I recently purchased a Jap Import Golf mk7
The vehicle developed the usual no sound from the MIB1 unit, so I purchased a used MIB2 unit that was updated and had CP removed.
I have installed it and it is working fine, but I have some coding errors I need help with!
Any advice guys?
Any advice guys?
Saturday,06,September,2025,16:54:36:28795
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
VIN: WVWZZZAUZFP503006 License Plate:
Mileage: 73024km-45375mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 13 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZFP503006 Mileage: 73024km-45375miles
Address 01: Engine (J623-CJZA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 CE HW: 04E 907 309 A
Component: 1.2l R4 TSI X09 7698
Revision: WAX09--- CVN: 5EA49689
Coding: 02250012230401082000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM12TFS01104E906016CE 001005
ROD: EV_ECM12TFS01104E906016CE.rod
VCID: 678BB1F38FEAD3822F9-8032
VINID: 9E69EAAAA465A9680500300018429A49FD
Readiness: 1110 0000
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 047 D HW: 0AM 927 769 K
Component: GSG DQ200-MQB H45 5221
Revision: 00045014 Serial number: CU501911056681 CVN: 00004E65
Shop #: WSC 04940 001 00001
ROD: EV_TCMDQ200021.rod
VCID: 3C213E9FA6ECA05A92B-8068
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 61364000000788
Coding: 04FA8AA12420296F0377060081C92520512494C06081A4F3F0220038D202
VCID: 45D75B7BD526E192FD5-8010
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 Q HW: 5G0 907 426 Q
Component: AC Manuell H02 0912
Revision: 00001K06
Coding: 02120004100100001000000010000000
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 392F278BA9DE957289D-806C
Part No SW: 5Q0 937 087 P HW: 5Q0 937 087 P
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86582405140121
Coding: 03001A424241227B49E44000000C07081000000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
ROD: EV_BCMBOSCH_013.rod
VCID: 48C9524FE234FCFA063-801C
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140426 042 0551
Serial number: 140430110327
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S5Y14M05D28H03M38S35
Coding: 37E8DD
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H04 0303
Serial number: 06051476510321 Dataset Number: 5g0114v____ 1017
Coding: 02001100FE0739
Shop #: WSC 00028 028 00066
VCID: 3829228F92D48C7A763-806C
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR05UED6 Dataset Number: 5G0003v____ 0094
Coding: 98FCC0C0000000005C5400CF00C800000065
Shop #: WSC 00028 028 00063
VCID: 7F5B0993F77A7B42F79-802A
Left seat belt tensioner:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B21051440560
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B20051451206
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 605 14
Serial number: 35767000000383149F0S
Subsystem 4 - Part No SW: ----------- HW: 480 001 605 14
Serial number: 3586700000054B9CCF0B
Subsystem 5 - Part No SW: ----------- HW: 480 401 905 14
Serial number: 35165029B12FAE31B39P
Subsystem 6 - Part No SW: ----------- HW: 480 402 105 14
Serial number: 3526502C5157E9E433BP
Subsystem 7 - Part No SW: ----------- HW: 480 400 605 14
Serial number: 35565029B157E994827Q
Part No SW: 5Q0 953 521 Q HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0155
Revision: FF028028 Serial number: 20140513400402
Coding: 0610
ROD: EV_SMLSVALEOMQB.rod
VCID: 40D94A6FCA04C4BACE3-8014
Part No SW: 5G1 920 640 HW: 5G1 920 640
Component: KOMBI 203 5297
Coding: 27A512082B80860C02886A011400000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009003
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 629DA0E764C8B6AAF87-8036
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 18051410801757 Dataset Number: 5G0067v____ 1821
Coding: 030100042B086400FF00004C1C0F00010001000000000000000000000000
GVL: 01503C0000000000400C90000000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
VCID: 42DD4067C408D6AAD87-8016
Generator:
Subsystem 2 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Serial number: 3121409021100913AB1B
Coding: 240000
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 9488373303
U1101 00 [00001001] - Active
Reset counter: 185
Mileage: 73024 km
Date: 2025.09.06
Time: 16:51:06
Terminal 30 power supply: 12.0 V
Terminal 15: On
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000102716987 Dataset Number: 5G0222v____ 0058
Coding: 00310320D001028000001000
VCID: 44D1467FDE1CD89AEAB-8010
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000005308044
Coding: 0D0000
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Dataset Number: 5G0074v____ 0354
Coding: 0103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DF4F6BC10ECDB2C1D-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000102757005 Dataset Number: 5G0157v____ 0055
Coding: 00310120DE01028000801000
VCID: 43D34563DB12DFA2D31-8016
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000005334206
Coding: 050000
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: -------------- Dataset Number: 5G0036v____ 0018
Coding: 068E000001010000
ROD: EV_HeadlRegulVWLWRMQB_VW37.rod
VCID: 75B7EBBBC5463112AD5-8020
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 874 C HW: 5Q0 035 874 C
Component: MU-S-ND-ER H41 0480
Serial number: SKZAZ2U0847444 Dataset Number: V03935285QF 0001
Coding: 02731201FF00000051111101C3CD06002F0104B601A00500CF
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 343116BF8EBC681A5AB-8060
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H51 0022
Serial number: VWZ8Z9PJ600ZHY
U1014 00 [00001001] - -
Reset counter: 185
Mileage: 73024 km
Date: 2025.09.06
Time: 16:51:05
Voltage terminal 30: 12.0 V
Byte_Coding_Condition-byte_0_condition: ERROR
B201A 00 [00001001] - -
Reset counter: 185
Mileage: 73024 km
Date: 2025.09.06
Time: 16:51:05
Status_Software_Version_Management-module_name: D
15360768 - Component Protection
[Anti-theft protection - component protection active (0xEA6300)]
Reset counter: 185
Mileage: 73024 km
Date: 2025.09.06
Time: 16:51:05
0013 - Antenna Amplifier 1 for Digital Radio
B1270 13 [00001001] - Open Circuit
Reset counter: 185
Mileage: 73024 km
Date: 2025.09.06
Time: 16:51:05
Status of digital radio antenna 1-Antenna current: 0 mA
Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
7178 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 185
Mileage: 73024 km
Date: 2025.09.06
Time: 16:51:08
BAP-BAP_Function_ID: 02
End----------(Elapsed Time: 01:31, VBatt start/end: 12.0V/12.0V)-----------
------------------------------6 Faults Found-------------------------------
