Component Locator database (scroll down to post 12 for details)
Jef
HQ
[01-Engine]
Component IDComponent Description[Meas. Blocks - 08][Adv. Meas. Values]
F1Oil Pressure SwitchIDE00497-MAS00627
F22Oil Pressure Switch
F378Reduced Oil Pressure SwitchIDE00497-MAS00628
F447Oil Pressure Switch Level 3IDE07031
G2Engine Coolant Temperature (ECT) Sensor001.2IDE00025
G6Transfer fuel pumpwhy?should be a V IMHO
G8Oil temperature sender
G27Engine temperature sender
G28Engine speed sensor001.1IDE00021
G31Charge air pressure sensor011.3 / 115.4IDE00191
G32Engine coolant level sensor
G39Heated oxygen sensor
G40Camshaft position sensor
G42Intake air temperature sensor004.4IDE00348 / ENG101741
G61Knock sensor 1
G62Engine coolant temperature sensor001.2IDE00025
G65High pressure sensor
G66Knock sensor 2
G69Throttle position sensor
G70Mass airflow sensor002.4 / 010.1IDE00347
G71Manifold absolute pressure sensor
G72Intake manifold temperature sensor007.3
G79Accelerator pedal position sensor 1062.3 / 030.1IDE00392
G81Fuel temperature sensor007.1
G83Engine coolant temperature sensor on radiator outlet
G98EGR temperature sensor
G108Heated oxygen sensor 2
G130Oxygen sensor after three way catalytic converter
G131Oxygen sensor 2 after catalytic converter
G163Camshaft position sensor 2
G185Accelerator pedal position sensor 2062.4 / 030.2IDE00393
G186EPC throttle drivewhy?should be V IMHO
G187EPC throttle drive angle sensor 1062.1ENG101929 / IDE12915
G188EPC throttle drive angle sensor 2062.2ENG102985 / IDE12916
G198Knock sensor 3
G199Knock sensor 4
G212EGR potentiometer
G235Exhaust Gas Temperature Sensor 1IDE00167
G246Mass Airflow Sensor 2
G247Fuel pressure sensor106.2IDE00589
G266Oil level thermal sensor
G294Brake booster pressure sensor
G296Throttle Drive 2
G297Throttle Drive 2 Angle Sensor 1
G298Throttle Drive 2 Angle Sensor 2
G299Intake Air Temperature Sensor 2
G300Camshaft position sensor 3
G301Camshaft position sensor 4
G336Intake manifold runner position sensor142.1
G400Fuel tank pressure sensor
G410Low fuel pressure sensorIDE00186
G430Intake manifold temperature sensor 2
G446Fuel quality sender
G447Charge air pressure sensor 2
G450Exhaust pressure sensor 1
G476Clutch position sensor
G448Exhaust gas temperature sensor 2
G495Exhaust gas temperature sensor 3
G500Turbocharger vane position sensor
G505Differential pressure sensor
G506Pre-Particulate Filter Temperature Sensor
G512Intake manifold runner position sensor 2144.1
G513Variable intake manifold position sender
G527Post-Particulate Filter Temperature Sensor
G581Charge air pressure actuator position sensor120.4IDE05312
G604Gear recognition sensor
G609Secondary air injection sensor 1IDE05593
G610Secondary Air Injection Sensor 2
G620Cylinder 1 internal pressure sensor
G621Cylinder 2 internal pressure sensor
G622Cylinder 3 internal pressure sensor
G624Fuel Pressure Sensor 2
G648Exhaust gas temperature sensor 4
G664Oil Temperature Sensor 2
G694Temperature sender for engine temperature regulation
G701Transmission neutral position sensor
G763Temperature sender 1 for charge air cooler
G764Temperature sender 2 for charge air cooler
G803Variable intake manifold position sender 2
G896Low Fuel Pressure Sensor 2
G950Tank Ventilation Pressure Sensor 1
G1004Engine Temperature Control Position Sensor
G1037Particulate Filter Differential Pressure Sensor
[02-Auto Trans]
FBrake Light Switch003.1 / 009.1
F125Multi-Function Switch009.4IDE06915-ENG98331 / IDE06915-ENG98436 / IDE06915-ENG98435 / IDE06915-ENG98824
G63Water separator sensor
G93Transmission fluid temperature sensor004.1 / 006.1IDE00024-ENG98981
G182Transmission input speed sensor001.2
G193Automatic transmission hydraulic pressure sensor 1
G194Automatic transmission hydraulic pressure sensor 2
G195Transmission output speed sensor001.3
G196Transmission output speed sensor 2
G270Transmission Hydraulic Pressure Sensor
G487Gear position distance sensor 1
G488Gear position distance sensor 2
G489Gear position distance sensor 3
G490Gear position distance sensor 4
G501Driveshaft speed sensor 1
G502Driveshaft speed sensor 2
G509Clutch oil temperature sensorENG113295
G510Temperature sensor in control moduleIDE00102
G545Hydraulic pressure sensor 1
G546Hydraulic pressure sensor 2
G612Transmission input speed sensor 2
G617Clutch Pedal Position Sensor 1
G618Clutch Pedal Position Sensor 2
G632Transmission input speed sensor 1
G641Transmission input speed sensor 3
G676Drive position sensor
G754Transmission fluid temperature sensor 2
G847Transmission fluid auxiliary hydraulic pump rotor position sensor
[03-ABS Brakes]
FBrake light switch002.1 / 002.2 / 005.4IDE02270-IDE02713
F47Brake pedal switch002.2
G44Right rear ABS wheel speed sensor001.4IDE04428-IDE00923
G45Right front ABS wheel speed sensor001.2IDE04426-IDE00921
G46Left rear ABS wheel speed sensor001.3IDE04427-IDE00922
G47Left front ABS wheel speed sensor001.1IDE04425-IDE00920
G85Steering angle sensor004.1 / 005.1IDE04443-MAS00815
G200Transverse acceleration sensor004.2 / 005.4
G201Brake pressure sensor 1005.1 / 005.3 / 066.3IDE04442-IDE04450
G202Rotation rate sensor005.2IDE04443-IDE04449
G251Longitudinal Acceleration Sensor004.4IDE04443-IDE02538
G476Clutch Position Sensor
G608Vacuum sensorIDE04422-IDE04442
[14-Susp. Elect.]
G76Left rear level control system sensor
G78Left front level control system sensor
G289Right front level control system sensor
G341Left front body acceleration sensor
G342Right front body acceleration sensor
[15-Airbags]
E24Belt switch driver's side003.3
E25Belt switch passenger's side003.4
G128Front passenger occupant detection sensor
G179Driver thorax airbag crash sensor
G180Front passenger thorax airbag crash sensor
G256Driver side rear thorax airbag crash sensor
G257Passenger side rear thorax airbag crash sensor
G283Driver front airbag crash sensor
G284Passenger side front airbag crash sensor
G452Passenger occupant detection system pressure sensor018.1
G453Passenger occupant detection system seat belt force sensor018.2
G551Driver belt force limiter
G552Front passenger belt force limiter
G553Driver seat position sensor
G554Front passenger seat position sensor
N95Airbag igniter 1 driver's side001.1MAS00001
N131Airbag igniter 1 front passenger's side001.2MAS00003
N132Airbag igniter 2 front passenger's side013.2MAS00004
N153Belt tensioner igniter driver's side001.3MAS00013
N154Belt tensioner igniter passenger's side001.4MAS00014
N196Rear belt tensioner driver's side002.1MAS00019
N197Rear belt tensioner passenger's side002.2MAS00020
N199Side airbag igniter driver's side005.1MAS00005
N200Side airbag igniter passenger's side005.2MAS00006
N250Airbag igniter 2 driver's side013.1MAS00002
N309Roll-over bar solenoid driver's side012.1
N310Roll-over bar solenoid passenter's side012.2
Notepad++
find = \r\n replace = [tr]
find = [/td]\r\n replace = [/td]
extended selected
Jef
HQ
[17-Instruments]
GFuel level sensor026.1
G1Fuel gauge
G169Fuel level sensor 2026.3
G237Fuel Level Sensor 3027.1
G393Fuel Level Sensor 4027.3
[26-Auto Roof]
Switch IDSwitch Description[Meas. Blocks - 08][Adv. Meas. Values]
F42Switch for folding top closed: rightIDE02664-MAS02269
F170Convertible Top Right Lock Switch001.2
F171Convertible top open position switch001.2 / 001.3IDE02664-MAS02263
F172Convertible Top Front Lock Switch001.2
F169Convertible top left lock switchIDE02664-MAS02266
F200Compartment Cover Locked Right Switch 1001.3
F201Compartment Cover Open Position Switch001.3
F202Convertible top front closed position switch001.2 / 001.3IDE02664-MAS02264
F290Left convertible top compartment cover switch001.3IDE02664-MAS02274
F291Right convertible top compartment cover switchIDE02664-MAS02275
F292Convertible Top Compartment Enclosure Position Switch001.3
F293Convertible top compartment latch -unlocked- switch001.3IDE02664-MAS02276
F294Convertible top latch -open- switch001.2IDE02664-MAS02265
F295Convertible top latch -closed- switch001.2
F323Left Convertible Top Open Lock Switch001.4
F324Left Convertible Top Closed Lock Switch001.4
F325Right Convertible Top Open Lock Switch001.4
F326Right Convertible Top Closed Lock Switch001.4
F328Convertible Top Tonneau Cover Switch001.3
F402Left convertible top compartment enclosure switchIDE02664-MAS02278
F403Right convertible top compartment enclosure switchIDE02664-MAS02279
F404Convertible top compartment -locked- switchIDE02664-MAS02277
F407Convertible top compartment -open- switchIDE02664-MAS02273
F408Upper tensioning bow switchIDE02664-MAS02270
F409Left tensioning bow switchIDE02664-MAS02271
F410Right tensioning bow switchIDE02664-MAS02272
F411Switch for folding top closed: leftIDE02664-MAS02268
G356Convertible roof tensioner position sender001.4
[34-Level Control]
G76Left rear level control system sensor005.3IDE02953
G77Right rear level control system sensor005.4IDE02954
G78Left front level control system sensor005.1IDE02951
G289Right front level control system sensor005.2IDE02952
G290Level control pump temperature sensor006.2IDE02941
G291Level control pressure sensor003.1 / 023.1IDE03064
G341Left front body acceleration sensor012.1
G342Right front body acceleration sensor012.2
G343Rear body acceleration sensor012.3
Jef
HQ
Temp dumping ground for this... most likely will get moved around or edited or something... I don't know... but here it is:
Component locatorComponent name
J104ABS control module
J126Fresh air blower control module
J136Memory seat/steering column adjustment control module
J197Level control system control module
J217Transmission control module
J234Airbag control module
J255Climatronic control module
J271Motronic engine control module power supply relay
J285Instrument cluster control module
J329Terminal 15 power supply relay
J338Throttle valve control module
J367Battery monitoring control module
J386Driver door control module
J387Front passenger door control module
J388Left rear door control module
J389Right rear door control module
J393Comfort system central control module
J428Distance regulation control module
J492All wheel drive control module
J519Vehicle electrical control module system
J527Steering column electronics control module
J695Relay 2 for starter
J500Power steering control module
J525Digital sound system control module
J532Voltage stabilizer
J533Data bus on board diagnostic interface
J538Fuel pump control module
J540Electromechanical parking brake control module
J554Front passenger seat position sensor
J587Selector lever sensor system control module
J604Auxiliary heater control module
J605Rear lid control module
J623Engine control module
J657Door closing assist control module
J706Passenger occupant detection system control module
J743DSG transmission Mechatronic
J757Engine component power supply relay
J770Lane change assistance control module 2
J792Active steering control module
J793Tire pressure monitoring control module 2
J850Distance regulation control module 2
J851Image processing control module
J852Camera control module
J854Left front seat belt tensioner control module
J855Right front seat belt tensioner control module
J883Exhaust door control unit
J897Air ionization system control module
J909Fuel tank leak detection control module
J938Rear lid opener control module
Jef
HQ
reserved for future use (maybe)
Jef
HQ
Jef
HQ
Jef
HQ
Jef
HQ
Jef
HQ
Jef
HQ
Jef
HQ
Jef
HQ
What is this?
An eye strain. In short, I've been thinking it might be nice to have a "quick reference" for the component locators from the wiring diagrams. So what you see if kind of what I've put together between phone calls.
How could this be useful?
Knowing where to find live data of a given sensor would be very useful when diagnosing a car. You could then compare the datato known good cars in the Reference Scans and Maps of Non-Broken Cars section of the forums.
Why all the "reserved for future use (maybe)" post?
It isn't easy to go back into an existing thread and insert a post. This gives us room to add data, and keep it at the top where it will be easy to find.
How can I help?
If you happen to know where [X] sensor data is found in VCDS, let us know the location in this thread. We'll see if we can confirm the information and add it to the list.
Wasn't there something like this before?
Kind of: https://forums.ross-tech.com/index.php?threads/3066/
How are you generating the tables?
I'm using this web site: https://tableconvert.com/csv-to-bbcode
DrPeter
16.4905° S, 151.7375° W
Is this for future use too?
drp
edit by Jef
Yes, is now being used in the future....
UDS modules can have bogus data:
Beware, or rather be aware, that UDS modules can and will lie to you about some stuff... it won't have [X] sensor, but will some bogus data at that location. Example:
  • IDE00186-Fuel low pressure: actual value
A lot of cars will not have a G410 sensor, but that ECM will look you right in the eye and tell you the low fuel pressure is 11.003 bar. There are other examples out there as well... an exhaust cam phase position being something like -60 but the exhaust cam is fixed... EGT reading of 1110.0 C, but there is no sensor for that.
If you have doubts, then verify the component or hardware is documented in the correct wiring diagram.
davisev5225
C?ID=263265
edit by Jef
Could be.
  • Haha
