VW Polo 6R ABS Long Coding Help?
Chr15
C?ID=207693
Hi
Looking for some help with this one. Got a 2012 Polo 6R been accident repaired.
Some of the fuses on top of the battery were blown (not sure if this was caused during accident or during repair :confused: ) . All replaced and no comms with ABS module, internal fault in control unit maybe from fuses blowing ??
Replaced unit with a second hand one with all matching part no's.
Full communication now but needs long coding (just show's 00000000000000000) hoping somebody might be able to save the day and get the correct code?
Have a feeling the dealers will only want to work with a new ABS Module :cry:
Thursday,21,January,2016,11:25:44:26527
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WVWZZZ6RZCU078053   License Plate: LG62GBO
Mileage: 83060km-51611mi   Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZCU078053   Mileage: 83060km-51611miles
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 CN    HW: 03C 906 024 BH
   Component:       CGGB  MM4HV   8994
   Revision: --H09---    Serial number: 00000000000000
   Coding: 0000071
   Shop #: WSC 31414 790 31414
   VCID: 6CD7C0964CEC685EBD-515C
Readiness: 0110 0001
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 000000000000000000000000000000000000
   VCID: 000F842697649C3E71-8054
            000 -  -
                    Reset counter: 231
                    Mileage: 83069 km
                    Date: 2016.01.21
                    Time: 19:43:04
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3013
                    Hex Value: 0x1491
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Status: 01100101
                    Reset counter: 231
                    Mileage: 83069 km
                    Date: 2016.01.21
                    Time: 19:43:04
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3051
                    Hex Value: 0x1B91
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
                    Reset counter: 231
                    Mileage: 83069 km
                    Date: 2016.01.21
                    Time: 19:43:04
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x30E1
                    Hex Value: 0x2091
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
03306 - Coding Not Valid
            000 -  -  - Intermittent
                    Reset counter: 15
                    Mileage: 83069 km
                    Date: 2016.01.21
                    Time: 19:49:08
                    Hex Value: 0x0003
                    Hex Value: 0x0002
                    Hex Value: 0x32E7
                    Hex Value: 0x25B1
                    Hex Value: 0x00FF
                    Hex Value: 0x7F85
                    Hex Value: 0x84F8
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 397929C2B03E0DF676-806C
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0254
   Revision: BF046001    Serial number: 0434 126123931
   Coding: 24B02BBF08A10000003008002D2B0CD00040410F60060000200000000000
   VCID: 45815532CCC6791602-8010
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  008 1611
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  008 1611
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 18BC32
   Subsystem 4 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 18BC32
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag027 H10 0020
   Revision: --------    Serial number: 003GX017FKJS
   Coding: 003237
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4A9B660EEDD8966EEF-801E
   Serial number: 3575HRB404V18NQQ91KD
   Serial number: 3585HRB404V1BEPUDOI-
   Serial number: 3515RRB405D15N42H1C.
   Serial number: 3525RRB406717ABUJ1IM
   Part No SW: 6R0 920 960 H    HW: 6R0 920 960 H
   Component: KOMBI         H03 0505
   Coding: 440A01
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3A7B36CEBD3806EE7F-806E
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0254
   Revision: BF046001
   Coding: 002300
   VCID: 70EFD4E6A3C48CBE81-8024
   Component: IMMO          H03 0505
   VCID: 6ADBC68E8D18766ECF-803E
   Revision: A1001003    Serial number: 7662526379
   VCID: 2959F982409EBD7606-807C
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 31414
   VCID: 2F6D179AEA7AD346D8-807A
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  042 0082
   Revision: 00000001    Serial number: VWZ1Z2M4117278
   Coding: 01000400020001
   VCID: 33651BEA9252F7A6BC-8066
End-------------------------(Elapsed Time: 02:08)--------------------------
Gone But Not Forgotten
just trolling...........
210228E3417300B8842914E282D100501300
210228E3417300B6842814E782D800421300
210224E3416E00B7842624E282D900521300
210224E3216E00B8842B24E584D900401100
110224DB817100BA882D24E981D300521300
110224DB817100BA882D24E981D300421300
[*]6R VW Polo
[*]2010
[*]6R0 907 379 R
[*]ESP8.2i front H04 0002
[*]2102 24 E3216E00B8842B24E584D90040 11 00
[*]6R VW Polo BlueMotion
[*]2010
[*]6R0 907 379 AF
[*]ESP8.2i front H05 0005
[*] 2102 24 E3417100BB842524E882D60052 13 00
[*]6R VW Polo GTI
[*]2011
[*]6R0 907 379 AJ
[*]ESP8.2i front H05 0001
[*]2102 48 E3416D00B3842712E882D80041 17 00
[*]6R VW Polo
[*]2011
[*]6R0 907 379 AK
[*]2102 28 E3417500BB842914E582D80052 13 00
[*]6R VW Polo GTI
[*]2011
[*]6R0 907 379 AK
[*]2102 48 E3417002B5842D12E582D94041 17 00
[*]6R VW Polo
[*]2012
[*]6R0 907 379 AK
[*]2102 28 E3416D00B2842614E682D80052 13 00
[*]2011
[*]6R0 907 379 AK
[*]2102 24 E3416D00B5842A24EA82D40052 13 00
[*]6R VW Polo Cross
[*]2012
[*]6R0 907 379 AK
[*]2102 28 E3426D00B9842714E842D60042 13 00
Chr15
C?ID=207693
Thanks for the effort but still no go.
Just got an A3 in aswell with the same thing, unplugged the cluster and now no ABS coding. Unfortunately not seen either of these cars before or would have a previous auto-scan to try and back up from :banghead:
Well I hope you at least auto-scanned before unplugging the A3 cluster crazy person......:p
I'm off to investigate coding's
000000000000000000000000000000000000 (36) on (18) WVWZZZ6R/ZCU078053
210224E3217400BA842524E784D400801300
210224E3217200B9842624EA84D300401300 Same ecu part # VCDS forum VIN: WVWZZZ6R/ZCY157182
210248E3416D02B2842612E482D240411700 WVWZZZ6R/********
210248E3417202B7842712EA82D640411700
210248E3417400BA842524E784D440411700 Try these! <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
210248E3417400BA842524E782D440411700
without TPMS
210248E3417400BA842524E784D440411300
210248E3417400BA842524E782D440411300
Revision: --------
Address 03: ABS Brakes (J104) Labels: 6J0-907-37x-ESP.clb
Revision: --------
Coding: 210228E3417300B6842814E782D800421300
Chr15
C?ID=207693
Not guilty of that one, they only seem to turn up on my door when they've done the deed and no previous auto scan. One of first things as a rule is auto scan and save file for future use. Even if its only in for service. (proven to be quite useful a number) just not for these 2 as i've never seen them until they've lost their code.
Will give any you have a chance and thanks for the help :thumbs:
Hopefully can get them sorted
azet
Poland
C?ID=123840
I have very similar problem, Car from another workshop with 000000000000000000000000000000 as coding in ABS/ESP (it's ESP 8.2)
Can anybody help me with this coding ?
AUTOSCAN:
Thursday,21,January,2016,14:48:04:29512
VIN: WVWZZZ6RZAY167175   License Plate:
Mileage: 53050km-32963mi   Repair Order:
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZAY167175   Mileage: 53050km-32963miles
01-Engine -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 G    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 8882
   Revision: --H13---    Serial number:
   Coding: 00114016000400080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023G 003008
   ROD: EV_ECM16TDI02103L906023AH.rod
   VCID: 2A51FA794D8C616E0F-807E
   Part No SW: 6R0 907 379 R    HW: 6R0 907 379 R
   Component: ESP8.2i front H04 0002
   Revision: --------
   Shop #: WSC 02069 000 00000
   VCID: 4D9B91E510A25656CA-8018
            000 -  -
                    Fault Frequency: 11
                    Reset counter: 242
                    Mileage: 53015 km
                    Date: 2010.06.12
                    Time: 08:36:31
                    Hex Value: 0x4003
                    Hex Value: 0x0000
                    Hex Value: 0x32E7
                    Hex Value: 0x25AD
                    Hex Value: 0x00FF
                    Hex Value: 0x7F80
                    Hex Value: 0x7E1B
                    Hex Value: 0x0000
            000 -  -
                    Reset counter: 242
                    Mileage: 53015 km
                    Date: 2010.06.12
                    Time: 08:36:36
                    Hex Value: 0x4007
                    Hex Value: 0x0000
                    Hex Value: 0x3211
                    Hex Value: 0x14AE
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
                    Fault Frequency: 9
                    Reset counter: 242
                    Mileage: 53015 km
                    Date: 2010.06.12
                    Time: 08:36:41
                    Hex Value: 0x4007
                    Hex Value: 0x0000
                    Hex Value: 0x12E1
                    Hex Value: 0x1AA9
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6R0 907 044 B    HW: 6R0 907 044 B
   Component: Climatronic   H08 0204
   Revision: V0000000
   VCID: 3261E2196D5C29AEB7-8066
01273 - Fresh Air Blower (V2)
                    Reset counter: 20
                    Mileage: 52891 km
                    Date: 2010.05.22
                    Time: 10:52:33
                    Reset counter: 24
                    Mileage: 125999 km
                    Date: 2014.05.12
                    Time: 18:44:05
   Part No SW: 6R0 937 087 D    HW: 6R0 937 087 D
   Component: BCM PQ25 H+4  H46 0207
   Revision: BF046001    Serial number: 0147 013101960
   Coding: 24B02BBF08A10000003000007D2B0CD00000410F60860000200000000000
   VCID: 3E79C629A904FDCE43-806A
   Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0902
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Coding: 08BC32
   Subsystem 4 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Coding: 08BC32
Address 15: Airbags        Labels: 5K0-959-655.clb
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag008 H09 0018
   Coding: 003038
   VCID: 4281B2D9D5FC992E27-8016
   Serial number: 3572SRB40000A3E49266
   Part No SW: 6R0 920 861 D    HW: 6R0 920 861 D
   Component: KOMBI         H03 0205
   Coding: 140800
   Shop #: WSC 00720 219 44749
   VCID: 3669DE098934358E9B-8062
   Part No SW: 6N0 909 901     HW: 6R0 937 087 D
   Component: GW-K-CAN TP20 0207
   Coding: 002200
   VCID: 70E52811A3D05BBE81-8024
                    Reset counter: 23
                    Mileage: 125999 km
                    Date: 2014.05.12
                    Time: 18:43:58
   Component: IMMO          H03 0205
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
   VCID: 6AD13A798D0CA16ECF-803E
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10130
   Shop #: WSC 00788
   VCID: 2E59F669ED640D4ED3-807A
Address 56: Radio (J503)       Labels: 1K0-035-1xx-56.lbl
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2K7015476
   Coding: 0500040002
   VCID: 6BDF3F7D8AF6B866B4-803E
End-------------------------(Elapsed Time: 01:55)--------------------------
I don't have autoscans from similar car , we are working generaly with audi (90%) , but i found some coding from ESP with same part number and same engine... don't knwo what transmission. hope it's usefull...
210228E3417400B2842514E282D300421300
and similar but different engine:
210228E3217000B4842514E884D300401300
210228E3216E00BA842E14E584D500401300
210228E3217000B2842714EA84D300401300
