Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZAUZGW087847 Mileage: 1891km-1175miles
03- Brakes -- Status: Malfunction 0010
05-/Start Auth. -- Status: Malfunction 0010
Address 01: Engine (J623-CRLB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 026 BP HW: 04L 907 309 R
Component: R4 2,0L H21 1198
Revision: B5H21---
Coding: 011D0032036405083000
Shop #: 01357 011 00200
Dataset: EV_ECM20TDI01104L906026BP 002002
ROD: EV_ECM20TDI01104L906026BP_VW37.rod
VCID: 79F3CD52F8E186F61A-802C
17158 - Databus
Mileage: 22 km
Date: 2015.11.03
Time: 22:23:25
U0428 00 [032] - -
Mileage: 22 km
Date: 2015.11.03
Time: 06:35:37
Part No SW: 0D9 300 041 H HW: 02E 927 770 AQ
Component: DQ250-6F H53 4902
Revision: 06253104 Serial number: TFK01507080002
Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021_AU37.rod
VCID: 1D3BF9C20C891AD656-8048
Address 03: Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62015000002156
Coding: 01FA62A124280973077F060441CA2980462490E0608294F31862507AC202
Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 7AF1D25EFDE78DEE13-802E
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 43
Date: 2015.11.03
Time: 06:35:44
16412 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Reset counter: 43
Mileage: 22 km
Date: 2015.11.03
Time: 06:35:56
16413 - Display for Tire Pressure Monitoring
Reset counter: 43
Mileage: 22 km
Date: 2015.11.03
Time: 06:35:56
32832 - Switch for Electric Parking Brake
C100C 07 [008] - Mechanical Failure
Reset counter: 53
Mileage: 322 km
Date: 2015.11.23
Time: 15:27:40
Address 05: /Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0375598215
Coding: 030C0C
Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A71125EBD674DEE53-806E
12717828 - Databus
U1121 00 [137] - Missing Message
Reset counter: 3
Mileage: 22 km
Date: 2015.11.03
Time: 06:35:45
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BC HW: 5G0 907 044 BC
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020104200100011005000000101002
Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 69D39D1288413676EA-803C
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 AQ HW: 5Q0 937 084 AL
Component: MQBAB M H24 0175
Serial number: 01061521500672
Coding: 00011842C24102FB4BE44000000403081800000000000000000000000000
Shop #: 59193 001 1048576
Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 0717BBAABE15E0061C-8052
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150716 043 0551
Serial number: 150718174853
Slave 2:
Component: 037 0059
Serial number: S3Y15M08D06H02M48S47
Coding: 90A8DD
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431520400180
Coding: 0031161051
Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_VW37.rod
VCID: 47977BAAFE952006DC-8012
13637426 - Databus
Reset counter: 43
Mileage: 22 km
Date: 2015.11.03
Time: 06:35:44
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: Bosch H05 0400
Serial number: 13071503210893
Coding: 001C1100FE0739
Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_AU37.rod
1058 - Databus
Reset counter: 43
Mileage: 22 km
Date: 2015.11.03
Time: 06:35:46
1062 - Databus
Reset counter: 53
Mileage: 322 km
Date: 2015.11.23
Time: 15:27:40
1059 - Databus
Reset counter: 43
Mileage: 22 km
Date: 2015.11.03
Time: 06:35:46
1078 - Databus
Reset counter: 43
Mileage: 22 km
Date: 2015.11.03
Time: 06:35:44
1043 - Automatic Distance Control
B10E7 F0 [008] - Disconnected
Reset counter: 43
Mileage: 22 km
Date: 2015.11.03
Time: 06:35:46
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R0ZLL65
Dataset: EV_AirbaVW20SMEVW37X 002130
VCID: 418365B2D0B11E3612-8014
Subsystem 1 - Part No SW: ----------- HW: 480 003 007 15
Serial number: 357670000008C540751R
Subsystem 2 - Part No SW: ----------- HW: 480 003 007 15
Serial number: 35867000000D5295D51$
Subsystem 3 - Part No SW: ----------- HW: 480 402 907 15
Serial number: 3516502A51B7E8E4B2D-
Subsystem 4 - Part No SW: ----------- HW: 480 403 007 15
Serial number: 3526502A91C52F4402FG
Subsystem 5 - Part No SW: ----------- HW: 480 402 907 15
Serial number: 3556502C51B7E8E0F1F0
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 04081504220165
Coding: 0C10
Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 0913BD92A80196760A-805C
Part No SW: 5G1 920 751 A HW: 5G1 920 751 A
Component: KOMBI 302 6420
Coding: 07A419182790000801886A011400000000000000
Dataset: EV_DashBoardVDDMQBAB 009046
VCID: 2649D62E59DFD90E07-8072
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Reset counter: 50
Mileage: 235 km
Date: 2015.11.16
Time: 14:46:18
U1110 00 [008] - -
Reset counter: 50
Mileage: 235 km
Date: 2015.11.16
Time: 14:46:18
16777022 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Reset counter: 50
Mileage: 235 km
Date: 2015.11.16
Time: 14:46:18
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW High 128 1223
Revision: -------- Serial number: 0003789175
Coding: 030100041F087300FB0002581C0F00010001050000000000000000000000
Dataset: EV_GatewLear 013020
ROD: EV_GatewLear.rod
VCID: 75EBC162D4F9E2967E-8020
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
Component: E221__MFL-DC1 H16 0040
Serial number: 29150001544340055311
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 5337277303
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
Reset counter: 65
Mileage: 118 km
Date: 2015.11.09
Time: 13:36:27
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000176785009
Coding: 5D00000000000000
Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 346D3C669F03BB9E89-8060
Component: FS 020 0041
Serial number: 210715BGL00315
Coding: 003B1320D000040000001000
Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 438F6FBACAAD0C2600-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000006845578
Coding: 110000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0303
Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB.rod
Component: BFS 020 0041
Serial number: 220715BGM03634
Coding: 003B1120DE00040000801000
Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 42816ABED5B7052E0B-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000006903024
Coding: 090000
Part No: -----------
Component: ------------- X500
Coding: 02730001FF00000051110001000808001F01009401200100CF
Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6FE7F30AB6A5D846B4-803A
Media Player Position 1:
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4060
Serial number: VWZ6Z9R2122443
Engine Control Module 2:
Subsystem 2 - Part No SW: 3G0 919 866 H HW: -----------
Component: ECE 2015/16 --- 0430
5661 - Control Head for Multimedia System; PTT Button
B1291 FF [009] - Unknown Error Elaboration
Fault Frequency: 74
Reset counter: 69
Mileage: 22 km
Date: 2015.11.04
Time: 23:14:06
End-------------------------(Elapsed Time: 04:26)--------------------------
