Hello and need some serious help.
sandog
hexc715-00a84b-dbba0c-9bf546-ccjahh-60e4
Hello. I am new here and just started using my original Ross Tech cable and VCDS. I pulled a log from 2003 audi a6 2.7t quattro and have quite the error list. In addition will need help coding new ABS module I installed.
Any help would be great and thank you again.
Michael
Saturday,03,May,2014,15:12:03:47628
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAULD64B03N053611   License Plate: 5AXR424
Mileage: 188482   Repair Order:
Chassis Type: 4B (4B - Audi A6 C5 (1998 > 2006))
          75 76 77
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 4Z7 907 551 R
   Component: 2.7L V6/5VT     G   0003
   Coding: 07752
   Shop #: WSC 02325
   VCID: 52A174D09E554D8E7D3-515A
   WAULD64B03N053611     AUZ7Z0B2232914
18057 - Powertrain Data Bus
            P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
16805 - Warm Up Catalyst; Bank 1
            P0421 - 35-00 - Efficiency Below Threshold
18058 - Powertrain Data Bus
            P1650 - 35-10 - Missing Message from Instrument Cluster - Intermittent
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 -  - Intermittent
17831 - Secondary Air Injection System; Bank 1
            P1423 - 35-00 - Insufficient Flow
17862 - Exhaust Gas Temp Sensor 1 (G235)
            P1454 - 35-10 - Short to Ground - Intermittent
Readiness: 0000 0001
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 4B0 927 156 FE
   Component: AG5 01V 2.7l5VT USA 2222
   Coding: 01002
   Shop #: WSC 02325
   VCID: 6FE7DD242D27006672D-515A
18169 - Shift Lock Solenoid (N110)
            P1761 - 35-10 - Short to Ground - Intermittent
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       1728
   Coding: 00000
   VCID: 254BFF0CBF5B0A36C81-515A
            66-10 - Not Matched - Intermittent
            35-00 - -
            30-00 - Open or Short to Plus
18256 - Please check DTC Memory of Engine Controller
            P1848 - 35-10 -  - Intermittent
            27-00 - Implausible Signal
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AL
   Component: A6-Klimavollautomat 0105
   Coding: 00010
   Shop #: WSC 02325
   VCID: 64CDA208F4E1B33E1FF-258C
            41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
            37-00 - Faulty
00796 - Fan for Interior Temp Sensor (V42)
            00-00 - -
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4B0 959 655 Q
   Component: Airbag 8.4EP        2001
   Coding: 0000607
   Shop #: WSC 02325 785 00200
   VCID: 3E7930606ACDB9EEA9B-5178
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 981 P
   Component: KOMBI+WEGFAHRS. VDO D12
   Coding: 02264
   VCID: 336F1154018F6486565-515A
Address 35: Centr. Locks        Labels: 4B0-962-258.lbl
   Part No: 4B0 962 258 M
   Component: Central Lock/Alarm  D37
   Coding: 15885
   Shop #: WSC 02325
   VCID: 336F1154018F6486565-4F02
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0102
   Coding: 00001
   VCID: 2C5D0A28DCB13B7E17F-4B18
Address 55: Xenon Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00050
   Shop #: WSC 02325
   VCID: 040D828814A1133EBFF-4B32
   Part No: 4B0 035 195 L
   Component: symphony II NP2    0051
   Coding: 00001
   Shop #: WSC 22161
   VCID: 2953F33CD3432E56EC9-4EB0
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
            44-10 - Short Circuit - Intermittent
01336 - Data Bus for Comfort System
I'm 99.44% sure you have the wrong ABS controller installed in this car.
sandog
Thank you for that. I will have to send my original controller off for repair. Any other help on the rest would be great.
Thank you in advance.
