Hi all
I have an AUDI A3 8P. No previous auto-scan (first time i've seen the vehicle)
I have been told the cluster was unplugged and now have no coding in the ABS just showing 00000000000000000000's
Anyone want to offer up a code ?? Much appreciated
Thanks Chris
Thanks Chris
Thursday,21,January,2016,16:25:15:26527
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WAUZZZ8P19A122812 License Plate: FG09 LHR
Mileage: 138770km-86227mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 55 56 62 72 77
VIN: WAUZZZ8P19A122812 Mileage: 138770km-86227miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 LS HW: 03L 906 022 BQ
Component: R4 2,0L EDC 0000SG 3610
Revision: 13H01--- Serial number: AUX7Z0I1FNQ01G
Coding: 0000072
Shop #: WSC 83968 420 592518
VCID: 01098122586E95367E-8054
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 06314 000 00000
VCID: 74E7D8F6D7DCB09E65-8020
Reset counter: 124
Date: 2017.01.16
Time: 00:12:04
Count: 3
Count: 4608
Count: 195
Count: 45824
Count: 65280
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000130 Serial number: 8P0820043BG
VCID: 72EBDEEE6DC8BEAE77-8026
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009442950
Coding: 118A0F81B0141380EF00000A0000000000084E0564060403642000000000
Shop #: WSC 06314 000 08192
VCID: 489F5C063BD4647EF9-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
01800 - Light Switch (E1)
Reset counter: 128
Mileage: 138615 km
Date: 2017.01.16
Time: 07:11:00
Voltage: 13.05 V
Fault Status: 00111010
Reset counter: 167
Mileage: 138600 km
Date: 2017.01.16
Time: 00:16:00
Voltage: 14.00 V
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Fault Status: 00101100
Reset counter: 167
Mileage: 138772 km
Date: 2016.01.21
Time: 10:49:00
Voltage: 14.10 V
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 F HW: 8P0 919 475
Component: PARKHILFE 4K H06 0102
Revision: 11001001 Serial number: 52340906100214
Coding: 000003
VCID: 41894122D8EE55363E-8014
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003CA005E4NS
Coding: 303142383038303030374A55305238503053
ROD: EV_Airba10AURB4.rod
VCID: 49995902E8DE9D76E6-801C
Serial number: 3572DRB400008314F8C.
Serial number: 3582DRB400008320C14H
Serial number: 35128RB400004B41013%
Serial number: 35228RB400004B411A18
Serial number: 35547RB400004B6C199W
Serial number: 35647RB400004B6C13AS
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004012
VCID: 4189412218EE55363E-8014
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H19 0860
Revision: D0H19007 Serial number: 2241I007016904
Coding: 0004428
Shop #: WSC 63170 067 57207
VCID: 397929C2703E0DF676-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K093050989
Coding: E9A17F06000602002103
VCID: 377D2FFA462A1B8680-8062
Revision: D0H19007 Serial number: AUX7Z0I1FNQ01G
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000692
VCID: 43854B2A02F247262C-8016
00912 - Window Regulator Switch; Front Left (E40)
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 233 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C5700968F6CA85EFD-8078
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D0985054C9FC637
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000692
VCID: 4487483607FC401E15-8010
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Coding: 0000013
VCID: 7AFBF6CE35B8C6EE3F-802E
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H04 0270
Revision: 00H04000 Serial number: AUZ1Z3I9732020
Coding: 0710201
VCID: 3F8D47DA6E1A23C648-806A
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 428B4E2E1DE84E2E27-8016
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005073536
Coding: 0001222
VCID: 4683523E31C0720E0B-8012
End-------------------------(Elapsed Time: 02:16)--------------------------
