Output Test problem 09 central electrics
pncarrerars
C?ID=13488
I hope that this is not considered a repeat posting but I thought that I should post in the correct forum the problems that I am having whilst using the lastest beta for output test on 09 central electrics to try to find the cause of a "vehicle lighting" fault.
Initially I could not get output test to work but have now found that the "actions" are reversed. If the action is set to "on" the output is actually turned off and vica versa. Also for most, if not all, of the car front lights there is only one entry in the list eg "Fog light" which is actually "Left fog light". There are no entries for the right lights. I can only work the front left high beam, low beam & fog light but none of the right as they are not in the list. A full scan is below to give the car details.
Thursday,08,May,2014,13:41:44:62831
VCDS Version: 14.5.0.0
Data version: 20140501
VIN: TMBKJ7NE2E0017506   License Plate:
Mileage: 8272km-5139mi   Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 20 42 44 52 5F
VIN: TMBKJ7NE2E0017506   Mileage: 8272km-5139miles
Address 01: Engine (J623-CKFC)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5514
   Revision: 83H22---
   Coding: 11190012032501090000
   Shop #: WSC 73430 031 00209
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
   ROD: EV_ECM20TDI01104L906021DS_SK37.rod
   VCID: F9F3F534782CBDF360-80AC
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 615330000000DE
   Coding: 1C078A9124210973007C060041C9243851249000608224F000630070C002
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
   VCID: CB9F7FFC6230FF6382-809E
   Part No SW: 5E0 907 044 C    HW: 5E0 907 044 C
   Component: Climatronic   H02 0604
   Revision: 00001K06
   Coding: 02110104000100011005000100100000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: A54BE944A414E91374-80F0
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011315000690
   Coding: 0F000966424702FB07A04082B11C07280000000000000000000000000000
   Shop #: WSC 73430 790 00000
   ROD: EV_BCMBOSCH_SK37.rod
   VCID: F7F7F30C4E38AB8316-80A2
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119
   Component: WWS371 130514  041 0570
   Serial number:         130523105227
   Coding: 065DDD
   Component: RLFS  024 0042
   Serial number: Y13M06D11H03M25S31S1
   Coding: 02805D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY131002FPU
   Serial number: 00000000000056886695
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831313600748
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: B875303003A664FBDF-80ED
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   011 0188
   Revision: --------    Serial number: 003P4PBG1XQF
   Coding: 98CCC000000000005C5400CC008800000065
   Shop #: WSC 73430 790 00209
   ROD: EV_AirbaVW20TS6VW48X_SK37.rod
   VCID: FF071B2C660893C35E-80AA
   Subsystem 1 - Part No SW: -----------    HW: 454 002 105 13
   Serial number: 3576U0000002C84CBC0Q
   Subsystem 2 - Part No SW: -----------    HW: 454 002 405 13
   Serial number: 3586U0000009A25CBC0R
   Subsystem 3 - Part No SW: -----------    HW: 454 801 505 13
   Serial number: 3516RFC8356010000006
   Subsystem 4 - Part No SW: -----------    HW: 454 801 505 13
   Serial number: 3526RE3815601000000
   Subsystem 5 - Part No SW: -----------    HW: 454 802 303 13
   Serial number: 3556VB5355300000000$
   Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
   Revision: --------    Serial number: 07061304221522
   Coding: 1400
   ROD: EV_SMLSKLOMQB_SE37.rod
   Part No SW: 5E0 920 971 D    HW: 5E0 920 971 D
   Component: KOMBI         333 2210
   Coding: 27A40A002180A60001086A00000000
   ROD: EV_DashBoardVDDMQBAB_SK37.rod
   VCID: AA511A78CD0AC66B59-80FF
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000656970
   Coding: 030100040B087300EF000648080F00010001000000000000000000000000
   ROD: EV_GatewLear_AU37.rod
   VCID: BB7F2F3C32904FE332-80EE
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H04 0120
   Serial number: 000000000A0331270513
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 2020930603
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 01028F6B74745D545420363E00
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: AB5F1F7CC2F0DF63A2-80FE
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000064267946
   Coding: 00150020D001020000001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 820192D815FAFE2B31-80D7
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000259164
   Coding: 1D0200
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 81
   ROD: EV_SteerAssisMQB.rod
   VCID: BD7B21242C8441D30C-80E8
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000064351274
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 81039DD410FCE53328-80D4
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000255216
   Coding: 050200
   Part No SW: 5E0 035 874 A    HW: 5E0 035 874 A
   Component: MU-S-ND-ER    040 0407
   Serial number: S7F00606130468
   Coding: 03730201FF0000001111120100A800002F0000860100010046
   ROD: EV_MUStd4CPASE_SE37.rod
   VCID: A649EE48D912E20B7D-80F3
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5E0 919 605 D    HW: 5E0 919 605 D
   Component: ABT_Std_Nav  H50 0022
   Serial number: SKZ8Z9NK80008J
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5E0 051 236 C    HW: -----------
   Component:  ECE 2014  --- 0036
I'm not ready to accept that this is a problem with VCDS. See my reply here.
