2014 Audi R8 Gen 1 no crank on first attempt and numerous comms errors - starts second time & drives perfectly
Volkswizard
Warwickshire, UK
C?ID=55393
Hello everyone,
I'm a long term VCDS user and thus rarely get stuck these days but this 2014 (Gen 1 facelift) Audi R8 V8 S tronic Spyder issue is driving me mad so any help appreciated.
The symptoms are as follows;
Intermittently but more often than not, when car has been left for a period of time, on first attempt to start the car, there is no crank and the brake system warning flashes up in red on DIS.
The instrument cluster does power up OK but the fuel range shows as zero when gauge shows plenty of fuel (every other reading is correct including 12v on voltmeter).
Then a few seconds later (it can vary from a second to maybe 10 seconds) you can hear the fuel pump energise and the fuel range shows correctly.
Cycle the ignition and car starts on second attempt every time and drives perfectly. For quite a long time previously it wouldn't crank on first turn but always on second but cluster behaved normally, however a Terminal 15 related DTC was logged so I suspect the issue has got worse over time.
Instrument cluster image here;
https://www.dropbox.com/scl/fi/9sbf...ey=hrzxwqzkcbsm19vlah3du7wga&st=qkn8znf5&dl=0
I have used Erwin to locate the terminal 15 relay which is in the passenger footwell and swapped for the other 643 relay in there no difference - it is possible but unlikely that the other relay (both genuine VWG parts made by Hella in China) is suffering exactly the same fault. I have also fitted a non-genuine Bosch relay with a part number that crosses over but it's possible it may not be 100% correct for the purpose here.
If I remove the terminal 15 relay altogether (from slot 6) the fault occurs exactly as stated above but doesn't resolve itself.
I've fitted a new Hella AGM battery as weak battery always used to cause this fault on older Audis but it's made no difference.
Below is a full scan, ignore passenger door electrics and microphone DTCs as they are pre-existing faults, everything else is 100% as a result of this issue.
Any help much appreciated.
Andrew
Tuesday,02,September,2025,09:02:01:44744
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250311 DS365.0
VIN: WUAZZZ427EN002581   License Plate:
Chassis Type: 42-AU35 (7N0)
Scan: 01 02 03 08 09 10 11 31 15 16 17 19 25 26 2E 37 3D 42 46 47
          52 56 61 77 A6 C2
VIN: WUAZZZ427EN002581   Mileage: 51910km-32255miles
3D-Special Function -- Status: Malfunction 0010
A6-Microphone -- Status: Malfunction 0010
C2-Auto Trans 2 -- Status: OK 0000
Address 01: Engine (CND)       Labels:. 079-910-560-BYH1.clb
   Part No SW: 424 910 560 K    HW: 420 907 560 C
   Component: 4.2L V8HDZ/4V FS   ª0010
   Revision: F6H10---    Serial number: AUX7Z0N2FN500P
   Coding: 0110000C240F0120
   Shop #: WSC 55169 001 104857
   VCID: 1A6C2980A095555A613-804E
   VINID: 9E546AAAA1021D578000214804598E1C77
Address 02: Auto Trans (J217)       Labels:. 0BH-927-711.clb
   Part No SW: 420 927 155 F    HW: 0BH 927 711 C
   Component: 0BZ_42FSI_RdW H08 1708
   Revision: 00H08V01    CVN: 39B8319B
   ASAM Dataset: EV_TCMDL800041 001006
   ROD: EV_TCMDL800041_AU35.rod
   VCID: 196E368CA9135E42689-804C
   Selector lever:
   Subsystem 1 - Part No: 420 713 041 E
   Component: SCHALTBETAET.  C05 0A13
   Serial number: 00000000001203143637
Address 03: ABS Brakes        Labels: 420-910-517.lbl
   Part No SW: 420 910 379 A    HW: 420 614 517 F
   Component: ESP8 quattro    H01 0300
   Coding: 0004356
   Shop #: WSC 02391 785 00200
   VCID: 147047B84271632A3BF-8040
Address 08: Auto HVAC        Labels: 420-820-043.clb
   Part No SW: 420 820 043 J    HW: 420 820 043 J
   Component: J255  Klima 1 Zone  0100
   Revision: 00H06008    Serial number: 00000001254178
   Coding: 1573896
   VCID: 117E4EAC7D639602109-8044
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:58:26
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:58:26
   Part No SW: 8P0 907 063 AD    HW: 8P0 907 063 AD
   Component: BCM PQ35  H   113 0771
   Revision: AE113771
   Coding: 07000A25E805F120207068E021200048D6F2AB00B120C92ADC0806140005
   VCID: 76B41D3078CDD13AA5B-8022
   Subsystem 1 - Part No SW: 427 955 114 A    HW: 427 955 114 A
   Component: Wischer AudiR  H23 0011
   Coding: 005912
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 025B32
   Subsystem 3 - Part No: 8J0 951 177
   Component: DWA-Sensor H0  H03 0030
9 Faults Found:
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Fault Status: 00101100
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:46:45
                    Voltage: 12.30 V
                        Term 50 On
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:46:48
                    Voltage: 12.40 V
                        Term 50 On
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:46:48
                    Voltage: 12.40 V
                        Term 50 On
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:46:48
                    Voltage: 12.40 V
                        Term 50 On
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:46:48
                    Voltage: 12.40 V
                        Term 50 On
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:46:48
                    Voltage: 12.40 V
                        Term 50 On
                    Fault Status: 00101001
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:52:27
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:54:17
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
01516 - Terminal 30; Left
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:54:18
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X2.clb
   Part No SW: 8P0 919 475 Q    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0150
   Revision: 11001001    Serial number: 12561409100017
   Coding: 10010E
   VCID: 4CC09FD856C1FBEA23F-8018
Address 11: Engine II        Labels:. 079-910-560-BYH2.clb
Address 15: Airbags        Labels: None
   Part No SW: 427 959 655     HW: 427 959 655
   Component: 13 Airbag 9.43  H02 0030
   Revision: 93H02003    Serial number: 003B80005WT2
   Coding: 0012595
   VCID: 64905778D25153AA0BF-8030
   Subsystem 1 - Serial number: 63328RB406E6708FY
   Subsystem 2 - Serial number: 63428RB406E6708CW
   Subsystem 3 - Serial number: 63747RB4072237509
   Subsystem 4 - Serial number: 63847RB4072227B7M
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H38 0070
   Coding: 0004141
   VCID: 41DEBEEC6D832682C09-8014
   Component: E0221           H06 0040
Address 17: Instruments        Labels: 420-920-xxx-17.clb
   Part No SW: 420 920 981 N    HW: 420 920 981 N
   Component: KOMBIINSTR. VDO H05 0793
   Revision: D0H05008    Serial number: 2242N008000202
   Coding: 0000428
   Shop #: WSC 58785 004 104857
   VCID: 211E1E6C8DC30682A09-8074
   Part No SW: 7N0 907 530 AL    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1642
   Revision:   H58       Serial number: 020414F1003801
   Coding: 355109
   VCID: 7AAC09004CD5B55AC13-802E
00576 - Terminal 15
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:46:47
   Revision: D0H05008    Serial number: AUX7Z0N2FN500P
Address 26: Auto Roof (J256)       Labels:| 427-959-255.clb
   Part No SW: 427 959 255 B    HW: 427 959 255 B
   Component: VSG-AU715     H05 0100
   ASAM Dataset: EV_ElectRoofContrAU715 001006
   ROD: EV_ElectRoofContrAU715.rod
   VCID: 221C116084451D9AB93-8076
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 420 035 785     HW: 420 035 785
   Component: SG ext.Player H08 0100
   Revision: 00000000
   Coding: 020202
   VCID: 52FC81A0B4E5AD1A693-8006
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 424 035 192 J    HW: 424 035 192 J
   Component: RNS-E PU EU     H09 0220
   Revision: 0000015S    Serial number: AUZBZ7S5100012
   Coding: 0730725
   Shop #: WSC 07214 003 1048576
   VCID: 186833885E99474A577-804C
Address 3D: Special Function        Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 A    HW: 8K0 907 440
   Component: STS             H04 0030
   Revision: S0H04000    Serial number: 00000000099511
   Coding: 01010101000000000000000102
   VCID: 2C00FF58FA01DBEA03F-8078
03420 - Activation of Accelerator Pedal Position Sensor
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:46:47
Address 42: Door Elect, Driver        Labels: None
   Part No SW: 427 959 801 E    HW: 427 959 801 E
   Component: Tuer-SG         H05 0107
   Coding: 0021117
   VCID: 221C116088C51D9AB93-8076
Address 47: Sound System        Labels: None
   Part No SW: 427 035 223 A    HW: 427 035 223 A
   Component: J525 Amp High   H05 0110
   Revision: 00H05001    Serial number: 94845028390103
   Coding: 0246122
   VCID: 0D4652DC615BB2E2F41-8058
                    Reset counter: 235
                    Mileage: 51910 km
                    Date: 2025.09.02
                    Time: 08:58:26
Address 52: Door Elect, Pass.        Labels: None
   Part No SW: 427 959 802 E    HW: 427 959 802 E
   Coding: 0021117
   VCID: 2312146497DF1492B25-8076
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0730725
   Component: Batt.regelung H58 1642
   Coding: F32E1146
   VCID: 71BE2E2C11A3F602709-8024
   Subsystem 1 - Part No SW: 420 915 181     HW: 420 915 181
   Component: J367-BDM  H07 0140
   Serial number: 41086537125041981164
   Part No SW: 8P1 862 335 A    HW: 8P1 862 335
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005650905
   Coding: 0011402
   VCID: 3536DA3C294B9A226C1-8060
Address A6: Microphone (J886)       Labels:. 420-907-394.clb
   Part No SW: 420 907 394     HW: 420 907 394
   Component: BELTMICBOX    H09 0060
   Coding: 0100010202
   ASAM Dataset: EV_BeltMicAU715 002011
   ROD: EV_BeltMicAU715_002.rod
   VCID: 56F47DB0988DB13A85B-8002
0080 - Microphone 1 for Drivers Side
          B1203 13 [00001001] - Open Circuit
0112 - Microphone 3 for Drivers Side
          B1205 13 [00001001] - Open Circuit
Address C2: Auto Trans 2 (J217)       Labels: None
   Part No SW: 420 927 109 B    HW: 420 927 109 B
   Component: 0BZ DL800     H04 0011
   Revision: --H04---    Serial number: 0000000062 CVN: 0000DF28
   ASAM Dataset: EV_TCMDL800421 001010
   ROD: EV_TCMDL800.rod
   VCID: 147047B84EF1632A3BF-8040
End----------(Elapsed Time: 01:38, VBatt start/end: 12.4V/12.4V)-----------
------------------------------17 Faults Found------------------------------
See if you can determine if that relay is actually closing when you try to start / crank. If not, you could try to manually ground it with a jumper wire and see if that closes it ; then try to crank/start.
You have several Term. 30 "opens" in the above scan which may be a clue.
Volkswizard
Warwickshire, UK
C?ID=55393
Thanks for your advice.
I pulled the cover off the relay and refitted it and I could see the relay operating fine but the car was having a good day today so I'll keep an eye on it.
I'm thinking body control module could be the issue if the relay is operating correctly and the fault recurs as that seems to be the next 'switch' in the circuit for the no commns modules
I would have a look around that module and its connections also; I'm also thinking that a Spyder R8 + UK = water ingress (??). If there is any corroded connections or water ingress to a module that may explain the intermittent problem also. Thanks for the update.
Volkswizard
Warwickshire, UK
C?ID=55393
Thanks. It appears to be an unusually dry car inside with zero condensation issues in the winter and no damp smells but I will check BCM (very easy to do as behind passenger footwell carpet near the T15 relay.
The key attribute of the fault as well as being intermittent is that it usually resolves itself within seconds so it feels like a switch that's a bit lazy. Once it's energised it's OK until it's been left. Do you know how long it takes for the BCM to fully shutdown after the car has been locked as it could be this that's required for the fault to recur, until then it's fine.
I've also been having issues with the active rear spoiler raising on startup which appears to be a faulty end stop microswitch causing an implausible signal. I started to diagnose this yesterday and even though I don't appear to have done anything apart from fiddle around with the microswitches and it's still recognising it as faulty, the original fault seems better (but it's too soon to be sure). I wonder if the spoiler fault was delaying the BCM start up? It's definitely controlled via the BCM (central electrics) as I spent a long time in there looking at the microswitch status.
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
I'm not deeply familiar with the R8.
However, the Terminal 30 Left and Terminal 30 Right DTC references make it sound like a dual battery system. I *am* quite familiar with the Phaeton dual battery setup. The start-on-second-crank thing sounds suspiciously like the Phaeton emergency start procedure wherein both batteries get bridged together on the second attempt.
You say you replaced the battery. Is there more than one?
Volkswizard
Warwickshire, UK
C?ID=55393
The Gen 1/42 R8 is thankfully not as complicated as a Phaeton!
It has just the one battery and the BCM is the one used in the facelift 8P A3 and 8J TT
  • Agree
Dr Sheldon
Windsor UK
C?ID=334979
Rather than all this guess work, swapping relays etc. Can you get your hands on a Scope, Preferably 8 channels and set it up to make ACTUAL measurements at strategic points in the circuit then make a Logic led diagnosis ?
  • Agree
Reactions: TTT
Volkswizard
Warwickshire, UK
C?ID=55393
I've got a multimeter and I'm doing a crash course in wiring diagrams so will try and be more scientific in my approach.
I think the next step is to replace the faulty rear spoiler microswitch and see if this fixes the issue.
Dr Sheldon
Windsor UK
C?ID=334979
You might want to be careful there, they fit diodes and resistors in Relays to stop modules being fried when the relay goes open !!
Dr Sheldon
Windsor UK
C?ID=334979
If that needs doing then it has to be a good step. I cannot see a rear spoiler fault causing an intermittent non crank !! Lets hope I am wrong !
Dr Sheldon
Windsor UK
C?ID=334979
If I had that car here in front of me - I would toss that multimeter in the bin !!
Volkswizard
Warwickshire, UK
C?ID=55393
It's the same type of relay but the resistance is a bit higher.
Volkswizard
Warwickshire, UK
C?ID=55393
I know it sounds weird but on reflection the crank issue has got worse as the spolier fault has got worse - previously you could lower it with the button, now it won't respond at all and the beep error for spoiler happens at exactly the same time the other errors flag up on DIS
Dr Sheldon
Windsor UK
C?ID=334979
It does sound weird and rather bizarre, I cannot get my head around it.
However, that spoiler needs to fixed and then if it does solve the other issues I will eat these words :facepalm: And we learn something from it !
If not then we can move on with a diagnosis with one less variable so a move in the right direction ?
Except for the Engine and Auto-Trans (if equipped), the rest of the Mk.1 R8 was indeed just like an 8P A3 or 8J TT from an electronic systems perspective. Back then, I was quite disappointed in this, because it meant we could not justify getting one for R&D purposes. :(
Nah. IIRC, those CECMs have two (or more?) Terminal 30 inputs, one for the left side loads and one for the right side loads.
This needs to be chased with a meter and a wiring diagram, although I think we've seen some cases where those faults were due to an internal failure in the CECM.
Ziddywerks
Northern NJ USA
C?ID=208579
I would also check for spread contacts at fuses.
Start video at ~ 6:00min.
Dr Sheldon
Windsor UK
C?ID=334979
Yes Agreed !! Only the Shit that VAG produce has that problem and I do see it often.
I dont think I have ever seen it on any other Marque in 45 years.
Tossers cannot get a fuse box right and claim to make a good car !! I cant see that !!
Volkswizard
Warwickshire, UK
C?ID=55393
Just an update on this. The car was in storage over the winter and on getting it out recently, I was reminded this fault was still present.
A quick recap is that the car won't crank on first attempt but usually on second it will (very occasionally more attempts might be needed) and the 00185 - Control Circuit; Relay for Supply Voltage Terminal 15 012 - Electrical Fault in Circuit - Intermittent error is logged in Central Electrics (this is the only DTC that was being logged once I put the original relays back in)
This is generally accompanied by the rear spoiler extending on the first failed attempt to start.
I did think it was possibly BCM related as the active spoiler is controlled through it but it turned to all be related to the igntion switch which on reflection is quite obvious, not only because its main function is starting the car but because the only mechanical part of terminal 15 is the switch.
