Problem with Update (RODS)
VCofig updating , HN plugged USB into PC, I originally checked for a update because the VCDS mobile would not do a Auto-Scan on the 2024 RS5 , it showed the gateway list only (rapidly) and failed on all the other modules. Well about half of them, as about 4min. passed and it was barely crawling along - so I stopped the AS.
I did try a few times checking and unchecking the VCDS-mobile app update box choice as well.
Auto-Scan with HN on NET setting and PC works fine.
Thank you!
Shaun
Can you please post the autoscan that works for reference?
Tuesday,19,August,2025,20:19:54:19210
VCDS Version: 25.7.0.0 (x64)  HEX-NET CB: 0.4672.4
Data version: 20250716 DS371.0
VIN: WUANWAF54RA902030   License Plate: RS5
Mileage: 5817km-3614mi   Repair Order: 8192025
Chassis Type: F5-AU49 (80C)
Scan: 01 02 03 06 08 09 13 15 16 17 19 1B 32 36 3C 42 44 46 52 5F
          65 6C 74 75 81 82 8B A5 A9 CA CF D6 D7 DE
VIN: WUANWAF54RA902030   Mileage: 5817km-3614miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DECA)       Labels: None
   Part No SW: 8W0 907 551 R    HW: 06M 907 309 H
   Component: V6 2.9l TFSI  H11 0001
   Revision: B9H11000    CVN: FDF7BD7C
   Coding: 1A2A00322566100E343E0000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM29TFS0118W0907551R 001001
   ROD: EV_ECM29TFS011_AU49.rod
   VCID: CCD41BF267809DFAEF-8098-R
   VINID: 9E545E9D158512244900200300E77B7A1A
   Part No SW: 8W0 927 158 BL    HW: 0D5 927 156 N
   Component: 0D5 29FSINAR  H06 0001
   Revision: --H06---    CVN: 14D9D9D4
   Coding: 100000
   Shop #: WSC 06325 790 00001
   ASAM Dataset: EV_TCMALX52011 002016
   ROD: EV_TCMALX52011_AU49.rod
   VCID: 8D52D6F65C1AD4F238-80D8-R
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-V2.clb
   Part No SW: 8W0 907 379 BK    HW: 8W0 907 379 BH
   Component: ESP9 Premium  H02 0934
   Dataset Number: 8W2909504BB 0002 CVN: D70F954E
   Coding: 5014300A11484218A2E4259A0A280C50881242184527A459
   ASAM Dataset: EV_ESP9BOSCHCMP 005023
   ROD: EV_ESP9BOSCHCMP_005_AU49.rod
   VCID: 8F6ECCFE5616E6E2CA-80DA-R SFD+SFD2
   Part No SW: 4K0 959 760 A    HW: 4K0 959 760 A
   Component: MEM-BFS       011 0071
   Serial number: 00000518059001 Dataset Number: 8W2909866F  0021
   Coding: 0116B004000CB2000003010141010000000000000000000000000000802002
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: B42463121F70E53A97-80E0-R
   Part No SW: 8W0 820 043 BR    HW: 8W0 820 043 BR
   Component: Klima Zone 3  H70 0350
   Dataset Number: 8W2909862B  0024
   Coding: 4608050D4544010D10020100080000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ASAM Dataset: EV_AirCondiBHTCAU491 001029
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 8444F3D20F5095BA67-80D0-R
   Subsystem 1 - Part No SW: 4M1 820 021 C    HW: 4M1 820 021 C
   Component: J126 FLuftV  H09 0004
   Serial number: 00000000000009773698
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H06 0012
   Serial number: BE39AE1400PAG0MUFU04
   Subsystem 3 - Part No SW: 8W0 919 158 C    HW: 8W0 919 158 C
   Component: E265 Kli Fond  H50 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W1 907 063 DN    HW: 8W1 907 063 N
   Component: BCM1 MLBevo   H12 0775
   Dataset Number: 8W6909514H  0029
   Coding: 07000360C0291CDD050D5F8918AD9CAA130B35440000009801050A0060001C01086902BBA2B70A0000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 020007
   ROD: EV_BCM1BOSCHAU651_020_AU49.rod
   VCID: 8B56D8EE220EDAC226-80DE-R
   Subsystem 1 - Part No SW: 8W6 955 119 D    HW: 8W6 955 119
   Component: 494 LL 071223  038 0490
   Serial number: 00000002312050302065
   Coding: FFC7F7
   Component: G397_RLFSS  H06 0004
   Serial number: 46186905X81A955555B0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AT    HW: 4M0 941 531 AT
   Component: E1 - LDS  H07 0008
   Serial number: 20 07 2023  03735595
   Subsystem 4 - Part No SW: 4N0 907 410 D    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600400Z003E02
   Coding: 250000
   Subsystem 5 - Part No SW: 4KE 857 511 C    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0003
   Serial number: GX1NR105092323310033
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 AH    HW: 4K0 947 135 AH
   Component: Dachmodul  H42 0419
   Serial number: A01669881
   Coding: 0D0104
   Valve block 1 in front seat driver side:
   Subsystem 7 - Part No SW: 8W0 907 182 A    HW: 8W0 907 182 A
   Component: J873 MKS_FSv  H11 0012
   Serial number: 7009137801M240281303
   Coding: BF0500
   Valve block 1 in front seat passenger side:
   Subsystem 8 - Part No SW: 8W0 907 182 A    HW: 8W0 907 182 A
   Component: J872 MKS_BFSv  H11 0012
   Serial number: 7009137801M240281274
   Coding: B30500
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 8W0 907 561 K    HW: 8W0 907 561
   Component: LRR4          H14 0478
   Dataset Number: 8W2909863T  0002
   Coding: B5779FF358FFEC06757B61A1
   ASAM Dataset: EV_ACCBOSCHAU49X 003029
   ROD: EV_ACCBOSCHAU49X_003_AU49.rod
   VCID: C6C029DA79EC67AA39-8092-R SFD+SFD2
Address 15: Airbags (J234)       Labels:. 8W0-959-655.clb
   Part No SW: 8W0 959 655 AH    HW: 8W0 959 655 AH
   Component: AirbagVW34    H08 1851
   Serial number: 003DJM000JJ9 Dataset Number: 8W0909602DB 0006
   Coding: BFCCF0C000800000A000003FF20C400000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 003003
   ROD: EV_AirbaVW31SMEAU65x_003_AU49.rod
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2044
   Serial number: 8W6857705P0332X00066
   Coding: 882005
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2044
   Serial number: 8W6857706P0340X00238
   Coding: 882005
   Component: BF-Gewichtss.  H15 0022
   Serial number: IBH0000D23000LPZAG0%
   Coding: 303739
   Subsystem 4 - Part No SW: -----------    HW: 480 001 501 24
   Serial number: 35700000000D36F4FD64
   Subsystem 5 - Part No SW: -----------    HW: 480 001 501 24
   Serial number: 35800000000DAA41FD62
   Subsystem 6 - Part No SW: -----------    HW: 480 051 912 23
   Component: FrontSensor_D  000 014A
   Serial number: 3550000BCCC7B499E8A3
   Subsystem 7 - Part No SW: -----------    HW: 480 051 912 23
   Component: FrontSensor_P  000 014A
   Serial number: 3560000C6CC7B3C6E99+
   Part No SW: 4N0 907 129 PA    HW: 4N0 907 129 PA
   Component: Lenks.Modul   H03 0011
   VCID: FF4E7C3E66B6F6623A-80AA-R
   Part No SW: 8W5 920 790 R    HW: 8W5 920 790 P
   Component: FBenRDW------ H13 0465
   Dataset Number: 8W1909525K  0026
   Coding: 8B4F34CF7EB8CF050290676418004B1008000800
   ASAM Dataset: EV_DashBoardAU65X 002039
   ROD: EV_DashBoardAU65X_002_AU49.rod
   VCID: D1EA0A8680A2B0129C-8084-R
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 80C 907 468 Q    HW: 80C 907 468 L
   Component: Gateway       H06 0042
   Serial number: F0298279007431 Dataset Number: 8W0909515AD 0053
   Coding: 03030001000002405407000000590012FC18008092000000010000CE04030000
   GVL: 01587C580000000040FCC8008002C800110C0000000000000000000000006500
   ASAM Dataset: EV_Gatew31xUNECE 005020
   ROD: EV_Gatew31xUNECE_AU49.rod
   VCID: BE30413A213C3F6A71-80EA SFD+SFD2
   Subsystem 1 - Part No SW: 8W0 951 523 AJ    HW: 8W0 951 523 AJ
   Component: J453 MFL  H06 0005
   Serial number: 20231116181235 31951
   Subsystem 2 - Part No SW: 8S0 915 181 D    HW: 8S0 915 181 D
   Component: J367-BDMHella  H01 2361
   Serial number: 2167053506
   Subsystem 3 - Part No SW: 4M8 419 508 B    HW: 4M8 419 508 B
   Component: J1158 KLR  H14 0012
   Serial number: 00000000000000286231
   Coding: FFFFFF
262727 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [BAP_Timeout_ConnectionManager]
                    Fault Frequency: 15
                    Reset counter: 167
                    Mileage: 1872 km
                    Date: 2025.04.20
                    Time: 19:14:06
16646149 - Predictive Route Data
          B1630 02 [00001000] - Signal Failure
                    Fault Frequency: 87
                    Reset counter: 173
                    Mileage: 1872 km
                    Date: 2025.04.20
                    Time: 03:15:11
16646152 - Predictive Route Data
                    Fault Frequency: 49
                    Reset counter: 173
                    Mileage: 1872 km
                    Date: 2025.04.20
                    Time: 03:15:11
16712308 - Tiredness and Distraction Warning
          U2022 00 [00001000] - Function Restriction
          [Attention_Drowsiness_Assist_roof_center_console_error]
                    Reset counter: 173
                    Mileage: 5817 km
                    Date: 2025.08.16
                    Time: 18:55:53
   Part No SW: 8W0 907 144 J    HW: 8W0 907 144 C
   Component: SCU_MLBevo    H03 0710
   Serial number: 30303030303030 Dataset Number: 8W2909848L  0002
   ASAM Dataset: EV_SCUZFLSAU49X 002019
   ROD: EV_SCUZFLSAU49X_002.rod
   VCID: C2C835CA55C45B8A15-8096-R
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163 B    HW: 8W0 907 163 B
   Component: QSP QCU Gen2  H08 0080
   Revision: A2C74525    Serial number: 605402410201107
   Coding: 0003
   ASAM Dataset: EV_TVDCQSP22 001008
   ROD: EV_TVDCQSP22.rod
   VCID: BB36482E322E2A4256-80EE-R
   Component: MEM-FS        011 0071
   Serial number: 00000513012846 Dataset Number: 8W2909856F  0021
   Coding: 011E9A04000CB2010003010141010000000000000000000000000000806002
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 G    HW: 4M0 907 566
   Component: MRR1Rear      H24 0452
   Revision: --------    Dataset Number: 8W0909535D  0003
   Coding: 0EC002
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   ROD: EV_RearRadarS1BoschAU736_AU49.rod
   VCID: B93A52263812185244-80EC-R
   Part No SW: 4M0 959 793 P    HW: 4M0 959 793 P
   Component: TSG FS        013 0401
   Serial number: 0000510217682  Dataset Number: 8W2909872G  0036
   Coding: 005D4B42520010A500012432
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001023
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: CBD618EE628E9AC2E6-809E-R
          B1487 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 163
                    Mileage: 1993 km
                    Date: 2025.05.09
                    Time: 05:16:14
Address 44: Steering Assist (J500)       Labels:| 8W0-909-144-V1.clb
   Part No SW: 8W0 909 144 J    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0411
   Dataset Number: 8W2909852R  0037
   Coding: 85888380000080
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: C4C433D24FD055BA27-8090-R
   Part No SW: 8W1 907 064 EC    HW: 8W1 907 064 EC
   Component: BCM2 MLBevo   050 0628
   Dataset Number: 8W2909501BB 0007
   Coding: 011263004FB00080650FA0006C01000203030000810426502F0400040B04003D201E0681002F310200000000000000000000
   ASAM Dataset: EV_BCM2HellaAU736 021020
   ROD: EV_BCM2HellaAU736_021_AU49.rod
   VCID: 8248F5CA15449B8A55-80D6-R SFD+SFD2
   Subsystem 1 - Part No SW: 5Q0 951 177 C    HW: 5Q0 951 172 C
   Component: Sensor, DWA  006 0501
   Serial number: 0000000000000Q3G3SS0
   Subsystem 2 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000003961571
   Left taillight 1:
   Subsystem 3 - Part No SW: 8W6 945 423 A    HW: 8W6 945 423 A
   Component: SHL_li1  H03 0017
   Serial number: 0000000000000L1D83C6
   Left taillight 2:
   Subsystem 4 - Part No SW: 8W6 945 429 A    HW: 8W6 945 429 A
   Component: SHL_li2  H03 0017
   Serial number: 0000000000000L1CRX9O
   Right taillight 1:
   Subsystem 5 - Part No SW: 8W6 945 424 A    HW: 8W6 945 424 A
   Component: SHL_re1  H03 0017
   Serial number: 0000000000000L1D837H
   Right taillight 2:
   Subsystem 6 - Part No SW: 8W6 945 430 A    HW: 8W6 945 430 A
   Component: SHL_re2  H03 0017
   Serial number: 0000000000000L1D22VP
   Part No SW: 4M0 959 792 P    HW: 4M0 959 792 P
   Component: TSG BFS       013 0401
   Serial number: 0000512484564  Dataset Number: 8W2909873G  0036
   Coding: 005D4B425E0010A500012430
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001023
   ROD: EV_DCU2PasseSideMAXHCONT_VW41.rod
   VCID: CAD81DEA6DF483CADD-809E-R
   Part No SW: 8W2 035 050 Q    HW: 8W2 035 050 B
   Component: MU-TH-NS-US   045 4404
   Serial number: GRO-63317.11.23 Dataset Number: 8W1909545AA 0065
   Coding: 14940000804120000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU27.rod
   VCID: BFCE3C3E263636627A-80EA-R SFD+SFD2
   Multimedia display unit 1:
   Subsystem 1 - Part No SW: 8W2 919 620     HW: 8W2 919 620
   Component: DU Top AU49x   H41 0070
   Serial number: TPO00126102310110871
   Subsystem 2 - Part No: V03 959 823 LJ
   Component: MIB3_NA_       1386
   Compact disc data bank:
   Component: Gracenote2     3008
   Volume Control 1:
   Subsystem 4 - Part No SW: 8W1 919 616 D    HW: 8W1 919 616 D
   Component: LSR-B9PA       H20 0103
   Serial number: ALJAL213102300020105
   Android control module:
   Subsystem 5 - Part No SW: 8W0 919 806 A    HW: 8W0 919 806
   Component: AED2-EU        H54 0554
   Serial number: YD700214112303190401
   Media socket:
   Subsystem 6 - Part No: 8W0 035 708 A
011 0010
   Digital Sound System Control Module 2:
   Subsystem 7 - Part No SW: 8Y0 035 465 A    HW: 8Y0 035 465 A
   Component: B_A_3_P_0_AU   H11 0100
   Serial number: HHA-07305.12.2342960
1637 - Interface for External Media
          U11B8 00 [00001000] - No Communications
          [USB - communication error]
                    Reset counter: 162
                    Mileage: 5229 km
                    Date: 2025.08.02
                    Time: 14:14:45
                    Voltage terminal 30: 14.3 V
                    Interface for external media: status: Open circuit
                    Reset counter: 65
                    Mileage: 1872 km
                    Date: 2025.04.19
                    Time: 13:09:48
                    Reception quality: Good signal
                    Audio Signal: Available
                    Satellite radio antenna status: electrically OK
                    Antenna current: 107 mA
                    Channel selection for satellite radio: 0
                    Satellite radio tuner: pre-activation status: factory_activation_successful
                    Satellite radio tuner: pre-activation value: 05
                    Voltage terminal 30: 12.5 V
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H06 0010
   Serial number: 30000000245982 Dataset Number: 8W2909850A  0004
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: AF2E6C7EF656C6E2EA-80FA-R
8400904 - Tires 03: Tire  Pressure Warning
          C111F 00 [00001000] - Pressure too Low
                    Reset counter: 152
                    Mileage: 4532 km
                    Date: 2025.07.17
                    Time: 17:38:36
                    Expanded ambient data 6-Vehicle speed: 17.77 km/h
                    Expanded ambient data 6-Outside temperature: 22.00  C
                    Expanded ambient data 4-Left rear tire pressure sensor: nominal pressure: 3.30 bar
                    Expanded ambient data 4-Left rear tire pressure sensor: actual pressure: 2.80 bar
                    Expanded ambient data 4-Left rear tire pressure sensor: temperature: 20  C
                    Expanded ambient data 4-Left rear tire pressure sensor: identification: 607284803
   Part No SW: 8W0 907 428 D    HW: 4M0 907 428
   Component: Areaview 2    H32 0109
   Serial number: C856611JV000649 Dataset Number: 8W2909460L  0027
   Coding: 02940402BE0FA10038004004
   ASAM Dataset: EV_CamSysRVAV2CE2MLBPA 002001
   ROD: EV_CamSysRVAV2CE2MLBPA_002.rod
   VCID: C1CA3AC650C240920C-8094-R
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 8W0 907 777 S    HW: 8W0 907 777 B
   Component: Fahrwerk-SG   H38 1252
   Serial number: 1012231123  Dataset Number: 8W2909576M  0001
   Coding: 5460A0C112
   ASAM Dataset: EV_ChassContrContiAU426 001004
   ROD: EV_ChassContrContiAU426_AU49.rod
   VCID: D7FEF49EAE46EE2252-8082-R
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 4KE 035 283 L    HW: 4KE 035 283 E
   Component: CB_H_NAR      043 0595
   Serial number: A971L0PS445461 Dataset Number: 8W0909612M  0041
   Coding: 01E0E0F8C04080F6F0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_AU49.rod
   VCID: C5C22ED644EA6CB230-8090-R SFD+SFD2
   Part No SW: 8W1 713 041 P    HW: 4M1 713 041 G
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 24010590625559
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: C0CC3FC25BC8499A03-8094-R
Address 82: Head Up Display (J898)       Labels:| 4M0-919-617-V1.clb
   Part No SW: 8W6 919 617 K    HW: 8W6 919 617 F
   Component: HeadUpDisplay H15 2322
   Coding: 4F01F0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU49.rod
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 8W0 907 541 K    HW: 8W0 907 541
   Dataset Number: 8W2909885H  0003
   ASAM Dataset: EV_ACC2BOSCHAU49X 003030
   ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
   VCID: C4C433D24FD055BA27-8090-R SFD+SFD2
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W6 907 217 G    HW: 8W6 907 217 G
   Component: BVS           H34 0091
   Dataset Number: 8W2909466H  0061
   Coding: 04040904000002030120238EC50000FCA8E0C024E280
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 003032
   ROD: EV_BVSMLBevKOSTAAU736_003.rod
   Part No SW: 8W0 907 159 AH    HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 231108290106
   ROD: EV_SoundActuaGen2AU64X_003_VW48.rod
   VCID: 875EE4DE3E66BEA202-80D2-R
   Part No SW: 4K8 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     010 0010
   Dataset Number: 8W2909469G  0008
   Coding: 248040049401
   ROD: EV_SunRoofCONTIAU736_009_VW48.rod
   VCID: FDB286366CBAE47228-80A8-R
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 4M0 907 590 G    HW: 4M0 907 590
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   ROD: EV_RearRadarS2BoschAU736_AU49.rod
   VCID: B620591A090CF72AA9-80E2-R
   Part No SW: 4K0 941 592 AJ    HW: 4K0 941 592 A
   Component: LMS_MLBevo    H20 0147
   Dataset Number: 8W2909471E  0009
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
   ROD: EV_LMSLeftHELLAAU58X_AU37.rod
   VCID: F8BC97224398C15A7B-80AC-R
   Dataset Number: 8W2909472E  0009
   ASAM Dataset: EV_LMSRightHELLAAU58X 001015
   ROD: EV_LMSRightHELLAAU58X_AU37.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 4K0 035 502 B    HW: 4K0 035 502 B
   Component: WLC Front     H14 0061
   Dataset Number: 4N0909485A  0007
   Coding: 400000
   ROD: EV_Charg1MobilDevicAU651_004_AU37.rod
   VCID: A00C9F42BB88699A63-80F4-R
End----------(Elapsed Time: 02:41, VBatt start/end: 12.5V/12.5V)-----------
------------------------------8 Faults Found-------------------------------
Address 65: DTCs cleared
OMG... code wrap! I expect better from YOU
Hi, I did toggle the [ ] icon to start, but didn't close with it. Thanks
Let me try again..... for Science!
   Coding: 100000
   Coding: FFC7F7
   Coding: 02005D
   Coding: 250000
   Coding: 0D0104
   Coding: BF0500
   Coding: B30500
   Coding: 882005
   Coding: 882005
   Coding: 303739
   Coding: FFFFFF
                    Fault Frequency: 15
                    Reset counter: 167
                    Mileage: 1872 km
                    Date: 2025.04.20
                    Time: 19:14:06
                    Fault Frequency: 87
                    Reset counter: 173
                    Mileage: 1872 km
                    Date: 2025.04.20
                    Time: 03:15:11
                    Fault Frequency: 49
                    Reset counter: 173
                    Mileage: 1872 km
                    Date: 2025.04.20
                    Time: 03:15:11
                    Reset counter: 173
                    Mileage: 5817 km
                    Date: 2025.08.16
                    Time: 18:55:53
   Coding: 0003
   Coding: 0EC002
                    Reset counter: 163
                    Mileage: 1993 km
                    Date: 2025.05.09
                    Time: 05:16:14
   Left taillight 1:
   Left taillight 2:
   Right taillight 1:
   Right taillight 2:
   Volume Control 1:
   Media socket:
011 0010
                    Reset counter: 162
                    Mileage: 5229 km
                    Date: 2025.08.02
                    Time: 14:14:45
                    Reset counter: 65
                    Mileage: 1872 km
                    Date: 2025.04.19
                    Time: 13:09:48
                    Reset counter: 152
                    Mileage: 4532 km
                    Date: 2025.07.17
                    Time: 17:38:36
   Coding: 5460A0C112
   Coding: 4F01F0
   Revision: --------
   Coding: 0EC002
   Coding: 400000
Right Bruce, and..... I'm a morning person - imagine what happens at the end of the day!
Shaun
This vehicle appears to be locked down with SFD2 and VCDS is using UDS-R mode to talk to every module but the gateway. This is a fairly new feature to deal with some of the restrictions here and it is not widely supported in VCDS-Mobile yet. I will make a note to bump this thread when it is available, but I don't have a specific time frame at the moment.
Ok Shaun, thanks for letting me know. Should I just ignore the update or just check the box to not update VCDS-mobile.
Shaun
Skipping mobile update is fine for now if you want it to stop bothering you.
