- Jan 8, 2025
- 24
- 7
- Arizona, USA
- C?ID=606674
Hello. As part of ongoing modifications to my 08 Passat, I have wanted to relocate the battery to the trunk ever since swapping to the 02Q 6-speed manual that is painted plumb purple. It can't be seen well from above due to the existing battery tray location in the engine compartment, and it makes little things like shift linkage adjustments and swaps a little more time consuming. There are other reasons I want the battery in the trunk, like heat, but the bottom line is that I stumbled across an 06 Passat in the junk yard and pulled the 3C0971227C wiring set which has the 8P0937548A pyro activated Battery Master/Isolation Switch. The manuals I have so far either do not directly address where on the J519 the Isolation Switch connects, and I don't know if my 08 Passat is already wired for it to properly operate when connected to the J519 and if it needs coding even if the existing wiring harness has the proper connections. So I will state the questions below and ask if anyone can point me in the location of info and documentation I need to figure this out quicker.
1. Where does the single wire from the Isolation Switch connect to on the J519?
2. Does anyone know if my Passat (info below) is wire to work with the Switch?
3. If my Passat is wired to work with the Switch, will I need to code for proper function?
Thank you
Thank you
Friday,08,August,2025,22:10:47:32592
VCDS Version: 25.3.1.2 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250604 DS365.0
VIN: WVWEK73C28P051615 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 0F 15 16 17 19 25 36 42 44 46 52 53 62 65 72 76
VIN: WVWEK73C28P051615 Mileage: 264630km-164433miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWZCZ000000000
Coding: 0404010A18070160
Shop #: WSC 00028 028 00001
VCID: 303ECF9A8624A68A3F9-8064
VINID: 9E69D56C70D3088800141181144723D9FB
Readiness: 0010 0100
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000776120319
Coding: 0000345
VCID: 1F1C3C26EBBA29F2963-804A
Address 08: Auto HVAC Labels: 3C0-907-044.clb
Part No SW: 3C0 907 044 BP HW: 3C0 907 044 BP
Component: ClimatronicPQ46 122 0707
Revision: 00122021 Serial number: 00000000000000
VCID: 70BE0F9A46A4E68A7F9-8024
Fault Status: 01110000
Reset counter: 9
Mileage: 264626 km
Date: 2025.04.27
Time: 02:51:34
01810 - Actuating Motor for Temperature Flap; Right (V159)
Reset counter: 9
Mileage: 264626 km
Date: 2025.04.27
Time: 02:51:34
00710 - Defroster Flap Positioning Motor (V107)
Reset counter: 9
Mileage: 264626 km
Date: 2025.04.27
Time: 02:51:34
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000005099467
Coding: F5848F0340041000470000000F00000000285D435C000100000000000000
VCID: 71B80A9E4DAEEF82707-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 191107 003 0205
Coding: 00046997
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 210907 046 0204
Coding: 00208933
Shop #: WSC 00028
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 H HW: 8E0 035 593 H
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0144829
VCID: 2E02D1E29C10B07A2D5-807A
Reset counter: 8
Mileage: 264611 km
Date: 2025.04.27
Time: 00:11:58
01304 - Radio
Fault Frequency: 20
Reset counter: 9
Mileage: 264630 km
Date: 2025.04.27
Time: 04:15:33
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 17 AIRBAG VW8R 032 2522
Revision: 13032000 Serial number: 003B2PJFP4EW
Coding: 0012599
VCID: 3138CA9E8D2EAF82307-8064
Subsystem 1 - Part No: 3C0 959 339 B
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 0000000003NVL1
Subsystem 3 - Serial number: 0001.01.000000700000000000 63
Subsystem 4 - Serial number: 000000 6332MSME162427070 63
Subsystem 5 - Serial number: 427070 6342MSME172C3049A 63
Subsystem 6 - Serial number: C3049A 6351HTS61CGC94P68 63
Subsystem 7 - Serial number: C94P68 6361HTS61CGS86J6K 63
Subsystem 8 - Serial number: S86J6K 63727TS61CGSG7V6X 63
Subsystem 9 - Serial number: SG7V6X 63827TS61CGSG1I6F
Subsystem 10 - Serial number: SG1I6F
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 K HW: 3C0 953 549 K
Component: J0527 0015
Revision: 00006000 Serial number: 3C5953507BG
Coding: 0000211
VCID: 3436C38A723C9AAA5B1-8060
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 F HW: 3C0 920 971 F
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 12345 111 45725
VCID: 280E27FABEF4EE4AE79-807C
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P0790300E0
Coding: F980FF0F0001021002
VCID: 231430D6C7D20D12B2B-8076
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 06402 785 00200
VCID: 73B4009637B2DD9282B-8026
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F3CCCE69B1AB972263-807A
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1131
Revision: 31008001 Serial number: 00000030078915
Coding: 0001463
VCID: 3C26EBAA5A6C52EA931-8068
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
VCID: 3530FE8E794683A26CF-8060
Component: KSG PQ46 RDK 051 0221
Coding: 13910F8001862E521004141FF08A8F0E085C00
Shop #: WSC 00137 211 56823
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1131
Revision: 31008001 Serial number: 00000042578907
Coding: 0001462
VCID: 3D20E6AE41765BE2A4F-8068
Address 53: Parking Brake
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1118
Revision: 12006001 Serial number: 00000002364457
Coding: 0001168
VCID: 3E22E1A24C7040FABD5-806A
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1118
Revision: 12006001 Serial number: 00000002375230
Coding: 0001168
VCID: 3FDC9CA64B7A49F2B63-806A
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 C HW: 3C0 919 283 C
Component: Parkhilfe 8-Kan 004 0013
Revision: 00004000 Serial number: 90630726011245
Coding: 0000114
VCID: 290822FEA5FED742F87-807C
End----------(Elapsed Time: 02:14, VBatt start/end: 12.6V/12.6V)-----------
------------------------------5 Faults Found-------------------------------
