Audi A4 B8 won't switch on ignition
Tendai
C?ID=263309
Here are the fault codes from my car. Ignition won't come on. The dashboard is not coming on hence not starting.
Sunday,13,December,2015,13:06:33:38927
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
Dealer/Shop Name: Tendai Kufandirori
VIN: WAUZZZ8K5AA184433   License Plate: EF10VMP
Mileage: 91860km-57079mi   Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 56 62 72
VIN: WAUZZZ8K5AA184433   Mileage: 91860km-57079miles
04-Steering Angle -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 1010
46-Central Conv. -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Malfunction 1010
Address 01: Engine (J623-CAGB)       Labels: 03L-906-019-CAG.clb
   Part No SW: 03L 906 019 C    HW: 03L 906 019 AL
   Component: R4 2,0L EDC   H25 8428
   Revision: 25H25---
   Coding: 0A194012230503080000
   Shop #: WSC 00202 210 80978
   ASAM Dataset: EV_ECM20TDI03L906019C A02006
   ROD: EV_ECM20TDI03L906019AL.rod
   VCID: 2B556698429D3F66EE-807E
16 Faults Found:
5595 - Crash Shut-Down Activated
          P1609 00 [032] - -
                    Mileage: 91861 km
                    Date: 2015.08.26
                    Time: 09:30:03
4527 - Coolant Fan Control Circuit 1
          P0480 00 [036] - Electrical Malfunction
                    Fault Frequency: 30
4531 - Fan 1 Control Circuit
          P0691 00 [036] - Short to GND
                    Fault Frequency: 9
5456 - Starter Will Not Turn
          P3054 00 [096] - Jammed or Electrical Malfunction
                    Mileage: 91861 km
                    Date: 2015.08.26
                    Time: 09:37:43
4640 - Engine Oil Temp. Sensor (G8)
          P0197 00 [039] - Signal too Low
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 01:02:44
5169 - Manifold Pressure / Boost Sensor (G31)
          P0238 00 [172] - Signal too High
                    Mileage: 91861 km
                    Date: 2015.08.26
                    Time: 09:30:04
5282 - Intake Air Temp. Sensor (G42)
          P0113 00 [172] - Signal too High
                    Mileage: 91861 km
                    Date: 2015.08.26
                    Time: 09:30:04
4996 - Glow Plug Control Module (J179)
          P0684 00 [032] - Implausible Signal
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:00:47
5608 - No Communications with Steering Angle Sender (G85)
          U0126 00 [039] - -
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [036] - -
4713 - No Communication with ABS Brake Control Module
          U0121 00 [036] - -
4714 - Steering Column Control Module
          U0212 00 [039] - No Communications
4715 - No Communication with Instrument Cluster
          U0155 00 [036] - -
4716 - No Communications with Parking Brake Control Module
          U0128 00 [036] - -
4719 - No Communication with Diagnostic Gateway
          U0146 00 [036] - -
4720 - Body Control Module (Central Electric 2)
          U0141 00 [039] - No Communications
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:07:13
Readiness: 1 2 0 0 0
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 BB    HW: 8K0 907 379 BB
   Component: ESP8 front    H04 0020
   Coding: 160504
   Shop #: WSC 06325 000 00000
   VCID: 7AFB93DCF54756EE25-802E
11 Faults Found:
                    Fault Frequency: 11
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.09.03
                    Time: 14:15:37
                    Hex Value: 0x0000
                    Hex Value: 0x10A2
                    Hex Value: 0x0003
                    Hex Value: 0x245F
                    Hex Value: 0x00FF
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.09.03
                    Time: 14:15:58
                    Hex Value: 0x0000
                    Hex Value: 0x17A2
                    Hex Value: 0x0033
                    Hex Value: 0x025A
                    Hex Value: 0x00FF
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 36
                    Reset counter: 80
                    Mileage: 91861 km
                    Date: 2015.09.03
                    Time: 20:20:18
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x002E
                    Hex Value: 0x0294
                    Hex Value: 0x00FF
                    Fault Status: 00101101
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 02:00:08
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x001C
                    Hex Value: 0x2384
                    Hex Value: 0x00FF
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 02:00:08
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x001C
                    Hex Value: 0x2384
                    Hex Value: 0x00FF
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 02:00:09
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x0032
                    Hex Value: 0x1F82
                    Hex Value: 0x00FF
01794 - Control Module - Incorrect Chassis (VIN) Number
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 02:00:11
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x0014
                    Hex Value: 0x1387
                    Hex Value: 0x00FF
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 02:00:08
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x001C
                    Hex Value: 0x2384
                    Hex Value: 0x00FF
                    Reset counter: 120
                    Hex Value: 0x0000
                    Hex Value: 0x2780
                    Hex Value: 0x0032
                    Hex Value: 0x1D99
                    Hex Value: 0x00FF
                    Reset counter: 120
                    Hex Value: 0x0000
                    Hex Value: 0x2780
                    Hex Value: 0x0027
                    Hex Value: 0xB999
                    Hex Value: 0x00FF
                    Reset counter: 120
                    Hex Value: 0x0000
                    Hex Value: 0x2780
                    Hex Value: 0x0032
                    Hex Value: 0x6699
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.
   Part No SW: 8T2 820 043 AD    HW: 8T2 820 043 AD
   Component: KLIMA 1 ZONE  H08 0180
   Revision: B0000000    Serial number: 01110520101872
   Coding: 34240000
   VCID: 74E7BDE4D723209E7F-8020
00457 - Control Module for Network (J519)
                    Reset counter: 80
                    Mileage: 91861 km
                    Date: 2015.08.26
                    Time: 09:30:07
                    Reset counter: 80
                    Mileage: 91861 km
                    Date: 2015.08.26
                    Time: 09:30:07
                    Temperature: 20.0�C
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:00:43
            000 -  -  - Intermittent
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 01:56:14
   Part No SW: 8K0 907 063 K    HW: 8K0 907 063 K
   Component: BCM1 1.0      H29 0380
   Revision: 06029001    Serial number: 00000000672627
   Coding: 690040B1003400010001000000005F5F001D020806000001000000
   VCID: 377D4AE886D58B869A-8062
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 120510  H05 0070
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
   Component: E1 - LDS  H08 0090
9 Faults Found:
03351 - Bulb for DRL and Marker Light; Left
                    Fault Status: 00101100
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.08.26
                    Time: 09:52:00
                    Reset counter: 120
01495 - Bulb for High-Beams; Left (M30)
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.07.13
                    Time: 03:32:00
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 01:50:00
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.09.01
                    Time: 18:24:00
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.09.01
                    Time: 18:34:00
01800 - Light Switch (E1)
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:22:00
03280 - Switch Position of Light-Switch Knob
                    Reset counter: 120
                    Mileage: 1048574 km
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.08.26
                    Time: 09:30:00
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GKD0GD285
   Coding: 30363435363030303030554A3052384B3053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 44872D24CF03D01E0F-8010
   Serial number: 6334MSME52056C047
   Serial number: 6344MSME531552397
   Serial number: 6352QSME44600402/
   Serial number: 6362QSME6E5D3B0C%
   Serial number: 63732SME7E5E4822C
   Serial number: 63832SME7E5E0B36H
12658176 - No Communications with Steering Angle Sender (G85)
             U0126 00 [009] - -
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 03:01:47
   Part No SW: 8K0 953 568 D    HW: 8K0 953 568 D
   Revision: --------    Serial number: 90304JEB000LV
   Coding: 000002
   VCID: 3B7556D8BAFDAFE67E-806E
7 Faults Found:
                    Fault Frequency: 62
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.09.03
                    Time: 14:15:26
                    Fault Frequency: 9
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.09.03
                    Time: 14:16:21
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:07:14
                    Fault Status: 00100001
                    Fault Status: 01100101
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 02:00:09
                    (no units): 44.0
                    Text: 2C92FFFFFFFF00C0FF
                    Lambda Factor: 4.24
                    Raw, Index/Key Err.: 255 255 000
                    Text: 3E710000FFFFFFFFFF
                    (no units): -0.00
                    Raw, Index/Key Err.: 255 255 255
                    Reset counter: 120
00886 - Turn Signal Switch (E2)
                    Fault Status: 00101110
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:18:27
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 950 F    HW: 8K0 920 950 F
   Component: KOMBIINSTR.   H20 0255
   Revision: 00300000    Serial number: CIR225C4A
   Coding: 2F04080002002600010000
   VCID: 326B7BFC6DB76EAEAD-8066
            000 -  -
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:35:04
   Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0117
   Revision: GB800053    Serial number: 5300G1051781C0
   Coding: 00CF07
   VCID: 0109E4309891053664-8054
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Component: J532_DCDCStab  H04 0003
17 Faults Found:
02252 - Generator
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.08.26
                    Time: 09:31:05
                    Bin. Bits:    10111
                    Voltage: 11.70 V
                    Count: 6
                    Bin. Bits:    10000
                    Fault Frequency: 9
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.09.01
                    Time: 19:03:52
                    Bin. Bits:    10000
                    Voltage: 12.10 V
                    Count: 7
                    Bin. Bits:    10000
01304 - Radio
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.09.01
                    Time: 19:03:53
                    Bin. Bits:    10000
                    Voltage: 12.10 V
                    Count: 8
                    Bin. Bits:    10000
                    Fault Frequency: 45
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.09.03
                    Time: 20:27:55
                    Bin. Bits:    10000
                    Voltage: 10.40 V
                    Count: 17
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:08:43
                    Bin. Bits:    00000
                    Voltage: 12.00 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
01312 - Powertrain Data Bus
                    Fault Frequency: 86
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:08:43
                    Bin. Bits:    00000
                    Voltage: 12.00 V
                    Count: 7
                    Bin. Bits:    10000
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:07:14
                    Bin. Bits:    11101
                    Voltage: 14.40 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:07:15
                    Bin. Bits:    11101
                    Voltage: 14.50 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
00576 - Terminal 15
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:12:52
                    Bin. Bits:    10100
                    Voltage: 7.30 V
                    Count: 7
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:11:31
                    Bin. Bits:    00000
                    Voltage: 13.50 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.90 s
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:22:38
                    Bin. Bits:    00000
                    Voltage: 13.80 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Reset counter: 120
                    Bin. Bits:    00000
                    Voltage: 14.00 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 01:01:07
                    Bin. Bits:    00000
                    Voltage: 6.90 V
                    Count: 8
                    Reset counter: 120
                    Bin. Bits:    00000
                    Voltage: 12.40 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.90 s
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:00:05
                    Bin. Bits:    10000
                    Voltage: 12.30 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 4.90 s
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 03:01:48
                    Bin. Bits:    10001
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
02256 - Quiescent Current
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 03:35:00
Address 46: Central Conv.
Address 52: Door Elect, Pass.
   Revision: 00000003    Serial number: 10000000518206
   VCID: 34677DE497A3609EBF-8060
8 Faults Found:
                    Fault Status: 00101011
                    Reset counter: 80
                    Mileage: 1048574 km
                    Voltage: 12.50 V
                    Count: 38
                    Hex Value: 0x0173
                    Hex Value: 0x0008
                    Hex Value: 0x1010
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.09.03
                    Time: 14:16:03
                    Voltage: 7.30 V
                    Count: 44
                    Hex Value: 0x0263
                    Hex Value: 0x0081
                    Hex Value: 0x1010
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:45:55
                    Voltage: 12.60 V
                    Count: 27
                    Hex Value: 0x0173
                    Hex Value: 0x0008
                    Hex Value: 0x1010
                    Reset counter: 120
                    Voltage: 12.40 V
                    Count: 67
                    Hex Value: 0x0277
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 120
                    Voltage: 12.40 V
                    Count: 64
                    Hex Value: 0x0277
                    Hex Value: 0x0001
                    Hex Value: 0x1010
02433 - Supply Voltage for Right Parking Brake Motor (V283)
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:00:01
                    Voltage: 11.60 V
                    Count: 29
                    Hex Value: 0x0177
                    Hex Value: 0x0008
                    Hex Value: 0x1010
02432 - Supply Voltage for Left Parking Brake Motor (V282)
                    Fault Frequency: 32
                    Reset counter: 80
                    Mileage: 1048574 km
                    Voltage: 11.60 V
                    Count: 28
                    Hex Value: 0x0173
                    Hex Value: 0x0008
                    Hex Value: 0x1010
                    Fault Status: 00100011
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:06:20
                    Voltage: 14.00 V
                    Count: 11
                    Hex Value: 0x0270
                    Hex Value: 0x0028
                    Hex Value: 0x1010
Address 56: Radio (J503)       Labels: 8Tx-035-152-56.clb
   Part No SW: 8T2 035 152 D    HW: 8T2 035 152 D
   Component: Chorus3       H01 0054
   Revision: 00000001    Serial number: AUZ1Z2K5113605
   Coding: 00000480040108000159070000
   Subsystem 1 - Part No SW: 8T0 919 603     HW: 8T0 919 603
   Component: Display  H09 X017
00849 - S-contact at Ignition/Starter Switch (D)
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:07:17
                    Reset counter: 120
                    Mileage: 1048574 km
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:11:59
            000 -  -
                    Fault Frequency: 129
                    Reset counter: 80
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 01:24:05
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 120
                    Mileage: 91861 km
                    Date: 2015.09.01
                    Time: 18:47:04
                    Bin. Bits:      001
00468 - CD-ROM Drive (R92)
                    Reset counter: 120
                    Mileage: 91860 km
                    Date: 2009.06.26
                    Time: 00:18:18
Address 62: Door, Rear Left
Address 72: Door, Rear Right
End-------------------------(Elapsed Time: 02:13)--------------------------
Welder75
Canada
C?ID=261654
Congratulations!! Longest autoscan ever!!!! 80 faults and 6 modules that don't be reached.
I know thats not helping but........WOW
history of car? something happened to this car. no mileage on it since 2009????? -91860 km Time Indication- 0 Date- 2009.06.26 ----top of auto scan shows current milage at 91860km
unless the ECM is so messed up....other dates show 2000.00.00 other Mileage: 1048574 km
did you hit something hard enough to trip sensors but not activate airbags? or did someone try to hide a accident?
18017/P1609/005641 - Crash Shut-Down Activated
Possible Symptoms
Fault Code cannot be cleared
Possible Causes
Crash Signal activated (i.e. Accident with Airbag Deployment)
Possible Solutions
Set Readiness, the Fault Code should be cleared automatically during this Process.
Special Notes
In case of an Accident the Airbag Control Module sends a Crash Signal which orders the Engine Control Module to stop the Engine. In Addition this Fault Code will be stored. The Engine may be restarted after cycling the Ignition, the Fault Code should not have any further Influence.
Welder75
Canada
C?ID=261654
From your autoscan-
Voltage: 11.60 V
Voltage: 7.30 V
Voltage: 6.90 V
check if your battery good? check alternator ?
make sure that battery is good, clear faults and send a newer autoscan thats not a month old
Tendai
C?ID=263309
Thank you for your feedback. Will run another auto scan and post it as soon as possible.
Tendai
C?ID=263309
Thanks for the feedback. Will run another auto scan and will post it soon
Tendai
C?ID=263309
The car was involved in an accident. Airbags deployed. Have replaced the airbags and module but no joy with ignition. All fuses and relays fine. Mr Dealership tried but failed. They changed pyrotechnic fuse but couldn't run diagnostics because the car is not switching the ignition on.
Tendai
C?ID=263309
Thanks for the feedback. Will run another auto scan and will post it here as soon as possible.
Welder75
Canada
C?ID=261654
if you replace battery make sure follow proper steps! you may have to change coding.
Fault Frequency: 45
Reset counter: 120
Mileage: 91861 km
Date: 2015.09.03
Time: 20:27:55
If your battery drains to low your car goes into survival mode to conserve power. not sure of all the details with this but...
Possible Symptoms
Shut-Off Stage active
Electric Systems disabled
Infotainment System disabled
Heating and/or Climate Control disabled
Interior Lights disabled
Window Regulators/Motors disabled
Seat Memory/Adjustment disabled
Auxiliary/Parking Heater disabled
Possible Causes
Battery discharged/faulty
Quiescent Current
Possible Solutions
Check/Replace Battery
Check for Quiescent Current Problems
Perform (Quick) Quiescent Current Analysis
Special Notes
This Fault Code changes from static to intermittent once the Engine is started. It doesn't necessarily reflect a bad Component (the Control Module it's stored in) but rather points to an underlying Issue and merely documents a Symptom.
Hope you didnt just buy a VCDS to find out you have a dead battery!!
Jef
HQ
Please put the CODE tags around the Auto-Scan. That is the "#" button.
So is there some back story on this?
Are ALL fuses in the vehicle good and accounted for?
Tendai
C?ID=263309
The battery is fine. I checked all the fuses and relays and they look fine. Will try to run another auto scan and will post the results. The car was involved in an accident and deployed airbags. Replaced the airbags and module but still the ignition is not switching on.
NostraJackAss
Check ignition switch and trace back as per WD and to BCM feeds.........
Terminal/load reduction relays should be observed.
