-run for park light
                Bedingungen zur Beendigung des Standlichtnachlaufs
                    abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit
                ZV verriegeln bei Klemme 15 Ein
                    active
                Standlicht-Nachlaufzeit
                    30 min
            Seat fan charac. curve
                Level 1 Sitz
                    30 %
                Level 1 Lehne
                    30 %
                Level 2 Sitz
                    30 %
                Level 2 Lehne
                    30 %
                Level 3 Sitz
                    50 %
                Level 3 Lehne
                    50 %
                Level 4 Sitz
                    50 %
                Level 4 Lehne
                    50 %
                Level 5 Sitz
                    75 %
                Level 5 Lehne
                    75 %
                Level 6 Sitz
                    80 %
                Level 6 Lehne
                    80 %
                Sitzlueftung
                    not installed
                Sitzlueftung reduzierbar
                    installed
                Sitzpneumatik
                    not installed
            Characteristics in production mode
                Headlamp washer system
                    2000 ms
            Transport mode
                    active
                    not active
            Writing parameter
                Parameter address
                    FE0000
                value
                    130
            Read parameter address
                Parameter address
                    FE0000
            Vernetzungs- Diagnosefunktionen
                can msg 1
                can msg 2
                can msg 3
                can msg 4
                lin msg 1
                lin msg 2
                lin msg 3
                lin msg 4
                lin msg 5
                lin msg 6
                    not active
            Energy management
                Hybridfahrzeug
                    No
                Recuperation
                    active
                Energiemanagement Abschaltung
                    active
                Zweitbatterie
                    not installed
                Energy Management Adaptation
                    Energy management active
                Praediktives Energiemanagement
                    not active
                Hochvoltfahrzeug
                    not installed
            Kopfraumheizung
                blower speed
                temperature
                    -2
            Querschnitts_funktionen
                Lenkungsanordnung
                    Left
                Verkehrsseite
                    Right
                Brand
                    VW
                Personalisierungsuebernahme
                    installed
                Bedien und Anzeigeprotokoll
                    active
                Schnittstelle TrackingSystem
                    not active
                Codierungsabsicherung
                    not active
                CAN Wecken bei Softtouchbetaetigung
                    active
                Hardware Eingang Drucktankklappenstatus
                    Pin A31
                Klemmenfehler auf CAN ausgeben
                    active
                Fahrgeschwindigkeit aus ESP 21
                    active
                Hupe
                    Sollspannungsanforderung 13,5V
            Aktivierung_Entwicklungsdiagnose
                log dtc status
                    not active
                Reaktion LOG-DTC
                    First dtc
                log-dtc DFCC
            Leuchtweitenregulierung
                sensor headlight range control installed
                    not installed
                sLWR verbaut
                    not installed
                1 Sensor LWR
                    1-Sensor LWR
                Fahrwerk Variante
                    Variante 1
                sLWR bei Abblendlicht
                    active
                Quelle Hoehenwerte
                    BCM
                Aktivierung LWR Fehlerlampe
                    not active
                Logik PWM Signal
                    Negative
                sLWR nach Motorstart
                    not active
                Entprellung Fehlerlampe
                    10.0 s
                Fail Safe sLWR
                    0.0 %
                Zyklus sLWR
                    0.00 s
                sLWR Touristenlicht
                    -100.0 %
                sLWR SW Grad
                    0.0 %/s
                sLWR Hysterese
                    20.0 %
                diagnose soll toleranz
                    15 %
                Ansteuerung untere grenze
                    10.0 %
                Ansteuerung obere grenze
                    90.0 %
                Delay DC Motor Versorgung
                    -127.0 ms
                Lineare Abbildung
                    normal
                fac Pwm Zu Hoehe V 1
                    -8.00 mm/%
                fac Pwm Zu Hoehe H 1
                    -8.00 mm/%
                fac Pwm Zu Hoehe V 2
                    -8.00 mm/%
                fac Pwm Zu Hoehe H 2
                    -8.00 mm/%
                fac Pwm Zu Hoehe V 3
                    -8.00 mm/%
                fac Pwm Zu Hoehe H 3
                    -8.00 mm/%
                Achsabstand des Fahrzeuges
                    0 mm
                lwr lFzg Sw Abstand
                    0 mm
                lwr lFzg Sw Hoehe
                    0 mm
                pa fDynFiltStatLwr
                    100 Hz
                fFiltEinf
                    0.00 Hz
                pa fFiltSwNeigung
                    0.00 Hz
                lwr pwm untere schwelle
                    5.0 %
                lwr pwm obere schwelle
                    95.0 %
                max v slwr
                    0 km/h
                lwr lEinfOffsHFahrw 1
                    0 mm
                lwr lEinfOffsHFahrw 2
                    0 mm
                lwr lEinfOffsHFahrw 3
                    0 mm
                lwr lEinfOffsHFahrw 4
                    0 mm
            Activate left/right hand drive switch-over
                    not active
            Interior light, light configuration
                Ambiente Applikationsleisten in Tuertafel
                    not installed
                Ambiente Lautsprecher
                    not installed
                Ambiente Applikationsleisten in Instrumententafel
                    not installed
                Cockpitbeleuchtung
                    not installed
                Mittelkonsolenbeleuchtung
                    not installed
                Dachbeleuchtung
                    not installed
                Panoramaschiebedachbeleuchtung
                    not installed
                Fussraumbeleuchtung
                    not installed
                Farbwahl ueber HMI
                    not installed
                Farbwahl ueber Fahrprofil
                    not installed
                LIN-Dachkonsole lokal aktivierbar
                    not active
                Ambientemenue mit globalem aus
                    active
                Ambientemenue mit alle Zonen
                    active
                Ambient Farbliste HMI
                    active
                Frei Farbwahl ueber HMI
                    not active
                Ambience light colorlist default
            Ambience_lightning_color_list_2
                Rotwert Farbe 11
                Gruenwert Farbe 11
                Blauwert Farbe 11
                Rotwert Farbe 12
                Gruenwert Farbe 12
                Blauwert Farbe 12
                Rotwert Farbe 13
                Gruenwert Farbe 13
                Blauwert Farbe 13
                Rotwert Farbe 14
                Gruenwert Farbe 14
                Blauwert Farbe 14
                Rotwert Farbe 15
                Gruenwert Farbe 15
                Blauwert Farbe 15
                Rotwert Farbe 16
                Gruenwert Farbe 16
                Blauwert Farbe 16
                Rotwert Farbe 17
                Gruenwert Farbe 17
                Blauwert Farbe 17
                Rotwert Farbe 18
                Gruenwert Farbe 18
                Blauwert Farbe 18
                Rotwert Farbe 19
                Gruenwert Farbe 19
                Blauwert Farbe 19
                Rotwert Farbe 20
                Gruenwert Farbe 20
                Blauwert Farbe 20
                Rotwert Farbe 21
                Gruenwert Farbe 21
                Blauwert Farbe 21
                Rotwert Farbe 22
                Gruenwert Farbe 22
                Blauwert Farbe 22
                Rotwert Farbe 23
                Gruenwert Farbe 23
                Blauwert Farbe 23
                Rotwert Farbe 24
                Gruenwert Farbe 24
                Blauwert Farbe 24
                Rotwert Farbe 25
                Gruenwert Farbe 25
                Blauwert Farbe 25
                Rotwert Farbe 26
                Gruenwert Farbe 26
                Blauwert Farbe 26
                Rotwert Farbe 27
                Gruenwert Farbe 27
                Blauwert Farbe 27
                Rotwert Farbe 28
                Gruenwert Farbe 28
                Blauwert Farbe 28
                Rotwert Farbe 29
                Gruenwert Farbe 29
                Blauwert Farbe 29
                Rotwert Farbe 30
                Gruenwert Farbe 30
                Blauwert Farbe 30
            LIN Ambient light color list
                Rotwert Farbe 1 lin
                Gruenwert Farbe 1 lin
                Blauwert Farbe 1 lin
                Rotwert Farbe 2 lin
                Gruenwert Farbe 2 lin
                Blauwert Farbe 2 lin
                Rotwert Farbe 3 lin
                Gruenwert Farbe 3 lin
                Blauwert Farbe 3 lin
                Rotwert Farbe 4 lin
                Gruenwert Farbe 4 lin
                Blauwert Farbe 4 lin
                Rotwert Farbe 5 lin
                Gruenwert Farbe 5 lin
                Blauwert Farbe 5 lin
                Rotwert Farbe 6 lin
                Gruenwert Farbe 6 lin
                Blauwert Farbe 6 lin
                Rotwert Farbe 7 lin
                Gruenwert Farbe 7 lin
                Blauwert Farbe 7 lin
                Rotwert Farbe 8 lin
                Gruenwert Farbe 8 lin
                Blauwert Farbe 8 lin
                Rotwert Farbe 9 lin
                Gruenwert Farbe 9 lin
                Blauwert Farbe 9 lin
                Rotwert Farbe 10 lin
                Gruenwert Farbe 10 lin
                Blauwert Farbe 10 lin
            Ambience_lightning_color_list_lin_2
                Rotwert Farbe 11 lin
                Gruenwert Farbe 11 lin
                Blauwert Farbe 11 lin
                Rotwert Farbe 12 lin
                Gruenwert Farbe 12 lin
                Blauwert Farbe 12 lin
                Rotwert Farbe 13 lin
                Gruenwert Farbe 13 lin
                Blauwert Farbe 13 lin
                Rotwert Farbe 14 lin
                Gruenwert Farbe 14 lin
                Blauwert Farbe 14 lin
                Rotwert Farbe 15 lin
                Gruenwert Farbe 15 lin
                Blauwert Farbe 15 lin
                Rotwert Farbe 16 lin
                Gruenwert Farbe 16 lin
                Blauwert Farbe 16 lin
                Rotwert Farbe 17 lin
                Gruenwert Farbe 17 lin
                Blauwert Farbe 17 lin
                Rotwert Farbe 18 lin
                Gruenwert Farbe 18 lin
                Blauwert Farbe 18 lin
                Rotwert Farbe 19 lin
                Gruenwert Farbe 19 lin
                Blauwert Farbe 19 lin
                Rotwert Farbe 20 lin
                Gruenwert Farbe 20 lin
                Blauwert Farbe 20 lin
                Rotwert Farbe 21 lin
                Gruenwert Farbe 21 lin
                Blauwert Farbe 21 lin
                Rotwert Farbe 22 lin
                Gruenwert Farbe 22 lin
                Blauwert Farbe 22 lin
                Rotwert Farbe 23 lin
                Gruenwert Farbe 23 lin
                Blauwert Farbe 23 lin
                Rotwert Farbe 24 lin
                Gruenwert Farbe 24 lin
                Blauwert Farbe 24 lin
                Rotwert Farbe 25 lin
                Gruenwert Farbe 25 lin
                Blauwert Farbe 25 lin
                Rotwert Farbe 26 lin
                Gruenwert Farbe 26 lin
                Blauwert Farbe 26 lin
                Rotwert Farbe 27 lin
                Gruenwert Farbe 27 lin
                Blauwert Farbe 27 lin
                Rotwert Farbe 28 lin
                Gruenwert Farbe 28 lin
                Blauwert Farbe 28 lin
                Rotwert Farbe 29 lin
                Gruenwert Farbe 29 lin
                Blauwert Farbe 29 lin
                Rotwert Farbe 30 lin
                Gruenwert Farbe 30 lin
                Blauwert Farbe 30 lin
            Ambientelicht Zuordnung der Farbe zum Fahrprofil
                Fahrprofil 0
                Fahrprofil 1
                    4
                Fahrprofil 2
                Fahrprofil 3
                Fahrprofil 4
                    5
                Fahrprofil 5
                    7
                Fahrprofil 6
                    8
                Fahrprofil 7
                Fahrprofil 8
                    8
                Fahrprofil 9
                Fahrprofil 10
                Fahrprofil 11
                Fahrprofil 12
                Fahrprofil 13
                Fahrprofil 14
                Fahrprofil 15
                Ambiente
                    Keine Spannungsanforderung
            Suchbeleuchtung_allgemein
                Warnblinktastersuchbeleuchtung Aktivierung
                    always active
                Eingabemedium Suchbeleuchtung
                    HMI
                Umgebungs helligkeit auswahl
                    Fotosensor Kombi
                Warnblinktastersuchbeleuchtung Grundwert
                    6.0 %
                Warnblinktastersuchbeleuchtung Faktor
                    0.100
                KL58 Einschalten mit Rampe
                    active
                KL58 Verriegelungsausschalten
                    not active
                Lichtsensor wirkt auf Suchbeleuchtung
                    active
                Suchbeleuchtung Festwert
                    100 %
                PWM Daempfung Aufdimmen KL58xs PWM
                    0.00 s
                Daempfung Abdimmen KL 58xs PWM
                    0.00 s
                Daempfung Aufdimmen KL 58xt PWM
                    0.00 s
                Daempfung Abdimmen KL 58xt PWM
                    0.00 s
                Daempfung Aufdimmen KL 58xd PWM
                    0.00 s
                Daempfung Abdimmen KL 58xd PWM
                    0.00 s
                Helligkeit RLS Daempfung Aufdimmen
                    0.0 s
                Helligkeit RLS Daempfung Abdimmen
                    1.1 s
                pa Hysterese RLS
                    11
            Anti-theft device
                Alarmsignal
                    frequency modulated
                Verzoegerung Panikalarm
                    keine verzoegerung
                DWA Alarmverzoegerung
                    not active
                DWA Camper Modus
                    not active
                Ueberwachung Innenentriegelungshebel
                    not active
                Sirenen Alarmzahl
                    10 Alarme
                Akustischer Alarm Signalhorn
                    active
                IRUE NGS Deaktivierungstaster direkt am BCM verdrahtet
                    No
                Diebstahlwarnanlage
                    active
                Heckscheibenbruchsensor
                    not installed
                Deaktivierung DWA Sensoren HMI
                    not active
                DWA Einfachhorn oder Sounder
                    not installed
                tilt sensor
                    No
                Schliesszylinder in Richtung Oeffnen aktiv (Thatcham inaktiv)
                    No
                Sensor fuer Innenraumueberwachung
                    No
                Parking heater
                    not installed
                OBD Alarm
                    not active
                Deaktivierung DWA-Sensoren via Doppelklick
                    activ
                RHF Panikalarm
                    activ
            Front_wiper
                Frontwischertyp
                    direct
                Frontwischer Referenzlauf
                    active
                Variable Regensensoraktivierung
                    not active
                Wischer stop bei KL15 aus
                    not active
                Wischer abparken bei Oeffnen der Motorhaube
                    not active
                Regensensor aktivieren
                    Not deactivated
                Menuesteuerung Frontwischer
                    not active
                Frontwischer Notlaufprogramm
                    active
                Tippwischen mit erhoehter Wischfrequenz
                    active
                Geschwindigkeitsabhaengige Wischstufenrueckschaltung
                    active
                Traenenwischen Front Status
                    not active
                Washer Tipwiping Variant
                    not active
                Adaptives Nachwischen bei SRA
                    not active
                Wischer Stopp bei Oeffnen der Motorhaube
                    active
                Frontwischer Abtauposition
                    not active
                Anfahrzeit servicestellung
                    800 ms
                Mindestwaschzeit Frontwischer
                    0 ms
                Timer DWP SRA delay
                    300 ms
                Frontwischer Spannungsanforderung konfig
            Rear Window Wiper
                Heckwischer
                    logikgesteuert
                Komfortwischen Heck
                    active
                Menuesteuerung Komfortwischen HW
                    active
                Automatisches Heckwischen
                    not active
                Traenenwischen Heck
                    active
                Heckwischer Weiterlauf
                    not active
                Komofortwischen Heck Intervallpausenzeit Stufe Intervall
                    7 s
                Komofortwischen Heck Intervallpausenzeit Stufe Automatik
                    7 s
                Komofortwischen Heck Intervallpausenzeit Stufe 1
                    5 s
                Komofortwischen Heck Intervallpausenzeit Stufe 2
                    3 s
                Einzelansteuerung Heckintervallwischen Zeitintervall 1
                    8 s
                Einzelansteuerung Heckintervallwischen Zeitintervall 2
                    16 s
                    not active
                Zeit wasch min heck
                    0 ms
                Spannungsanforderung konfig Wischer
            Production mode
                Scheinwerferreinigung
                    not active
                Heckwischer
                    not active
                Innenbeleuchtung
                    not active
                Aussenbeleuchtung
                    not active
                Zugangskontrolle
                    not active
                Virtuel pedal
                    not active
            LIN-Mirrormode
                mirror mode typ
                    not active
                Data bus LIN 1
                    not active
                Data bus LIN 2
                    not active
                Data bus LIN 3
                    not active
                Data bus LIN 4
                    not active
                Data bus LIN 5
                    not active
                Data bus LIN 6
                    not active
            Personalisierung
                Personalisierung Profilfunkion
                    profiles active
                Profil Variante
                    Konto (v. 2.x)
                Personalisierung aktiv
                    active
                Aktivierungsoption im HMI-Menue sichtbar
                    active
                Benutzerkontenverwaltung in HMI-Menue sichtbar
                    active
                Personalisierungsfunktionen in HMI-Menue sichtbar
                    active
                Anzahl Benutzerkonten
                    7
                Automatische  Schluesselzuordnung
                    not active
                PSO FSG Setup2 Bit 1
                    active
                PSO FSG Setup2 Bit 2
                    not active
                PSO FSG Setup2 Bit 3
                    not active
                PSO FSG Setup2 Bit 4
                    not active
            LIN-SMLS_konfig_2
                Ignition key removal lock
                    not installed
                Buttons for multi-function display
                    not installed
                Rear Window Wiper
                    installed
                Driver assistance systems button
                    not installed
                CCS on turn signal switch
                    not installed
                CCS Switch
                    not installed
                Distance regulation
                    not installed
                Signal horn activation
                    Always
                Contact bounce suppression for signal horn
                    not active
                gra grahebel 2 st
                    installed
                speed limiter button
                    not installed
                diagnosis limitation
                    not active
                reading P locked
                    not active
            SMLS_konfig_entw
                blinker err el kurzschluss
                    200 ms
                blinker err el unterbrechung
                    1000 ms
                blinker err unplausibel
                    200 ms
                blinker err lichthupe haengt ein
                    300 s
                blinker err lichthupe haengt aus
                    5000 ms
                blinker err fernlicht haengt ein
                    300 s
                blinker err fernlicht haengt aus
                    5000 ms
                blinker err gra haengt ein
                    300 s
                blinker err gra haengt aus
                    5000 ms
                blinker err weckkontakthaengt ein
                    0 ms
                blinker err weckkontakthaengt aus
                    0 ms
                wischer err el kurzschluss
                    200 ms
                wischer err el unterbrechung
                    1000 ms
                wischer err unplausibel
                    200 ms
                wischer err mfa haengt ein
                    300 s
                wischer err mfa haengt aus
                    5000 ms
                grahebel err el kurzschluss
                    200 ms
                wischer err wischen haengt ein
                    300 s
                wischer err wischen haengt aus
                    5000 ms
                wischer err waschen haengt ein
                    300 s
                wischer err waschen haengt aus
                    5000 ms
                grahebel err el unterbrechung
                    1000 ms
                grahebel err unplausibel
                    200 ms
                grahebel err gra haengt ein
                    300 s
                grahebel err gra haengt aus
                    5000 ms
                hupe err hupe haengt ein
                    60 s
                hupe err hupe haengt aus
                    5000 ms
                hupe err hinweis
                    2000 ms
                verriegelt err el kurzschluss
                    0 ms
                verriegelt err unplausibel ein
                    0 ms
                verriegelt err unplausibel aus
                    0 ms
                verriegelt err unplausibel in parkposition ein
                    0 s
                verriegelt err unplausibel in parkposition aus
                    0 ms
                entprellzeit unterspannung
                    90000 ms
                entprellzeit ueberspannung
                    90000 ms
                spannung untere schwelle
                    8.5 V
                spannung obere schwelle
                    16.5 V
                wischer err intervallpoti haengt ein
                    0 s
                wischer err intervallpoti haengt aus
                    0.0 s
                spannung obere schwelle funkt einschr
                    15.5 V
                spannung untere schwelle funkt einschr
                    8.5 V
                gra ea error
                    200 ms
                entprellung unplausibel
                    0 ms
                n fehler verriegelt
                lrh kurzschluss entprellen
                    20 ms
                lrh unterbrechung entprellen
                    0 ms
                    0 s
                    0 ms
            Aussenlicht_Front
                Abblendlicht Leuchtentyp
                    H7
                Zahl der aktiven Scheinwerfer auf 2 limitieren
                    in Betrieb lassen
                Lichthupe bei Zuendung aus moeglich
                    active
                ABL Redundanz Check sperren
                    active
                Allwetterlicht Einschaltgrenze
                    350 km/h
                Allwetterlicht Ausschaltgrenze
                    350 km/h
                Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht
                    not active
                Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich
                    active
                Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge
                    active
                Standlicht aktiviert zusaetzlich Tagfahrlicht
                    active
                Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten
                    not active
                Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
                    active
                Tagfahrlichtkontrollleuchte
                    not active
                Fahrlicht bei Tag
                    Daytime running lights
                Tagfahrlicht nur in Schalterstellung AUTO
                    active
                Signaturlicht verbaut
                    not installed
                Signaturlicht HMI-default Anzeige im Kombiinstrument
                    not active
                TFL Abschaltung ueber Geschwindigkeit
                    not active
                Geschwindigkeitsabhaengiges TFL
                    5 km/h
            Lichttaster
                LTM BGL Wegabhängig
                    active
                LTM BGL Geschwindigkeitsabhängig
                    not active
                LTM BGL Geschwindigkeitsabhängig Parameter
                    active
                LTM Beleuchtung Geschwindigkeits Schwelle
                    30 km/h
                LTM GlobalOFF Wegabhängig
                    active
                LTM GlobalOFF Geschwindigkeitsabhängig
                    not active
                LTM GlobalOFF Zündungsabhängig
                    not active
                LTM GlobalOFF Geschwindigkeitsabhängig Parameter
                    active
                Beleuchtung LTM Auto LED 58xt logik
                    active
                Beleuchtung Auto LED bei Nebelfunktion
                    active
                Licht Reaktivierungs grenze
                    100 m
                LTM Anzeige Config
                Anzeigezeit LTM PopUp1
                    2.0 s
                Anzeigezeit LTM PopUp1 lang
                    10 s
                Licht anforderung Pilopark
                    not active
                Licht anforderung FAS
                    nicht verbaut
                Lichttastermodul
                    LDS
            Button in center console
                Function of button 1
                    Start-stop
                Function of button 2
                    not coded/not installed
                Function of button 3
                Function of button 4
                Zusatzcodierung Fahrprofiltaster hat keine LED
                    LED not installed
            Seat heater level current consumption allocation
                Sitzheizung Filterkonstante fuer Waermefluss
                    1 s
                Sitzheizung Regeltemperaturkorrektur bei Waermefluss
                    0.00 °C
                Sitzheizung Stufe 1 untere Schaltschwelle
                    24.50 °C
                Sitzheizung Stufe 1 obere Schaltschwelle
                    25.00 °C
                Sitzheizung Stufe 2 untere Schaltschwelle
                    24.50 °C
                Sitzheizung Stufe 2 obere Schaltschwelle
                    25.00 °C
                Sitzheizung Stufe 3 untere Schaltschwelle
                    37.50 °C
                Sitzheizung Stufe 3 obere Schaltschwelle
                    38.00 °C
                Sitzheizung Stufe 4 untere Schaltschwelle
                    37.50 °C
                Sitzheizung Stufe 4 obere Schaltschwelle
                    38.00 °C
                Sitzheizung Stufe 5 untere Schaltschwelle
                    57.50 °C
                Sitzheizung Stufe 5 obere Schaltschwelle
                    58.00 °C
                Sitzheizung Stufe 6 untere Schaltschwelle
                    57.50 °C
                Sitzheizung Stufe 6 obere Schaltschwelle
                    58.00 °C
                Spannungsoffset SIH 75
                    15.7 V
                SIH PWM Teiler
                Sitzheitzung CAN
                    Heizmatten am BCM
                Sitzheizungsfreigabe
                    not installed
                Sitzheizung.Regelbetrieb LO
                Sitzheizung.Aufheizphase HI
                    Sollspannungsanforderung 14,7V
            Window heater
                Heizbare Frontscheibe
                    not installed
                Heizbare Heckscheibe
                    installed
                Waschduesenheizung
                    installed
                Frontscheibenheizung LED direkt
                    not installed
                Frontscheibenheizungsansteuerung direkt von externem Algorithmus
                    not installed
                Temperaturabhaengige Einschaltzeit HSH
                    active
                Temperaturabhaengige Einschaltzeit FSH
                    active
                FSH Automatik
                    active
                Heckscheibenheizung Zeitwert
                    320 s
                Running time of heated front window
                    240 s
                Abschalttemperatur fuer Heckscheibenheizung
                    35.0 °C
                Abschalttemperatur fuer Frontscheibenheizung
                    35.0 °C
                Frontscheibenheizung  maximale Dauer
                    0 s
                window heating front activation time pause
                    320 s
                HZG Wischer Ablage
                    not installed
                WAH Temp Wischer aktiv
                    4.0 °C
            Verdecksteuergeraet
                Nachsaven nach Verdecklauf
                    not active
                Komfortbedienung Verdeck global
                    active
                Komfortbedienung Verdeck oeffnen
                    active
                Komfortbedienung Verdeck schliessen
                    active
                Verdeck oeffnen via Schliesszylinder
                    active
                Verdeck schliessen via Schliesszylinder
                    active
                Verdeck oeffnen via Funkfernbedienung
                    active
                Verdeck schliessen via Funkfernbedienung
                    active
                Verdeck oeffnen via Kessy
                    active
                Verdeck schliessen via Kessy
                    active
                Doppelpuls nur Verdeck
                    active
                Verdeck mit Schiebedach
                    not active
                Heckdeckel sperren bei Verdeckbetrieb
                    not active
                Softtouch-Betaetigung senden
                    immer
                Servoheck Schlossansteuerung
                    immer
                Reichweitenbegrenzung fuer Servoheck schliessen
                    not active
                Cabrio Verdeck
                    not installed
                trunk lid conrol unit
                    not installed
                Virtuelles Pedal Verbau
                    not installed
                Virtuelles Pedal
                    not active
                Virtuelles Pedal HMI einstellbar
                    not active
                easycloselight aktiv
                    not active
                Kick and close
                    not installed
                Virtuelles Pedal Version
                    Version 1 2
            Lenkstockschalter
                Verbauort Lenkstockschalter
                    LIN
                Geschwindigkeitesschwele erkennung fahrt P plausibel
                    10 km/h
                Zeit erkennung fahrt für P plausibel
                    1000 ms
                Anzahl fehler P-verriegelt
                    250
                Zeit t P-verriegelt entprellen
                    40 ms
            Allwetterlicht_Spoiler
                tt spoiler
                    not installed
                Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT
                    active
                Spoiler Einfahrunterdrueckung nach manuellem Ausfahren
                    active
            LIN-SMLS_konfig_1
                blinker entprellen
                    40 ms
                blinker gra entprellen
                    40 ms
                fas entprellen
                    40 ms
                wischer entprellen
                    40 ms
                wischer intervall entprellen
                    40 ms
                wischer winterstellung
                    60 s
                grahebel entprellen
                    40 ms
                hupe entprellen
                    40 ms
                    0 ms
                s NWDF spg
                hupe indien entprellen
                    500 ms
                blinker sperrzeit
                    100 ms
                speedlimiter entprellen
                    40 ms
                erkennung fahrt
                    10 ms
                grenze v
                    1 km/h
                soll 0
                    40 °C
                soll 1
                    45 °C
                soll 2
                    50 °C
                k i
                    0.50
                k p
                    25.0 %
                k i offset
                    5 °C
                temlenkradheizung aus
                    57 °C
                lrh entprellen
                    40 ms
                pwm lrh
                    25 Hz
                leistung lrh
                    110 W
                zeit temperatur statisch lrh
                    30 s
                w zss direktansteuerung
                    0 ms
            Vernetzung
                Klimaelektronik
                    installed
                Anhaengeranschlussgeraet
                    not installed
                Bremsen Steuergeraet
                    installed
                Getriebesteuergeraet
                    installed
                Kunden spezifisches Funktions SG
                    not installed
                Kopfraumheizung
                    not installed
            Aussenlicht_uebergreifend
                Light Control Module
                    not installed
                Kontrollleuchte fuer Begrenzungslicht
                    integriert in Suchbeleuchtung
                Standlicht aus
                    active
                Parklicht ueber LSS aktiviert
                    not active
                Standlichtreduzierung mit beidseitigem Parklicht
                    not active
                Menueeinstellung CHO LHO
                    Menuesteuerung Zeit aktivieren
                Faktor fuer Verfuegbarkeitstimer
                    Faktor fuer x5 Minuten
                Umfeldleuchte als Manoevrierleuchte
                    not active
                Fahrlichtwarnung Hinweis Konfig
                    Hinweis in LDS-Stellung Null und SL
                Fahrlicht Hinweis mehrfach
                    active
                Bedingungen zur Standlichtbegrenzung
                    abschaltbar über Energiemanagement
                Standlicht-Verfügbarkeit
                    24 s
                bewusstes Standlicht
                    Aktive Begrenzung
                Bedingungen zur Parklichtbegrenzung
                Lichtwarnungsverhalten
                    klemmenabhaengig
                Coming Home Verbaustatus
                    automatic
                Menuesteuerung Coming Home Werkseinstellung
                    active
                Coming home Leuchten
                    Low beam
                Menueeinstellung Cominghome
                    10 seconds
                CHo LHo Nachlauf
                    0 ms
                Licht Schaltung nach ECE48 Rev6
                    not active
                TFL Abschaltung nach ECE48 Rev6
                    No
                Coming-home Einschaltereignis
                    ignition
                Helligkeitsschwelle Infrarot-Messung
                    800 lx
                Leaving-Home Verbausstatus
                    Enabled
                Menuesteuerung Leaving-home Freischaltung per BAP
                    active
                LDS mit Nebellicht
                    No
                Lichtdrehschalter (LDS)
                    discrete
                Menueeinstellung Leaving-home Zeit per BAP
                    10 seconds
                Helligkeitsschwelle Forward-Messung
                    696 lx
                LDS mit Nebel Schlusslicht
                    No
                LDS mit AFL
                    Yes
                LDS mit Standlichtstellung
                    Yes
                HVLM Ladezustandsanzeige
                    No
                LCM blinker
                    TRUE
                Allwetterlicht
                    not installed
                ABL Abschaltung nach ECE48 Rev6
                    No
                Abblendlicht
                Fernlicht LH
                Nebellicht
                Blinker
            Aussenlicht_Blinker
                Warnblinken durch Fahrerassistenz
                    not active
                Komfortblinken Blinkzyklen
                    3
                Abbruch Komfortblinken
                    active
                Komfortblinken
                    active
                Blinkkontrolleuchte fuer Anhaenger
                    separte
                Schluessel Anlern Blinken
                    not active
                UGDO  Anlern Blinken
                    not active
                ZV Blinken zu
                    not active
                ZV Blinken auf
                    not active
                Telematikblinken1 STS Blinken Telematikblinken2 OCU Blinken
                    not active
                DWA Schaerfungsquittung
                    not active
                DWA Alarm Blinken
                    not active
                Taxialarmblinken
                    not active
                Panikblinken
                    not active
                Multi kollisions Blinken
                    not active
                Emergency alert blinken
                    not active
                Notwarn blinken NBA Phase 2
                    not active
                Rollenmodusblinken
                    not active
                Richtungs blinken rechts
                    not active
                Richtungs blinken links
                    not active
                ABBA Blinken
                    not active
                Crashblinken
                    not active
                Warnblinken Zuendung EIN
                    not active
                Warnblinken Zuendung AUS
                    not active
                Warnblinken TP max
                    120 min
                Dynamische Blink Delay
                    50 ms
                Fahrerassistenz Blinkenfunktionen
                    Warnblinke zulaessig
                PreCrash RECAS
                    PreCrash passiv
                Travel Assist Blinken
                    not active
            Int. light, 2nd generation
                Aufloesung Dimmzeit
                    0.10 s
                weicher Farbwechsel
                    not active
                Tuertafelbeleuchtung mehrfarbig
                    not active
                Instrumententafelbeleuchtung mehrfarbig
                    not active
                Cockpitbeleuchtung mehrfarbig
                    not active
                Lautsprecherbeleuchtung mehrfarbig
                    not active
                Mittelkonsolenbeleuchtung mehrfarbig
                    active
                Dachbeleuchtung mehrfarbig
                    not active
                Panoramaschiebedachbeleuchtung mehrfarbig
                    not active
                Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren
                    not active
                BAP Farbwert Farbe 1
                BAP Farbwert Farbe 2
                    3
                BAP Farbwert Farbe 3
                Defaultwert Ambienteprofil Mittelkonsole
                    50 %
                Defaultwert Ambienteprofil Dach
                    50 %
                Defaultwert Ambienteprofil Farbe
                Defaultwert Ambienteprofil Fussraum
                    50 %
                Defaultwert Ambienteprofil Tuer
                    50 %
                Defaultwert Ambienteprofil Vorn
                    50 %
                Ambiente Farbliste HMI mit Farbtransformation
                    not active
                Helligkeit Tuertafelbeleuchtung nicht berechnen
                    not active
                Helligkeit Instrumententafelbeleuchtung nicht berechnen
                    active
                Helligkeit Cockpitbeleuchtung nicht berechnen
                    not active
                Helligkeit Lautsprecherbeleuchtung nicht berechnen
                    active
                Helligkeit Mittelkonsolenbeleuchtung nicht berechnen
                    active
                Helligkeit Dachbeleuchtung nicht berechnen
                    active
                Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen
                    active
                Farbausgabe Tuertafelbeleuchtung nicht berechnen
                    not active
                Farbausgabe Instrumententafelbeleuchtung nicht berechnen
                    active
                Farbausgabe Cockpitbeleuchtung nicht berechnen
                    active
                Farbausgabe Lautsprecherbeleuchtung nicht berechnen
                    active
                Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen
                    active
                Farbausgabe Dachbeleuchtung nicht berechnen
                    active
                Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen
                    active
                Innenlicht bei offenem Heckdeckel einschalten
                    active
                KL30G ohne PWM
                    not active
                Weckfaehigkeit klemme 30G
                    installed
                LIN-Dachkonsole mit Flaechenlicht
                    not installed
                Tuerinnengriffbeleuchtung mit I-Tafel
                    not installed
                Tuerinnengriff mit Tuertafel
                    not installed
                Ambiente Farbwahl FPA waehlbare Kopplung
                    active
                Ambiente Fahrprofil Individual
                    7
                Ambiente Farbwahl FPA waehlbare Kopplung Status hmi default
                    coupled
                Innenlicht
                Ambiente Fahrprofil Offroad Individual
                    11
            Acknowledgement signals
                Optical feedback during locking
                    Decelerate
                Optische Rueckmeldung Komfortschliessen
                    active
                Optische Rueckmeldung 3.Bremsleuchte
                    not active
                Akustische Rueckmeldung global
                    active
                Akustische Rueckmeldung entriegeln
                    not active
                Akustische Rueckmeldung verriegeln
                    active
                Quittierton bei zweitem ZV-ZU-Befehl
                    active
                Menuesteuerung akustische Rueckmeldung
                    active
                Dauer der Akustischen Rueckmeldung vom Einfachhorn
                    kurz
                Akustische Rueckmeldung Signalhorn
                    active
                ZV-Blinken Hellzeit
                    250 ms
                ZV-Blinken Dunkelzeit
                    250 ms
                ZV-Blinken Abschluss Dunkelzeit
                    250 ms
            ZV Komfort
                Freigabenachlauf FH bei Kl 15 aus
                    active
                Freigabenachlauf FH bei Tueroeffnen abbrechen
                    not active
                Komfortbedienung global
                    active
                Comfort opening
                    active
                Komfortoeffnen nur FH Fahrertuer
                    not active
                Schliesszylinder Komfort oeffnen
                    not active
                Funk Komfort oeffnen
                    active
                Fahrertuerbedienung Fensterheber oeffnen
                    active
                FH SAD Kl15Aus Freigabezeit
                    600 s
                Comfort closing
                    active
                Schliesszylinder Komfort schliessen
                    not active
                Funk Komfort schliessen
                    active
                Fahrertuerbedienung Fensterheber schliessen
                    not active
                Menuesteuerung Komfortbedienung einstellbar
                    adjustable
                Regenschliessen ein aus
                    not active
                Regenschliessen art
                    once
                Menuesteuerung Regenschliessen
                    not active
                elektrischer Fensterheber hinten
                    Yes
            digital_key
                central locking digital key general
                    not installed
                komfortbedienung fh oeffnen ueber nfc fahrertuer
                    not active
                komfortbedienung fh schliessen ueber nfc fahrertuer
                    not active
                komfortbedienung fh oeffnen ueber btle
                    not active
                komfortbedienung fh schliessen ueber btle
                    not active
                komfortbedienung fh oeffnen ueber btle sonderfunktion
                    not active
                komfortbedienung fh schliessen ueber btle sonderfunktion
                    not active
                pa Two Keys
                    not active
            Rear_view_camera_wash
                RVC Wash
                    not installed
                RVC Speed max
                    50 km/h
                RVC Speed Hysteresis
                    5 km/h
                RVC Waschen HMI
                    not active
                RVC Time cleaning Pumpe active BCM
                    1.5 s
            Waschen_Parameter
                N RVC Activation
                    5
                T1 RVC Treshold
                    30 s
                T2 RVC Deactivation
                    180 s
                Scheinwerferreinigungsanlage
                    not installed
                SRA bei Waschwassermangel
                    active
                Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung
                    5
                SRA Verzoegerungszeit
                    30 ms
                SRA Waschzeit
                    2000 ms
                SRA Einweichpausenzeit
                    0 ms
                SRA Nachwaschzeit
                    0 ms
                SRA Pausenzeit
                    10000 ms
                Waschen
                Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung
            A/C heater function via remote control
                Remotestart
                    installed
                Rueckmeldung bei Aktivierung
                    active
                Kombi Fahrerhinweis m Uebernahme RSt
                    active
                Abbruch Hupen RSt
                    not active
                Abbruch d Warnblinker moeglich
                    active
                Kombi Fahrerhinweis m Akustik
                    active
                Aktivierung Drehzahlanzeige
                    active
                Remotestart externe FFB verbaut
                    not installed
                pa RSt MOD verbaut
                    installed
            Roller test bench mode, functional
                    not active
            Keyless access and start authorization
                Kessy
                    installed
                Elektische Lenkradverriegelung
                    not installed
                Kessy Komfort oeffnen
                    active
                Kessy Komfort schliessen
                    active
                Oeffnung Heckdeckel bei Wiederentriegelung
                    not active
                Kessy Komfortbedienung Reichweitenbegrenzung
                    active
                Kessy Bewegungsüberwachung IDGeber
                    active
                Kessy Protokollvariante EntryExit
                    active
                Kessy Ruhephase EntryExit
                    not active
            OCU
                OCU
                    installed
                DWA push
                    active
                Remote Unlock Lock
                    Via BAP / Fazit
                Honk DWA Ausgabe Fanfare
                    active
                IAA -Nutzer management
                    installed
                Remote Lock Unlock Timer s3
                    2000 ms
                Remote Lock Unlock Timer s1
                    80 s
                Remote HuF Abbruch
                    20 km/h
                Remote HuF Hupfrequenz
                    3 Hz
            UGDO
                ugdo transmitter
                    not installed
                ugdo via mmi configurable
                    not active
                Bedienfeld
                    not installed
                Anlernblinken
                    not active
            PKW-Schiebetueren
                PKW Schiebetuer HFS verbaut
                    No
                PKW Schiebetuer HBFS verbaut
                    No
                STSG HFS verbaut
                    No
                STSG HBFS verbaut
                    No
                PKW Schiebetuer HFS nachverriegeln
                    No
                PKW Schiebetuer HBFS nachverriegeln
                    No
                CAN TSG HFS verbaut
                    No
                CAN TSG HBFS verbaut
                    No
                SBT Entr im Zustand entriegelt
                    No
            Identification of sub-bus participant
                Control Unit For Wiper Motor
                    Not available
                Rain Light Recognition Sensor
                    Not available
                Light Switch
                    Not available
                Garage Door Opener Control Module
                    Not available
                Garage Door Opener Operating Unit
                    Not available
                Sensor For Anti Theft Alarm System
                    Not available
                Alarm Horn
                    Not available
                Sun Roof
                    Not available
                Ceiling Light Module
                    Not available
                Roof Blind
                    Not available
                Relative Air Humidity Interior Sender
                    Not available
                Neck Heating Left
                    Not available
                Neck Heating Right
                    Not available
                Seat Backrest Fan 1 Front Left
                    Not available
                Seat Cushion Fan 1 Front Left
                    Not available
                Seat Backrest Fan 1 Front Right
                    Not available
                Seat Cushion Fan 1 Front Right
                    Not available
                Steering Column Switch
                    Not available
                Remote Control
                    Not available
        Mileage: 21642 km
        Date: 2025-05-05 21:00:25
    Backup
        13 Adaptive Cruise Control
        System description: ACCCONTIMQB
        Software number: 2Q0907572AB
        Software version: 0397
        Hardware number: 2Q0907572B
        Hardware version: H04
        Backup name: Adaptive Cruise Control
        Long coding
            3000C70118FFC348949C812483578300000000000000000004
        Adaptations
                    Not activated
            Deactivate production mode
                    Deactivating
            Production mode
                    Deactivating
            Activating and deactivating all development messages
                Development Message S100
                    Off
                Development Message S101
                    Off
                Development Message S102
                    Off
                Development Message ECU specific
                    Off
                XCP on FlexRay
                    Off
            Distance basic setting option
                    On
            Expanded restart function
                    Off
            Presentation mode
                    not active
            Distance change via speed adjustment
                    On
            Prioritized target object display
                    Off
            Sail function
                    Deactivating
            Constant delay after transfer request
                    No
            Reduced radar performance
                    38
            Active participant function activated
                    activated
            Predictive speed limit regulation
                    activated
        Mileage: 21642 km
    Backup
        15 Airbag
        System description: AirbagVW21
        Software number: 5Q0959655CB
        Software version: 0421
        Hardware number: 5Q0959655CB
        Hardware version: 008
        Backup name: Airbag
        Long coding
            8CCCFC00000000005000001FC24800000065
        Adaptations
            Airbag adaptations
                Passenger airbag igniter
                    activated
                Driver airbag igniter
                    activated
                Front passenger side airbag igniter
                    activated
                Driver thorax airbag igniter
                    activated
                Front passenger rear thorax airbag igniter
                    not defined
                Driver side rear thorax airbag igniter
                    not defined
                Front passenger head curtain airbag igniter
                    activated
                Driver head curtain airbag igniter
                    activated
                Front passenger knee airbag igniter
                    not defined
                Driver knee airbag igniter
                    not defined
                Reserved
                    not defined
                Reserved
                    activated
                Pedestrian protection igniter engine hood
                    not defined
                Front passenger side seat belt tension igniter
                    activated
                Driver side seat belt tension igniter
                    activated
                Passenger side rear safety belt tension igniter
                    not defined
                Driver side rear safety belt tension igniter
                    not defined
                Igniter for battery interrupt
                    not defined
                Rollover protection system
                    not defined
                Key switch
                    Airbag deactivation key switch not parameterized
                Seat occupied recognition
                    not defined
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Igniter for battery interrupt, high voltage battery
                    not defined
                Reserved
                    activated
            Calibration data, pre-crash
                Raw-Data
            Adaptation airbag 2
                Reserved
                    not defined
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Assistance system monitor
                    activated
                Reserved
                    activated
        Mileage: 21642 km
    Backup
        17 Dashboard
        System description: KOMBI
        Software number: 17A920320B
        Software version: 6221
        Hardware number: 17A920320B
        Hardware version: 524
        Backup name: Dashboard
        Long coding
            09A4480827880008028076095000000820600904
        Adaptations
                    Not activated
            dimming_characteristic_curve_adjustment_clock_dial_day
                X1
                Y1
                    4
                X2
                    A
                Y2
                    4
                X3
                    32
                Y3
                    C
                X4
                    64
                Y4
                    14
                X5
                    96
                Y5
                    50
                X6
                    FD
                Y6
                    64
            dimming_characteristic_curve_adjustment_clock_dial_night
                X1
                Y1
                    4
                X2
                    A
                Y2
                    4
                X3
                    32
                Y3
                    C
                X4
                    64
                Y4
                    14
                X5
                    96
                Y5
                    50
                X6
                    FD
                Y6
                    64
            dimming_characteristic_curve_adjustment_bargraph_main_colour
                X1
                Y1
                X2
                    A
                Y2
                X3
                    32
                Y3
                    5
                X4
                    64
                Y4
                    8
                X5
                    96
                Y5
                    32
                X6
                    FD
                Y6
                    64
            dimming_characteristic_curve_adjustment_internal_phototransistor
                X1
                Y1
                X2
                    32
                Y2
                    28
                X3
                    64
                Y3
                    50
                X4
                    FA
                Y4
                    96
                X5
                    1F4
                Y5
                    FD
            time_parameter_display
                tDDWUP
                    1.55
                tDD15 on
                    0.00
                tDD15 off
                    0.15
                hmi t Dreiter ms
                    0.0 s
                hmi t dummyMenuTimeout ms
                    0 s
                hmi t UhrTimeout ms
                    0 s
                hmi t MenuTimeout ms
                    0 s
                hmi t TWSAnz ms
                    0 s
                hmi t NextWarning ms
                    0 s
                hmi t NextServiceAnz ms
                    0 s
                hmi t P2Pause ms
                    0 s
                hmi t Quit ms
                    0 s
                hmi t FondGurt
                    65 s
                hmi t USZ
                    0.00 s
                hmi t FTuerAUF
                    300 ms
                hmi t P1Pause ms
                    0 s
                rollierblockgroesse
            outside_temperature
                p time constant pt1
                    40 s
                p time constant slow damping
                    2.0
                p speed threshold
                    20 km/h
                p tendency threshold
                    1.0 °C
                p kmt at delta
                    25 °C
                p blocking time after v bigger 0
                    15 s
                p storage time engine off
                    180 min
                p mileage after v bigger 0
                    5.0 km
                p ice warning exit temperature
                    6 °C
                p ice warning entry temperature
                    4 °C
                p tendency damping
                    15 s
            Configuration of Development CAN-Messages
                Block 1
                    off
                Block 2
                    off
                Block 3
                    off
                Block 4
                    off
                Block 5
                    off
                Block 6
                    off
                Block 7
                    off
                Block 8
                    off
                Block 9
                    off
                Block 10
                    off
                Block 11
                    off
                Block 12
                    off
                Block 13
                    off
                Block 14
                    off
                Block 15
                    off
                Block 16
                    off
                Block 17
                    off
                Block 18
                    off
                Block 19
                    off
                Block 20
                    off
                Block 21
                    off
                Block 22
                    off
                Block 23
                    off
                Block 24
                    off
                Block 25
                    off
                Block 26
                    off
                Block 27
                    off
                Block 28
                    off
                Block 29
                    off
                Block 30
                    off
                Block 31
                    off
                Block 32
                    off
                Block 33
                    off
                Block 34
                    off
                Block 35
                    off
                Block 36
                    off
                Block 37
                    off
                Block 38
                    off
                Block 39
                    off
            Picture_Upload_Download
                Picture Upload Download
                    not active
            Illumination_algorithm
                Scale switching algorithm
                    auto lowbeam foglight
                Pointer illumination algorithim
                    terminal 58xd log bus parkinglight
            dimming_characteristic_curve_adjustment_fpk_middle_display_main_field
                X1
                Y1
                    C
                X2
                    A
                Y2
                    C
                X3
                    32
                Y3
                    23
                X4
                    64
                Y4
                    46
                X5
                    96
                Y5
                    1F4
                X6
                    FD
                Y6
                    3E8
            Statistic_phev_mileage
                    5 km
            Leaving_warning_delay
                Leaving warning delay
                    1.6 s
            Display_Save_CP
                    Yes
                send messages
                    not active
            Service-key settings
                p write delay time
                    40 s
                p write delay speed
                    20 km/h
                p write distance
                    20 km
                p forcewrite qual time
                    10 s
                p main switch Keyless
                    On
                p main switch Basic
                    On
                p deactivate SK Function
                    On
            Display depiction
                    Version 1
            Service notification
                    30 d
            Service_Key_Clear_All_Counter
                clear all counter
                    Yes
            BAP_Debug_Mode_Release
                Release
                    not released
            Gas_functionality
                Gas functionality
                    not active
            total_range_gas
                state
                    not active
                selection consumption factor
                    consumption factor CAN
                consumption profile
                    consumption profile calculation
                consumption factor
                    0.000
            defuel_threshold
                defuel threshold
                    9 L
            init_fuel_algorithm
                initialisation
                    No
            Distance
                    21648 km
            WIV: Resetting ESI
                    no warning
            Language version
                    US English
            Display correction of consumptions and operating range
                    100 %
            MFA3-Reset
                MFI button RESET / OK
                    Manual reset, not possible
                Refuel detection gasoline / diesel
                    MFA3-Reset
                    MFA3-Reset
                Electrical refueling detection
                    MFA3-Reset
            Hour
                    20 h
            Minute
                    58 min
            Year
                    2025 a
            Month
                    5 mon
            Day
                    5 d
            SIE: distance driven from inspection
                    5746 km
            SIE: time from inspection
                    127 d
            SIE: minimum value km-driving distance/inspection
                    15000 km
            SIE: maximum value km-driving distance/inspection
                    30000 km
            SIE: maximum value of time between inspections
                    730 d
            SIE: oil quality
                    Poor oil quality
            SIE: soot entry
                    0 km
            SIE: thermal load
                    12200 km
            Driving profiled for range remaining
                    9.7 l/100 km
            Offset for tank calibration values
                Offset sensor 1
                    -12.8 L
                Offset sensor 2
                    12.7 L
                Offset sensor 3
                    12.7 L
                Offset sensor 4
                    12.7 L
                Complete tank calibration
                    -12.8 L
            Units adjusted
                Temperature
                    °C
                Distance
                    Kilometers
                Speed
                    Kilometers per hour
                Pressure
                    Bar
                Volume
                    Liter
                Time
                    24h
                Date
                    dd mm yy
                Consumption gasoline / diesel - LPG (liquefied petroleum gas)
                    Liters per 100 km
                Operating range consumption, CNG (compressed natural gas)
                    kg per 100 km
                Average consumption, electric drive
                    kWh per 100 km
                Trailer/support load ground
                    Kilogram (kg)
            Speed warning
                    not active
                Unit
                    Kilometers per hour
                Speed
            Oil temperature display
                    On
            Day counter
                    125 d
            WIV: minimum value of time between inspections
                    365 d
            SIA: maximum value of distance to service
                    15000 km
            SIA: maximum value of time to service
                    365 d
            Fix: Max. distance until next mileage-related inspection
                    30000 km
            FIX: Maximum time until next time-dependent inspection
                    1095 d
            FIX: Distance covered since last mileage-dependent inspection
                    5700 km
            FIX: Time since last time-dependent inspection
                    127 d
            Source for synchronization of time
                    internal clock
            Deactivate seat belt warning
                    No
            Service notification in days
                    30 d
            FIX: Reset value for next mileage-dependent inspection
                    30000 km
            FIX: Reset value for next mileage-dependent inspections
                    365 d
            Ignition active message, actuator
                    All doors
            No-voltage display
                    Not available
            Cylinder shut-off
                    Display
            Display of colour adjustment
                Red
                Green
                Blue
                    Deactivating
            Production mode
                    No
                    No
            Display of longitudinal regulation coordinator
                Automatic distance regulation
                    active
                CCS
                    not active
                Speed limiter
                    not active
            dimming_characteristic_curve_adjustment_fpk_indicator_lights
                X1
                Y1
                    32
                X2
                    A
                Y2
                    32
                X3
                    32
                Y3
                    78
                X4
                    64
                Y4
                    E6
                X5
                    96
                Y5
                    1F4
                X6
                    FD
                Y6
                    3E8
            Driving profile display
                    No
            Tubes illustration
                    Version 0
            Second_digital_speed
                Secondary speed in case of unit replacement
                    No display
            Offroad
                    Display
            Sport
                    No display
            Lock display contents
                Lock infotainment list
                    No
                Lock function lists
                    No
                Lock MFA displays
                    No
                Dynamic image lock
                    No
                Lock functional animation
                    No
                Lock
                    No
                Lock system status animation
                    No
                Lock operating support animation
                    No
                List time out
                    0 s
                Map locked
                    No
                Vehicle model locked
                    No
                Piloted driving locked
                    No
                Cover intensity locked
                    100 %
                Number of list entries blocked
            Tachometer end value
                    Version 4
            Vehicle speed warning for India
                    No
                    60 s
            Active participant personalization
                    No
            China variant
                    No
            MDK_parameter
                Time Esm Aktiv
                    10 s
                Rep User Auth
                Veh Arch
                AZK bConfig COV
                AZK num Time resp KY
                    800 ms
                AZK num Time resp MDK
                    800 ms
                AZK num Time resp WFS
                    5000 ms
                MDK num Time Zv Cmd High
                    200 ms
                Time Out Mob Dev Key Cmd
                    30 s
                Time Out VTAN Resp
                    10 s
                Time Out Resp Apdu
                    500 s
                Rep Cmd Apdu
                Time SKC1
                    15 s
                Time Out VTAN Dec
                    2 s
                Time Out Ticket Table
                    120 s
                MDK num Time Zv Cmd Low
                    100 ms
            Digital key 3
                time for waiting of receive of message MDK ZV Resp
                    1F4 s
                number of repeats of authentication of central locking
            MDK_parameter_2
                Dev Param 1
                Dev Param 2
                    140232323232323202C8C8050A1E6401000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
            MDK_coding
            ACC illustration China
                    No display
            Shift exit warning
                    Car exit warning
            R logo
                    no R logo
            Activate/deactivate development messages via Ethernet
                send messages
                    not active
            gps_speed
                gps speed
                    not active
            3D_speed
                3D speed
                    not active
            Switching_Networking
                switching networking
                    Ethernet
        Mileage: 21642 km
    Backup
        19 Gateway
        System description: GW MQB High
        Software number: 3Q0907530AL
        Software version: 5463
        Hardware number: 3Q0907530E
        Backup name: Gateway
        Long coding
            030900047F085700FA0000C81C0F00010001070000000000000000000000
        Adaptations
            Installation list, specified installations
                Gateway
                    coded
                Node 0x01
                    Not coded
                Node 0x02
                    Not coded
                Node 0x03
                    Not coded
                Node 0x04
                    Not coded
                Node 0x05
                    Not coded
                Node 0x06
                    Not coded
                Node 0x07
                    Not coded
                Node 0x08
                    Not coded
                Multifunction Module
                    Not coded
                Parking Assistance
                    Not coded
                Tire Pressure Monitoring 1
                    Not coded
                Steering Column Electronics
                    Not coded
                Node 0x0D
                    Not coded
                Central Electrics
                    coded
                All Wheel Control
                    Not coded
                Node 0x11
                    Not coded
                Steering Assistance
                    coded
                Brakes 1
                    coded
                Dash Board
                    coded
                Airbag
                    coded
                Node 0x16
                    Not coded
                Node 0x17
                    Not coded
                Radio
                    Not coded
                Air Conditioning Compressor
                    Not coded
                Node 0x1A
                    Not coded
                Head Up Display
                    Not coded
                Actuator For Structure-Borne Sound
                    Not coded
                Node 0x1D
                    Not coded
                Lock Electronics
                    Not coded
                Node 0x1F
                    Not coded
                Node 0x20
                    Not coded
                Node 0x21
                    Not coded
                Node 0x22
                    Not coded
                Deck Lid Control Unit
                    Not coded
                Node 0x24
                    Not coded
                Node 0x25
                    Not coded
                Node 0x26
                    Not coded
                Node 0x27
                    Not coded
                Node 0x28
                    Not coded
                Node 0x29
                    Not coded
                Node 0x2A
                    Not coded
                Special Function 2
                    Not coded
                Special Function
                    Not coded
                Electronic Roof Control
                    Not coded
                Node 0x2E
                    Not coded
                Node 0x2F
                    Not coded
                High Beam Assistance
                    Not coded
                Steering Column Locking
                    Not coded
                Access Startsystem Interface
                    coded
                Sliding Door Rear Left
                    Not coded
                Sliding Door Rear Right
                    Not coded
                Node 0x35
                    Not coded
                Node 0x36
                    Not coded
                Node 0x37
                    Not coded
                Node 0x38
                    Not coded
                Node 0x39
                    Not coded
                Node 0x3A
                    Not coded
                Brake Boost
                    Not coded
                Node 0x3C
                    Not coded
                Node 0x3D
                    Not coded
                Door Electronics Rear Driver Side
                    Not coded
                Door Electronics Rear Passenger Side
                    Not coded
                Node 0x40
                    Not coded
                Node 0x41
                    Not coded
                Thermal Management
                    Not coded
                Node 0x43
                    Not coded
                Battery Charger Control Module
                    Not coded
                Node 0x45
                    Not coded
                Air Conditioning
                    coded
                Trailer Function
                    Not coded
                Node 0x48
                    Not coded
                Node 0x49
                    Not coded
                Door Electronics Driver Side
                    coded
                Door Electronics Passenger Side
                    coded
                Seat Adjustment Driver Side
                    Not coded
                Seat Adjustment Passenger Side
                    Not coded
                Lane Change Assistant
                    coded
                Front Sensors Driver Assistance System
                    Not coded
                Vehicle Position Detection
                    Not coded
                Node 0x51
                    Not coded
                Node 0x52
                    Not coded
                Node 0x53
                    Not coded
                Headlight Regulation
                    Not coded
                Node 0x55
                    Not coded
                Node 0x56
                    Not coded
                    coded
                Node 0x58
                    Not coded
                Node 0x59
                    Not coded
                Node 0x5A
                    Not coded
                Node 0x5B
                    Not coded
                Node 0x5C
                    Not coded
                Node 0x5D
                    Not coded
                Node 0x5E
                    Not coded
                Node 0x5F
                    Not coded
                Node 0x60
                    Not coded
                Node 0x61
                    Not coded
                Node 0x62
                    Not coded
                Microphone Control Unit
                    Not coded
                Actuator For Exterior Noise
                    Not coded
                High Voltage Battery Charge Management
                    Not coded
                Node 0x66
                    Not coded
                Telematics Communication Unit
                    coded
                Node 0x68
                    Not coded
                Camera System Rear View
                    Not coded
                Auxiliary Parking Heater
                    Not coded
                Node 0x6B
                    Not coded
                Node 0x6C
                    Not coded
                TV Tuner
                    Not coded
                Node 0x6E
                    Not coded
                Sound System
                    Not coded
                Media Player Position 1
                    Not coded
                Tachograph
                    Not coded
                Wheel Dampening Electronics
                    Not coded
                Information Control Unit 1
                    coded
                Node 0x74
                    Not coded
                Node 0x75
                    Not coded
                Engine Control Module 1
                    coded
                Transmission Control Module
                    coded
                Node 0x78
                    Not coded
                Node 0x79
                    Not coded
                Node 0x7A
                    Not coded
                Battery Energy Control Module
                    Not coded
                Drive Motor Control Module
                    Not coded
                Node 0x7D
                    Not coded
                Node 0x7E
                    Not coded
                Node 0x7F
                    Not coded
                Node 0x80
                    Not coded
                Node 0x81
                    Not coded
                Node 0x82
                    Not coded
                Node 0x83
                    Not coded
                Control Module For Sunroof
                    coded
                Starter / Generator Control Module
                    Not coded
                Node 0x86
                    Not coded
                Node 0x87
                    Not coded
                Node 0x88
                    Not coded
                Node 0x89
                    Not coded
                Control Unit Lane Change Assistant 2
                    Not coded
                Node 0x8B
                    Not coded
                Node 0x8C
                    Not coded
                Node 0x8D
                    Not coded
                Node 0x8E
                    Not coded
                Node 0x8F
                    Not coded
                Node 0x90
                    Not coded
                Node 0x91
                    Not coded
                Node 0x92
                    Not coded
                Node 0x93
                    Not coded
                Node 0x94
                    Not coded
                Node 0x95
                    Not coded
                Node 0x96
                    Not coded
                Node 0x97
                    Not coded
                Node 0x98
                    Not coded
                Node 0x99
                    Not coded
                Node 0x9A
                    Not coded
                Node 0x9B
                    Not coded
                Battery Energy Control Module 2
                    Not coded
                Node 0x9D
                    Not coded
                Node 0x9E
                    Not coded
                Node 0x9F
                    Not coded
                Node 0xA0
                    Not coded
                Node 0xA1
                    Not coded
                Node 0xA2
                    Not coded
                Node 0xA3
                    Not coded
                Auxiliary Air Heater
                    Not coded
                Node 0xA5
                    Not coded
                Node 0xA6
                    Not coded
                Node 0xA7
                    Not coded
                Node 0xA8
                    Not coded
                    Not coded
                Node 0xAA
                    Not coded
                Node 0xAB
                    Not coded
                Node 0xAC
                    Not coded
                Node 0xAD
                    Not coded
                Battery Regulation Auxiliary Accumulator 1
                    Not coded
                Node 0xAF
                    Not coded
                Node 0xB0
                    Not coded
                Node 0xB1
                    Not coded
                Node 0xB2
                    Not coded
                Node 0xB3
                    Not coded
                Node 0xB4
                    Not coded
                Node 0xB5
                    Not coded
                Node 0xB6
                    Not coded
                Node 0xB7
                    Not coded
                Node 0xB8
                    Not coded
                Node 0xB9
                    Not coded
                Node 0xBA
                    Not coded
                Node 0xBB
                    Not coded
                Node 0xBC
                    Not coded
                Node 0xBD
                    Not coded
                Node 0xBE
                    Not coded
                Node 0xBF
                    Not coded
                Node 0xC0
                    Not coded
                Node 0xC1
                    Not coded
                Node 0xC2
                    Not coded
                Node 0xC3
                    Not coded
                Node 0xC4
                    Not coded
                Node 0xC5
                    Not coded
                Node 0xC6
                    Not coded
                Node 0xC7
                    Not coded
                Node 0xC8
                    Not coded
                Node 0xC9
                    Not coded
                Node 0xCA
                    Not coded
                Node 0xCB
                    Not coded
                Node 0xCC
                    Not coded
                Node 0xCD
                    Not coded
                Node 0xCE
                    Not coded
                Node 0xCF
                    Not coded
                Node 0xD0
                    Not coded
                Node 0xD1
                    Not coded
                Node 0xD2
                    Not coded
                Node 0xD3
                    Not coded
                Node 0xD4
                    Not coded
                Node 0xD5
                    Not coded
                Node 0xD6
                    Not coded
                Node 0xD7
                    Not coded
                Node 0xD8
                    Not coded
                Node 0xD9
                    Not coded
                Node 0xDA
                    Not coded
                Node 0xDB
                    Not coded
                Node 0xDC
                    Not coded
                Node 0xDD
                    Not coded
                Node 0xDE
                    Not coded
                Node 0xDF
                    Not coded
                Node 0xE0
                    Not coded
                Node 0xE1
                    Not coded
                Node 0xE2
                    Not coded
                Node 0xE3
                    Not coded
                Node 0xE4
                    Not coded
                Node 0xE5
                    Not coded
                Node 0xE6
                    Not coded
                Node 0xE7
                    Not coded
                Node 0xE8
                    Not coded
                Node 0xE9
                    Not coded
                Node 0xEA
                    Not coded
                Node 0xEB
                    Not coded
                Node 0xEC
                    Not coded
                Node 0xED
                    Not coded
                Node 0xEE
                    Not coded
                Node 0xEF
                    Not coded
                Node 0xF0
                    Not coded
                Node 0xF1
                    Not coded
                Node 0xF2
                    Not coded
                Node 0xF3
                    Not coded
                Node 0xF4
                    Not coded
                Node 0xF5
                    Not coded
                Node 0xF6
                    Not coded
                Node 0xF7
                    Not coded
                Node 0xF8
                    Not coded
                Node 0xF9
                    Not coded
                Node 0xFA
                    Not coded
                Node 0xFB
                    Not coded
                Node 0xFC
                    Not coded
                Node 0xFD
                    Not coded
                Node 0xFE
                    Not coded
                Node 0xFF
                    Not coded
            Battery adaptation
                Rated battery capacity
                    59 Ah
                Battery manufacturer
                    JCB
                Battery serial number
                    1111111111
                Battery technology
                    EFB
            Static current measuring mode
                    Not activated
            Transport mode
                    not active
            GW_mirror_mode
                mirror mode bus
                    Databus drivetrain
                mirror mode typ
                    not active
            MKE Check box
                    Not activated
            WakeUpMonitor_Configuration
                Sample Time Keeping Awake Events
                    12 s
                Max Num Keeping Awake Events
                    100
                WakeUpMonitor Start Delay
                    0 s
                Max Num Logical WakeUp Events
                    20
                Max Num Physical WakeUp Events
                    20
                Open Filter Time
                    45 min
            WakeUpMonitor_Activation
                Activation
                    activated
                Open Filter Activate
                    activated
            Distance left for deactivation of static current measuring mode
            Distance left for deactivation of transport mode
                    50
            Deactivation of start-stop function
                    Mode not active
            Auxiliary heater activation restriction request
                Switch on ban activation
                    Mode not active
                Set point target time
            Energy management deactivation stage
                    Mode not active
            EM_energy_management_warning_displays
                Generatormeldungen
                    Mode not active
                Batteriemeldungen
                    Mode not active
                MMI Vorwarnungen
                    Mode not active
                Ladezustand
                    Mode not active
            Energy management heat output control status
                    Mode not active
            Increase idle speed request
                    Mode not active
            Battery terminal recognition
                    connected
            EM_nominal_voltage_limitation_low_beams
                    12.1 V
            Generator specified voltage value variable
                Set point voltage
                    10.6 V
            EM_requirement_reduction_air_blowers
                    Mode not active
            EM_requirement_cyclic_time_voltage_measurement
                    0 s
            Production mode
                p mode deactivate recuperation
                    Deactivating
                p mode deactivate mfl keys
                    Deactivating
                Development messages
                    not active
            Driving_Profile_Selection_Parameter
                Driving Profile Selection Toogle Time Adaptation
                    500 ms
                Driving Profile Selection Touch Contact Time Adaption
                    2500 ms
                Driving Profile Selection Indication Control Adaption
                    3000 ms
                Driving Profile Selection Kombi Offset Adaption
                    0 ms
                Driving Profile Selection Sync Time Adaptation
                    1500 ms
                Driving Profile Selection Request Repetition Time Adaptation
                    255000 ms
                Driving Profile Selection Fiddle Proofing Time Adaptation
                    10000 ms
                Driving Profile Selection Fiddle Proofing Limit Adaptation
                    100
                Driving Profile Selection Fiddle Proofing Lock Adaptation
                    60000 ms
                Driving Profile Selection Counter Master Reset
                    active
            Efficiency program display
                Live tip air resistance: close window/sunroof
                    activated
                Live tip engine brake: uncouple not until below 1300 RPM
                    activated
                Live tip do not operate gas pedal during engine start
                    activated
                Live tip adhere to switch display (only manual switch)
                    activated
                Live tip use start-stop-system
                    activated
                Live tip switch on start-stop-system
                    activated
                Live tip air conditioning: close window/sunroof
                    activated
                Live tip use gearshift position D
                    Not activated
                Live tip Do not press accelerator pedal at standstill
                    activated
                Live tip sunroof open: switch of A/C (AC button)
                    activated
                Live tip avoid engine warm-up at standstill
                    activated
                Comfort use A/C
                    activated
                Rear A/C System blower convenience consumption
                    activated
                Comfort use parking heater
                    activated
                Comfort use windshield heater
                    activated
                Comfort use rear window heater
                    activated
                Comfort use steering wheel heater
                    activated
                Comfort use rear heater
                    activated
                Comfort use mirror heater
                    activated
                Comfort use front seat heater
                    activated
                Comfort use rear seat heater
                    activated
                Comfort use front seat ventilation
                    activated
                Comfort use rear seat ventilation
                    activated
                Comfort use fog light
                    activated
                Comfort use rear fog light
                    Not activated
                Dependence of ECO tips on driver profile selection
                    ECO tips independent of driver profile selection
                Comfort use parking heater consumption emission
                    activated
                Convenience consumption outer mirror heater dependency
                    Until temperature threshold, with after-run, with switch
            Multi Function Steering Wheel Control Module
                Steering wheel tiptronic switch
                    installed
                Temperature sensor
                    installed
                Version
                    ACC
                clamp behaviour
                    active with terminal 58
                Steering wheel heating button
                    not active
                FoD ACC
                    activated
                FoD Travel Assist
                    activated
                Alarm horn wake-up function
                    not active
                    active
                Kombi 02 gueltig
                    not active
                Two-stage
                    not active
                Platform
                    MQB
            Production process data 1
            Counter for inconsistent states
                    408
            Start/stop start voltage limit
                    7.6 V
            Transfer of release code for a SWaP function
                    00
            Selection of release codes for a SWaP function
                    FFFFFFFF
            Range gain
                PTC(low voltage) consumption
                    Not activated
                Convenience consumption socket
                    Not activated
                Outer mirror heater consumption in rear window heating
                    Not activated
                Windshield heater consumption in AC system
                    Not activated
                List at engine still stand
                    activated
                List display absolute values with weighting
                    activated
                Catalogue range display
                    activated
                Loading condition catalogue range display
                    activated
                A/C System blower manual convenience consumption
                    activated
                Range gain AC system
                    activated
                Range gain auxiliary heater
                    activated
                Range gain window defogger
                    activated
                Range gain seat heater front
                    activated
                Range gain front set ventilation
                    activated
                Range gain rear heater
                    activated
                Range gain fog light
                    activated
                Range gain rear fog light
                    activated
                Range gain windshield heating
                    activated
                Range gain steering wheel heater
                    activated
                Range gain mirror heater
                    activated
                Range gain rear seat heater
                    activated
                    activated
                Windshield heater range gain in AC system
                    Not activated
                PTC(low voltage) range gain
                    Not activated
            Number requests autonomous recharging
                    3
            Cyclization limitation request battery service
            EM_heating_power_quota_adjustment
                    1000 W
            GW_Enable_CAN_Timeout_DTC
                Gateway
                    enabled
                Gateway Component List Failure Mask Node 0x01
                    enabled
                Gateway Component List Failure Mask Node 0x02
                    enabled
                Gateway Component List Failure Mask Node 0x03
                    enabled
                Gateway Component List Failure Mask Node 0x04
                    enabled
                Gateway Component List Failure Mask Node 0x05
                    enabled
                Gateway Component List Failure Mask Node 0x06
                    enabled
                Gateway Component List Failure Mask Node 0x07
                    enabled
                Gateway Component List Failure Mask Node 0x08
                    enabled
                    enabled
                Parking Assistance
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x0D
                    enabled
                Central Electrics
                    enabled
                All Wheel Control
                    enabled
                Gateway Component List Failure Mask Node 0x11
                    enabled
                Steering Assistance
                    enabled
                Brakes 1
                    not enabled
                Dash Board
                    enabled
                Airbag
                    not enabled
                Gateway Component List Failure Mask Node 0x16
                    enabled
                Gateway Component List Failure Mask Node 0x17
                    enabled
                Radio
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x1A
                    enabled
                Head Up Display
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x1D
                    enabled
                Lock Electronics
                    enabled
                Gateway Component List Failure Mask Node 0x1F
                    enabled
                Gateway Component List Failure Mask Node 0x20
                    enabled
                Gateway Component List Failure Mask Node 0x21
                    enabled
                Gateway Component List Failure Mask Node 0x22
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x24
                    enabled
                Gateway Component List Failure Mask Node 0x25
                    enabled
                Gateway Component List Failure Mask Node 0x26
                    enabled
                Gateway Component List Failure Mask Node 0x27
                    enabled
                Gateway Component List Failure Mask Node 0x28
                    enabled
                Gateway Component List Failure Mask Node 0x29
                    enabled
                Gateway Component List Failure Mask Node 0x2A
                    enabled
                Special Function 2
                    enabled
                Special Function
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x2E
                    enabled
                Gateway Component List Failure Mask Node 0x2F
                    enabled
                    enabled
                    enabled
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x35
                    enabled
                Gateway Component List Failure Mask Node 0x36
                    enabled
                Gateway Component List Failure Mask Node 0x37
                    enabled
                Gateway Component List Failure Mask Node 0x38
                    enabled
                Gateway Component List Failure Mask Node 0x39
                    enabled
                Gateway Component List Failure Mask Node 0x3A
                    enabled
                Brake Boost
                    enabled
                Gateway Component List Failure Mask Node 0x3C
                    enabled
                Gateway Component List Failure Mask Node 0x3D
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x40
                    enabled
                Gateway Component List Failure Mask Node 0x41
                    enabled
                Thermal Management
                    enabled
                Gateway Component List Failure Mask Node 0x43
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x45
                    enabled
                Air Conditioning
                    enabled
                Trailer Function
                    enabled
                Gateway Component List Failure Mask Node 0x48
                    enabled
                Gateway Component List Failure Mask Node 0x49
                    enabled
                    enabled
                    enabled
                    enabled
                    enabled
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x51
                    enabled
                Gateway Component List Failure Mask Node 0x52
                    enabled
                Gateway Component List Failure Mask Node 0x53
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x55
                    enabled
                Gateway Component List Failure Mask Node 0x56
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x58
                    enabled
                Gateway Component List Failure Mask Node 0x59
                    enabled
                Gateway Component List Failure Mask Node 0x5A
                    enabled
                Gateway Component List Failure Mask Node 0x5B
                    enabled
                Gateway Component List Failure Mask Node 0x5C
                    enabled
                Gateway Component List Failure Mask Node 0x5D
                    enabled
                Gateway Component List Failure Mask Node 0x5E
                    enabled
                Gateway Component List Failure Mask Node 0x5F
                    enabled
                Gateway Component List Failure Mask Node 0x60
                    enabled
                Gateway Component List Failure Mask Node 0x61
                    enabled
                Gateway Component List Failure Mask Node 0x62
                    enabled
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x66
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x68
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x6B
                    enabled
                Gateway Component List Failure Mask Node 0x6C
                    enabled
                TV Tuner
                    enabled
                Gateway Component List Failure Mask Node 0x6E
                    enabled
                Sound System
                    enabled
                    enabled
                Tachograph
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x74
                    enabled
                Gateway Component List Failure Mask Node 0x75
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x78
                    enabled
                Gateway Component List Failure Mask Node 0x79
                    enabled
                Gateway Component List Failure Mask Node 0x7A
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x7D
                    enabled
                Gateway Component List Failure Mask Node 0x7E
                    enabled
                Gateway Component List Failure Mask Node 0x7F
                    enabled
                Gateway Component List Failure Mask Node 0x80
                    enabled
                Gateway Component List Failure Mask Node 0x81
                    enabled
                Gateway Component List Failure Mask Node 0x82
                    enabled
                Gateway Component List Failure Mask Node 0x83
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x86
                    enabled
                Gateway Component List Failure Mask Node 0x87
                    enabled
                Gateway Component List Failure Mask Node 0x88
                    enabled
                Gateway Component List Failure Mask Node 0x89
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x8B
                    enabled
                Gateway Component List Failure Mask Node 0x8C
                    enabled
                Gateway Component List Failure Mask Node 0x8D
                    enabled
                Gateway Component List Failure Mask Node 0x8E
                    enabled
                Gateway Component List Failure Mask Node 0x8F
                    enabled
                Gateway Component List Failure Mask Node 0x90
                    enabled
                Gateway Component List Failure Mask Node 0x91
                    enabled
                Gateway Component List Failure Mask Node 0x92
                    enabled
                Gateway Component List Failure Mask Node 0x93
                    enabled
                Gateway Component List Failure Mask Node 0x94
                    enabled
                Gateway Component List Failure Mask Node 0x95
                    enabled
                Gateway Component List Failure Mask Node 0x96
                    enabled
                Gateway Component List Failure Mask Node 0x97
                    enabled
                Gateway Component List Failure Mask Node 0x98
                    enabled
                Gateway Component List Failure Mask Node 0x99
                    enabled
                Gateway Component List Failure Mask Node 0x9A
                    enabled
                Gateway Component List Failure Mask Node 0x9B
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x9D
                    enabled
                Gateway Component List Failure Mask Node 0x9E
                    enabled
                Gateway Component List Failure Mask Node 0x9F
                    enabled
                Gateway Component List Failure Mask Node 0xA0
                    enabled
                Gateway Component List Failure Mask Node 0xA1
                    enabled
                Gateway Component List Failure Mask Node 0xA2
                    enabled
                Gateway Component List Failure Mask Node 0xA3
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0xA5
                    enabled
                Gateway Component List Failure Mask Node 0xA6
                    enabled
                Gateway Component List Failure Mask Node 0xA7
                    enabled
                Gateway Component List Failure Mask Node 0xA8
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0xAA
                    enabled
                Gateway Component List Failure Mask Node 0xAB
                    enabled
                Gateway Component List Failure Mask Node 0xAC
                    enabled
                Gateway Component List Failure Mask Node 0xAD
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0xAF
                    enabled
                Gateway Component List Failure Mask Node 0xB0
                    enabled
                Gateway Component List Failure Mask Node 0xB1
                    enabled
                Gateway Component List Failure Mask Node 0xB2
                    enabled
                Gateway Component List Failure Mask Node 0xB3
                    enabled
                Gateway Component List Failure Mask Node 0xB4
                    enabled
                Gateway Component List Failure Mask Node 0xB5
                    enabled
                Gateway Component List Failure Mask Node 0xB6
                    enabled
                Gateway Component List Failure Mask Node 0xB7
                    enabled
                Gateway Component List Failure Mask Node 0xB8
                    enabled
                Gateway Component List Failure Mask Node 0xB9
                    enabled
                Gateway Component List Failure Mask Node 0xBA
                    enabled
                Gateway Component List Failure Mask Node 0xBB
                    enabled
                Gateway Component List Failure Mask Node 0xBC
                    enabled
                Gateway Component List Failure Mask Node 0xBD
                    enabled
                Gateway Component List Failure Mask Node 0xBE
                    enabled
                Gateway Component List Failure Mask Node 0xBF
                    enabled
                Gateway Component List Failure Mask Node 0xC0
                    enabled
                Gateway Component List Failure Mask Node 0xC1
                    enabled
                Gateway Component List Failure Mask Node 0xC2
                    enabled
                Gateway Component List Failure Mask Node 0xC3
                    enabled
                Gateway Component List Failure Mask Node 0xC4
                    enabled
                Gateway Component List Failure Mask Node 0xC5
                    enabled
                Gateway Component List Failure Mask Node 0xC6
                    enabled
                Gateway Component List Failure Mask Node 0xC7
                    enabled
                Gateway Component List Failure Mask Node 0xC8
                    enabled
                Gateway Component List Failure Mask Node 0xC9
                    enabled
                Gateway Component List Failure Mask Node 0xCA
                    enabled
                Gateway Component List Failure Mask Node 0xCB
                    enabled
                Gateway Component List Failure Mask Node 0xCC
                    enabled
                Gateway Component List Failure Mask Node 0xCD
                    enabled
                Gateway Component List Failure Mask Node 0xCE
                    enabled
                Gateway Component List Failure Mask Node 0xCF
                    enabled
                Gateway Component List Failure Mask Node 0xD0
                    enabled
                Gateway Component List Failure Mask Node 0xD1
                    enabled
                Gateway Component List Failure Mask Node 0xD2
                    enabled
                Gateway Component List Failure Mask Node 0xD3
                    enabled
                Gateway Component List Failure Mask Node 0xD4
                    enabled
                Gateway Component List Failure Mask Node 0xD5
                    enabled
                Gateway Component List Failure Mask Node 0xD6
                    enabled
                Gateway Component List Failure Mask Node 0xD7
                    enabled
                Gateway Component List Failure Mask Node 0xD8
                    enabled
                Gateway Component List Failure Mask Node 0xD9
                    enabled
                Gateway Component List Failure Mask Node 0xDA
                    enabled
                Gateway Component List Failure Mask Node 0xDB
                    enabled
                Gateway Component List Failure Mask Node 0xDC
                    enabled
                Gateway Component List Failure Mask Node 0xDD
                    enabled
                Gateway Component List Failure Mask Node 0xDE
                    enabled
                Gateway Component List Failure Mask Node 0xDF
                    enabled
                Gateway Component List Failure Mask Node 0xE0
                    enabled
                Gateway Component List Failure Mask Node 0xE1
                    enabled
                Gateway Component List Failure Mask Node 0xE2
                    enabled
                Gateway Component List Failure Mask Node 0xE3
                    enabled
                Gateway Component List Failure Mask Node 0xE4
                    enabled
                Gateway Component List Failure Mask Node 0xE5
                    enabled
                Gateway Component List Failure Mask Node 0xE6
                    enabled
                Gateway Component List Failure Mask Node 0xE7
                    enabled
                Gateway Component List Failure Mask Node 0xE8
                    enabled
                Gateway Component List Failure Mask Node 0xE9
                    enabled
                Gateway Component List Failure Mask Node 0xEA
                    enabled
                Gateway Component List Failure Mask Node 0xEB
                    enabled
                Gateway Component List Failure Mask Node 0xEC
                    enabled
                Gateway Component List Failure Mask Node 0xED
                    enabled
                Gateway Component List Failure Mask Node 0xEE
                    enabled
                Gateway Component List Failure Mask Node 0xEF
                    enabled
                Gateway Component List Failure Mask Node 0xF0
                    enabled
                Gateway Component List Failure Mask Node 0xF1
                    enabled
                Gateway Component List Failure Mask Node 0xF2
                    enabled
                Gateway Component List Failure Mask Node 0xF3
                    enabled
                Gateway Component List Failure Mask Node 0xF4
                    enabled
                Gateway Component List Failure Mask Node 0xF5
                    enabled
                Gateway Component List Failure Mask Node 0xF6
                    enabled
                Gateway Component List Failure Mask Node 0xF7
                    enabled
                Gateway Component List Failure Mask Node 0xF8
                    enabled
                Gateway Component List Failure Mask Node 0xF9
                    enabled
                Gateway Component List Failure Mask Node 0xFA
                    enabled
                Gateway Component List Failure Mask Node 0xFB
                    enabled
                Gateway Component List Failure Mask Node 0xFC
                    enabled
                Gateway Component List Failure Mask Node 0xFD
                    enabled
                Gateway Component List Failure Mask Node 0xFE
                    enabled
                Gateway Component List Failure Mask Node 0xFF
                    enabled
                Gateway Component List Failure Mask Node 0x00
                    enabled
            Security version number
                    3
            48V-System, locking
                    Regular operation
            MVK_Warning
                    Regular operation
            MV-EM_adaption_48V_zero_potential
                    Regular operation
            Diagnosis filter, activation
                    active
            Diagnosis filter, kilometer thresholds
                Kilometer threshold, production
                    200 km
                Kilometer threshold, customer service
                    20 km
            Multifunction steering wheel extended adaptation
                steering wheel rim configuration
                    Configuration 4
        Mileage: 21642 km
    Backup
        3C Lane Change Assistant Right
        System description: HRE3_Kl15_Mst
        Software number: 2Q0907686B
        Software version: 0150
        Hardware number: 2Q0907686B
        Hardware version: H07
        Backup name: Lane Change Assistant Right
        Long coding
            5294C620
        Adaptations
            Analysis 15
                    FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            Production mode
                    Off
                Deactivation of lane change assistance and exit warning
                    not active
                Deactivation of Cross traffic assistant rear and pre sense rear
                    not active
                Parking lock, malfunction
                    not active
                    Deactivating
            lane change assist. control module calibration values
                    -10.24 °
            lane change assist. control module 2 calibration values
                    -10.24 °
                Group 2
                    Not activated
                Group 3
                    Not activated
            Test bench data for calibration, production
                Transverse position, vehicle, front axle
                    0 mm
                Transverse position, vehicle, rear axle
                    0 mm
                Body height left front wheel house edge
                    0.00 mm
                Body height right front wheel house edge
                    0.00 mm
                Body height left rear wheel house edge
                    0.00 mm
                Body height right rear wheel house edge
                    0.00 mm
                Y-coordinate, Doppler simulator, left
                    0 mm
                Z-coordinate, Doppler simulator, left
                    0.00 mm
                X-coordinate, Doppler simulator, right
                    0 mm
                Y-coordinate, Doppler simulator, right
                    0 mm
                Z-coordinate, Doppler simulator, right
                    0.00 mm
                X-coordinate, Doppler simulator, left
                    0 mm
                    Not activated
        Mileage: 21642 km
        Date: 2025-05-05 21:00:26
    Backup
        42 Driver Door
        System description: TSG FS
        Software number: 5Q4959393N
        Software version: 0820
        Hardware number: 5Q4959393N
        Backup name: Driver Door
        Long coding
            003017200000028008000000
        Adaptations
            Production mode
                Reduce reverse threshold
                    Deactivating
                Activate test mode for the fold-in mirror
                    Deactivating
                Deactivate speed control for power windows
                    Deactivating
                Reduce switch-on time of lighting
                    Deactivating
                Power windows operable with terminal 15 off
                    Deactivating
                Activate test mode for power windows
                    Deactivating
                Deactivate closing aid
                    Deactivating
                Deactivation of actuation of opening assistance motor, e-lock
                    Deactivating
                Deactivation of CarWakeUp due to activation of seatbelt feeder
                    Deactivating
                    Deactivating
            Reversing_Threshold_Driver_Side_Front
                    90 %
            Reversing_Threshold_Driver_Side_Rear
                    90 %
            Window_Regulator_VW_Settings_Driver_Side_Rear
                Window Regulator VW Settings Driver Side
                    14041A03521F13001414002800230384017C02580A7D081E2600323200F000000000000000E300DA3F059C4E204D581D00004E44A74D9F320A9C1F9C000000000000000000FA000034513031030000000000000000004B7D
            Window_Regulator_Supplier_Settings_Driver_Side_Rear_1
                Parameter 1
                    6D4E2702000018247F7C029A150D2A7A040F1E180700053E2303061428AA0000185AAA070903050000006E96641E0A68040000007300043D4CC0020C14285264D314C887464646468780A39992121212A33202010E050928000004A41EF5FF1E230C1E5A5F0A50963C0096960500000001014C0000020305147533000000
                Parameter 2
                    682E
            Patch_Code_Driver_Side_Rear
                Parameter 1
                    000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000004F9701044F0C08034D15203D0464000000000000000000C23204
                Parameter 2
                    3348
        Mileage: 21642 km
    Backup
        44 Steering Assistance
        System description: EPS_MQB_ZFLS
        Software number: 5QM909144C
        Software version: 1082
        Hardware number: 5QM909144B
        Hardware version: 173
        Backup name: Steering Assistance
        Long coding
            051F0000
        Adaptations
                    not active
            Characteristic curve of steering assistance
                    Dynamic
            Activation of pwr steering asst without engine running
                    not active
            XCP calibration protocol
                    not active
            Software end stop
                    active
            Straight line running
                    active
            Support power
                    100%
            Driving profile switchover
                    Direct, controlled over threshold value
            Download without rest bus
                Suspension data bus
                    not active
            RPM monitoring
                    active
        Mileage: 21642 km
    Backup
        52 Passenger Door
        System description: TSG BFS
        Software number: 5Q4959392N
        Hardware number: 5Q4959392N
        Backup name: Passenger Door
        Long coding
            003013200000028000000000
        Adaptations
            Production mode
                    Deactivating
                    Deactivating
                    Deactivating
                    Deactivating
                    Deactivating
                    Deactivating
                    Deactivating
                    Deactivating
                    Deactivating
                    Deactivating
            Reversing_Threshold_Passenger_Side_Front
                    90 %
            Reversing_Threshold_Passenger_Side_Rear
                    90 %
            Window_Regulator_VW_Settings_Passenger_Side_Rear
                    14041A03521F13001414002800230384017C02580A7D081E2600323200F000000000000000E300DA3F059C4E204D581D0C0C4E44A74D9F320A9C1F9C000000000000000000FA000034513031030000000000000000008EBD
            Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1
                Parameter 1
                    674E2702000018247F7C029A150D2A7A040F1E180700053E2303061428AA0000185AAA070903050000006E96641E0A68040000007300043D4CC0020C14285264D314C887464646468780A39992121212A33202010E050928000004A41EF5FF1E230C1E5A5F0A50963C0096960500000002014C0000020305147533000000
                Parameter 2
                    46C3
            Patch_Code_Passenger_Side_Rear
                Parameter 1
                Parameter 2
                    3348
        Mileage: 21642 km
    Backup
        5F Multimedia
        System description: MU-O-NS-US
        Software number: 3G5035842B
        Software version: 0841
        Hardware number: 3G5035842
        Hardware version: H56
        Backup name: Multimedia
        Long coding
            23165000002000000000000000000000000000000000000000
        Adaptations
                Data bus
                    Off
                Local data bus
                    Off
            Audio management input gain
                TV tuner
                    -128 dB(A)
                Radio (FM)
                    -128 dB(A)
                Radio (AM)
                    -128 dB(A)
                Digital radio (DAB)
                    -128 dB(A)
                Satellite radio
                    -128 dB(A)
                Tuner TI
                    -128 dB(A)
                Media AUXIN
                    -128 dB(A)
                Media AUX Adapter
                    -128 dB(A)
                Media CDA
                    -128 dB(A)
                Media DVD
                    -128 dB(A)
                Media MFP
                    -128 dB(A)
                Media BTDevice
                    -128 dB(A)
                TA Tuner FM
                    -128 dB(A)
                Media Bluray
                    -128 dB(A)
                Media HDMI
                    -128 dB(A)
                Tuner Online
                    -128 dB(A)
                Media Airplay
                    -128 dB(A)
                Media UPNP
                    -128 dB(A)
                Media Cloud
                    -128 dB(A)
                Tuner Personal
                    -128 dB(A)
                Tone Beep
                    -128 dB(A)
                Tone Warning
                    -128 dB(A)
                Tone Touchscreen
                    -128 dB(A)
                Tone Messaging
                    -128 dB(A)
                Exbox DMB
                    -128 dB(A)
                Mirrorlink
                    -128 dB(A)
                TTS Nav
                    -128 dB(A)
                TTS SDS
                    -128 dB(A)
                Phone Voice
                    -128 dB(A)
                Phone Ringer MFP
                    -128 dB(A)
                Phone Ringer OB
                    -128 dB(A)
                HFP
                    -128 dB(A)
                TV AV IN
                    -128 dB(A)
                touch screen player
                    -128 dB(A)
            Electrical test of loudspeakers
                Mode
                    automatic
                Parameter AC-Diagnostics Channel 1 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 1 Test Volume
                    27
                channel 1 upper threshold
                    26
                channel 1 lower threshold
                    28
                Parameter AC-Diagnostics Channel 2 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 2 Test Volume
                    27
                channel 2 upper threshold
                    26
                channel 2 lower threshold
                    28
                Parameter AC-Diagnostics Channel 3 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 3 Test Volume
                    27
                channel 3 upper threshold
                    26
                channel 3 lower threshold
                    28
                Parameter AC-Diagnostics Channel 4 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 4 Test Volume
                    27
                channel 4 upper threshold
                    26
                channel 4 lower threshold
                    28
                Parameter AC-Diagnostics Channel 5 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 5 Test Volume
                    27
                channel 5 upper threshold
                    26
                channel 5 lower threshold
                    28
                Parameter AC-Diagnostics Channel 6 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 6 Test Volume
                    27
                channel 6 upper threshold
                    26
                channel 6 lower threshold
                    28
                Parameter AC-Diagnostics Channel 7 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 7 Test Volume
                    27
                channel 7 upper threshold
                    26
                channel 7 lower threshold
                    28
                Parameter AC-Diagnostics Channel 8 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 8 Test Volume
                    27
                channel 8 upper threshold
                    26
                channel 8 lower threshold
                    28
                Parameter AC-Diagnostics Channel 9 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 9 Test Volume
                    27
                channel 9 upper threshold
                    26
                channel 9 lower threshold
                    28
                Parameter AC-Diagnostics Channel 10 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 10 Test Volume
                    27
                channel 10 upper threshold
                    26
                channel 10 lower threshold
                    28
                Parameter AC-Diagnostics Channel 11 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 11 Test Volume
                    27
                channel 11 upper threshold
                    26
                channel 11 lower threshold
                    28
                Parameter AC-Diagnostics Channel 12 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 12 Test Volume
                    27
                channel 12 upper threshold
                    26
                channel 12 lower threshold
                    28
                Parameter AC-Diagnostics Channel 13 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 13 Test Volume
                    27
                channel 13 upper threshold
                    26
                channel 13 lower threshold
                    28
                Parameter AC-Diagnostics Channel 14 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 14 Test Volume
                    27
                channel 14 upper threshold
                    26
                channel 14 lower threshold
                    28
                Parameter AC-Diagnostics Channel 15 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 15 Test Volume
                    27
                channel 15 upper threshold
                    26
                channel 15 lower threshold
                    28
                Parameter AC-Diagnostics Channel 16 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 16 Test Volume
                    27
                channel 16 upper threshold
                    26
                channel 16 lower threshold
                    28
                Parameter AC-Diagnostics Channel 17 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 17 Test Volume
                    27
                channel 17 upper threshold
                    26
                channel 17 lower threshold
                    28
                Parameter AC-Diagnostics Channel 18 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 18 Test Volume
                    27
                channel 18 upper threshold
                    26
                channel 18 lower threshold
                    28
                Parameter AC-Diagnostics Channel 19 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 19 Test Volume
                    27
                channel 19 upper threshold
                    26
                channel 19 lower threshold
                    28
                Parameter AC-Diagnostics Channel 20 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 20 Test Volume
                    27
                channel 20 upper threshold
                    26
                channel 20 lower threshold
                    28
                Parameter AC-Diagnostics Channel 21 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 21 Test Volume
                    27
                channel 21 upper threshold
                    26
                channel 21 lower threshold
                    28
                Parameter AC-Diagnostics Channel 22 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 22 Test Volume
                    27
                channel 22 upper threshold
                    26
                channel 22 lower threshold
                    28
                Parameter AC-Diagnostics Channel 23 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 23 Test Volume
                    27
                channel 23 upper threshold
                    26
                channel 23 lower threshold
                    28
                Parameter AC-Diagnostics Channel 24 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 24 Test Volume
                    27
                channel 24 upper threshold
                    26
                channel 24 lower threshold
                    28
                Release
                    not released
            Summertime-automatic
                    automatic
            function_configuration_car
                conditioning variant
                bap sds sd
                    On
                bap online functions
                    Off
                dashboard connection
                    BAP over CAN and IP
                Rotary Knobs Function
                    Not activated
            function_configuration_phone
                interlink box pwm
                    installed
                interlink box antenna
                    not installed
                interlink box wireless charging
                    installed
                interlink box nfc
                    not installed
                Dtmf without active call
                    Off
                Support for response and hold
                    Off
                Support second phone
                    none
                LTE modul
                    Deactivated
                phone nad
                    not installed
                user menu three way calling
                    installed
                Support of threeway calling
                    Off
                map sms support
                    On
                map email support
                    On
                map instant messaging support
                    Off
                BTLE Messaging support
                    Off
                esim data only sms support
                    Off
                allow message editing
                    On
                GSM Antenna 3
                    Deactivated
                GSM Antenna 4
                    Deactivated
                Kopplebox Fast Charger
                    Deactivated
                interlink box CAN
                    Deactivated
            Number 1 for Info call
            Number 2 for Info call
            Number 1 for roadside assistance
            Number 2 for roadside assistance
            Number 1 (roaming) for roadside assistance
            Bluetooth
                    On
            Bluetooth: Sniff mode
                    On
            WLAN
                    On
            function_configuration_connectivity
                wlan module
                    activated
                external wlan antenna
                    none
                WIFI Hotspot 2 4GHz
                    On
                WIFI Hotspot 5GHz
                    On
                wifi client mode 2 GHz
                    On
                wifi client mode 5GHz
                    On
                app connect over wifi
                    Yes
                online media
                    Off
                Baidu Car Life
                    Off
                google android auto
                    On
                apple car play
                    On
                Mirror link
                    On
                mirror link country code
                    EU
                MirrorLink RGB Preference
                    RGB565
                viwi function
                    not installed
                viwi access mode
                    no restriction
                bluetooth visibility
                    on
                Bluetooth Availability
                    available without low energy
                messaging via map
                    installed
                Conbox encrytion
                    not installed
                messaging pagewise scrolling
                    not installed
                calendar via ctn
                    Off
                wlan aps to ccu routing
                    On
                wlan tethering connection check via disgnosis
                    On
                Bluetooth Multimedia Functionality
                    Not available
                Bluetooth Phone
                    Not available
                Bluetooth Audio
                    Not available
                Bluetooth Headphones
                    Not available
                Baidu Car Life ios
                    Off
                welink
                    Off
                Bluetooth secure transport on ethernet
                    Off
            nhtsa_properties
                limitation dependency
                    speed threshold
                nhtsa limitation switches for androidauto no video playback
                    activated
                nhtsa limitation switches for androidauto no text input
                    activated
                nhtsa limitation switches for androidauto no voice  input
                    Not activated
                nhtsa limitation switches for androidauto no setup configuration
                    activated
                nhtsa limitation switches for androidauto limit displayed message length
                    activated
                nhtsa limitation switches for carplay no softKeyboard
                    Not activated
                nhtsa limitation switches for carplay no softPhoneKeypad
                    Not activated
                nhtsa limitation switches for carplay limit nonMusicLists
                    Not activated
                nhtsa limitation switches for carplay limit musicLists
                    Not activated
                nhtsa limitation switches for carplay no japanMaps
                    Not activated
            Locked menu contents
                FB TUNER 0
                    non blocked
                FB TUNER 1
                    non blocked
                FB TUNER 2
                    non blocked
                FB TUNER 3
                    non blocked
                FB TUNER 4
                    non blocked
                FB TUNER 5
                    blocked
                FB TUNER 6
                    blocked
                FB TUNER 7
                    blocked
                FB TUNER 8
                    non blocked
                FB TUNER 9
                    non blocked
                FB TUNER 10
                    non blocked
                FB TUNER 11
                    non blocked
                FB TUNER 12
                    non blocked
                FB TUNER 13
                    non blocked
                FB TUNER 14
                    non blocked
                FB TUNER 15
                    non blocked
                FB MEDIA 0
                    non blocked
                FB MEDIA 1
                    blocked
                FB MEDIA 2
                    non blocked
                FB MEDIA 3
                    blocked
                FB MEDIA 4
                    non blocked
                FB MEDIA 5
                    non blocked
                FB MEDIA 6
                    blocked
                FB MEDIA 7
                    non blocked
                FB MEDIA 8
                    blocked
                FB MEDIA 9
                    non blocked
                FB MEDIA 10
                    non blocked
                FB MEDIA 11
                    blocked
                FB MEDIA 12
                    blocked
                FB MEDIA 13
                    blocked
                FB MEDIA 14
                    non blocked
                FB MEDIA 15
                    blocked
                FB MEDIA 16
                    non blocked
                FB MEDIA 17
                    non blocked
                FB MEDIA 18
                    non blocked
                FB MEDIA 19
                    blocked
                FB MEDIA 20
                    non blocked
                FB MEDIA 21
                    non blocked
                FB MEDIA 22
                    non blocked
                FB MEDIA 23
                    non blocked
                FB PHONE 0
                    blocked
                FB PHONE 1
                    non blocked
                FB PHONE 2
                    non blocked
                FB PHONE 3
                    blocked
                FB PHONE 4
                    non blocked
                FB PHONE 5
                    blocked
                FB PHONE 6
                    blocked
                FB PHONE 7
                    blocked
                FB PHONE 8
                    blocked
                FB PHONE 9
                    blocked
                FB PHONE 10
                    blocked
                FB PHONE 11
                    non blocked
                FB PHONE 12
                    blocked
                FB PHONE 13
                    non blocked
                FB PHONE 14
                    non blocked
                FB PHONE 15
                    blocked
                FB NAV 0
                    blocked
                FB NAV 1
                    blocked
                FB NAV 2
                    non blocked
                FB NAV 3
                    non blocked
                FB NAV 4
                    non blocked
                FB NAV 5
                    non blocked
                FB NAV 6
                    blocked
                FB NAV 7
                    blocked
                FB NAV 8
                    non blocked
                FB NAV 9
                    non blocked
                FB NAV 10
                    non blocked
                FB NAV 11
                    non blocked
                FB NAV 12
                    non blocked
                FB NAV 13
                    non blocked
                FB NAV 14
                    non blocked
                FB NAV 15
                    non blocked
                FB NAV 16
                    non blocked
                FB NAV 17
                    non blocked
                FB NAV 18
                    non blocked
                FB NAV 19
                    non blocked
                FB NAV 20
                    non blocked
                FB NAV 21
                    blocked
                FB NAV 22
                    non blocked
                FB NAV 23
                    non blocked
                FB NAV 24
                    non blocked
                FB NAV 25
                    non blocked
                FB NAV 26
                    non blocked
                FB NAV 27
                    non blocked
                FB NAV 28
                    non blocked
                FB NAV 29
                    non blocked
                FB NAV 30
                    non blocked
                FB NAV 31
                    non blocked
                FB NAV 32
                    non blocked
                FB NAV 33
                    non blocked
                FB NAV 34
                    non blocked
                FB NAV 35
                    non blocked
                FB NAV 36
                    non blocked
                FB NAV 37
                    non blocked
                FB NAV 38
                    non blocked
                FB NAV 39
                    non blocked
                FB Car 0
                    blocked
                FB Car 1
                    non blocked
                FB Car 2
                    blocked
                FB Car 3
                    blocked
                FB Car 4
                    non blocked
                FB Car 5
                    non blocked
                FB CAR 6
                    blocked
                FB CAR 7
                    blocked
                FB CAR 8
                    non blocked
                FB CAR 9
                    blocked
                FB CAR 10
                    blocked
                FB CAR 11
                    blocked
                FB CAR 12
                    blocked
                FB CAR 13
                    non blocked
                FB CAR 14
                    blocked
                FB CAR 15
                    non blocked
                FB CAR 16
                    non blocked
                FB CAR 17
                    non blocked
                FB CAR 18
                    non blocked
                FB CAR 19
                    non blocked
                FB CAR 20
                    non blocked
                FB CAR 21
                    non blocked
                FB CAR 22
                    non blocked
                FB CAR 23
                    blocked
                FB MISC 0
                    blocked
                FB MISC 1
                    blocked
                FB MISC 2
                    blocked
                FB MISC 3
                    non blocked
                FB MISC 4
                    non blocked
                FB MISC 5
                    non blocked
                FB MISC 6
                    non blocked
                FB MISC 7
                    non blocked
                FB MISC 8
                    non blocked
                FB MISC 9
                    non blocked
                FB MISC 10
                    non blocked
                FB MISC 11
                    non blocked
                FB MISC 12
                    blocked
                FB MISC 13
                    non blocked
                FB MISC 14
                    blocked
                FB MISC 15
                    non blocked
                FB MISC 16
                    non blocked
                FB MISC 17
                    non blocked
                FB MISC 18
                    non blocked
                FB MISC 19
                    non blocked
                FB MISC 20
                    non blocked
                FB MISC 21
                    non blocked
                FB MISC 22
                    non blocked
                FB MISC 23
                    non blocked
                FB MISC 24
                    non blocked
                FB MISC 25
                    blocked
                FB MISC 26
                    blocked
                FB MISC 27
                    non blocked
                FB MISC 28
                    non blocked
                FB MISC 29
                    blocked
                FB MISC 30
                    non blocked
                FB MISC 31
                    blocked
                FB MISC 32
                    non blocked
                FB MISC 33
                    non blocked
                FB MISC 34
                    non blocked
                FB MISC 35
                    blocked
                FB MISC 36
                    non blocked
                FB MISC 37
                    blocked
                FB MISC 38
                    blocked
                FB MISC 39
                    non blocked
                FB MISC 40
                    blocked
                FB MISC 41
                    blocked
                FB MISC 42
                    blocked
                FB MISC 43
                    blocked
                FB MISC 44
                    non blocked
                FB MISC 45
                    non blocked
                FB MISC 46
                    blocked
                FB MISC 47
                    blocked
                FB HELP 0
                    non blocked
                FB HELP 1
                    non blocked
                FB HELP 2
                    non blocked
                FB HELP 3
                    non blocked
                FB HELP 4
                    non blocked
                FB HELP 5
                    non blocked
                FB HELP 6
                    non blocked
                FB HELP 7
                    non blocked
                FB HELP 8
                    non blocked
                FB HELP 9
                    non blocked
            Country identification, country of sale HMI
                    DE
            function_configuration_hmi
                skinning
                screenings
                log book
                    not displayed
                speller
                    On
                hmi initial disclaimer
                    Off
                hmi legal disclaimer
                    On
                helpcontext 0
                    Off
                helpcontext 1
                    Off
                helpcontext 2
                    Off
                helpcontext 3
                    Off
                helpcontext 4
                    Off
                helpcontext 5
                    Off
                helpcontext 6
                    Off
                helpcontext 7
                    Off
                helpcontext 8
                    Off
                helpcontext 9
                    Off
                Popup if GPS services in use
                    Off
                Twin Wheel
                    Deactivated
                Nav showing
                    activated
                Google search default
                    On
                Show google search default
                    On
                    DE
            Interface for external media, activation
                Connection 1
                    activated
                Connection 2
                    activated
                Connection 3
                    Not activated
                Connection 4
                    Not activated
            function_configuration_media
                Import Media Data
                    Not activated
                Ripping Media Data
                    Not activated
                gracenote online coverarts
                    Off
                gracenote online other
                    Off
                gracenote local coverarts
                    Off
                gracenote local other
                    Off
                USB
                    usb ipod
                AUX IN
                    Off
                picture viewer
                    Off
                app start automatically on customer device
                    Off
                online media services
                    On
                online tv
                    Off
                external cd drive
                    Off
                external tv tuner
                    Off
            FM tuner, mono/stereo setting
                lower HF stereo threshold in dBµV
                    36
                Maximum NF stereo channel separation in dB
                    35
                lower HF stereo threshold in seconds
                    15.00 s
            function_configuration_radio
                Station Logo DB Mode
                band settings fm tuner
                    NAR
                band settings am tuner
                    NAR
                band settings dab tuner band 1
                    Off
                HD FM Antenna Mode
                    MRC
                FM Antenna
                    available
                dab mode antenna mode 1
                    Not activated
                am fm dab antenna
                    Not activated
                AF
                    persistent
                fm hd hmi switch default value
                    activated
                am hd hmi switch default value
                    activated
                DAB Alarm Announcement
                    Not activated
                FM PTY31 Alarm
                    Off
                AM disable
                    Deactivated
                drm30 mf
                    Deactivated
                drm plus fm
                    Deactivated
                multiple entry switch
                    On
                rds hmi switch visibility
                    Off
                rds hmi switch default value
                    On
                af hmi switch default value
                    On
                Radio Text Plus
                    Not activated
                PI ignore
                    On
                Hybrid Radio additional online data
                    Deactivated
                Hybrid Radio Range Extender
                    deactivated
                online radio
                    native hmi only
                fm radio profiles
                    not valid
                SDARS type
                    SAT and IP
                SDARS band activation
                    activated
                PTy switch visibility
                    Off
                PTy switch default value
                    Off
            Voice operation for telephone
                Apple device
                    not installed
                Other
                    installed
            function_configuration_swap_fod
                enable swap fod
                    swap active fod not active
            Confirmation of installation change
                Key
                    3DF5
            error_mask
                dtc dfcc 1
                dtc dfcc 2
                dtc dfcc 3
                dtc dfcc 4
                dtc dfcc 5
                dtc dfcc 6
                dtc dfcc 7
                dtc dfcc 8
                dtc dfcc 9
                dtc dfcc 10
            Production mode
                operation
                    Not activated
                volume control
                    Not activated
                frequency modification
                    Not activated
                wifi
                    Not activated
                display 1 move
                    Not activated
                display 1 on off
                    Not activated
                radio link esim
                    Not activated
                fpk
                    Not activated
                fpk display
                    Not activated
                display 2 move
                    Not activated
                display 2 on off
                    Not activated
                sds
                    Not activated
                p mode id 13
                    Not activated
                p mode id 14
                    Not activated
                bluetooth
                    Not activated
                extendible tweeters
                    Not activated
                air condition operation
                    Not activated
                display 3 on off
                    Not activated
                early audio
                    Not activated
                Display 4 on off
                    Not activated
                parameter 21
                    Not activated
                parameter 22
                    Not activated
                parameter 23
                    Not activated
                paramter 24
                    Not activated
            Developer mode
                    activated
            Key_code_monitoring
                monitoring keycode 0x00 0x07
                    FF
                monitoring keycode 0x08 0x0F
                    FF
                monitoring keycode 0x10 0x17
                    FF
                monitoring keycode 0x18 0x1F
                    FF
                monitoring keycode 0x20 0x27
                    FF
                monitoring keycode 0x28 0x2F
                    FF
                monitoring keycode 0x30 0x37
                    FF
                monitoring keycode 0x38 0x3F
                    FF
                monitoring keycode 0x40 0x47
                    FF
                monitoring keycode 0x48 0x4F
                    FF
                monitoring keycode 0x50 0x57
                    FF
                monitoring keycode 0x58 0x5F
                    FF
                monitoring keycode 0x60 0x67
                    FF
                monitoring keycode 0x68 0x6F
                    FF
                monitoring keycode 0x70 0x77
                    FF
                monitoring keycode 0x78 0x7F
                    FF
                monitoring keycode 0x80 0x87
                    FF
                monitoring keycode 0x88 0x8F
                    FF
                monitoring keycode 0x90 0x97
                    FF
                monitoring keycode 0x98 0x9F
                    FF
                monitoring keycode 0xA0 0xA7
                    FF
                monitoring keycode 0xA8 0xAF
                    FF
                monitoring keycode 0xB0 0xB7
                    FF
                monitoring keycode 0xB8 0xBF
                    FF
                monitoring keycode 0xC0 0xC7
                    FF
                monitoring keycode 0xC8 0xCF
                    FF
                monitoring keycode 0xD0 0xD7
                    FF
                monitoring keycode 0xD8 0xDF
                    FF
                monitoring keycode 0xE0 0xE7
                    FF
                monitoring keycode 0xE8 0xEF
                    FF
                monitoring keycode 0xF0 0xF7
                    FF
                monitoring keycode 0xF8 0xFF
                    FF
            function_configuration_unit
                RVC video input
                    FBAS
                second display via lvds connection
                    not connected
                Display Turn Out Speed
                    normal
                Pilot Parking
                    Deactivated
                web app plattform side loading
                    Deactivated
                Suspend to RAM
                    Deactivated
                reset type hardware reset
                    IVI partition only
            Dimming_Ambient_Illumination_Operating_and_Display_Unit
                X1
                Y1
                X2
                    50
                Y2
                    50
                X3
                    100
                Y3
                    100
                    00
                    FFFFFFFF
            Radio_Level_Quality_Offsets
                Set AM Quality Level Offset
                Set FM Quality Level Offset
            Vehicle function list BAP
                climatic master 0x01
                    activated
                climatic master 0x01 msg bus
                    Comfort data bus
                climatic slave 0x02
                    Not activated
                climatic slave 0x02 msg bus
                    Comfort data bus
                auxilary heating 0x03
                    Not activated
                auxilary heating 0x03 msg bus
                    Not activated
                headup displ 0x04
                    Not activated
                headup displ 0x04 msg bus
                    Not activated
                ACC 0x05
                    activated
                ACC 0x05 msg bus
                    Databus extended
                air suspension 0x06
                    Not activated
                air suspension 0x06 msg bus
                    Not activated
                tire pressure system 0x07
                    activated
                tire pressure system 0x07 msg bus
                    Suspension data bus
                interieur light 0x08
                    activated
                interieur light 0x08 msg bus
                    Comfort data bus
                exterieur light 0x09
                    activated
                exterieur light 0x09 msg bus
                    Comfort data bus
                parking assist 0x0A
                    Not activated
                parking assist 0x0A msg bus
                    Not activated
                VPS 0x0B
                    Not activated
                VPS 0x0B msg bus
                    Not activated
                wiper comfort 0x0C
                    activated
                wiper comfort 0x0C msg bus
                    Comfort data bus
                central locking 0x0D
                    activated
                central locking 0x0D msg bus
                    Comfort data bus
                mirror 0x0E
                    activated
                mirror 0x0E msg bus
                    Comfort data bus
                MFA 0x0F
                    activated
                MFA 0x0F msg bus
                    Comfort data bus
                driver seat 0x10
                    Not activated
                driver seat 0x10 msg bus
                    Comfort data bus
                clock 0x11
                    activated
                clock 0x11 msg bus
                    Comfort data bus
                service interval display 0x12
                    activated
                service interval display 0x12 msg bus
                    Comfort data bus
                unit master 0x13
                    activated
                unit master 0x13 msg bus
                    Comfort data bus
                UGDO 0x14
                    Not activated
                UGDO 0x14 msg bus
                    Not activated
                compass 0x15
                    Not activated
                compass 0x15 msg bus
                    Not activated
                clima slave 2 0x16
                    Not activated
                clima slave 2 0x16 msg bus
                    Not activated
                charisma 0x17
                    Not activated
                charisma 0x17 msg bus
                    Comfort data bus
                Night Vision 0x18
                    Not activated
                Night Vision 0x18 msg bus
                    Not activated
                LDW HCA 0x19
                    Not activated
                LDW HCA 0x19 msg bus
                    Databus extended
                SWA 0x1A
                    activated
                SWA 0x1A msg bus
                    Databus extended
                AWV 0x1B
                    activated
                AWV 0x1B msg bus
                    Databus extended
                Hybrid 0x1D
                    Not activated
                Hybrid 0x1D msg bus
                    Databus drivetrain
                SideView 0x1E
                    Not activated
                SideView 0x1E msg bus
                    Not activated
                Reversible Seat Belt Tightener 0x1F
                    Not activated
                Reversible Seat Belt Tightener 0x1F msg bus
                    Databus drivetrain
                Passanger Seat 0x20
                    Not activated
                Passanger Seat 0x20 msg bus
                    Not activated
                traffic sign recognition 0x21
                    Not activated
                traffic sign recognition 0x21 msg bus
                    Databus extended
                weariness rcognition 0x22
                    Not activated
                weariness rcognition 0x22 msg bus
                    Comfort data bus
                BCmE 0x23
                    activated
                BCmE 0x23 msg bus
                    Databus Infotainment
                Angle Of Slope 0x24
                    Not activated
                Angle Of Slope 0x24 msg bus
                    Not activated
                Battery Management 0x25
                    Not activated
                Battery Management 0x25 msg bus
                    Databus drivetrain
                Brake 0x26
                    activated
                Brake 0x26 msg bus
                    Suspension data bus
                Start Stop reasons 0x27
                    Not activated
                Start Stop reasons 0x27 msg bus
                    Not activated
                TV tuner 0x2C
                    Not activated
                TV tuner 0x2C msg bus
                    Not activated
                Amplifier 0x2D
                    Not activated
                Amplifier 0x2D msg bus
                    Not activated
                RearSeatEntertainment 0x2E
                    Not activated
                RearSeatEntertainment 0x2E msg bus
                    Not activated
                eCall 0x33
                    activated
                eCall 0x33 msg bus
                    Comfort data bus
                MFL Jocker 0x34
                    Not activated
                MFL Jocker msg bus 0x34
                    Not activated
                Special Functions 0x35
                    Not activated
                Special Functions msg bus 0x35
                    Not activated
                Trailer Assistant 0x36
                    Not activated
                Trailer Assistant msg bus 0x36
                    Not activated
                ENI 0x37
                    activated
                ENI 0x37 msg bus
                    Comfort data bus
                Range Data 0x39
                    Not activated
                Range Data msg bus 0x39
                    Comfort data bus
                Pedestrian Assist 0x3A
                    Not activated
                Pedestrian Assist msg bus 0x3A
                    Not activated
                Seat Pneumatic 0x3B
                    Not activated
                Seat Pneumatic msg bus 0x3B
                    Not activated
                efficiency assist 0x3C
                    Not activated
                efficiency assis msg bus 0x3C
                    Not activated
                Seatmemory driver rear 0x3E
                    Not activated
                Seatmemory driver rear msg bus 0x3E
                    Not activated
                Seatmemory codriver rear 0x3F
                    Not activated
                Seatmemory codriver rear msg bus 0x3F
                    Not activated
                spoiler 0x40
                    Not activated
                spoiler 0x40 msg bus
                    Not activated
                front traffic assist 0x41
                    Not activated
                front traffic assist 0x41 msg bus
                    Not activated
                climate master 0x42
                    Not activated
                climate master 0x42 msg bus
                    Not activated
                Soundcontrol 0x44
                    Not activated
                Soundcontrol 0x44 msg bus
                    Not activated
                display configuration 0x45
                    activated
                display configuration 0x45 msg bus
                    Comfort data bus
                connection manager 0x47
                    Not activated
                connection manager 0x47 msg bus
                    Not activated
                wireless charging 0x48
                    Not activated
                wireless charging 0x48 msg bus
                    Not activated
                statistic 0x4A
                    Not activated
                statistic 0x4A msg bus
                    Not activated
                sunroof front 0x4B
                    Not activated
                sunroof front 0x4B msg bus
                    Not activated
                sunroof rear 0x4C
                    Not activated
                sunroof rear 0x4C msg bus
                    Not activated
                fas profile 0x4D
                    Not activated
                fas profile 0x4D msg bus
                    Not activated
                remote services 0x4E
                    Not activated
                remote services 0x4E msg bus
                    Not activated
                infotainmentsettings profile 0x50
                    Not activated
                infotainmentsettings profile 0x50 msg bus
                    Not activated
                daf profile 0x51
                    Not activated
                daf profile 0x51 msg bus
                    Not activated
                IAA PSO 0x52
                    activated
                IAA PSO 0x52 msg bus
                    Comfort data bus
                Mascot 0x53
                    Not activated
                Mascot 0x53 msg bus
                    Not activated
                VAS 0x54
                    Not activated
                VAS 0x54 msg bus
                    Not activated
                PaCo 0x55
                    Not activated
                PaCo 0x55 msg bus
                    Not activated
                EngineFunctions 0x5D
                    Not activated
                EngineFunctions 0x5D msg bus
                    Not activated
                Car2X 0x61 msg bus
                    Not activated
                Car2X 0x61
                    Not activated
                ITM 0x65 msg bus
                    Not activated
                ITM 0x65
                    Not activated
                SoundControl2 0x66 msg bus
                    Not activated
                SoundControl2 0x66
                    Not activated
                interieur light 2 0x6A msg bus
                    Not activated
                    Not activated
                exterieur light 2 0x6B msg bus
                    Not activated
                    Not activated
                ENI2 0x58 msg bus
                    Not activated
                ENI2 0x58
                    Not activated
                Trained Park Assist 0x5F msg bus
                    Not activated
                    Not activated
                ENI3 0x6E msg bus
                    Not activated
                ENI3 0x6E
                    Not activated
                ENI4 0x6F msg bus
                    Not activated
                ENI4 0x6F
                    Not activated
                lift 0x64 msg bus
                    Not activated
                lift 0x64
                    Not activated
                ChassisControl 0x57 msg bus
                    Not activated
                ChassisControl 0x57
                    Not activated
                LLCC 0x78 msg bus
                    Not activated
                LLCC 0x78
                    Not activated
                BSMOIS 0x76 msg bus
                    Not activated
                BSMOIS 0x76
                    Not activated
                Doorlocking 2nd 0x79 msg bus
                    Not activated
                    Not activated
                BSMOIS2 0x7A msg bus
                    Not activated
                BSMOIS2 0x7A
                    Not activated
                BSMOIS3 0x7B msg bus
                    Not activated
                BSMOIS3 0x7B
                    Not activated
                RushhourPilot 0x7C msg bus
                    Not activated
                RushhourPilot 0x7C
                    Not activated
                DrivingDynamics 0x7E msg bus
                    Not activated
                    Not activated
                RollingAbility 0x75 msg bus
                    Not activated
                RollingAbility 0x75
                    Not activated
                California 0x81 msg bus
                    Not activated
                California 0x81
                    Not activated
                MobDevKey 0x77 msg bus
                    Not activated
                MobDevKey 0x77
                    Not activated
                Plug and Charge 0x80 msg bus
                    Not activated
                    Not activated
                SecurityEvent 0x82 msg bus
                    Not activated
                SecurityEvent 0x82
                    Not activated
            Vehicle menu operation
                menu display ACC
                    activated
                menu display ACC operation clamp 15 off
                    Not activated
                menu display ACC over threshold high
                    activated
                menu display ACC standstill
                    Not activated
                menu display ACC after disclaimer
                    Not activated
                menu display ambient illumination
                    activated
                menu display ambient illumination clamp 15 off
                    Not activated
                menu display ambient illumination over threshold high
                    activated
                menu display ambient illumination standstill
                    Not activated
                menu display ambient illumination after disclaimer
                    Not activated
                menu display pdc
                    activated
                menu display pdc clamp 15 off
                    Not activated
                menu display pdc over threshold high
                    activated
                menu display pdc standstill
                    Not activated
                menu display pdc after disclaimer
                    Not activated
                menu display awv
                    activated
                menu display awv clamp 15 off
                    Not activated
                menu display awv over threshold high
                    activated
                menu display awv standstill
                    Not activated
                menu display awv after disclaimer
                    Not activated
                menu display Lane Departure Warning
                    Not activated
                menu display Lane Departure Warning clamp 15 off
                    Not activated
                menu display Lane Departure Warning over threshold high
                    Not activated
                menu display Lane Departure Warning standstill
                    Not activated
                menu display Lane Departure Warning after disclaimer
                    Not activated
                menu display lane assistant
                    activated
                menu display lane assistant clamp 15 off
                    Not activated
                menu display lane assistant over threshold high
                    activated
                menu display lane assistant standstill
                    Not activated
                menu display lane assistant after disclaimer
                    Not activated
                menu display exterior illumination
                    activated
                menu display exterior illumination clamp 15 off
                    Not activated
                menu display exterior illumination over threshold high
                    activated
                menu display exterior illumination standstill
                    Not activated
                menu display exterior illumination after disclaimer
                    Not activated
                menu display windows
                    activated
                menu display windows clamp 15 off
                    Not activated
                menu display windows over threshold high
                    activated
                menu display windows standstill
                    Not activated
                menu display windows after disclaimer
                    Not activated
                menu display clima configuration
                    activated
                menu display clima configuration clamp 15 off
                    Not activated
                menu display clima configuration over threshold high
                    activated
                menu display clima configuration standstill
                    Not activated
                menu display clima configuration after disclaimer
                    Not activated
                menu display auxiliary heating
                    Not activated
                menu display auxiliary heating clamp 15 off
                    Not activated
                menu display auxiliary heating over threshold high
                    Not activated
                menu display auxiliary heating standstill
                    Not activated
                menu display auxiliary heating after disclaimer
                    Not activated
                menu display board computer
                    activated
                menu display board computer clamp 15 off
                    Not activated
                menu display board computer over threshold high
                    activated
                menu display board computer standstill
                    Not activated
                menu display board computer after disclaimer
                    Not activated
                menu display rdk
                    activated
                menu display rdk clamp 15 off
                    Not activated
                menu display rdk over threshold high
                    activated
                menu display rdk standstill
                    Not activated
                menu display rdk after disclaimer
                    Not activated
                menu display wiper
                    activated
                menu display wiper clamp 15 off
                    Not activated
                menu display wiper over threshold high
                    activated
                menu display wiper standstill
                    Not activated
                menu display wiper after disclaimer
                    Not activated
                menu display sia
                    activated
                menu display sia clamp 15 off
                    Not activated
                menu display sia over threshold high
                    activated
                menu display sia standstill
                    Not activated
                menu display sia after disclaimer
                    Not activated
                menu display seat configuration
                    Not activated
                menu display seat configuration clamp 15 off
                    Not activated
                menu display seat configuration over threshold high
                    Not activated
                menu display seat configuration standstill
                    Not activated
                menu display seat configuration after disclaimer
                    Not activated
                menu display central locking
                    activated
                menu display central locking clamp 15 off
                    Not activated
                menu display central locking over threshold high
                    activated
                menu display central locking standstill
                    Not activated
                menu display central locking after disclaimer
                    Not activated
                menu display compass
                    activated
                menu display compass clamp 15 off
                    Not activated
                menu display compass over threshold high
                    activated
                menu display compass standstill
                    Not activated
                menu display compass after disclaimer
                    Not activated
                menu display charisma
                    activated
                menu display charisma clamp 15 off
                    Not activated
                menu display charisma over threshold high
                    activated
                menu display charisma standstill
                    Not activated
                menu display charisma after disclaimer
                    Not activated
                menu display oil level
                    Not activated
                menu display oil level clamp 15 off
                    Not activated
                menu display oil level over threshold high
                    Not activated
                menu display oil level standstill
                    Not activated
                menu display oil level after disclaimer
                    Not activated
                menu display vin
                    activated
                menu display vin clamp 15 off
                    Not activated
                menu display vin over threshold high
                    activated
                menu display vin standstill
                    Not activated
                menu display vin after disclaimer
                    Not activated
                menu display clock
                    activated
                menu display clock clamp 15 off
                    Not activated
                menu display clock over threshold high
                    activated
                menu display clock standstill
                    Not activated
                menu display clock after disclaimer
                    Not activated
                menu display air damper
                    Not activated
                menu display air damper clamp 15 off
                    Not activated
                menu display air damper over threshold high
                    Not activated
                menu display air damper standstill
                    Not activated
                menu display air damper after disclaimer
                    Not activated
                menu display headup display
                    Not activated
                menu display headup display clamp 15 off
                    Not activated
                menu display headup display over threshold high
                    Not activated
                menu display headup display standstill
                    Not activated
                menu display headup display after disclaimer
                    Not activated
                menu display central unit master
                    activated
                menu display central unit master clamp 15 off
                    Not activated
                menu display central unit master over threshold high
                    activated
                menu display central unit master standstill
                    Not activated
                menu display central unit master after disclaimer
                    Not activated
                menu display hybrid
                    Not activated
                menu display hybrid clamp 15 off
                    Not activated
                menu display hybrid over threshold high
                    Not activated
                menu display hybrid standstill
                    Not activated
                menu display hybrid after disclaimer
                    Not activated
                menu display ugdo
                    Not activated
                menu display ugdo clamp 15 off
                    Not activated
                menu display ugdo over threshold high
                    Not activated
                menu display ugdo standstill
                    Not activated
                menu display ugdo after disclaimer
                    Not activated
                menu display night vision
                    Not activated
                menu display night vision clamp 15 off
                    Not activated
                menu display night vision over threshold high
                    Not activated
                menu display night vision standstill
                    Not activated
                menu display night vision after disclaimer
                    Not activated
                menu display side view
                    Not activated
                menu display side view clamp 15 off
                    Not activated
                menu display side view over threshold high
                    Not activated
                menu display side view standstill
                    Not activated
                menu display side view after disclaimer
                    Not activated
                menu display reversible belt pre load
                    Not activated
                menu display reversible belt pre load clamp 15 off
                    Not activated
                menu display reversible belt pre load over threshold high
                    Not activated
                menu display reversible belt pre load standstill
                    Not activated
                menu display reversible belt pre load after disclaimer
                    Not activated
                menu display MFL jocker
                    Not activated
                menu display MFL jocker clamp 15 off
                    Not activated
                menu display MFL jocker over threshold high
                    Not activated
                menu display MFL jocker standstill
                    Not activated
                menu display MFL jocker after disclaimer
                    Not activated
                menu display road sign identification
                    Not activated
                menu display road sign identification clamp 15 off
                    Not activated
                menu display road sign identification over threshold high
                    Not activated
                menu display road sign identification standstill
                    Not activated
                menu display road sign identification after disclaimer
                    Not activated
                menu display attention identification
                    Not activated
                menu display attention identification clamp 15 off
                    Not activated
                menu display attention identification over threshold high
                    Not activated
                menu display attention identification standstill
                    Not activated
                menu display attention identification after disclaimer
                    Not activated
                menu display adaptive key
                    Not activated
                menu display adaptive key clamp 15 off
                    Not activated
                menu display adaptive key over threshold high
                    Not activated
                menu display adaptive key standstill
                    Not activated
                menu display adaptive key after disclaimer
                    Not activated
                menu display car mirror
                    activated
                menu display car mirror clamp 15 off
                    Not activated
                menu display car mirror over threshold high
                    activated
                menu display car mirror standstill
                    Not activated
                menu display car mirror after disclaimer
                    Not activated
                menu display driving school
                    Not activated
                menu display driving school clamp 15 off
                    Not activated
                menu display driving school over threshold high
                    Not activated
                menu display driving school standstill
                    Not activated
                menu display driving school after disclaimer
                    Not activated
                menu display weariness recognition
                    Not activated
                menu display weariness recognition clamp 15 off
                    Not activated
                menu display weariness recognition over threshold high
                    Not activated
                menu display weariness recognition standstill
                    Not activated
                menu display weariness recognition after disclaimer
                    Not activated
                menu display BCmE
                    activated
                menu display BCmE clamp 15 off
                    Not activated
                menu display BCmE over threshold high
                    activated
                menu display BCmE standstill
                    Not activated
                menu display BCmE after disclaimer
                    Not activated
                menu display user eco rating
                    Not activated
                menu display user eco rating clamp 15 off
                    Not activated
                menu display user eco rating over threshold high
                    Not activated
                menu display user eco rating standstill
                    Not activated
                menu display user eco rating after disclaimer
                    Not activated
                menu display Brake Function
                    activated
                menu display Brake Function clamp 15 off
                    Not activated
                menu display Brake Function over threshold high
                    activated
                menu display Brake Function standstill
                    Not activated
                menu display Brake Function after disclaimer
                    Not activated
                menu display Start Stop reasons
                    Not activated
                menu display Start Stop reasons clamp 15 off
                    Not activated
                menu display Start Stop reasons over threshold high
                    Not activated
                menu display Start Stop reasons standstill
                    Not activated
                menu display Start Stop reasons after disclaimer
                    Not activated
                menu display angle of slope
                    Not activated
                menu display angle of slope clamp 15 off
                    Not activated
                menu display angle of slope over threshold high
                    Not activated
                menu display angle of slope standstill
                    Not activated
                menu display angle of slope after disclaimer
                    Not activated
                menu display battery management
                    Not activated
                menu display battery management clamp 15 off
                    Not activated
                menu display battery management over threshold high
                    Not activated
                menu display battery management standstill
                    Not activated
                menu display battery management after disclaimer
                    Not activated
                menu display RearSeatEntertainment
                    Not activated
                menu display RearSeatEntertainment clamp 15 off
                    Not activated
                menu display RearSeatEntertainment over threshold high
                    Not activated
                menu display RearSeatEntertainment standstill
                    Not activated
                menu display RearSeatEntertainment after disclaimer
                    Not activated
                menu display special functions
                    Not activated
                menu display special functions clamp 15 off
                    Not activated
                menu display special functions over threshold high
                    Not activated
                menu display special functions standstill
                    Not activated
                menu display special functions after disclaimer
                    Not activated
                menu display trailer assistant
                    Not activated
                menu display trailer assistant clamp 15 off
                    Not activated
                menu display trailer assistant over threshold high
                    Not activated
                menu display trailer assistant standstill
                    Not activated
                menu display trailer assistant after disclaimer
                    Not activated
                menu display TV tuner
                    Not activated
                menu display TV tuner clamp 15 off
                    Not activated
                menu display TV tuner over threshold high
                    Not activated
                menu display TV Tuner standstill
                    Not activated
                menu display TV Tuner after disclaimer
                    Not activated
                menu auxiliary climatization
                    Not activated
                menu auxiliary climatization clamp 15 off
                    Not activated
                menu auxiliary climatization over threshold high
                    Not activated
                menu auxiliary climatization standstill
                    Not activated
                menu auxiliary climatization after disclaimer
                    Not activated
                menu display Pedestrian Assist
                    Not activated
                menu display Pedestrian Assist clamp 15 off
                    Not activated
                menu display Pedestrian Assist over threshold high
                    Not activated
                menu display Pedestrian Assist standstill
                    Not activated
                menu display Pedestrian Assist after disclaimer
                    Not activated
                menu display Seat Pneumatic
                    Not activated
                menu display Seat Pneumatic clamp 15 off
                    Not activated
                menu display Seat Pneumatic over threshold high
                    Not activated
                menu display Seat Pneumatic standstill
                    Not activated
                menu display Seat Pneumatic after disclaimer
                    Not activated
                menu display Curve Assist
                    Not activated
                menu display Curve Assist clamp 15 off
                    Not activated
                menu display Curve Assist over threshold high
                    Not activated
                menu display Curve Assist standstill
                    Not activated
                menu display Curve Assist after disclaimer
                    Not activated
                menu display eCall
                    activated
                menu display eCall clamp 15 off
                    Not activated
                menu display eCall over threshold high
                    activated
                menu display eCall standstill
                    Not activated
                menu display eCall after disclaimer
                    Not activated
                menu display ENI
                    activated
                menu display ENI clamp 15 off
                    Not activated
                menu display ENI over threshold high
                    activated
                menu display ENI standstill
                    Not activated
                menu display ENI after disclaimer
                    Not activated
                menu display SportHMI
                    activated
                menu display SportHMI clamp 15 off
                    Not activated
                menu display SportHMI over threshold high
                    activated
                menu display SportHMI standstill
                    Not activated
                menu display SportHMI after disclaimer
                    Not activated
                menu display Adblue
                    Not activated
                menu display Adblue clamp 15 off
                    Not activated
                menu display Adblue over threshold high
                    Not activated
                menu display Adblue standstill
                    Not activated
                menu display Adblue after disclaimer
                    Not activated
                menu display Spoiler
                    Not activated
                menu display Spoiler clamp 15 off
                    Not activated
                menu display Spoiler over threshold high
                    Not activated
                menu display Spoiler standstill
                    Not activated
                menu display Spoiler after disclaimer
                    Not activated
                menu display Efficiency Assist
                    Not activated
                menu display Efficiency Assist clamp 15 off
                    Not activated
                menu display Efficiency Assist over threshold high
                    Not activated
                menu display Efficiency Assist standstill
                    Not activated
                menu display Efficiency Assist after disclaimer
                    Not activated
                menu display Display Configuration
                    activated
                menu display Display Configuration clamp 15 off
                    Not activated
                menu display Display Configuration over threshold high
                    activated
                menu display Display Configuration standstill
                    Not activated
                menu display Display Configuration after disclaimer
                    Not activated
                menu soundcontrol
                    Not activated
                menu soundcontrol clamp 15 off
                    Not activated
                menu soundcontrol over threshold high
                    Not activated
                menu soundcontrol standstill
                    Not activated
                menu soundcontrol after disclaimer
                    Not activated
                menu auxiliary ventilation
                    Not activated
                menu auxiliary ventilation clamp 15 off
                    Not activated
                menu auxiliary ventilation over threshold high
                    Not activated
                menu auxiliary ventilation standstill
                    Not activated
                menu auxiliary ventilation after disclaimer
                    Not activated
                menu crossroad assistent
                    Not activated
                menu crossroad assistent clamp 15 off
                    Not activated
                menu crossroad assistent over threshold high
                    Not activated
                menu crossroad assistent standstill
                    Not activated
                menu crossroad assistent after disclaimer
                    Not activated
                menu connection manager
                    Not activated
                menu connection manager clamp 15 off
                    Not activated
                menu connection manager over threshold high
                    Not activated
                menu connection manager standstill
                    Not activated
                menu connection manager after disclaimer
                    Not activated
                menu wireless charging
                    Not activated
                menu wireless charging clamp 15 off
                    Not activated
                menu wireless charging over threshold high
                    Not activated
                menu wireless charging standstill
                    Not activated
                menu wireless charging after disclaimer
                    Not activated
                menu statistic
                    Not activated
                menu statistic clamp 15 off
                    Not activated
                menu statistic over threshold high
                    Not activated
                menu statistic stillstand
                    Not activated
                menu statistic after disclaimer
                    Not activated
                menu sunroof
                    Not activated
                menu sunroof clamp 15 off
                    Not activated
                menu sunroof over threshold high
                    Not activated
                menu sunroof stillstand
                    Not activated
                menu sunroof after disclaimer
                    Not activated
                menu fas profile
                    Not activated
                menu fas profile clamp 15 off
                    Not activated
                menu fas profile over threshold high
                    Not activated
                menu fas profile stillstand
                    Not activated
                menu fas profile after disclaimer
                    Not activated
                menu daf profile
                    Not activated
                menu daf profile clamp 15 off
                    Not activated
                menu daf profile over threshold high
                    Not activated
                menu daf profile stillstand
                    Not activated
                menu daf profile after disclaimer
                    Not activated
                menu mobile device key profile
                    Not activated
                menu mobile device key profile clamp 15 off
                    Not activated
                menu mobile device key profile over threshold high
                    Not activated
                menu mobile device key profile stillstand
                    Not activated
                menu mobile device key profile after disclaimer
                    Not activated
                menu IAA PSO
                    activated
                menu IAA PSO clamp 15 off
                    Not activated
                menu IAA PSO over threshold high
                    activated
                menu IAA PSO stillstand
                    Not activated
                menu IAA PSO after disclaimer
                    Not activated
                menu Mascot
                    Not activated
                menu Mascot clamp 15 off
                    Not activated
                menu Mascot over threshold high
                    Not activated
                menu Mascot stillstand
                    Not activated
                menu Mascot after disclaimer
                    Not activated
                menu VAS
                    Not activated
                menu VAS clamp 15 off
                    Not activated
                menu VAS over threshold high
                    Not activated
                menu VAS stillstand
                    Not activated
                menu VAS after disclaimer
                    Not activated
                menu PaCo
                    Not activated
                menu PaCo clamp 15 off
                    Not activated
                menu PaCo over threshold high
                    Not activated
                menu PaCo stillstand
                    Not activated
                menu PaCo after disclaimer
                    Not activated
                menu EngineFunctions
                    Not activated
                menu EngineFunctions clamp 15 off
                    Not activated
                menu EngineFunctions over threshold high
                    Not activated
                menu EngineFunctions stillstand
                    Not activated
                menu EngineFunctions after disclaimer
                    Not activated
                menu Car2X after disclaimer
                    Not activated
                menu Car2X stillstand
                    Not activated
                menu Car2X over threshold high
                    Not activated
                menu Car2X clamp 15 off
                    Not activated
                menu Car2X
                    Not activated
                menu ITM after disclaimer
                    Not activated
                menu ITM stillstand
                    Not activated
                menu ITM over threshold high
                    Not activated
                menu ITM clamp 15 off
                    Not activated
                menu ITM
                    Not activated
                menu SoundControl 2 after disclaimer
                    Not activated
                menu SoundControl 2 stillstand
                    Not activated
                menu SoundControl 2 over threshold high
                    Not activated
                menu SoundControl 2 clamp 15 off
                    Not activated
                menu SoundControl 2
                    Not activated
                menu FOD after disclaimer
                    Not activated
                menu FOD stillstand
                    Not activated
                menu FOD over threshold high
                    Not activated
                menu FOD clamp 15 off
                    Not activated
                menu FOD
                    Not activated
                menu DCC monitor after disclaimer
                    Not activated
                menu DCC monitor stillstand
                    Not activated
                menu DCC monitor over threshold high
                    Not activated
                menu DCC monitor clamp 15 off
                    Not activated
                menu DCC monitor
                    Not activated
                menu ambient illumination 2 after disclaimer
                    Not activated
                menu ambient illumination 2 stillstand
                    Not activated
                menu ambient illumination 2 over threshold high
                    Not activated
                menu ambient illumination 2 clamp 15 off
                    Not activated
                    Not activated
                menu exterior illumination 2 after disclaimer
                    Not activated
                menu exterior illumination 2 stillstand
                    Not activated
                menu exterior illumination 2 over threshold high
                    Not activated
                menu exterior illumination 2 clamp 15 off
                    Not activated
                    Not activated
                menu lift after disclaimer
                    Not activated
                menu lift stillstand
                    Not activated
                menu lift over threshold high
                    Not activated
                menu lift clamp 15 off
                    Not activated
                menu lift
                    Not activated
                menu LLCC after disclaimer
                    Not activated
                menu LLCC standstill
                    Not activated
                menu LLCC over threshold high
                    Not activated
                menu LLCC clamp 15 off
                    Not activated
                menu LLCC
                    Not activated
                menu chassis control after disclaimer
                    Not activated
                menu chassis control standstill
                    Not activated
                menu chassis control over threshold high
                    Not activated
                menu chassis control clamp 15 off
                    Not activated
                    Not activated
                menu Doorlocking 2nd after disclaimer
                    Not activated
                menu Doorlocking 2nd standstill
                    Not activated
                menu Doorlocking 2nd over threshold high
                    Not activated
                menu Doorlocking 2nd clamp 15 off
                    Not activated
                    Not activated
                menu MOIS after disclaimer
                    Not activated
                menu MOIS standstill
                    Not activated
                menu MOIS over threshold high
                    Not activated
                menu MOIS clamp 15 off
                    Not activated
                menu MOIS
                    Not activated
                menu BSIS after disclaimer
                    Not activated
                menu BSIS standstill
                    Not activated
                menu BSIS over threshold high
                    Not activated
                menu BSIS clamp 15 off
                    Not activated
                menu BSIS
                    Not activated
                menu RushhourPilot after disclaimer
                    Not activated
                menu RushhourPilot standstill
                    Not activated
                menu RushhourPilot over threshold high
                    Not activated
                menu RushhourPilot clamp 15 off
                    Not activated
                menu RushhourPilot
                    Not activated
                menu RollingAbility after disclaimer
                    Not activated
                menu RollingAbility standstill
                    Not activated
                menu RollingAbility over threshold high
                    Not activated
                menu RollingAbility clamp 15 off
                    Not activated
                menu RollingAbility
                    Not activated
                menu DrivingDynamics after disclaimer
                    Not activated
                menu DrivingDynamics standstill
                    Not activated
                menu DrivingDynamics over threshold high
                    Not activated
                menu DrivingDynamics clamp 15 off
                    Not activated
                    Not activated
                menu AirHeater after disclaimer
                    Not activated
                menu AirHeater standstill
                    Not activated
                menu AirHeater over threshold high
                    Not activated
                menu AirHeater clamp 15 off
                    Not activated
                menu AirHeater
                    Not activated
                menu PowerOnDemand after disclaimer
                    Not activated
                menu PowerOnDemand standstill
                    Not activated
                menu PowerOnDemand over threshold high
                    Not activated
                menu PowerOnDemand clamp 15 off
                    Not activated
                menu PowerOnDemand
                    Not activated
                menu Plug and Charge after disclaimer
                    Not activated
                menu Plug and Charge standstill
                    Not activated
                menu Plug and Charge over threshold high
                    Not activated
                menu Plug and Charge clamp 15 off
                    Not activated
                    Not activated
            function_configuration_audio
                sound system
                    internal
                channel 1 HT
                    not installed
                channel 1 TT
                    not installed
                channel 2 HT
                    not installed
                channel 2 TT
                    not installed
                channel 3 HT
                    not installed
                channel 3 TT
                    not installed
                channel 4 HT
                    not installed
                channel 4 TT
                    not installed
                channel 5 HT
                    not installed
                channel 5 TT
                    not installed
                channel 6 HT
                    not installed
                channel 6 TT
                    not installed
                channel 7 HT
                    not installed
                channel 7 TT
                    not installed
                channel 8 HT
                    not installed
                channel 8 TT
                    not installed
                channel 9 HT
                    not installed
                channel 9 TT
                    not installed
                channel 10 HT
                    not installed
                channel 10 TT
                    not installed
                channel 11 HT
                    not installed
                channel 11 TT
                    not installed
                channel 12 HT
                    not installed
                channel 12 TT
                    not installed
                channel 13 HT
                    not installed
                channel 13 TT
                    not installed
                channel 14 HT
                    not installed
                channel 14 TT
                    not installed
                channel 15 HT
                    not installed
                channel 15 TT
                    not installed
                channel 16 HT
                    not installed
                channel 16 TT
                    not installed
                channel 17 HT
                    not installed
                channel 17 TT
                    not installed
                channel 18 HT
                    not installed
                channel 18 TT
                    not installed
                channel 19 HT
                    not installed
                channel 19TT
                    not installed
                channel 20 HT
                    not installed
                channel 20 TT
                    not installed
                channel 21 HT
                    not installed
                channel 21 TT
                    not installed
                channel 22 HT
                    not installed
                channel 22 TT
                    not installed
                channel 23 HT
                    not installed
                channel 23 TT
                    not installed
                channel 24 HT
                    not installed
                channel 24 TT
                    not installed
                microphone 1
                    installed
                microphone 2
                    not installed
                microphone 3
                    not installed
                microphone 4
                    not installed
                welcome sound
                    Off
                channel 25 HT
                    not installed
                channel 25 TT
                    not installed
                Signal flow topology
                    20
                Early engine sound
                    Off
                microphones ANC
                    not installed
            Roller test bench mode, functional
                    Not activated
            5_ghz_wlan
                    On
            same_ssid_for_2_4_and_5_ghz
                    No
            channel_band_width_802_11ac
                    80MHz
            wlan_channel_numbers
                channel number for 2 4GHz
                    6
                channel number for 5GHz
            geocoordinate_create
                    do not create
            geocoordinate_show
                    do not show
            number_to_name_matching_algorithm
                    detect numbers
            sortorder
                    sortorder 4
            calendar_reminder
                acoustic reminder
                    Off
                haptic reminder
                    Off
            function_configuration_sound
                brand sound
                    default
                vehicle readiness sound
                    Not activated
                vehicle leaving sound
                    Not activated
                Microphone for vehicle noise cancelation
                    Not activated
                retractable tweeters
                    Not activated
            function_configuration_navigation
                Country Navigation
                    EU
                Navigation System
                    activated
                gnns antenna Availability
                    activated
                vza
                    activated
                VZO
                    Off
                psd
                    activated
                advanced range display
                    Off
                TPEG availability
                    Off
                LGI
                    Off
                Map Style
                ttraffic information
                    On
            function_configuration_speech
                country language change
                    no country
                SDS Region Flag
                    REGION EU
            function_configuration_sw_update
                UOTA
                    On
                UOTA 2
                    Off
                UOTA onboard tester
                    Not available
                UOTA T Box
                    Not available
            Satellite radio tuner, pre-activated subscription
                SDARS Preparation
                    5
            Bluetooth audio codec
                Audio codec
            Infotainment recorder
                    activated
            Head-Up-Display, configuration
                crossroad detail map transmission mode
                    off
                crossroad detail map compression mode
                    RLE
                crossroad detail map resolution
            Dashboard_Display_Configuration
                navigation map transmission mode
                    IP streaming
                navigation map compression mode
                    H264
                navigation map resolution
                    3
                    off
                coverart
                    bap
                stationart
                    bap
                call picture
                    bap
                dynamic icon
                    bap
                ability switch nav maps
                    No
            function_configuration_rvc
                rear view low rvc
                    active legal screen
                rvc low black screen velocity threshold
                    activated
                rvc low failsafe
                    Not activated
                rvc low black screen trunk open
                    activated
                rvc low lid close delay time
                    8 s
                rvc low videofailure detection time
                    5
            Logging_Configuration
                interface
                memory
                loglevel
            alphabetic_scrollbar
                    On
            ipv4_address_of_subnet_1_on_mib
                segment 1
                    10
                segment 2
                    173
                segment 3
                    201
                segment 4
            ipv4_address_of_subnet_1_on_ccu
                segment 1
                    10
                segment 2
                    173
                segment 3
                    201
                segment 4
            ipv4_address_of_subnet_2_on_mib
                segment 1
                    10
                segment 2
                    173
                segment 3
                    202
                segment 4
            ipv4_address_of_subnet_2_on_ccu
                segment 1
                    10
                segment 2
                    173
                segment 3
                    202
                segment 4
            ipv4_address_of_the_wlan_ap
                segment 1
                    10
                segment 2
                    173
                segment 3
                    189
                segment 4
            ipv6_address_of_subnet_1_on_mib
                segment 1
                    FD30
                segment 2
                    E08E
                segment 3
                    C031
                segment 4
            ipv6_address_of_subnet_1_on_ccu
                segment 1
                    FD30
                segment 2
                    E08E
                segment 3
                    C031
                segment 4
            ipv6_address_of_subnet_2_on_mib
                segment 1
                    FD30
                segment 2
                    E08E
                segment 3
                    C031
                segment 4
            ipv6_address_of_subnet_2_on_ccu
                segment 1
                    FD30
                segment 2
                    E08E
                segment 3
                    C031
                segment 4
            ipv6_address_of_the_wlan_ap
                segment 1
                    FD30
                segment 2
                    E08E
                segment 3
                    C031
                segment 4
                    103
            wlan_ap_local_net_dhcp_lease_time
                lease time
                    72 h
            Menu entries for mobile online services
                    Not activated
            Fan
                    normal
            Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation
                Proximity Sensor Basic Adaptation
                    01013C023C023C025002500264026E0278023C023C023C0250021E021E021E021E0202020214055C
            Dimming_Functional_Illumination_for_Operating_Unit
                X1
                Y1
                    2 %
                X2
                    10
                Y2
                    2 %
                X3
                    50
                Y3
                    6 %
                X4
                    100
                Y4
                    10 %
                X5
                    220
                Y5
                    80 %
                X6
                    253
                Y6
                    100 %
            Dimming_Illumination_for_Display_Unit
                X1
                Y1
                    1 %
                X2
                    10
                Y2
                    1 %
                X3
                    50
                Y3
                    3 %
                X4
                    100
                Y4
                    6 %
                X5
                    150
                Y5
                    44 %
                X6
                    253
                Y6
                    100 %
            Startup_Screen_Sticker_HMI
                Startup Screen Sticker HMI
            Copy multimedia data
                Data medium
                    On
                Optical drive
                    Off
            Ethernet, configuration
                Ethernet activation, branch 1
                    Master
                Ethernet activation, branch 2
                    Deactivated
                Ethernet activation, branch 3
                    Deactivated
                Ethernet activation, branch 4
                    Master
            Navigation receiver GNSS configuration
                Default
                    Not activated
                GPS
                    Not activated
                Galileo
                    Not activated
                Glonass
                    Not activated
                Compass
                    Not activated
                external GPS receiver via bus
                    Not activated
                external GPS receiver 2 via bus
                    Not activated
                Beidou
                    Not activated
                Gnss update rate
                    10
                GNSS over ethernet
                    Not activated
            function_configuration_pso
                pso function
                    Deactivated
                iaa function
                    activated
                iaa function new
                    activated
            ipv4_address_of_subnet_4_on_mib
                segment 1
                    10
                segment 2
                    175
                segment 3
                    202
                segment 4
            ipv4_address_of_subnet_4_on_ccu
                segment 1
                    10
                segment 2
                    175
                segment 3
                    202
                segment 4
            ipv6_address_of_subnet_4_on_mib
                segment 1
                    64816
                segment 2
                    57486
                segment 3
                    49201
                segment 4
                    512
            ipv6_address_of_subnet_4_on_ccu
                segment 1
                    64816
                segment 2
                    57486
                segment 3
                    49201
                segment 4
                    512
            privacy_mode
                supress privacy mode
                    activated
                globe icon
                    Not activated
            Car_net
                settings
                    car net eu nar
            Market_and_brand_specific_preInstSet_of_webapps
                preinstallation set values
                    preinstallation set 2
        Mileage: 21642 km
    Backup
        75 Telematics
        System description: OCUGen3High
        Software number: 5WA035285
        Software version: 0306
        Hardware number: 5WA035285
        Hardware version: H12
        Serial number: 0000000105VIAX795104
        Backup name: Telematics
        Long coding
            023160201968AC209005460160102607
        Adaptations
            Deactivate production mode
                    000000
            Production mode
                    000000
            Pearl_Chain_Generation_Criteria
                Distance
                    500 m
                Driving direction
                    30 °
                Speed
                    30 km/h
                Height
                    50 m
                Time
                    60 s
                Debounce
                    10 m
            Geofencing_Area_First_Radius
                max.value
                    4294967294 m
                min.value
                    1 m
            Geofencing_Area_Second_Radius
                max.value
                    4294967294 m
                min.value
                    1 m
            Geofencing_Area_Width
                max.value
                    4294967294 m
                min.value
                    1 m
            Geofencing_Area_Longitude
                max.value
                    2147483647 °
                min.value
                    -2147483648 °
            Geofencing_Area_Latitude
                max.value
                    2147483647 °
                min.value
                    -2147483648 °
            Driving_Follow_Up_Time
                Driving Follow Up Time
                    5 min
            Remote_Vehicle_Tracking_Mileage_Trigger
                max.value
                    65535 m
                min.value
                    0 m
            Remote_Vehicle_Tracking_Time_Trigger
                max.value
                    65535 s
                min.value
                    0 s
                    +18334227638
                    empty
                    empty
                    empty
            Speed warning maximum speed
                    0 km/h
                Service interval display (SID)
                    activated
                Charge manager
                    Not activated
                Multifunction indicator
                    activated
                Central locking
                    activated
                Parking heater
                    Not activated
                Head-Up Display
                    Not activated
                ACC
                    Not activated
                Interior light
                    activated
                High beam
                    activated
                Parking aid
                    Not activated
                Wiper
                    activated
                BAP-Strecke mirror 0x0E
                    activated
                Seat adjustment
                    Not activated
                BAP-Strecke unit master 0x13
                    activated
                Driving profile selection
                    Not activated
                Lane assistant
                    Not activated
                Lane change assistance
                    activated
                Stopping distance reduction
                    activated
                Road sign detection
                    Not activated
                BAP-Strecke PaCo 0x55
                    Not activated
                Climate control
                    Not activated
                BAP-Strecke remote services 0x4E
                    Not activated
                BAP-Strecke info settings 0x50 Buszuordnung
                    by Ethernet
                BAP-Strecke infotainment settings 0x50
                    Not activated
                Doors
                    Not activated
                BAP-Strecke REM 0x5B
                    Not activated
                BAP-Strecke REM2 0x67
                    Not activated
                BAP-Strecke doors2 0x63
                    Not activated
                IDS 0x7D
                    Not activated
            User profile name
                    blank
            User profile password
                    blank
            Mobile Online services, activation threshold
                Distance for activation
                    0 km
                Lock time during deactivation
                    0 min
            Fuel tank volume
                    70 L
            Dimming charac. curve of red function illumination
                X1
                X2
                    10
                X3
                    50
                X4
                    100
                X5
                    150
                X6
                    253
                Y1
                    1 %
                Y2
                    1 %
                Y3
                    2 %
                Y4
                    4 %
                Y5
                    80 %
                Y6
                    100 %
            Dimming charac. curve of green function illumination
                X1
                X2
                    10
                X3
                    50
                X4
                    100
                X5
                    150
                X6
                    253
                Y1
                    1 %
                Y2
                    1 %
                Y3
                    2 %
                Y4
                    4 %
                Y5
                    80 %
                Y6
                    100 %
            Threshold for vehicle movement recognition
                    5 km/h
            Remote vehicle immobilizer safety protocol
                    Fazit4MyCar
            Vehicle status remote query
                Remote Vehicle Status Clamp 15 On Delay
                    1275 s
                Remote Vehicle Status Clamp 15 Off Delay
                    5 s
                Remote Vehicle Status Bussleep
                    activated
                Remote Vehicle Status Bussleep Delay
                    5 s
                Remote Vehicle Status BEM Alert Changed
                    Not activated
                Remote Vehicle Status Trigger Relock
                    10 s
            Delay of audio output
                    0.0 s
            Remote BatteryCharging Management_Battery Status Report
                Threshold
                    95 %
                StepsBelowThreshold
                    5 %
                Steps Above Threshold
                    1 %
            Transmission_status_activation
                Transmission status activation
                    activated
                No transmission after OTVreques
                    1000 d
                Number of days prior to service schedule before display combi
                    30 d
                Number of days before service reminder
                    0 d
            Gnss data transmission rate
                Data Rate
                    10 Hz
            Gnss min height
                Angle
                    5 °
            Type of fuel
                Petrol
                    installed
                Diesel
                    not installed
                Natural gas
                    not installed
                Petroleum gas
                    not installed
                Battery / electric
                    not installed
                Hydrogen
                    not installed
            supress_climatisation_settings
                    Not activated
            supress_climatisation_temperature
                    Not activated
            Voice_Connection_Timeouts
                Call Failed Timer
                    30 s
                Wait Tone Timer
                    30 s
                Redial Attempts
                Redial Timer
                    2 s
                Voice Data Transfer Failed Timer
                    20 s
            Mobile network operator
                    info.m2mcubic.com
            After-run time
                Long term energy budget
                    3600 mAh
                Short term energy budget
                    1000 mAh
                Waiting period from sleep to standby mode
                    5 min
            Mobile Online services, first host name
                Preselection of host names
                    FREE
                    https://t-h-m.dp.us00.p.con-veh.net:15443/vas/vehicles/v2/deviceRegistered
                Online Service Backend Type
                    AERIS
            Dimming curve of the red functional lighting in case of various colors at the same time
                X1
                X2
                    20
                X3
                    50
                X4
                    100
                X5
                    150
                X6
                    253
                Y1
                    0 %
                Y2
                    1 %
                Y3
                    2 %
                Y4
                    3 %
                Y5
                    40 %
                Y6
                    50 %
            Dimming curve of the green functional lighting in case of various colors at the same time
                X1
                X2
                    20
                X3
                    50
                X4
                    100
                X5
                    150
                X6
                    253
                Y1
                    0 %
                Y2
                    1 %
                Y3
                    2 %
                Y4
                    3 %
                Y5
                    40 %
                Y6
                    50 %
            Keypad
                Keys
                    Three button keypad
                LED
                    Direct
                GPS
                    Off
                Galileo
                    Off
                Glonass
                    Off
                    Off
                beidou
                    Off
                GPS output on CAN
                    On
                Dead reckoning position transmission
                    Off
            Door configuration
                Left rear door
                    installed
                Right rear door
                    installed
                Left Rear Door Control Module
                    not installed
                Right Rear Door Control Module
                    not installed
            Control module switch-off, switch-off time
                Control module
                    255 min
                Data bus
                    60 min
            Wifi hotspot mobile phone connection: network operator
                    wifi.m2mcubic.com
            Wifi hotspot mobile phone connection: user profile name
                    blank
            Wifi hotspot mobile phone connection: password
                    blank
            Vehicle type
                    Passenger car (category M1)
            Dimming characteristics of pushbutton module
                X1
                X2
                    50
                X3
                    100
                Y1
                    0 %
                Y2
                    50 %
                Y3
                    100 %
            Query interval for Real Time Monitoring
                    1 s
            Fault memory mobile online service threshold
                Step 00
                    100
                Step 01
                    100
                Step 02
                    100
                Step 03
                    100
                Step 04
                    100
                Step 05
                    100
                Step 06
                    100
                Step 07
                    100
                Step 08
                Step 09
                Step 10
                Step 11
                Step 12
                Step 13
                Step 14
                Step 15
            Acoustic warning for vehicle shut-down
                    activated
            Geofencing_Area_Height
                max.value
                    4294967294 m
                min.value
                    1 m
                UOTA
                    On
            Activating and deactivating all development messages
                    Not activated
                gnss position debug traces
                    On
            Damping factor for dimming up and down
                Functional Illumination Damping Up
                    0.2 s
                Functional Illumination Damping Down
                    0.1 s
                Ambient Light Illumination Damping Up
                    0.2 s
                Ambient Light Illumination Damping Down
                    0.1 s
            Digital key, backend notification
                    Not activated
            Activation status for local hazard warning service
                Locale hazard warning
                    Off
                Crash
                    Off
                Breakdown
                    Off
                Loss of traction
                    Off
                Visual obstruction
                    Off
                Hydroplaning
                    Off
            Acoustic return message for breakdown assistance call system
                    activated
            Breakdown assistance call, protocol version
                    Generation 20
            Identify Authorize Authenticate - user management
                    installed
            Time window for key recognition
                    5 min
            Authorization level after-run time
                    0 min
            Key recognition mode setting
                    automatic
            User images display
                User images display
                    On
            BCM user switching
                BCM user switching
                    Off
            Permanent safety mode setting
                    On
            Maximum waiting time to transfer UserID from IAA
                    150 ms
            Delay time for synchronization with memory site
                    400 ms
            Operation during severe BAP errors while storing data
                    Operation fortführen
            Maximum synchronization of an unused shadow drive
                    28 d
            Waiting time until change to settings is transferred
                    60 s
            Number of extensions until transfer is completed
                    3 s
            Delay time for picking up changes
                    120 s
            Maximum waiting time for HMI availability
                    5 min
            Download before activating driver (driver already stored)
                    Do not perform download
            Maximum duration of relocation
                    60 s
            Maximum storage duration
                    120 s
            Maximum waiting time before storing is canceled
                    5 s
            Setting the product data
                    10000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
            Broadband audio
                Breakdown assistance/information call
                    Not activated
                Emergency call
                    Not activated
            Private sphere mode, workshop settings
                Services
                    Tracking Data group selected
                Data collector
                    activated
                Basic setting not recognized Guest, services
                    Workshop settings adopted
                Basic setting not recognized Guest, campaigns with interest weighting
                Basic setting not recognized Guest, campaigns with consent
                Display info window for current privacy settings
                    No display
                Display selection for recurring dialog display
                    No display
                Selection for recurring dialog display availability
                    for personalized users
                Reserved
            Private sphere mode, customer settings
                Services
                Data collector
                    activated
                    No display
            Vehicle function list CAN
                Central Electrics
                    activated
                Gateway
                    activated
                Dash Board
                    activated
                Brakes
                    activated
                Engine
                    activated
                Clima
                    activated
                Front door driver
                    activated
                Front door co driver
                    activated
                Steering Column Electronics
                    activated
                seat memory driver
                    Not activated
                Reserved
            Muting of audio sources
                Mute audio sources eCall selection
                    Muting not active
            BAP route control
                Head-Up Display
                    Off
                ACC
                    Off
                Interior light
                    automatic
                High beam
                    automatic
                Parking aid
                    Off
                Wiper
                    automatic
                Central locking
                    automatic
                    automatic
                    automatic
                Seat adjustment
                    Off
                    automatic
                    Off
                Lane assistant
                    Off
                    automatic
                    automatic
                Road sign detection
                    Off
                Climate control
                    Off
                    Off
                    Off
                Doors
                    Off
                    Off
                reserved
                    Off
                reserved 01
                    Off
                reserved 02
                    Off
        Mileage: 21642 km
        Date: 2025-05-05 21:00:26
    Backup
        B7 Start System Interface
        System description: VWKESSYMQB
        Software number: 3Q0959435N
        Software version: 1307
        Hardware number: 3Q0959435N
        Hardware version: 037
        Backup name: Start System Interface
        Long coding
            132C0C0723
        Adaptations
                Control module
                    20 min
                Data bus
                    30 min
                    Deactivating
            Production mode
                Deactivation of automatic shutdowns of terminal 15
                    not active
                Deactivation of automatic rear lid opening
                    not active
                Deactivation of terminal 50 request
                    not active
            rpm_threshold_engine_runnning
                    100 1/min
            Number_of_ZAT_activations_to_DTC
                    10
            Number_of_Multiple_ZAT_activations_to_emergency_shutoff
            Display_duration_please_engage_P
                    10 s
            time_to_drive_cycle_detection
                    1.00 s
            Display_duration_emergency_off
                    3000 ms
            Display_duration_error_mode_2_SPN
                    10 s
            min_time_for_Terminal_50_request
                    200 ms
            Terminal_S_Timeout
                    30 min
            time_to_ignore_ignition_trigger
                    35 s
            delay_time_Terminal_15_S_Shut_down_by_BEM
                    60.00 s
            delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle
                    300 ms
            time_ZAT_actuation_detection
                    3000 ms
            duration_ZAT_debounce
                    50 ms
            time_to_ZAT_Short_circuit_fault_detection
                    60 s
            duration_to_ZAT_continuous_actuation_detection
                    1000 ms
            duration_to_ZAT_multi_actuation_detection
                    3000 ms
            time_ZAT_lock_after emergency_shutoff
                    1000 ms
            time_ZAT_lock_after_normal_shutoff
                    500 ms
            time_to_ZAT_Open_circuit_detection
                    1000 ms
            Speed_threshold_for_moving_vehicle_detection
                    1.0 km/h
            Speed_threshold_for_driving_cycle_detection
                    3.0 km/h
            Speed_threshold_for_terminal_15_emergency_shutoff
                    7.0 km/h
            CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff
                    1.00 s
            Ignition_For_Immobilizer
                    Default
            Terminal_15_adaption_body_control_module
                    Default
            Debounce_time_driver_presence
                    200 ms
            Debounce_time_detection
                    500 ms
            Timeframe_request_immobilizer_terminal_approval
                    10000 ms
            CAN_signal_transmitting_duration_of_comfort_switch_off
                    10.00 s
            CAN_signal_transmitting_delay_of_car_roll _away_warning
                    1.00 s
            Byte13_vit_lf
                vit exit
                    Not activated
                vit evaluate inversbit
                    Not activated
                toggleVariante
                    China
                toggle active
                    activated
                toggle at  open door
                    Not activated
                lock via toggle by closed vehicle skin
                    Not activated
            min_receptiontime_vit
                    0 ms
            Timeout_trigger_terminal_deactivation_central_locking
                    1.00 s
            Diagnostic: wait time after power on
                    500 ms
            CAN-timeout service-key message
                    260 ms
            LED dimming curve first point 20 percent dimming
                    40.0 %
            Delta value LED dimming curve first point 40 percent dimming
                    30.0 %
            Delta value LED dimming curve second point 60 percent dimming
                    15.0 %
            Delta value LED dimming curve third point 80 percent dimming
                    10.0 %
            Delta value LED dimming curve forth point 100 percent dimming
                    5.0 %
            Standard dimming value ZAT
                    80.0 %
            Correction value LED dimming
                    1.0
            ZAT post-carridge during clamp 15 off
                    10 min
            ZAT nominal voltage
                    13.0 V
            ZAT init value
                    0.0 %
            Stop release for start-stop function
                    According to function requirements
            Proximity Sensor: duration of proximity Signal
                    10 s
            Internal
                    0 B
            Passive Entry Exit: T_ACT_OP_2
                    5000 ms
            Passive Entry Exit: minimum activity time locking sensor
                    140 ms
            Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY
                    210 ms
            Passive Entry Exit: control by pulling the door handle during active DSL_timeout
                    2.00 s
            Passive Entry Exit: entry request e-sliding door active time
                    500 ms
            Initialization_diagnostics_switching_terminal
                    Not activated
            Reduced current for transponder-ID request
                    0 Step
            MCTX settling phase
                    10 B
            MCTX pause
                    1 B
            MCTX pause for Go / Key Minder
                    20 ms
            MCTX pause for Go authentification
                    14 B
            Scan Procedure: Timeout Authentification Result
                    150 ms
            Scan Procedure: p_keyless_eventsuche_retries_pause
                    100 ms
            Scan Procedure: Timeout LF Repetition
                    100 ms
            Scan Procedure: Number of Repeats
            Scan Procedure: cycle convenience coverage limiting
                    65 ms
            Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go
                    190 ms
            Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi
                    700 ms
            Scan Procedure: current limiting on undervoltage at Go-protocol
                    5 Step
            ScanProcedure: Timeout Entry Response
                    260 ms
            ScanProcedure: Timeout Response
                    100 ms
            timeout_convenience_coverage_limiting
                    75 s
            internal_passive_entry_exit_byte1
                lf crc
                    Not activated
                Impairment Entry / Exit key on low battery
                    Not activated
                Passive Exit: access door not open
                    activated
                Passive Exit: all doors not open
                    Not activated
                passive exit door slam lock
                    Not activated
            internal_passive_entry_exit_byte2
                Passive Entry Exit: control by pulling door handle during active DSL
                    activated
                Passive Entry Exit
                    activated
                Passive Entry: second control concept
                    Not activated
                Passive Entry Exit: retry with antennastep 1
                    activated
                Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed
                    activated
                lf shutdown
                    activated
                lf shutdown gotrigger
                    Not activated
            internal_keyminder_byte1
                Seat Memory: scan after driver door opening
                    activated
                Seat Memory: scan after driver door opening no KESSY unlocking
                    activated
                Softtouch mounted
                    installed
                Cyclic interior scan during active warning message "Key not found"
                    Not activated
                allowa remotestart to disable keys
                    Not activated
                aktivate function trigger access leaving elv
                    Not activated
            internal_keyminder_byte2
                No locking with ID-transmitter last used interior
                    activated
                Re-open after passive comfort closing
                    activated
                Re-open last handling
                    Not activated
                Re-open tailgate
                    activated
                Lock prevention tailgate
                    activated
                Inhibit ID-transmitter for passive go
                    activated
            DeveloperCoding: Search lights
                ZAT active during clamp 58t on
                    activated
                Standardisation of ZAT
                    activated
                ZAT detecting open load
                    Not activated
                ZAT illumination modus mybeat clamp58xt
                    activated
                ZAT illumination concept mybeat clamp58xt
                    activated
            DeveloperCoding: vehicle environment
                Steering wheel
                    Left-hand drive
                Convertible
                    Not activated
                Pre Catch for Trunk
                    Not activated
                reactivate all doorhandles
                    Not activated
            DeveloperCoding: Passiv Go
                Passive Go
                    activated
                GO only via antenna IN1 if tailgate open
                    Not activated
                GO only via antenna IN1 if sliding door open
                    Not activated
                Passive Go: tailgate authorized to start
                    Not activated
                Impairment go on a low key battery
                    Not activated
            Sonstiges_byte1
                Backdoor TSG
                    Not activated
                Response extension for scan procedure
                    Not activated
                Diagnostic: service 86 - response on event
                    Not activated
                Internal
                    Not activated
                Use default antenna data
                    Not activated
                Battery manager mounted
                    activated
                Scan Procedure: timeoutcontrol active
                    activated
            DeveloperCoding: Proximity Sensor
                AUDI doorknobs mounted
                    Not activated
                Proximity Sensor: sensor stays active after fault detection
                    Not activated
                Detection of an repeated failed doorknob actuation
                    activated
                Suppress fault manager entry "Falschverbau aktiv"
                    activated
                No turn off for driver doorknob while passive
                    activated
                energized doorhandles at stateKL15on when opening door
                    activated
            Byte9_VIP
                active vip
                    Not activated
                vip activation on clamp15
                    Not activated
                vip deactivation on running engine
                    Not activated
                Hitch trailer installation
                    Not activated
                Coding kick and close function
                    Not activated
                Coding easyclose locking
                    Not activated
                ECL Start ueber ViP
                    Not activated
            sonstiges_byte2
                interiorscan clamp15 reach trashhold
                    Not activated
                sad existing
                    activated
                trunk ecu existing
                    Not activated
            Byte12_diverse
                environment scan step1
                    Not activated
                environment scan step2
                    Not activated
                interior scan clamp 15 new concept
                    activated
                exeption drivers doors interior scan
                    activated
                suppression access detection for remotestart
                    activated
                open cabrio canopy interior scan
                    Not activated
            proximity Sensor: max. length of Diagnosticimpuls
                    71 ms
            proximity Sensor: max. length of Entryimpuls
                    10400 µs
            Proximity Sensor: max. length of Exitimpuls
                    40400 µs
            Proximity Sensor: max. Impulslength of proximity-Impuls
                    20400 µs
                    75 ms
            Proximity Sensor: max. intermission-length Diagnostic
                    14 ms
            Proximity Sensor: upper limit intermission-length
                    10 ms
            Proximity Sensor: max. signal-length
                    120 s
            Proximity Sensor: min. length of Diagnosticimpuls
                    42 ms
            Proximity Sensor: min. length of Entryimpuls
                    6200 µs
            Proximity Sensor: min. length of Exitimpuls
                    24200 µs
            Proximity Sensor: lower limit proximity-Impuls
                    12200 µs
            Proximity Sensor: lower limit Impuls
                    2000 µs
            Proximity Sensor: max. length of signal hall sensor
                    100 s
            Doorknob contact sensor disconnecting time
                    5400 min
            Time Sensor Power Off Group 2
                    3600 min
            Proximity Sensor: Time Power On
                    1960 ms
            Key Minder: delay reunlocking tailgate
                    500 ms
            Proximity Sensor: SP_X2
                    10 min
            Proximity Sensor: SP_X3
            Proximity Sensor: SP_X4
                    80
            Proximity Sensor: SP_X5
            Proximity Sensor: SP_X6
                    30 min
            Proximity Sensor: SP_X7
            Proximity Sensor: Timervalue for ExitReverseOption
                    0 ms
            Proximity Sensor: Comfort Exit-Enlargement
                    200 ms
            Proximity Sensor: turn-off limit from battery-manager
            Proximity Sensor: min. enginespeed for a running engine
                    300 1/min
            Proximity Sensor: min Vehiclespeed for a driving vehicle
                    20.0 km/h
            Proximity Sensor: max Vehiclespeed for a standing vehicle
                    10.0 km/h
            Proximity Sensor: min. tolerance data bit length
                    120 µs
            Proximity Sensor: max. tolerance data bit length
                    200 µs
            deactivation_time_vip_slidingdoor
                    15 s
            Time_frame_VIP_kick_forecast
                    5
            Voltage monitoring: undervoltage for Keyless Go
                    6000 mV
            Voltage monitoring: undervoltage Delta
                    500 mV
            Voltage monitoring: undervoltage Jumpstart 1 Delta
                    0 mV
            Voltage monitoring: undervoltage for KESSY ECU
                    9000 mV
            Voltage monitoring: overvoltage for KESSY ECU
                    16000 mV
            Voltage monitoring: overvoltage for Keyless Go
                    27000 mV
            Voltage monitoring: overvoltage Delta
                    500 mV
            Voltage monitoring: overvoltage Jumpstart 2 Delta
                    0 mV
            Cycletime for voltage monitoring during sleepmode
                    100 ms
            settime_trigger_exit_vehicle
                    500 ms
            settime_trigger_entry_vehicle
                    500 ms
            Key Minder: p_keyless_eventsearch_holding_time
                    10 s
            Interior scan: opening threshold window lifter
                    5.0 %
            Interior scan: opening threshold sliding roof
                    1.0 %
            Interior scan: Speed - threshold
                    20 km/h
            Interior scan: max. engine speed for standing engine
                    10 km/h
            Key Minder: p_keyless_eventsearch_retries
            Interior scan: deceleration after comfort closing
                    3200 ms
            Cyclic interior scan during clamp 15 on
                    10 s
            environment_scan_duration_step1
                    300 min
            environment_scan_cyclic_step1
                    700 ms
            environment_scan_duration_step2
                    24 h
            environment_scan_cyclic_step2
                    2000 ms
            environment_scan_responselevel_reduction
                    500
            environment_scan_level_bem
            environment_scan_startdelay_time
                    5 s
            Deactivation of start-stop function
                    not active
            Control module rear lid opening, duration status query
                    4960 ms
            Control module rear lid opening, vehicle type
                    FE
            Easy_close_detection_areas
                Easy close antenna current step
                    E
                Easy close open door antenna current step
                    5
                Value area 4
                    70 V/m
                Value area leaving area
                    65 V/m
            Easy_close_alignment
                RSSI  sample rate
                    500 ms
                Timeframe scan active
                    20.00 s
                Min threashold trunk
                    70 %
                Max time IDGeber rear
                    2.00 s
                max threashold reopen EasyClose
                    30 %
                max time reentry EasyClose
                    5.00 s
                min rssi values hysteresis EasyClose
                    150
                Development messages
                    not active
            ZAT_motor_signal_timer_1
                Time
                    3000 ms
            ZAT_motor_signal_timer_2
                Time
                    3000 ms
            Interior_scans_clamp15_retry_at_active_message
                Interior scans clamp15 retry at active message
                    5
            Interior_scans_clamp15_break_at_active_message
                Time
                    5000 ms
            ZAT_first_rise_time_low_high_state
                Time
                    100 ms
            ZAT_first_fall_time_high_low_state
                Time
                    900 ms
            ZAT_second_fall_time_high_low_state
                Time
                    2000 ms
            ZAT_pwm_offset_1_lower_limit
                    5.0 %
            ZAT_pwm_offset_2_lower_limit
                    10.0 %
            ZAT_pwm_peak1_upper_limit
                    90.0 %
            ZAT_pwm_peak2_upper_limit
                    100.0 %
            ZAT_clamp58xt_signal_factor
                ZAT clamp58xt signal factor
                    0.200
            ZAT_clamp58xt_signal_offset
                ZAT clamp58xt signal offset
                    3.0
            lf_shutdown_timeout_2nd_operation
                    5 s
            duration_A-CAN_wake_up_for_Engine_ECU_wake_up
                Time
                    2000 ms
            Speed_ threshold_for_start_request_plausibilisation
                    10 km/h
            Toggle_offtime_same_doorhandle
                Time
                    2.00 s
            Toggle_offtime_other_doorhandle
                Time
                    2.00 s
            Minimum_holdtime_ak
                Time
                    500 ms
            EasyOpen_optical_active
                    Not activated
        Mileage: 21642 km
        Date: 2025-05-05 21:00:27
    Backup
        CA Sunroof
        System description: SAD_STG_1
        Software number: 4K0907594AC
        Software version: 0002
        Hardware number: 4K0907594
        Hardware version: 006
        Backup name: Sunroof
        Long coding
            00804073163C
        Adaptations
            Travel path
                Sliding position, reduc. opening width
                    not active
                Sliding position, intermed. pos.
                    active
                Tilted position, max. opening width
                    not active
                Sunroof shade, interm. position open
                    not active
                Sunroof shade, interm. position close
                    not active
            Temperature dependent activation
                Open sun roof
                    active
                Open roof blind
                    active
                Close sunroof
                    not active
                Close roof blind
                    active
            Speed dependent activation
                Open sun roof
                    active
                Open roof blind
                    not active
                Close sunroof
                    not active
                Close roof blind
                    not active
                Reduce sunroof tilt
                    not active
            Logic switch-over, controls
                Sunroof button
                    not active
                Button for sliding roof
                    not active
                Sunroof shade button
                    not active
                Button for sunroof/tilt roof, rear
                    not active
                Sunroof shade button, rear
                    not active
            Production mode
                Production mode, stand-alone operation
                    not active
                    Deactivating
                    not active
            Applikationmode deactivate
                    Deactivating
            Power sunroof control module - convenience function
                Target position for comfort opening
                    Tilt out posi.
                Comfort opening of roof shade
                    active
                Comfort closing of roof shade
                    active
                Private sphere mode
                    not active
                Comfort opening sunroof
                    active
                Sunroof comfort closing
                    active
        Mileage: 21642 km
Westbury, UK
That's an OBD11 scan but this is a forum run by Ross-Tech to support owners of genuine VCDS.
If you have genuine VCDS then please post an Auto-Scan.
If you only have OBD11 then you need to ask for assistance on their support forum.
Timirey
Chisinau, Moldova
Sorry mate, but does this really matter what type of scan I do use?
I am having an issue with the car itself, not with the scanner, and odis/vcds/obd11 share absolutely the same adaptations and codings names.
In the end, I thought that people here share the same hobby and love for cars, but not dividing them into "vcds" users and "others".
You don't have to be like that :).
Westbury, UK
Yes, as I said this site is run by Ross-Tech (the makers of VCDS) to support their customers, if you're not one of their customers then you're asking for help in the wrong place.
Timirey
Chisinau, Moldova
Is this written anywhere here that says that I am not allowed to ask for help on this forum, if I am not owning a VCDS device? Or it's just your personal opinion and assumptions?
This is a public forum, with open registration. Anybody on the internet can come, register, and ask for help at any point of time.
I do get your opinion, but you don't have to be that toxic and selfish, just because a person who asked for help does not belong to your "PREMIUM" club.
And I got to emphasize again, in case you didn't get it - I am not looking for device support, I am looking for a solution to the problem I met with my car.
Disgusting community (at least you made it look this way on my first impression)
Please see post #3.
Viking
C?ID=151455
Oh, you can certainly register here and ask, but unfortunately the answer will be as stated. If you're unable to post an auto scan with a legitimate VCDS system but insist on using a competitors tool, then this is not the place for you. As far as I know, OBD 11 have a support forum. That would be the place for your queries as you appear to be one of their customers.
Timirey
Chisinau, Moldova
It would not surprise me if they sent him here. ;)
It's much simpler, I thought that a lot more smarter people are located here, but the community of VCDS unfortunately is awful and too arrogant. Instead of sharing and helping.
"How dare you writing your message here" - ah vibes.
If you will share a VCDS or ODIS scan anywhere (either obd11 forum, or odis forum), people will actually help you, instead of being bunch of ssholes
Viking
C?ID=151455
Take your beer bought at the Kings Head & take it into the Black Bull, take a seat at the bar and try joining in the conversation mate. They make their living (and pay the rent etc) from selling their own beer. That's what happens here. You buy a tool from someone else & turn up here asking how to use it etc.
Ross Techs support forum is for Ross Techs customers I'm afraid, it's not that hard to understand is it?
Timirey
Chisinau, Moldova
I get that you are a shit community, no more words needed. Mate.
Viking
C?ID=151455
And yet here you are still... 🤔
That's probably true. Now ask yourself why that might be?
