Thank you in advance. I'm still learning how to read this VCDS Fault Code print out. My heater stopped blowing yesterday and it's pretty freakin cold out. 4' today. Read forums of Thermostat, Blower, Fuse etc
I checked the climatric fuse (40) and it's fine. figured Id run a diagnostic to see if anyone can assist me. It's really to cold to diagnos outside with no garage. Any help is appreciated
Thursday,12,March,2015,20:25:11:47509
VCDS Version: 14.10.2.0
Data version: 20150311
Address 01: Engine Labels: 06J-906-026-CCT.CLB
Control Module Part Number: 1K0 907 115 AE HW: 1K0 907 115 AA
Component and/or Version: 2.0l R4/4V TFSI 0030
Software Coding: 0403010A1C070160
Work Shop Code: WSC 00066 000 00000
VCID: 69F74C7D40C07769D91-803C
18 Faults Found:
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - MIL ON
Fault Status: 11100000
Mileage: 153069 km
Time: 09:18:54
Temperature: 57.0°C
Temperature: 33.0°C
Absolute Pres.: 970.0 mbar
Voltage: 11.811 V
001287 - Idle Control System RPM
P0507 - 000 - Higher than Expected. - Intermittent
Mileage: 153088 km
Time: 07:43:58
RPM: 1381 /min
Load: 11.0 %
Temperature: 71.0°C
Temperature: 4.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
U0155 - 000 - - Intermittent
Fault Frequency: 91
Mileage: 154580 km
Time: 20:24:26
RPM: 1619 /min
Load: 32.9 %
Temperature: 67.0°C
Temperature: 19.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.970 V
049682 - Steering Column Control Module
U0212 - 000 - No Communications - Intermittent
Fault Frequency: 80
Mileage: 154580 km
Time: 20:24:27
RPM: 1654 /min
Load: 32.5 %
Temperature: 67.0°C
Temperature: 19.0°C
Voltage: 13.970 V
049153 - Powertrain Databus
U0001 - 000 - Unspecified Malfunction - Intermittent
Mileage: 154469 km
Time: 07:18:09
RPM: 1969 /min
Load: 16.9 %
Temperature: 73.0°C
Temperature: 18.0°C
Voltage: 13.843 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 000 - - Intermittent
Fault Frequency: 44
RPM: 4220 /min
Load: 40.8 %
Speed: 114.0 km/h
Temperature: 80.0°C
Temperature: 10.0°C
Voltage: 13.716 V
049409 - No Communication with Transmission Control Module
U0101 - 000 - - Intermittent
Mileage: 156225 km
Time: 16:38:53
RPM: 1699 /min
Load: 10.6 %
Temperature: 76.0°C
Temperature: 0.0°C
Voltage: 14.097 V
P0300 - 000 - - Intermittent - MIL ON
Fault Status: 10100000
Fault Frequency: 15
Mileage: 156327 km
Time: 14:24:21
RPM: 2837 /min
Load: 80.0 %
Temperature: 70.0°C
Temperature: 6.0°C
Voltage: 14.224 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected - Intermittent - MIL ON
Fault Frequency: 15
Mileage: 156327 km
Time: 14:24:21
RPM: 2837 /min
Load: 80.0 %
Temperature: 70.0°C
Temperature: 6.0°C
Voltage: 14.224 V
004874 - Cylinder Disabling
P130A - 000 - - Intermittent
Fault Frequency: 11
Mileage: 156327 km
Time: 14:24:23
RPM: 3463 /min
Load: 77.2 %
Temperature: 71.0°C
Temperature: 5.0°C
Voltage: 14.224 V
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Date: 2047.15.31
Time: 31:63:63
Temperature: 20.0°C
Temperature: 7.0°C
Voltage: 11.684 V
000771 - Cylinder 3
P0303 - 000 - Misfire Detected - Intermittent - MIL ON
Mileage: 156339 km
Time: 07:04:44
RPM: 670 /min
Load: 31.4 %
Temperature: 76.0°C
Temperature: 18.0°C
Voltage: 13.462 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - Intermittent
Mileage: 156339 km
Time: 07:04:44
RPM: 670 /min
Load: 31.4 %
Temperature: 76.0°C
Temperature: 18.0°C
Voltage: 13.462 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - Intermittent - MIL ON
Mileage: 156341 km
Time: 08:04:43
RPM: 1444 /min
Load: 24.7 %
Temperature: 75.0°C
Temperature: 12.0°C
Voltage: 13.970 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 000 - Supply Voltage - Intermittent
Mileage: 156341 km
Time: 00:40:41
RPM: 739 /min
Load: 22.0 %
Temperature: 90.0°C
Temperature: 28.0°C
Voltage: 13.589 V
U1017 - 007 - - Intermittent
Fault Status: 00100111
Mileage: 156384 km
Time: 18:11:18
RPM: 2086 /min
Load: 42.7 %
Speed: 71.0 km/h
Temperature: 72.0°C
Temperature: 3.0°C
Voltage: 13.589 V
050197 - Implausible Data Received from ABS Control Module
U0415 - 002 - - Intermittent
Mileage: 156341 km
Time: 02:55:40
RPM: 1407 /min
Load: 50.6 %
Speed: 255.0 km/h
Temperature: 77.0°C
Temperature: 33.0°C
Voltage: 13.589 V
U1017 - 015 - - Intermittent
Fault Status: 00101111
Mileage: 156353 km
Time: 04:55:25
RPM: 2817 /min
Load: 12.2 %
Speed: 114.0 km/h
Temperature: 78.0°C
Temperature: 25.0°C
Voltage: 13.716 V
