Things have been progressing slowly. I put in one new conrod and installed the cylinder head, which I finally after one and a half months I received back from the machine shop. Before doing that, since the normal FSI gasolene injectors were removed along with the lower part of the intake manifold, they required their teflon seals to be replaced and also required a spot of ultrasonic cleaning because of deposits left behind by the oil burning. I bought four VW genuine seal kits and since I lacked the special tools, I had them replaced, reinstalled into the lower part of intake manifold and that, in turn, installed on the cylinder head.
I long mulled about whether using a updated VW genuine but very-very expensive chain kit 03C198229B or go with an affordable updated aftermarket kit, but I made the compromise to go with Febi Bilstein 181349 chain kit + appropriate INA oil pump chain kit. This is, after all, a kind-of budget build.
The second thing I mulled over whether I, without any such experience, can properly lay that 2mm bead of green anaerobic sealant on the camshaft module's sealing surfaces without it getting into any of the numerous oil passages. Factory manual also specified using silicone in some areas but diagrams were quite unclear where...
The last thing is whether to trust the T10171 and T10340 timing tools from the orient, which I used for engine disassembly. I got to comparatively measure them with genuine VW tools - camshaft angles relative to each other slighly more apart. Genuine T10340 is shorter by 1mm, so crankshaft may not be at TDC with the aftermarket tool. So I decided to have the camshaft module installed and chain kit properly timed up in the shop where I got all the other previous misc stuff done. Will cost me probably 4 hours of labor, but it will at least be done properly. Then I'm home free putting the engine back together.
