HEX+CAN not recognized
MMMH2O
C?ID=206496
REcently tried to use my HEX+CAN on my 2008 Eos, but after installing the new update the software does not recognize it. Selecting "Test" returns a dialog that says no interface found. I have tried 2 different computers and several different USB ports. Rebooted, but no results.
In VCIconfig it does not show the device as a recognized interface. Tried refreshing the scan for it.
I have used this for years, so I suspect there is a new bug that is keeping it from being seeing.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Did you check the first item, install the driver for the legacy interface?
What version of Windows is on these PCs? Open Device Manager. Plug in the HEX+CAN. Unplug it. Look for something that changes in Device Manager when you do this to find where it is in there. Once you find it, open its Properties Sheet, and show us what's there.
MMMH2O
C?ID=206496
Windows 11. Have the same computer that has run VCDS before.
Ross Tech USB driver has orange warning triangle. USB driver is not installed properly it seems. Tried updating from Ross Tech folder....no good. Yes i did select install Legacy Drivers.
MMMH2O
C?ID=206496
Ok, here is warning I get. HEX+CAN plugged in via USB. This is on two different Windows 11 machines, with multiple USB ports tried on each machine.
Boki Ar
C?ID=57300
Post #1.
If you're using a legacy interface (anything other than a HEX-V2 or HEX-NET), the old drivers may be a problem with the way Windows 11 appears to be configured by default. We believe work around should be:
Settings -> Update & Security -> Windows Security -> Device Security -> Core Isolation -> Memory Integrity.
Turn Memory Integrity OFF.
MMMH2O
C?ID=206496
Already tried that one Boki. My machine does not have Memory Integrity listed as option.
Please double-click on it to open its Properties Sheet and show us what's going on there.
MMMH2O
C?ID=206496
Ran an update on the computer and was able to turn Memory Integrity off. It's hidden farther than shown above.
Cable now is recognized...but RT drivers will prevent being able to turn Memory Integrity back on:
MMMH2O
C?ID=206496
Funniest part..my wife came home yesterday and said there was a warning light on the dash. I figured I'd fire up the VAGCOM and diagnose it.
After all this it was a headlight out. But at least with the cable I can scan again.......
Correct. We stopped selling HEX+CAN interfaces long before Windows 11 and the Memory Integrity "feature" was a thing. If you wish to use a HEX+CAN with (many? most?) Windows 11 PCs you'll have to turn and leave Memory Integrity off.
MMMH2O
C?ID=206496
Thanks UWE! Love your help......and wit to some users....
