- Jul 9, 2014
- 2,429
- 2,037
- Tallinn, Estonia
- C?ID=330192
When I installed T10171A to hold the camshafts in time, there is indeed some droop in the chain between the camshafts. But anyway, the head is now off. Cylinder walls are in excellent shape. I removed piston 2 - piston rings appeared to move freely. The oil control ring seemed to be slightly coked. Almost no wear on the bottom rod bearing, some wear on the top bearing. Will have to get a valve spring tool to see how are the valve stem seals. Looking for a reasonable machine shop to clean it up, replace valve guides and stem seals.
A little video about the cylinder head removal ->
Immediate plan is to:
- Clean up the pistons
- Replace piston rings
- Replace rod bearings
