Problem with ABS after unsuccessful coding
KwiatekCh
C?ID=350252
I was trying to lock my differential and somehow I ended up with ABS codes can anyone help me fix that and lock my dif
Tuesday,19,August,2025,07:23:13:28226 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64 VCDS Version: 25.3.1.2 (x64) HEX-NET CB: 0.4671.4 Data version: 20250604 DS365.0 www.Ross-Tech.com VIN: 1VWBV7A34FC062601 License Plate: Mileage: 226370km-140659mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: A3-VW41 (7N0) Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72 75 77 VIN: 1VWBV7A34FC062601 Mileage: 226370km-140659miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Sporadic communication error 1000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 1C-Position Sensing -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 75-Telematics -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb Part No SW: 04L 997 016 C HW: 04L 907 309 K Component: R4 2.0l TDI H20 9467 Revision: 8AH20--- CVN: 121EE4110000000000000000 Coding: 01190012032410080000 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_ECM20TDI01104L997016C 004002 ROD: EV_ECM20TDI01104L997016C.rod VCID: 3326E3F19A5B2A0304-8066 VINID: 0669D29874431164C0182180042A45DC11 1 Fault Found: 4713 - No Communication with ABS Brake Control Module U0121 00 [00100000] - - [Lost Communication WithAnti-Lock Brake System (ABS) Control Module] Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Mileage: 226354 km Date: 2000.00.00 Time: 00:00:00 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 32 C Intake air temperature: 33 C Ambient air pressure: 990 mbar Voltage terminal 30: 12.180 V Unlearning counter according OBD: 38 Limitation: accelerator pedal: 126.6 Nm CAN status - engine control module-Bits 0-7: 0 Cruise Control System (CCS): status-Bits 0-7: 2 CAN status - transmission control module-Bits 0-7: 8 CAN status - brake control module 1-Bits 0-7: 0 CAN status - brake control module 2-Bits 0-7: 0 selected gear-Bits 0-7: 0 Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V4.clb Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS Component: ESP MK60EC1 H46 0166 Revision: 00H46001 Coding: C54BC0F5492800FCA31103E4921A0042A1100012 Shop #: WSC 00046 000 00000 VCID: 0444702D87755DBBED-8050 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb Part No SW: 561 907 426 J HW: 561 907 426 J Component: AC Manuell H02 0404 Revision: 00001K01 Coding: 0010001002 Shop #: WSC 28682 003 104857 ASAM Dataset: EV_ACManuaElectGen2BHTC 001002 ROD: EV_ACManuaElectGen2BHTC_VW41.rod VCID: 220816B535A1B38BFF-8076 1 Fault Found: 13701392 - Function Restricted due to Missing Message(s) U1111 00 [00001000] - - [Bremsensteuerger t - kein Signal/Kommunikation] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 62 Mileage: 226354 km Date: 2025.08.15. Time: 22:58:06 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb Part No SW: 5K0 937 085 AB HW: 5K0 937 085 AB Component: BCM PQ35 B+ 122 0174 Revision: BH122001 Coding: EF200E18902B08D4098800010600044800F1A08650801520648060000C70 Shop #: WSC 09003 957 00200 VCID: 73A623F1D2DB6A03C4-8026 2 Faults Found: 00931 - Locking Module for Central Locking; Rear Right (F223) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 62 Mileage: 226354 km Time Indication: 0 Date: 2020.01.06. Time: 00:10:48 Freeze Frame: Term 15 Off Voltage: 12.40 V OFF ON OFF OFF OFF 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 62 Mileage: 226354 km Time Indication: 0 Date: 2020.01.06. Time: 22:58:05 Freeze Frame: Term 15 On Voltage: 12.25 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB Component: AirbagVW10 500 0975 Serial number: 003LZD046SAY Dataset Number: 560003v__A_ 0135 Coding: 00004D53 Shop #: WSC 28684 003 1048576 ASAM Dataset: EV_AirbaVW10SMEVW360 001030 ROD: EV_AirbaVW10SMEVW360.rod VCID: 72A826F5A5C1630BCF-8026 Seat occupied recognition: Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B Component: BF-Gewichtss. H10 0046 Serial number: 6940000Y1400019CZG02 Coding: 303046 Crash sensor for side airbag: driver side: Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354 Component: S.Sens.Fahr.V H02 ---- Serial number: 3572MSME4C60384AZZZ/ Crash sensor for side airbag: passenger side: Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354 Component: S.Sens.Beif.V H02 ---- Serial number: 3582MSME5A3A1A4BZZZ5 Rear Side Airbag Crash Sensor (on driver's side): Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A Component: S.Sens.Fahr.H H02 ---- Serial number: 3516KSME300F6732ZZZP Passenger side rear thorax airbag crash sensor: Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A Component: S.Sens.Beif.H H02 ---- Serial number: 3526KSME571E6732ZZZZ Crash sensor for front airbag: driver side: Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A Component: F.Sens.Fahr H02 ---- Serial number: 3556LSME77147331ZZZR Crash sensor for front airbag: passenger side: Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A Component: F.Sens.Beif H02 ---- Serial number: 3566LSME63057331ZZZN 3 Faults Found: 9445973 - Seat occupied recognition control module B1022 55 [10001001] - Not Configured MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 22 Mileage: 226354 km Date: 2025.08.14. Time: 19:50:05 12656896 - No Communication with ABS Brake Control Module U0121 00 [00001000] - - [Lost Communication With Vehicle Dynamics Control Module] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 2 Reset counter: 62 Mileage: 226354 km Date: 2025.08.15. Time: 22:58:05 9482752 - Seat Occupied Recognition B10B2 00 [00001000] - Function Restriction due to Missing Message(s) Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 62 Mileage: 226354 km Date: 2025.08.15. Time: 22:58:23 ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb Part No SW: 1K5 953 521 BM HW: 5K0 953 569 AE Component: LENKS.MODUL 016 0140 Revision: FF010042 Serial number: 20141027300159 Coding: 008A140000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_SMLSNGVOLWSXS A01004 ROD: EV_SMLSNGVOLWS.rod VCID: 79BA11D9F8B710538E-802C Multifunction steering wheel control module: 1 Fault Found: 147462 - Terminal 15 B1148 12 [00001000] - Short to Plus Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 3 Reset counter: 62 ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1 Part No SW: 561 920 970 G HW: 561 920 970 G Component: KOMBI H05 0813 Serial number: 00000000000000 Coding: 031E01 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723 ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod VCID: 1E70224501D9976BDB-804A 1 Fault Found: 12656896 - Function Restricted due to Missing Message(s) U1111 00 [00001000] - - [Steuerger t f r Bremse: keine Kommunikation] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 62 Mileage: 226354 km Date: 2025.08.15. Time: 22:58:05 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM Component: J533 Gateway H55 1653 Revision: H55 Serial number: 10121403001656 Coding: 461000 Shop #: WSC 09003 957 00200 VCID: 004C7C3D936D419BC9-8054 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 62 Mileage: 226354 km Time Indication: 0 Date: 2020.01.06. Time: 22:58:04 ------------------------------------------------------------------------------- Address 1C: Position Sensing Cannot be reached ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H05 0813 Serial number: Coding: 000000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09_VW23.rod VCID: 6A983E958D11ABCB77-803E No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 Cannot be reached ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb Part No SW: 561 959 701 HW: 3C0 959 793 B Component: TUER-SG FT 002 0525 Revision: 13110009 Serial number: 0009165396 Coding: 0404B5 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001 ROD: EV_TSGFPQ25BRFVW46X.rod VCID: 5BF66B51524BC243FC-800E Slave Driver: Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB Component: J388__TSG_HL 006 5470 Serial number: 14102630150106142739 Coding: 800000 1 Fault Found: 131584 - Motor for Rear Window Regulator B11EE 54 [00001001] - Missing Calibration / Basic Setting Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 7 Fault Frequency: 1 Reset counter: 22 Mileage: 226354 km Date: 2025.08.14. Time: 19:50:03 ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 R Component: EPS_ZFLS Kl. 215 3501 Revision: 00H22000 Shop #: WSC 01357 011 00200 VCID: 393AD1D97037D053CE-806C 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 62 Mileage: 226354 km Time Indication: 0 Date: 2020.01.06. Time: 22:58:06 Freeze Frame: Voltage: 12.25 V DD Temperature: 33.0 C RPM: 0 /min Speed: 0.0 km/h Speed: 0.0 km/h Count: 0 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb Part No SW: 7N0 907 532 HW: 7N0 907 530 AM Component: EZE_2 H55 1653 Revision: H55 Serial number: 10121403001656 Coding: 00000008 Shop #: WSC 09003 957 00200 VCID: 6FAE2F81BEF34EE320-803A Subsystem 1 - Part No SW: 561 919 204 B HW: 561 919 204 B Component: Analoguhr 009 0005 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb Part No SW: 561 959 702 HW: 3C0 959 792 B Component: TUER-SG BT 002 0525 Revision: 15110009 Serial number: 0009175121 Coding: 0404B4 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001 ROD: EV_TSGBPQ25BRFVW46X.rod VCID: 5CF4684D5745C57BF5-8008 Slave Passenger: Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB Component: J389__TSG_HR 006 5470 Serial number: 14102631141203180644 Coding: 800000 1 Fault Found: 131584 - Motor for Rear Window Regulator B11EE 54 [00001001] - Missing Calibration / Basic Setting Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 7 Fault Frequency: 1 Reset counter: 22 Mileage: 226354 km Date: 2025.08.14. Time: 19:50:03 ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb Part No SW: 1K0 035 188 F HW: 1K0 035 188 F Component: Radio Prem-8 H07 0009 Revision: -----12S Serial number: VWZ4Z7R3651285 Coding: 0100044004000B Shop #: WSC 09003 957 00200 VCID: 2B16FB914A6B72C34C-807E 2 Faults Found: 02635 - Tuner Not Enabled/Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 22 Mileage: 226354 km Time Indication: 0 Date: 2020.01.06. Time: 01:39:12 00625 - Vehicle Speed Signal 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 62 Mileage: 226354 km Time Indication: 0 Date: 2020.01.06. Time: 22:58:04 ------------------------------------------------------------------------------- Address 75: Telematics (J949) Labels:| 12E-035-284.clb Part No SW: 561 035 285 A HW: 561 035 285 A Component: OCULowUSA 020 0156 Serial number: 000003554140531 Dataset Number: 561098V____ 0017 Coding: 02140102C21612007F1606C00000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_OCULow 002009 ROD: EV_OCULow_002_VW41.rod VCID: 1464406DFF15CD3B7D-8040 1 Fault Found: 12670464 - Databus U1121 00 [00001000] - Missing Message [CAN TO brake] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 62 Mileage: 226354 km Date: 2025.08.15. Time: 22:58:17 ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels:| 5N0-035-729.clb Part No SW: 5N0 035 729 E HW: 5N0 035 729 E Component: TELEFON H07 0593 Revision: 1B001001 Serial number: 00007666921658 Dataset Number: 5N0035729E 0001 Coding: 0A10030080010110 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_UHVUMI 001007 ROD: EV_UHVUMI.rod VCID: 3228E6F56541230B0F-8066 No fault code found. End----------(Elapsed Time: 01:16, VBatt start/end: 12.4V/12.4V)----------- --------------
