- Jul 9, 2014
- 2,438
- 2,046
- Tallinn, Estonia
- C?ID=330192
My trusty 2011 Passat B7 EcoFuel has served me well for close to 9 years, from 76000km to 247000km before all of a sudden developing a voracious appetite for motor oil - almost 1l per 1000km. Also puffing white-grayish oily-smelling smoke intermittently, mostly when warmed up. The engine is a EA111 series 1.4 TSI Twincharger with engine code CDGA. It's just like the infamous CAVA/CAVB/CAVC/CAVD/CAVE and CTHD/CTHE engines, but meant to run on compressed natural gas in addition to gasoline. Every single oil change done at a VW dealer with an interval of 15000km with their Castrol 5W30 but last two changes were done with 0W30 because VW moved away from 5W oils. Before the oil consumption skyrocketed, it consumed a very manageable one liter per 15000km. The engine runs fine otherwise.
I had it diagnosed at a reputable local shop, who borescoped it and found that the cylinder wall and exhaust valves of cylinder 2 were oily, and also the spark plug being blackened. This is also the case for cylinder 3 but not as severe. Cylinders 1 and 4 were OK. So their assessment was that the valve stem seals need to be replaced. The quote for that was close to 1700€ most of which are the shop hours. Involves taking the intake and exhaust manifolds off, camshaft module off, chain cover and also surprisingly taking the oil pan off, replacing all appropriate seals and so on, and finishing it off with an oil change. Since I want to keep the vehicle for a few years more and I've already done things here and there, I want to do the rebuild myself, at least most of it. It would be a project car, essentially
I'll lay out some of my work steps which I'm not that sure about - please feel free to let me know if anything needs to be done differently.
Since the CDGA engine isn't all that common, then for familiarity's sake, you can assume this is a CAVA engine - engine mechanicals are pretty much the same.
It will definetly be interesting. Fortunately I will have something else to drive around in. Also, thank you if you read till the end.
- Since such aforementioned oil consumption probably can't solely come from valve stem seals, I can assume that I will have to take the pistons out and have a look at them?
- Take the cylinder head off. Send if off to get new valve guides, valve stem seals and possibly new valves, also a general cleanup. VW has TPI 2029499/10, which applies to my vehicle, and pretty much tells to install a new cylinder head with optimized valve guides. Freccia valves and valve guides are OK? Elring seals generally are OK?
- If pistons are all intact, clean them up and change rings OR get complete new pistons? The oil passages in the pistons might be gummed up - soaking in brake cleaner will solve it or not? CDGA engine has different pistons to the gasolene-only engines and those only seem available as factory spare parts. Which manufacturer rings to get? Mahle or something else?
- If pistons are removed, without a doubt install new connecting rod crank bearings? From which company? Mahle, Kolbenschmidt, something else? Youtubers measure the bearing clearance with plastigauge - is that actually needed for a non-performance engine?
- Obviously inspect the timing chain as mine's still factory original. It didn't have any chain rattle on startup. Probably a good idea to change it (while in there), though putting in the full chain kit is quite expensive. Chain kits from reputable manufacturers with the intake cam variator are ~500€. Something probably can be had at 300€. The variator itself is probably fine but the sprocket teeth wear will need to be evaluated?
- Oil pump chain, sprocket and tensioner also to be renewed (while in there)?
- Anything else I'm not mentioning?
I did a U-turn and came back a few minutes later and a cyclist had hopped off his bike, to walk through the remaining cloud
I replaced the pipe, and it's much better... though it still needs a new filter housing as it's still leaking.
