ECU connector cable not showing Blinking LED and no connection to controller.
pviljoen
C?ID=261547
Engine is ALH and pins are 1, 4,5,6,7,14, 16
16 red power, 14 brown earth
problem is green is pin 4 and 5, this is not connected to any unit on other end -- Where does this need to go to?
1 = blue
6 = black
7 = white
Any ideas where these wires should connect to since my cable is dead.
ECU gets power, verified at relays
photo.php
pviljoen
C?ID=261547
Ok Opened the harness some more.
white (7) connected to Gr\ws T121/73
brown (14) - connected to or/b (Can Low)
Black(6) - or/sw (Can high)
red (16) - connect to main relay
Blue (1) - sw/gr after a few y connectors going to T121/88
pviljoen
C?ID=261547
OK after reading some threads it looks like Pin 4 & 5 should be ground. Please can somebody confirm. Ground body or ground ECM?
pviljoen
C?ID=261547
Ok both pin 4& 5 goes to ground. T121/4 or T121/5 Br/Ro on ECU.
pviljoen
C?ID=261547
DLC pins (that VCDS cares about):
1 - Switched power -- not all cars have this -- only HEX-NET cares at all and will work without it.
4 & 5 - Ground.
6 - CAN-H (not relevant to VCDS on an ALH)
7 - K-line (data to/from an ALH ECU)
14 - CAN-L (not relevant to VCDS on an ALH)
15 - L-Line (not relevant to VCDS on an ALH)
16 - Power.
Your ECU needs power on at least two different pins, one is for switched power, the other for unswitched.
If the ECU is installed in a car, the K-line goes into the cluster first, where the cluster can disconnect it from the "W" line that runs to the ECU.
