Hi everyone, I have looked for something in the forum but could not find anything so posting here.
My R36 from December 2009, seems to be equipped with TPMS sensors inside the rim (the car is a bit of the last version with modernized interior, has no rubber valves but matellic valves instead (all original) and also has the module 65 stating "HW: 3C0 959 433 AM" and suggesting that I have indeed the TPMS module installed at 433 MHz.
Unsurprisingly for a 15 year old car (I bought the car when it was 5 years old), the TPMS batteries went dead and I progressively started to have more and more TPMS issues.
While I can disconnect the TPMS measuring when my winter wheels (which do not have any TPMS sensor in them) are fitted, the TPMS measuring comes back On all the time after a few seconds when I have the Summer wheels (equipped with old TPMS sensors) on and after I press a long time on the TPMS button and get the "Tire monitoring off".
To me it is a signal that while the TPMS Module cannot get info from the TPMS sensors, it knows that there are TPMS sensors in the wheel, so refuses to be switched off for more than a few seconds (I have seen videos on how to remove the function, but this is not what I am after).
What I do not understand is that in my VCDS, in the section 65, the "Basic Function" is greyed out. From what I understand, this is this function that would allow to sync the new TPMS sensors with the TPMS module.
From what I understand, there are 2 types of TPMS:
- The generic ones that require a USD 200 tool to scan the RF code of each sensor and then connect via OBD2 to the 65 module to inform the TPMS module of what sensor is where
- The pre-programmed TPMS sensors that already have the parameters for a few cars coded, and that only require to drive the car for 15-20 minutes at speed over 30 mph in order to wake the senror up and get the TPMS module to recognise each sensor.
The issue is that this pre-programed sensors seem to come from "Huf", which does not list Passat B6 compatible options. On usual website like auto-doc, it seems that the "HUF RDE042V26" is compatible, but I do not find this info anywhere outside this website so I am not sure.
My questions are as follows:
- Has anyone replaced old TPMS sensors on Passat R36 equipped with in-wheel TPMS sensors?
- If yes, what sensors have they bought/installed?
- If yes, how did they pair these sensors to the TPMS module? Did it pair automatically after driving 15-20 minutes?
Thanks much for your help - Full scan attached. Note: forget the faults outside Module 65 as he other faults are expected (like changing the radio) and/or cae after a battery disconnection. So this scan is more for you to see what modules I have.
Monday,04,August,2025,11:00:06:29962
VCDS Version: 25.3.1.2 (x64)
Data version: 20250604 DS365.0
VIN: WVWZZZ3CZAE070499 License Plate: ZH468884
Mileage: 111110km-69040mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 0F 10 13 14 15 16 17 19 22 25 2E 36 37 42 44
46 47 52 53 55 56 5C 62 65 69 6C 6D 72 77
VIN: WVWZZZ3CZAE070499 Mileage: 111110km-69040miles
09-Cent. Elect. -- Status: Malfunction 1010
0F-Digital Radio -- Status: Cannot be reached 1100
14-Susp. Elect. -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Malfunction 1010
37-Navigation -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
5C-Lane Maintain. -- Status: Malfunction 0010
69-Trailer -- Status: Sporadic communication error 1000
Address 01: Engine (BWS) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 FS HW: 03H 906 032 AB
Component: CC3.6-FSI-EU5 F 4855
Revision: 5GH04--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 05311 000 08193
VCID: 78FFD15D0BA6415BF1-802C
VINID: 9E69EAAAA0D3A915401C0109240FA7F6E6
006439 - Relay for Aux Coolant Pump (J496)
P1927 - 004 - Open Circuit - Intermittent
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:13:51
RPM: 632 /min
Load: 30.6 %
Temperature: 77.0 C
Temperature: 29.0 C
Absolute Pres.: 960.0 mbar
Voltage: 13.208 V
001299 - Incorrect Immobilizer Key
P0513 - 008 - - Intermittent
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:01:34
RPM: 1420 /min
Load: 29.0 %
Temperature: 49.0 C
Temperature: 27.0 C
Voltage: 12.065 V
Part No SW: 02E 300 012 E HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1905
Revision: 04844002 Serial number: 00000910271125
VCID: 122B83F50D1A8B0B6F-8046
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AG HW: 3C0 614 109 AG
Component: J104 C4 440 V3 0015
Revision: --025--- Serial number: 00000795837522
Coding: 0024995
VCID: 63C59631A220B283B4-8036
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
Shop #: WSC 05311 115 08193
VCID: 7EF3C745E1827F6BBB-802A
13635840 - Supply voltage
U1011 00 [00001000] - Voltage too Low
Reset counter: 114
Mileage: 110589 km
Date: 2025.08.04.
Time: 02:06:26
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000003435834
Coding: EE0F8F2700281000570A00000F000000000B59435C000120000000000000
Shop #: WSC 05124 123 12345
VCID: 336526715240620304-8066
Subsystem 1 - Part No: 3C1 955 419 B Labels: 1KX-955-119.CLB
Component: Wischer 210909 006 0208
Coding: 00049045
Shop #: WSC 05124
Component: RLS 031109 054 0402
Coding: 00208936
Shop #: WSC 05124
9 Faults Found:
01501 - Bulb for Blinkers; Rear Left (M6)
Fault Status: 00111100
Reset counter: 116
Mileage: 110589 km
Voltage: 11.80 V
Reset counter: 117
Voltage: 12.55 V
Fault Status: 00101100
Reset counter: 114
Mileage: 110588 km
Voltage: 12.00 V
Reset counter: 114
Mileage: 110588 km
Voltage: 12.00 V
Reset counter: 114
Mileage: 110589 km
Voltage: 11.90 V
01502 - Bulb for Rear Fog; Left (L46)
Reset counter: 114
Mileage: 110589 km
Voltage: 11.85 V
Reset counter: 114
Mileage: 110589 km
Voltage: 11.90 V
Reset counter: 116
Voltage: 12.50 V
Fault Frequency: 23
Reset counter: 117
Voltage: 12.25 V
Address 0F: Digital Radio
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 3C8 919 475 A HW: 3C8 919 475
Component: PARKHILFE 8K H07 0009
Revision: -------- Serial number: 08720929301687
Coding: 310102
Shop #: WSC 05314 000 00000
VCID: 326B23756D5A6B0B0F-8066
02070 - Rear Parking Aid Sensors
Fault Status: 00101011
Reset counter: 115
Mileage: 110588 km
Date: 2019.12.26.
Time: 15:42:44
Temperature: 33.0 C
01517 - Control Module for Trailer/Towing Sensor (J345)
Fault Frequency: 28
Reset counter: 117
Mileage: 109470 km
Date: 2019.12.26.
Time: 09:37:36
Temperature: 14.0 C
Reset counter: 116
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:01:37
Temperature: 22.0 C
Address 13: Auto Dist. Reg Labels: 3C0-907-567.clb
Part No SW: 3C0 907 567 M HW: 3C0 907 567 M
Component: AC201 RDW A 031 0243
Revision: 00031000 Serial number: 00000000047850
Coding: 0010000
VCID: 356118695C347C332A-8060
Reset counter: 115
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:44:20
Count: 92
Reset counter: 115
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:05:02
Count: 1
Address 14: Susp. Elect.
Part No SW: 5N0 959 655 H HW: 5N0 959 655 H
Component: J234__025 VW10 HI 1916
Revision: 20013000 Serial number: 003E1PNF11PM
Coding: 0012853
VCID: 428B73B51DFADB8B9F-8016
Subsystem 1 - Serial number: 6332MTS617052889
Subsystem 2 - Serial number: 6342MTS620522729
Subsystem 3 - Serial number: 6351HTS67B3E66KJ
Subsystem 4 - Serial number: 6361HTS6C4J966KR
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BM HW: 5K0 953 569 T
Component: LENKS.MODUL 009 0122
Revision: FF010E35 Serial number: 20091104200108
Coding: B998A70002
ASAM Dataset: EV_VW360SteerWheelUDS A03002
VCID: 75E1D869D4B43C33EA-8020
Component: E221 - MFL H02 0003
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
Reset counter: 114
Mileage: 110589 km
Date: 2025.08.04.
Time: 00:39:45
117012 - Databus
Reset counter: 116
Mileage: 110589 km
Date: 2025.08.04.
Time: 00:01:37
136194 - Supply voltage
Reset counter: 114
Mileage: 110589 km
Date: 2025.08.04.
Time: 02:03:30
Part No SW: 3C0 920 872 J HW: 3C0 920 872 J
Component: KOMBI H03 0305
Coding: 161F00
Shop #: WSC 05314 115 12345
VCID: 2C573D0D477E3DFB45-8078
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
Reset counter: 117
Mileage: 110589 km
Date: 2025.08.04.
Time: 00:00:02
13639168 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
Reset counter: 74
Mileage: 110589 km
Date: 2025.08.04.
Time: 11:13:49
Reset counter: 114
Mileage: 110589 km
Date: 2025.08.04.
Time: 02:01:02
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 P HW: 3C0 907 951
Component: J533 Gateway H13 0170
Revision: H13 Serial number: 3520Q09B02008A
Coding: FDAFFF4752471A002002
Shop #: WSC 05314 123 12345
VCID: 2E533705B9624FEB6B-807A
8 Faults Found:
Reset counter: 21
Mileage: 107427 km
Reset counter: 117
Mileage: 110589 km
Fault Frequency: 159
Reset counter: 117
Mileage: 107427 km
03272 - Control Module for Audio Interface
Fault Frequency: 162
Reset counter: 122
Mileage: 107427 km
02649 - Digital Radio Tuner
Reset counter: 23
Mileage: 107555 km
Reset counter: 117
Mileage: 110589 km
Reset counter: 76
Mileage: 110589 km
00471 - Control Module for Elect. Regulated Dampers (J250)
Reset counter: 77
Mileage: 110589 km
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BS 907 554 A HW: 0BS 907 554 A
Component: Haldex 4Motion 4013
Coding: 0000005
VCID: 448775AD07EED5BBAD-8010
Part No SW: 3C0 959 433 AM HW: 3C0 959 433 AM
Component: IMMO 052 0383
Revision: 00052000 Serial number: VWZCZ000000000
VCID: 75E1D8691CB43C33EA-8020
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Address 2E: Media Player 3
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F6D2A01BE6846E360-807A
Address 37: Navigation
Part No SW: 1K0 959 701 AS HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1501
Revision: 71009005 Serial number: 00000644899031
Coding: 0004535
VCID: 7F0D3A412E887663B0-802A
Reset counter: 116
Mileage: 110589 km
Date: 2019.12.26.
Time: 02:12:04
Fault Status: 00100101
Reset counter: 118
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:01:05
Fault Frequency: 9
Reset counter: 117
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:01:07
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.159 0703
Revision: 1AH03256 Serial number: 00092540030402
Coding: 0000258
VCID: 3A7B0B55752A934BC7-806E
01288 - Terminal 30; Steering Assist
Fault Priority: 9
Reset counter: 116
(no units): 2.0
Voltage: 11.90 V
00576 - Terminal 15
Reset counter: 116
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:01:37
(no units): 8.0
Voltage: 11.90 V
Component: KSG PQ46 RDK 052 0412
Coding: 18900A00D103407E3F0294157008CFCE705801
Subsystem 1 - Part No: 1K8 951 605
Component: LIN BACKUP HORN H10 9003
Component: Neigungssensor 004 0611
Reset counter: 117
Mileage: 107427 km
Date: 2019.12.26.
Time: 23:01:58
Reset counter: 114
Mileage: 110589 km
Date: 2019.12.26.
Time: 02:00:44
Reset counter: 116
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:01:39
Address 47: Sound System (R12) Labels: None
Part No HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218198622208 Dataset Number: 1K8050v____ 3C01
ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
ROD: EV_AudioVerst8KanalBNO2.rod
VCID: 55A1B8E934745C33CA-8000
Reset counter: 114
Mileage: 110589 km
Date: 2025.08.04.
Time: 01:49:56
Part No SW: 1K0 959 702 AS HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1501
Revision: 71009005 Serial number: 00000630499023
Coding: 0004534
VCID: 000FB9BD5376099BC9-8054
Reset counter: 116
Mileage: 110589 km
Date: 2019.12.26.
Time: 02:11:54
Reset counter: 118
Reset counter: 117
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:01:07
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 010 Serial number: 00000000071393
Coding: 0000057
VCID: 2C573D0D8F7E3DFB45-8078
00576 - Terminal 15
Reset counter: 116
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:01:34
Voltage: 11.70 V
Count: 54
Hex Value: 0x12E0
Hex Value: 0x0008
Hex Value: 0x0101
Reset counter: 116
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:01:35
Voltage: 11.40 V
Count: 112
Hex Value: 0x12F0
Hex Value: 0x0008
Hex Value: 0x0101
Address 55: Headlight Range
Address 56: Radio
Address 5C: Lane Maintain. Labels: 3C0-907-217.clb
Part No SW: 3C0 907 217 A HW: 4E0 907 217 C
Component: J759 HCA 0150
Revision: 00H07004 Serial number: 400209B0900090
Coding: 0122001
VCID: 2149DC39F8BCE093E6-8074
Reset counter: 116
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:01:34
Fault Frequency: 13
Reset counter: 117
Mileage: 109470 km
Date: 2019.12.26.
Time: 09:37:35
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000001131999
Coding: 0000144
Shop #: WSC 05311 000 00000
VCID: 70EFE97D63D6191B39-8024
Reset counter: 99
Mileage: 109869 km
Date: 2019.12.26.
Time: 12:54:05
00934 - Electric Window Motor; Rear Left (V26)
Reset counter: 119
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Reset counter: 116
Mileage: 110589 km
Date: 2019.12.26.
Time: 02:13:41
Component: RDK 0453
Coding: 0161211
Fault Status: 01110100
Mileage: 111119 km
Date: 2019.12.26.
Time: 10:50:14
Address 69: Trailer (J345) Labels:. 7N0-907-383.clb
Part No SW: 7N0 907 383 HW: 7N0 907 383
Component: Towbar module H09 0120
Revision: 3A001001 Serial number: 006789752928
Coding: 410C040001000000
VCID: 73E5E671D2C02203C4-8026
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C9 907 441 HW: 3C9 907 441
Component: J772__Rearview 0020
Revision: 00H07000 Serial number: 525PA8-J990312
Coding: 0020007
VCID: 68DF811D5B06D1DB61-803C
02203 - Audio / Video Input 1
Reset counter: 114
Mileage: 110589 km
Reverse OFF
Count: 3
Reset counter: 115
Mileage: 110589 km
Term 15 Off
Reverse OFF
Count: 3
Reset counter: 114
Mileage: 110589 km
Term 15 Off
Reverse OFF
Count: 3
Fault Frequency: 27
Reset counter: 117
Mileage: 110589 km
Term 15 Off
Reverse OFF
Count: 3
Address 6D: Trunk Elect. Labels: 3C9-827-383.clb
Part No SW: 3C9 827 383 G HW: 3C9 827 383 G
Component: J605 HECKDECKEL 0730
Revision: 00H27001
Subsystem 1 - Part No: 3C9 827 384 G
Component: J756 HECKDECKEL 0730
Subsystem 2 - Serial number: 0900H27001001B0193
00317 - Rear Lid Control Module (J605)
Reset counter: 122
Mileage: 107424 km
Date: 2019.12.26.
Time: 21:50:09
Reset counter: 115
Mileage: 110589 km
Date: 2019.12.26.
Time: 01:42:27
Fault Frequency: 26
Reset counter: 117
Mileage: 110589 km
Date: 2019.12.26.
Time: 00:00:04
02364 - Closing Assistance
Reset counter: 114
Mileage: 110589 km
Date: 2019.12.26.
Time: 06:21:28
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000001142751
Coding: 0000144
VCID: 71E9EC7968DC101336-8024
00935 - Electric Window Motor; Rear Right (V27)
Reset counter: 118
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Reset counter: 116
Mileage: 110589 km
Date: 2019.12.26.
Time: 02:13:17
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0982
Revision: -------- Serial number: 35502105205536
Coding: 020000000100000000000001
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi_002_VW32.rod
VCID: 2447D52D2FAEF5BB8D-8070
B104F 13 [00001001] - Short to GND
Reset counter: 21
Mileage: 107427 km
Date: 2025.08.04.
Time: 22:55:23
B104E 13 [00001001] - Short to GND
Reset counter: 21
Mileage: 107427 km
Date: 2025.08.04.
Time: 22:55:23
9455635 - Telephone Microphone
B1048 13 [00001001] - Open Circuit
Reset counter: 21
Mileage: 107427 km
Date: 2025.08.04.
Time: 22:55:23
12664832 - Body Control Module (Central Electric)
U0140 00 [00001000] - No Communications
Reset counter: 116
Mileage: 110589 km
Date: 2025.08.04.
Time: 00:01:39
End-------------------------(Elapsed Time: 05:28)--------------------------
------------------------------67 Faults Found------------------------------
