StuttgartAutotech
- Jan 12, 2016
- 3
- 0
- HC498787 (2nd hand?)
Have an odd one.
2007 Jetta. 2.5 BGP engine code. Manual Transmission. Towed in, died on the freeway. I get to the car and the battery is dead. There was a P000a Camshaft Position Sensor bank 1 intake slow response.
Replaced the battery, vehicle fires right up. Checked charging system. It is good. I go out and put 15 miles on the car. Monitored voltage the whole time and it didn't drop below 14.2 volts. Test drove the vehicle a couple more times and never had it stall or fail to start for me. The fault for the camshaft sensor never returned.
Customer came to pick up the vehicle and they didn't make it out of the parking lot. Took the vehicle back in.
What is happening is after the vehicle sits for a time and you go to start it, it will crank and crank and not start. As soon as you cycle the key, the vehicle will fire right up. Checked and found there is no spark during the times it is not starting. I also checked and found that I have good fuel pressure while it is not starting. So it is for sure a spark problem.
Through all this, no faults have ever returned. I replaced the crank position/engine speed sensor. The problem persists in the same manner, cranks and cranks with no start. Cycle the key and it fires right up.
I replaced the cam sensor. Still the same issue. Again, still no faults. I have checked and I do not have a flashing immobilizer light. Nor have I had any communication issues with the vehicle. My thoughts would be that if I had a relay problem I should have a plethora of faults for open circuit or short to ground, but there is nothing.
Anyone have any thoughts or tips? Anyone have any experience with this?
Thanks in advance!
Thanks in advance!
