Unable to read NOx sensors on 2009 TDI Touareg 3.0
casioqv
California, USA
C?ID=502948
I have a 2009 Touareg with the 3.0 TDI engine, and it has an adblue "death countdown" that will not reset that I am trying to fix.
I took it to the dealer, and they wanted to replace the rear NOx sensor, but I suspect they just didn't warm the engine up enough, as the sensor is OEM and under 2 years old, so I brought back the car to diagnose and fix on my own. They told me they were seeing a reading from the front NOx sensor, but not the rear one.
However, I cannot seem to read either sensor with VCDS. There are 4 channels in "Advanced Measuring Values" marked as NOx sensors (129-3, 129-4, 229-3, and 229-4) and they always read "NOX-S1 1", "NOX-S2 1", 0.0, and 0.0 respectively even after driving 20 minutes on the freeway to warm them up.
I suspect that there aren't correct maps for this vehicle for these channels, as there are a huge number of measuring block outputs that obviously represent various sensors, but are unlabled in the system when I page through them.
Any idea how to figure out where to read the NOx sensors on this car? There is a lot of info out there, but it almost all seems to apply only to later UDS T3 Touaregs.
I have attached here a VCDS autoscan:
Wednesday,03,September,2025,21:19:14:65527
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 25.3.1.2  HEX-V2 CB: 0.4671.4
Data version: 20250604 DS365.0
VIN: WVGFM77L09D037073   License Plate:
Mileage: 257990km-160307mi   Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2E 37 46 47 55 56 65 68 69
          6C 6D 6E 76 77
VIN: WVGFM77L09D037073   Mileage: 257990km-160307miles
68-Wiper Electr. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (CAT)       Labels:. 059-907-401-CAT1.clb
   Part No SW: 7L0 997 401     HW: 7L0 907 401 K
   Component: 3.0TDI FSA  G004AG  0010
   Revision: 33H01---    Serial number: VWX3Z0I2847313
   Coding: 0421002A590F0968
   Shop #: WSC 83840 280 600584
   VCID: 71BFDAE06DB6E5F2707-5184
   VINID: 9E65D67471DC0095000C70070CEEDA8A26
012558 - Bypass Valve for EGR Cooler 2
               P310E - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 257817 km
                    Date: 2025.08.27
                    Time: 07:59:38
                    RPM: 1974 /min
                    Speed: 43.7 km/h
                    Inj. Quantity: 6.0 mg/str
                    Temperature: 318.6∞C
                    Temperature: 212.4∞C
                    Duty Cycle: 66.0 %
                    (no units): 56.0
008319 - Reductant Quality Performance
               P207F - 000 -  - MIL ON
                    Mileage: 257967 km
                    Date: 2025.09.03
                    Time: 17:57:20
                    RPM: 1428 /min
                    Speed: 71.7 km/h
                    Voltage: 14.21 V
                    Temperature: 318.0∞C
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 1.02
Readiness: 1 2 0 0 0
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 HN    HW: 09D 927 750 HN
   Component: AL 750 6A           3403
   Revision: 00H75000    Serial number:
   Coding: 0004984
   Shop #: WSC 41870 001 1048576
   VCID: 015F8A205D16F572807-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 P    HW: 7L0 614 517 C
   Component: ESP ALLRAD MK25E1   0304
   Revision: 00H53001
   Coding: 0004354
   Shop #: WSC 31414 790 00001
   VCID: 46D5593C34E8124AF55-8012
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 135 C    HW: 7L0 909 135 C
   Component:    Kessy            6850
   Revision: 00H22072    Serial number: VWX3Z0I2847313
   Coding: 0000232
   VCID: 313F1AE0AD66A5F2307-8064
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AL
   Component: CLIMAtronic R/L     4537
   Coding: 0023030
   VCID: 7AADFDCC3090A6AAC1D-802E
02101 - Side Vent Motor (V262)
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2004
   Revision: -0004---    Serial number: --------------
   Coding: 220008002F00BC000000000000000000
   VCID: 00598F24564CFC7A8F9-8054
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234__3N VW8T       0250
   Revision: 92012025    Serial number: 0039P0078L0U
   Coding: 0013134
   VCID: 7AADFDCC30C0A6AAC1D-5184
   Subsystem 1 - Part No: 7L0 959 339 F
   Component: BF-Gewichtsens. 007 0010
   Subsystem 2 - Serial number: 3VJ9M
   Subsystem 3 - Serial number: 0001.01.000000700000000000ˇ
   Subsystem 4 - Serial number: 000000ˇ
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 F
   Component: J527                3601
   Coding: 0010011
   VCID: 42DD452C18C02E6AD9D-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 990 P    HW: 7L6 920 990 P
   Component: J285 KOMBI-INST.    9733
   Revision: KHH06V42
   Coding: 0007201
   Shop #: WSC 63055 003 1048576
   VCID: 46D5593C34A8124AF55-8012
                    Reset counter: 8
                    Mileage: 257725 km
                    Date: 2025.08.17
                    Time: 13:15:01
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 990 P
   Component: J533  GW-K-CAN TP20 9733
   Coding: 77E2F7DBCB846002
   VCID: 70B9DFE466ACECFA7F9-8024
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0084
   Revision: A1001003    Serial number: 7667366993
   Coding: 020000
   VCID: 2615F9BC98E8F24AD55-8072
   Part No SW: 3C0 035 684 K    HW: 3C0 035 684 H
   Component: RNS-MID       H02 4366
   Revision: AB001001    Serial number: VWZ6Z7M8207133
   Coding: 00010000010000200000
   VCID: 2B030888830ACF220AB-807E
   Subsystem 1 - Part No: 7L6 919 859
   Component: NAR V12  8534
                    Reset counter: 230
                    Mileage: 239736 km
                    Date: 2024.03.12
                    Time: 02:28:05
                    Reset counter: 230
                    Mileage: 239736 km
                    Date: 2024.03.12
                    Time: 03:18:44
01550 - Signal for Reverse Gear
                    Reset counter: 90
                    Mileage: 240369 km
                    Date: 2024.07.19
                    Time: 17:07:17
                    Fault Status: 00100111
                    Reset counter: 14
                    Mileage: 253720 km
                    Date: 2025.06.20
                    Time: 09:09:15
Address 46: Central Conv.        Labels: 7L0-959-933.clb
   Part No: 7L6 959 933 A
   Component: 4M HSG              0601
   Coding: 0000085
   VCID: 40D94F24169C3C7ACF9-4B1E
   Subsystem 1 - Part No: 7L0 959 701 M
   Component: Tuersteuergeraet FS 6304
   Subsystem 2 - Part No: 7L0 959 702 M
   Component: Tuersteuergeraet BF 6304
   Subsystem 3 - Part No: 7L0 959 703 C
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 C
   Component: Tuersteuergeraet HR 0201
   Part No SW: 7L6 035 456 C    HW: 7L6 035 456 C
   Component: 08K Audioverst.     0001
   Revision: 00001000    Serial number: 00000000214608
   VCID: 333310E8573A97E242B-8066
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
   Component: AFS-Steuergeraet    0136
   Coding: 1290371
   VCID: 3B2338C87F2A5FA29AB-806E
   Coding: 00000019
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000019
                    Reset counter: 230
                    Mileage: 239736 km
                    Date: 2024.03.12
                    Time: 02:28:05
                    Reset counter: 230
                    Mileage: 239736 km
                    Date: 2024.03.12
                    Time: 03:18:44
                    Reset counter: 90
                    Mileage: 240369 km
                    Date: 2024.07.19
                    Time: 17:07:17
                    Reset counter: 14
                    Mileage: 253720 km
                    Date: 2025.06.20
                    Time: 09:09:15
Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl
   Part No SW: 7L6 907 273 E    HW: 7L6 907 273 E
   Component: J0502 RDK           0006
   Revision: 00004006    Serial number: 00000600012486
   Coding: 0440008D8D0000000000000000
   VCID: 3A2D3DCC701066AA81D-806E
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 B
   Component: J400__ Front Wiper  5301
   Coding: 0001397
   VCID: 392F22C075566DB2887-806C
   Component: RLS     190309 054  0402
   Coding: 00208941
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
   Component: J345  Anhaenger     0080
   Revision: 4A008002    Serial number: 00000117332719
   Coding: 0016386
   VCID: 3FDB4CD86B324382B63-806A
   Part No SW: 7L6 907 441 B    HW: 7L6 907 441 B
   Component: J772__Rearview      0033
   Revision: 00H13000    Serial number:    PA8 J920149
   Coding: 0110001
   VCID: 343113F4523490DA5B1-8060
Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
   Part No SW: 7L6 959 107 B    HW: 7L6 959 107 B
   Component: J605  HECKKLAPPE    1310
   Revision: --H05---    Serial number: --------044577
   Coding: 0122110
Address 6E: Ctrl Head Roof        Labels: None
   Part No SW: 7L6 919 044 AD    HW: 7L6 919 044 AD
   Component: J702  Dachdisplay   0401
   Revision: 1030006S    Serial number: 00000000111596
   VCID: 79AFE2C035D6ADB2C87-802C
   Part No: 7L0 919 283 F
   Component: 0L Einparkhilfe     1108
   VCID: 392F22C075166DB2887-806C
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 D    HW: 1Z0 035 729 D
   Component: FSE_2P8x        H35 0160
   Revision: 00000000    Serial number: 00000005022402
   Coding: 0012077
End----------(Elapsed Time: 02:28, VBatt start/end: 12.5V/12.5V)-----------
------------------------------12 Faults Found------------------------------
If desired, I can go through everything else I have done to diagnose this issue (or see link here at ClubTouareg), but I have confirmed that the adblue injector output and pressure are correct, the injector is clean and sprays well, the output test resulted in 26ml and 4.9 bar, the tank is full with new DEF, and the fill level is set. MVB 174.1 reads "100" - registering that the tank is full.
I asked you where you're looking in our private chat, and although you said you were looking in both places, this tells me you're only looking under measuring values instead.
This is measuring blocks, and where you are looking
This is advanced measuring values where I asked you to look
One of these things is NOT like the other.
casioqv
California, USA
C?ID=502948
I was looking at both, including searching for "nox" and logging and graphing all 4 channels that come up in Advanced Measuring Values.
I also went through everything in measuring blocks to see all of the data being produced by the engine, and there are sensors that look like they could be NOx sensors, but are unlabeled.
See here, apologies for the camera screenshot (I hate it when people do that, but this VCDS tablet didn't have internet access):
Have you looked at your aux cooler's valve and solenoid? Ran output tests to ensure it functions?
casioqv
California, USA
C?ID=502948
No, I have been trying first to fix the SCR system first so I could clear the countdown, but your comments in private chat convinced me that they can't really be treated as isolated systems- I will now look into this sooner rather than later.
I did drive while graphing the EGR output as seen in the screenshot above, and the actual closely follows the demand.
Overall, it seems highly implausible to me that both NOx sensors have failed simultaneously given all of the evidence:
  • one NOx sensor is a brand new OEM part some ~10-15k miles ago
  • it never has posted codes about implausible values
  • the dealer claimed they were seeing readings from the front sensor just this week
  • my historical VCDS scans show that the values have always been 0.0 for these two channels
Seems far more likely that those are simply not the correct channels for reading the NOx sensors.
EGR flow and EGR cooling are different things though.... so I'd suggest trying to fix the DTC that you have, as we all know how controllers and DTCs in the engine controller can cockblock other systems from playing along.
If my memory serves me correct, the bypass valve(s) are regulated and cycled during normal engine operation and deceleration in order to maintain correct operating temps for things like CATs.... so if yours is stuck, you'd probably have issues reaching and maintaining required system\component temps, which could also be a factor into why your DeNOx can't do its job.... it may not be related to the DEF quality or whatever.
casioqv
California, USA
C?ID=502948
Now that is a very interesting hypothesis... because it could also account for both of the NOx sensors not being able to warm up enough to function, and/or stay clean. I could believe they are both actually reading 0.0 if it's from the same underlying cause. Besides fixing the EGR, I may try pulling them and taking a blow torch to them to clean them off, as often recommended on here.
Might want to also check that you don't have a lazy EGT or anything like that... lots of components need to play together to make everything happen properly.
casioqv
California, USA
C?ID=502948
Soot, you're a genius. I'll dig in and let you know if this is right.
If true, I'm sure it's confounded by the fact that I live in a dense area and there is just too damn much traffic to ever really run the engine hard or really warm stuff up. I drove it a while yesterday while plotting the NOx outputs, but I had trouble getting the vehicle over 20mph or well above idle RPMs due to heavy stop and go traffic.
The dealer was trying to just warm up the sensors running the engine at high idle in the shop, which I also doubt would have worked.
Edit: However, I still suspect these are the wrong channels labeled at NOx sensors, we will see.
casioqv
California, USA
C?ID=502948
Update: It turns out I can read the NOx sensors via OBD, using my phone and an OBDlink bluetooth dongle, and they both work properly. So at some point I will circle back and investigate deeper why VCDS cannot read them.
My ClubToureg link in the first post shows a lot more progress in figuring out this problem, but no final success yet. The "Bypass Valve for EGR Cooler 2" fault was caused by a vacuum line routed incorrectly against the exhaust system, causing it to melt.
My current thinking is that the readiness test just isn't completed yet for the Adblue system, but everything is working as intended. Eventually a lot of driving should reset it, but the countdown doesn't make that much driving really possible, until now, because (as mentioned on ClubTouareg), I was also successful in resetting the SCR lock, so I can reset the countdown from 0 to 50 to enable restarts. The working procedure for resetting the SCR lock on my vehicle is the one in VW Tech Tip 26-19-01TT, however it must get all the way to 0 before you can perform it.
Here is my current readiness data:
Saturday,13,September,2025,20:43:06:65527
Readiness Status: 00000000 00001111 11101011 00000010
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Passed
Number of EOBD-related DTC(s): 0
Any idea how to interpret these bits? Ross Tech Wiki says there are 8 readiness bits, but there are clearly 16 displayed. Does 0 mean passed or does 1 mean passed? Should they all read 0 or 1 if everything is set as ready?
NEtech
Denmark
C?ID=56995
Have you tried [OBD-II]?
I guess there is NOx sensor 1 value in MWB 176 and sensor 2 in MWB 177.
And maybe voltage for NOx controller when it is started.
casioqv
California, USA
C?ID=502948
Thanks for the reply. Yes, in the post I made right above yours (#12) I report that OBD can successfully read the NOx sensors (w/ an OBDLink MX+ bluetooth dongle), and both sensors work properly and indicate that the SCR system is also working as it reduces NOx to about 1/4 to 1/2 what it is coming into the system.
At some point I will check those measuring blocks you mentioned, and see if I can figure out how to read these with VCDS, but for now I am confident there is no issue with my NOx sensors, and that is not the cause of the continued adblue countdown.
casioqv
California, USA
C?ID=502948
You guys were correct about the NOx sensors- they can be read both in OBD-II in the standard way, and they also output on MVB 176.1 and MVB 177.1. I cannot confirm which sensor is which. The MVBs currently labeled in VCDS as NOx are incorrect for this vehicle, and likely also on the 2010 Touaregs. Is there anything I can do to help contribute this info back to future versions of VCDS?
Also, the adblue countdown is fixed now... this morning the adblue countdown jumped from 20 miles to 8100 miles, and then after another restart it was clear, and the vehicle works normally again.
For anyone struggling with clearing the adblue countdown- this was driving with the three faults still posted to the engine ECU that were caused by the VW procedure of pulling a fuse and cycling the key. So it is okay to leave those faults, and drive the vehicle with them, and it might be essential to get the countdown to clear.
For anyone trying to follow along here, look at my ClubTouareg thread posted at the top, as it contains a lot more details about diagnosing and fixing adblue issues on these T2 Touaregs.
Thank you everyone for your help. I hope this thread makes it easier for myself and others to systematically diagnose these issues in the future.
I wonder if this changed with the Dieselgate software that your ECU has?
Grab a Measuring Block channel map with the engine idling and send it to Support along with a link to this thread.
