- Oct 17, 2017
- 1,109
- 554
- Northwest UK
- C?ID=321059
Hi
I retrofitted CCS and installed a replacement stork and the wire from the Steering to the ECM.
I'm struggling to work out why I am getting this error. Any ideas/suggestions..
Mohammed
Mohammed
Friday,19,September,2025,19:11:46:58300
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
Dealer/Shop Name: VW UK
VIN: TMBKJ7NEXE0017446 License Plate: FW13 CYV
Mileage: 175391km-108982mi Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F 69
VIN: TMBKJ7NEXE0017446 Mileage: 175391km-108982miles
Address 01: Engine (J623-CKFC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5520
Revision: 83H22--- CVN: 4B545CBB
Coding: 111D0012033501090000
ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AAC0754FC51621AC07-802E
VINID: 91D49B687795A150000471041881C18B8C
17165 - Databus
U1123 00 [00100111] - Received Error Message
Mileage: 175391 km
Date: 2025.09.19
Time: 00:32:58
Engine speed: 0.00 /min
Coolant temperature: 51 C
Intake air temperature: 48 C
Voltage terminal 30: 12.220 V
ACC variants-Bits 0-7: 0
CCS Switch-Bits 0-7: 1
Cruise control switch actuation-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 48
ACC variants (coding)-Bits 0-7: 1
Acceleration: 0.000 m/s
17166 - Cruise Control Switch (E45)
P0568 00 [00100111] - Implausible Signal
Mileage: 175391 km
Date: 2025.09.19
Time: 00:32:58
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [00100110] - -
[Checking coding/versions ofcontrol modules in drivetrain]
Mileage: 175391 km
Date: 2025.09.19
Time: 00:32:59
Part No SW: 0D9 300 040 K HW: 02E 927 770 AN
Component: DQ250-6F MQB H52 4005
Revision: 05652104 Serial number: TFK01304250950 CVN: 0000793E
Shop #: WSC 73430 031 00063
ROD: EV_TCMDQ250021.rod
VCID: 1F1A16C00733E732979-804A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 6153300000009C
Coding: 1C078A9124210973007B060441C9243851249000608224F000610070C002
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033_SK37.rod
VCID: 4BC29290E34B2B922B1-801E
Part No SW: 5E0 907 044 HW: 5E0 907 044
Component: Climatronic H02 0604
Revision: 00001K06
Coding: 02110104000100011005000000100000
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_002_VW37.rod
VCID: 629C5F3474C18ADAF87-8036
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011428902884 Dataset Number: 5E0063t____ 0059
Coding: 0F001842424700DB07A04082B10407280000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 005875BC9A8D38CA8E3-8054
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 130514 041 0570
Serial number: 130523105145
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY131002FUD
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000056896879
Humidity sensor: interior:
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20384914
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831313600738 Dataset Number: 5E0039t____ 0001
Coding: 0001050111
ASAM Dataset: EV_EPHVA14AU3700000 002018
VCID: 3828DD5C82DDB00A763-806C
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 011 0188
Revision: -------- Serial number: 003P4PBG1VRE Dataset Number: 5E0003t____ 0048
Coding: 98CCC000000000005C5400CC008800000065
Shop #: WSC 73430 790 00063
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5AF640E7734732F79-802A
Subsystem 1 - Part No SW: ----------- HW: 454 002 405 13
Serial number: 3576U000000A375CBC0P
Subsystem 2 - Part No SW: ----------- HW: 454 002 405 13
Serial number: 3586U00000075938EC0O
Subsystem 3 - Part No SW: ----------- HW: 454 801 505 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R01215E01000000N
Subsystem 4 - Part No SW: ----------- HW: 454 801 505 13
Component: SideSensor_Pr 111 0148
Serial number: 3526RCC8E6401000000E
Subsystem 5 - Part No SW: ----------- HW: 454 802 403 13
Component: FrontSensor_D 114 0149
Serial number: 3556VDD2C5300000000C
Part No SW: 5Q0 953 507 AD HW: 5Q0 953 549
Revision: -------- Serial number: 03091404401227 Dataset Number: ----------
Coding: 1600
ROD: EV_SMLSKLOMQB_009.rod
VCID: 78A81D5CC25D700AB63-802C
Part No SW: 5E0 920 961 E HW: 5E0 920 961 E
Component: KOMBI 204 3360
Coding: 27A40A082180A60001082A00040000
ASAM Dataset: EV_DashBoardJCIMQBAB 008011
ROD: EV_DashBoardJCIMQBAB_008.rod
VCID: 2A0CF7144C71129AF07-807E
Part No SW: 5Q0 907 530 K HW: 5Q0 907 530 D
Component: GW MQB Low 123 1144
Revision: -------- Serial number: 0000662571 Dataset Number: 5E0067t____ 0012
Coding: 030000040B087300EF0002481C0F00010001000000000000000000000000
GVL: 01543C0000000000C00C00000000C80000000000000000000000000000000000
ROD: EV_GatewLear_009.rod
VCID: 392ED858B9D7A90289D-806C
Generator:
Subsystem 2 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 4635930603
Part No SW: 5Q4 959 393 HW: 5Q4 959 393
Component: TSG FS 007 0006
Serial number: 0000064382902 Dataset Number: 5E0222t____ 0009
Coding: 001000208001020000001100
VCID: 55F674E8358F6D628D5-8000
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000258071
Coding: 1D0200
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Dataset Number: 5E0074t____ 0006
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D26CC48ADFF9522A55-8068
Part No SW: 5Q4 959 392 HW: 5Q4 959 392
Component: TSG BFS 007 0006
Serial number: 0000063952299 Dataset Number: 5E0157t____ 0009
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000251765
Coding: 050200
Address 5F: Information Electr. (J794) Labels:| 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 842 A HW: 5E0 035 842 A
Component: MU-S-D-ER 040 0407
Serial number: S7E02805131449 Dataset Number: 5E0CV1t____ 0032
Coding: 03730200FF0000001111120100A800002F0000860100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 211E10383147D1C2A1D-8074
Subsystem 1 - Part No SW: 5E0 919 605 B HW: 5E0 919 605 B
Component: ABT_Std_Plus H50 0022
Serial number: SKZ8Z9NK60038T
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anheanger H21 0203
Serial number: 00006789045536 Dataset Number: v12400160G0 0016
Coding: 0100000202000000
VCID: 3B22C250B3EB9B129B1-806E
End----------(Elapsed Time: 01:14, VBatt start/end: 12.2V/12.2V)-----------
------------------------------3 Faults Found-------------------------------
