JUST Purchased,VW T6
Jmatt@41164
England
C?ID=575443
Hi ive done autoscan of my t6 2.0 2018 that ive just purchased
as you can see its done a few miles
auto scan only found 1 fault
is there anything else i should / can check with vcds
Thursday,17,July,2025,21:02:28:20922
VCDS Version: 25.3.1.2 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250604 DS365.0
VIN: WV1ZZZ7HZJH040921   License Plate:
Mileage: 365530km-227129mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 09 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZJH040921   Mileage: 365530km-227129miles
Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KA    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 6163
   Revision: 23002001
   Coding: 00114010430401090000
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KA 004012
   ROD: EV_ECM20TDI03004L906056KA.rod
   VCID: 76B4E12D6842261AA55-8022
   VINID: 9E606AAAA1D8A9A60010024204278B76E7
Readiness: N/A
   Revision: 00000000    Serial number: 62197000002288
   Coding: 517E40982566847E8A7E0278A48321E679F100
   VCID: 3FDA440907F8A752B63-806A
   Serial number: 25071713471436
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA4F90D40726E5AFD5-802A
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 216170855
   Coding: E0A4303A0A212031002009742C2B8C500F00708F60444D60330400220800
   Shop #: WSC 02739 022 1434084
   VCID: 2B020059E3002BF20AB-807E
   Subsystem 1 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU014081772261016
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU026071772073945
   Coding: 0400A0
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 0608170452AEC4 Dataset Number: 7E0114v____ 0009
   Coding: 00004000FE1779
   Shop #: WSC 01383 790 50316
   ROD: EV_ACCBEGVW361.rod
   VCID: 3634212D28C2661A655-8062
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag021 H08 0018
   Revision: --------    Serial number: 003V3005RWCR Dataset Number: 7E0003V____ 0905
   Coding: 000000000000000000000000000000003231
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3A2C351D1CDA827A81D-806E
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1107
   Coding: 750B010300
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042305
   VCID: 6888BF553276C0EA279-803C
   Component: IMMO          H03 1107
   VCID: 6A8CC55D2CFAF2FA31D-803E
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     056 7205
   Serial number: 14071700010370 Dataset Number: V03935266VJ 0001
   Coding: 065700003C00000041111101008000001F0000C60000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E04094DD0925EDA2D5-807A
0001 - Antenna 1 for Radio
          B1119 13 [00001001] - Open Circuit
                    Reset counter: 196
                    Mileage: 365539 km
                    Date: 2025.07.17.
                    Time: 08:42:54
                    Voltage terminal 30: 11.7 V
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030B7A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 75885700001708020A39
End----------(Elapsed Time: 01:09, VBatt start/end: 13.4V/13.4V)-----------
-------------------------------1 Fault Found-------------------------------
Have a look at injector deviations (engine warmed up and idling):
Jmatt@41164
England
C?ID=575443
Ok thanks Uwe
I’ll check it out later
TTT
C?ID=547002
You don’t? If Advanced Measuring button is not greyed out?
Jmatt@41164
England
C?ID=575443
Thanks for reply
Why would it greyed out ?
How do I test injectors
TTT
C?ID=547002
Is the above print screen from a T6?
Jmatt@41164
England
C?ID=575443
Yes 2018 2.0 t6
Jmatt@41164
England
C?ID=575443
Sorry the pic I posted isn’t from my van
I photo shot it from someones pics on here
the autoscan at top is
TTT
C?ID=547002
So the answer is no. Do you see a pattern here? No T6 have Measuring Blocks.
But I ask a second time.
Advanced Measuring is available?
Jmatt@41164
England
C?ID=575443
No it’s not available
TTT
C?ID=547002
I find it hard to believe. Please post a print screen of engine selection and menu buttons there. See above How-to Post Pictures.
  • Agree
Jmatt@41164
England
C?ID=575443
I don’t know who’s confusing who here
08 measuring blocks is greyed out
So not available
Advanced measuring values is available
On a 2018 T6 that's not surprising. Your ECU uses the newer UDS protcol. See:
What is surprising is that your ECU doesn't appear to have the measuring values in this screen-shot:
I thought those were pretty universal on CR TDIs, but apparently not.
The closest thing I see in your ECU are these:
IDE12085 -- Fuel injection time deviation: cylinder 1 (µs)
IDE12086 -- Fuel injection time deviation: cylinder 2 (µs)
IDE12087 -- Fuel injection time deviation: cylinder 3 (µs)
IDE12088 -- Fuel injection time deviation: cylinder 4 (µs)
However, I'm not sure how to interpret the values that you might have there.
TTT
C?ID=547002
To answer his initial question, probably the roof antenna is water damaged. I would remove it and do a close visual inspection.
Viking
C?ID=151455
I think the T6 has the antennas in the door mirrors?
