2014 golf gti rough running
TINTIN13
C?ID=540018
Hello scanned a car for another garage, came up with coolant bypass valve so they changed this but code still present.
Also come up leak in air intake system (NO LEAKS WITH SMOKE PRO)
Also MAP/MAF <-> Throttle Position Correlation, when the MAP sensor is unplugged it seems to run ok reconnect it and runs rough its had 2 intermotor map sensors and still its running rough, its as though it has a misfire when its reconnected.
has anyone else had this problem please.
Monday,19,May,2025,17:30:23:31378
VCDS Version: 24.7.0.0  HEX-V2 CB: 0.4643.4
Dealer/Shop Name: A Tinning
VIN: WVWZZZAUZEW263923   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
VIN: WVWZZZAUZEW263923   Mileage: 97021km-60286miles
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0007
   Revision: --H13---    CVN: BF528719
   Coding: 091900322444050B2000
   ASAM Dataset: EV_ECM20TFS0215G0906259 001011
   ROD: EV_ECM20TFS0215G0906259.rod
   VCID: 6B82C4D6130259729A1-803E
   VINID: 9E69EAAAA465A959C21832420CE1BDF1FE
15472 - Engine Coolant Level Sensor/Switch
          P2556 00 [10101111] - Electrical Malfunction
                    Mileage: 97021 km
                    Date: 2025.04.28
                    Time: 16:45:48
                    Engine RPM: 0.00 /min
                    Coolant temperature: 27 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 11.523 V
                    Engine: operating status: ES
                    Engine temp. management actuator: raw value: 0
                    Engine temperature management actuator: stop open: 133
                    Engine temperature management actuator: after-run stop: 3956
                    RVC_SP: 33.20 °
                    RVC_AV: 0.00 °
                    RVCPWM: -100.000 %
15466 - Control Circuit for Coolant Bypass Valve
          P2683 00 [00101111] - Short to Plus
                    Mileage: 97021 km
                    Date: 2025.04.28
                    Time: 16:45:48
                    RVC_SP: 6.25 °
                    RVC_AV: 0.00 °
                    RVCPWM: 34.998 %
15101 - MAP/MAF <-> Throttle Position Correlation
          P0068 00 [01100101] - -
                    Mileage: 97021 km
                    Date: 2025.05.15
                    Time: 17:27:03
                    Engine RPM: 1039.00 /min
                    Normed load value: 17.6 %
                    Coolant temperature: 31 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 12.832 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 16 s
                    MAP_MES_SAE: 57 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
                    FAC_TPS_1_SAE: 11.718750 %
                    FAC_LAM_LIM[1]: -8.826 %
15093 - Leak in Air Intake System
          P2279 00 [01100000] - -
                    Mileage: 97021 km
                    Date: 2025.05.15
                    Time: 17:27:03
                    Engine RPM: 1044.25 /min
                    Voltage terminal 30: 12.773 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 16 s
                    MAP_MES_SAE: 57 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 11.328125 %
                    FAC_LAM_LIM[1]: -8.914 %
Readiness: 1110 0001
   Revision: 00000000    Serial number: 6340300000073C
   Coding: 01FA93A13426296F03800602C1C6A980C92C94C0608395F7F4405078C009
   VCID: 7BA2F4966362C9F20A1-802E
   Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00120004200100011005000000101000
   VCID: 38282B9A12D422EAA73-806C
   Air quality sensor:
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011401102182 Dataset Number: 5G0063v____ 0001
   Coding: 03000A42C20122FB0B244080B10C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   Component: WWS    131215  042 0551
   Serial number:         131220223802
   Component: RLFS  024 0042
   Serial number: Y14M01D17H00M34S30S6
   Coding: 00A8DD
   Serial number: 000000000ZY133501DG4
   Serial number: 00000000000028628931
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331401103956 Dataset Number: 5G0039v__A_ 0013
   Coding: 0071051001
   VCID: 3E243D8230F01CDA6DF-806A
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 02011476511031 Dataset Number: 5g0114v____ 1013
   Coding: 00000300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   VCID: 363425A218C0D49AB5F-8062
1043 - Automatic Distance Control
          B10E7 F0 [00001001] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 97
                    Mileage: 97021 km
                    Date: 2025.04.28
                    Time: 16:43:10
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 11.5 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR02T91S Dataset Number: 5G0003v____ 0089
   VCID: 7F5A0086777AD5D2269-802A
   Left seat belt tensioner:
   Serial number: 34169661C12121351396
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169662C13121350098
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 012 13
   Serial number: 35767000000D82248E0-
   Subsystem 4 - Part No SW: -----------    HW: 480 002 012 13
   Serial number: 3586700000046A558E0
   Subsystem 5 - Part No SW: -----------    HW: 480 400 401 14
   Serial number: 35165029B11FBE95D24V
   Subsystem 6 - Part No SW: -----------    HW: 480 400 401 14
   Serial number: 35265029D11FBE92513L
   Subsystem 7 - Part No SW: -----------    HW: 480 400 401 14
   Serial number: 3556502BD11FBE94A1F2
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 10011404220752
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   Part No SW: 5G6 920 970     HW: 5G6 920 970
   Component: KOMBI         314 2210
   Coding: 27AD01002F80260001882A01040000
   VCID: 6D86CACE2D165742845-8038
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001412486 Dataset Number: 5G0067v____ 1613
   Coding: 030100042B085900EF00027E080F00010001000000000000000000000000
   GVL: 01543C1000000000400C90000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3FDA408637FA15D2669-806A
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0038
   Serial number: 27130002036130063483
   Coding: 2CFFFF
   Serial number: 9398122203
   Serial number: 08011404080021 Dataset Number: 5G0222v____ 0052
   Coding: 003F0220D001048100001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 40D8437A4A046A2A1F3-8014
          B1487 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 137
                    Mileage: 97021 km
                    Date: 2025.04.28
                    Time: 16:43:14
65604 - Door Warning Lamp
          B1326 01 [00001001] - Electrical Failure
                    Reset counter: 97
                    Mileage: 97021 km
                    Date: 2025.04.28
                    Time: 16:43:14
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5061
   Dataset Number: 5G0074v____ 0976
   Coding: 8103
   VCID: 372A28A61FCA2D92AE9-8062
   Serial number: 20121301101199 Dataset Number: 5G0157v____ 0051
   Coding: 003F0020DE01048100801000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
                    Reset counter: 137
                    Mileage: 97021 km
                    Date: 2025.04.28
                    Time: 16:43:16
65654 - Motor for mirror fold-in
          B11F6 13 [00001001] - Open Circuit
                    Reset counter: 97
                    Mileage: 97021 km
                    Date: 2025.04.28
                    Time: 16:53:16
65608 - Lamp for Ambient Speaker Illumination
          B13C8 01 [00001000] - Electrical Failure
                    Reset counter: 137
                    Mileage: 97021 km
                    Date: 2025.05.15
                    Time: 15:33:35
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Revision: --------    Serial number: -------------- Dataset Number: 5G0036v____ 0015
   Coding: 029E01000B000200
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 3D263A8E3DF607C2745-8068
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
5276435 - Stationary Cornering Lamp Left
          C1083 13 [00001001] - Open Circuit
                    Reset counter: 97
                    Mileage: 97021 km
                    Date: 2025.04.28
                    Time: 16:51:12
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     040 0421
   Serial number: V5C01101142434 Dataset Number: 5G0CV1v____ 0001
   Coding: 02730000FF00000021111201002800001F0203060100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1F1AE006973A75D2469-804A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H51 0022
   Serial number: VWZ8Z9NJ703FK9
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [00001001] - Open Circuit
                    Reset counter: 97
                    Mileage: 97021 km
                    Date: 2025.04.28
                    Time: 16:43:21
                    Voltage terminal 30: 11.5 V
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
0013 - Antenna Amplifier 1 for Digital Radio
          B1270 13 [00001001] - Open Circuit
                    Reset counter: 97
                    Mileage: 97021 km
                    Date: 2025.04.28
                    Time: 16:43:21
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
   Component: SAS-GEN 2     H06 0013
   Serial number: 131201202183
End----(Elapsed Time: 01:26, VBatt start/end: 12.4V/13.3V. VIgn 0.0V)------
Westbury, UK
Have you tried checking the wiring and looking for any common points for the coolant bypass valve and the MAF using a wiring diagram (that's a link)?
TINTIN13
C?ID=540018
Wiring looks ok
Westbury, UK
Wiring looks ok
Looks isn't enough, have you checked it electrically using a DVOM?
Plus have you checked the grounds and fuses for corrosion and continuity?
TINTIN13
C?ID=540018
Will be having a look again this week when we get back on it
I did one of those valves a couple of weeks ago and it worked fine using Febi part but I wouldn’t fit Intermotor if it was free! Try taking the oil filler cap off with it running.
