"Request out of range" error
PfauWeh
C?ID=265830
Not sure whether to post this in the VCDS Support or Tweaks thread, but here goes:
I've had very spotty results trying to change some lighting adaptation channels on my 2016 Golf R. I've run into persistent "Request out of range" errors. These happen after I successfully enter the security code (31347) into the 09-Cent Electronics module. When I locate the "Leuchte" channels and try to change the "Dimmwert" I get an "Error Request out of Range" dialog.
After several tries I was finally able to lower the orange front sidemarkers from 127 to 0 to turn them off. I decided that I did not want to do without the white LED in the headlights which are also turned off by this channel, but now I'm not able to get the original value accepted again. Getting the "Request out of range" each time (meaning driving the car for long periods between attempts, rebooting and reconnecting VCDS each time).
A bit more pressingly, in trying to adjust the brightness of the reverse lights (Leuchte 28RFL and 29RFL) I inadvertently changed the Dimmwert on these to 0 as well. Now I have no backup lights. Interestingly, the backup camera seems to get its power from this circuit as well, because it is not working either and has thrown a fault.
I'm running Windows 10 on a Surface Pro 4. Tried reinstalling the VCDS software - didn't help either. Any guidance would be most appreciated.
Here's an autoscan:
Sunday,10,January,2016,20:28:08:25534
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WVWUF7AU0GW154595   License Plate:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55 5F
          75 A5 A9
VIN: WVWUF7AU0GW154595   Mileage: 2472km-1536miles
Address 01: Engine (J623-CYFB)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
   Revision: --H13---
   Coding: 091900122446000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
   ROD: EV_ECM20TFS0208V0906259H_VW37.rod
   VCID: 45AFAB2CC4C2581602-8010
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 62715000002331
   Coding: 01FA6BA154250970057C030941C86980D62A90A0C08296B7144050D4C088
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 79D717DCF8BAECF636-802C
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 61
                    Mileage: 642 km
                    Date: 2015.12.22
                    Time: 13:00:22
   Revision: 00021000    Serial number: 0383513784
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A55C8D0BD3C27EE7F-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020004200100000105000012111402
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 6AF538908D1C576ECF-803E
   Part No SW: 5Q0 937 085 AJ    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061527400589
   Coding: 00010A46C041A2E169E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 01277F3C906AB4367E-8054
   Slave 1:
   Component: WWS    150927  043 0551
   Serial number:         151008211541
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S3Y15M10D19H17M11S12
   Coding: 90A8DD
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39391528700714
   Coding: 0071155001
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: 43ABB534CAF666262C-8016
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 02091503210141
   Coding: 01004700FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H16 0120
   Serial number: 07071541350324
   ROD: EV_DRCONTITEMIC.rod
   VCID: 3753D1E48E2E3A8680-8062
   Serial number: 003GCR03RVXN
   VCID: 47B3A124FECE4A06F0-8012
   Seat occupant detection; front passenger side:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH000000000003EOD1F
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 000 810 15
   Serial number: 357000000008D06DC61V
   Subsystem 3 - Part No SW: -----------    HW: 480 000 810 15
   Serial number: 358000000003855DD61R
   Subsystem 4 - Part No SW: -----------    HW: 480 400 510 15
   Serial number: 3510002991D25F8212E6
   Subsystem 5 - Part No SW: -----------    HW: 480 400 809 15
   Serial number: 3520002B31CF1D34E09C
   Subsystem 6 - Part No SW: -----------    HW: 480 400 610 15
   Serial number: 3550002C71CF2D72627F
   Subsystem 7 - Part No SW: -----------    HW: 480 400 610 15
   Serial number: 3560002C71CF2D733128
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 09101504220081
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 0937671CA85AFC7626-805C
   Part No SW: 5G1 920 858 A    HW: 5G1 920 858 A
   Component: KOMBI         303 6420
   Coding: 0BAD08127F88CF0502886A0B5400000000000000
   VCID: 2E7DF4807174FB4ED3-807A
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1223
   Revision: --------    Serial number: 0004045254
   Coding: 0101000830085900FB00023A880F00000001050000000000000000000000
   ROD: EV_GatewLear.rod
   VCID: 75CF1BECD4A2889652-8020
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S
   Serial number: 29150001980020075406
   Coding: 34FFFF
   Serial number: HA1-00027.08.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4AB59810EDDCB76EEF-801E
   Revision: 00000000    Serial number: 15000219108002
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3449E6E89F58D19EA5-8060
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H11 0071
   Serial number: 0381853903
   Coding: 02011103
   ROD: EV_HREntryHella_SK37.rod
   VCID: 3C59CEC8B70819DE6D-8068
   Lane Change Assistant 2:
   Serial number: 310515BEU17079
   Coding: 003E13208000040000000000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000007570108
   Coding: 111000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 9102
   ROD: EV_SteerAssisMQB.rod
   VCID: 3957D7DCB83A2CF676-806C
12289 - Supply voltage
                    Mileage: 148 km
                    Date: 2015.12.11
                    Time: 00:00:43
   Serial number: 120615BFB0479A
   Coding: 003E13208000040000800000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 42A5B030D5EC6F2E27-8016
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000007653252
   Coding: 091000
   Coding: 022202010B000400
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 40A1BA38DBE07D3E31-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 876     HW: 3Q0 035 876
   Component: MU-S-NS-US    H25 0245
   Serial number: VWZAZ2R0489992
   Coding: 027300020000000051220002001808001F0207F401200105C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 71C72FFCA0CAA4B68E-8024
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H52 1028
   Serial number: VWZ8Z9RFC008UX
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
6720 - Rear View Camera
          B1102 31 [009] - No Signal
                    Reset counter: 56
                    Mileage: 2321 km
                    Date: 2016.01.09
                    Time: 22:25:05
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000440484
   Coding: 0100000000020306000400010100000100
   ROD: EV_MFKBoschAU370_AU37.rod
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 150909200209
   VCID: 2F43E984767EF246D8-807A
End-------------------------(Elapsed Time: 04:22)--------------------------
Although I doubt the Surface Pro 4 is at fault, I would try this on another PC just to see if the results are identical.
Edit, after reading the recent conversation in this thread I suspect you already reverted the Coding in this vehicle back to the stock configuration - but if you haven't I would try that also. Another thing that couldn't hurt is locking the vehicle doors with the remote when it has a factory-like coding config and letting it go to sleep for 10+ min. Unlock and wake it, connect VCDS and try tweaking those channels again with the regular PC and the tester PC (providing another PC didn't resolve this in the first place).
PfauWeh : Hello again. Just to add to Dana's sage advice, I'm using VCDS software loaded onto a Surface pro laptop (3, in my case) and also running windows 10. No problems at all. Just a further consideration- are you running any nanny-ware that could be affecting the operation of the software?
PfauWeh
C?ID=265830
Thanks Dana - I have not been able to get back to factory coding. I'll try your suggestions and report back.
PfauWeh
C?ID=265830
PV52 - No nannyware that I know of, but who knows what kind of junk Microsoft has packed into Windows 10. I will do a layperson's review of power management, usb properties etc. Thanks!
Hello Peter,
We received the debug files and should have something for you next week. I didn't want you to think you were forgotten about due to the weekend.
Eric
HC800000
From what I can see on the few adaptation channels you're trying to change, VCDS is reading the old value and sending the new value correctly, it's just that the module is refusing it for some reason. I do however see some unreasonable delays between you entering the security access and the first adaptation. That could cause use to lose the advanced diagnostic session. Is the adaptation screen really slow to load (how long)? If so, does it happen the same on another machine?
PfauWeh
C?ID=265830
I don't really have a good benchmark for what constitutes "really slow". There is some delay when I go into the adaptation channel. I also am scrolling through the adaptation channels which takes quite a bit of time. I'll try to time the delay and see if I can use the search box to speed up finding the adaptation channel. I had the same issue with the other machine I tried.
PfauWeh
C?ID=265830
Delay is not more than a few seconds - maybe 5-10. I will send a video to your support mailbox.
Eric
HC800000
I didn't mean to imply to the total time it takes you to do it is a problem; I was concerned with the time loading the adaptation screen. After viewing your video, that's not an issue. What might be, however, is the time you spend scrolling looking for the channel you need. I think this may consume resources to the point that VCDS can't keep the session alive (or more accurately, Windows doesn't let VCDS keep the session alive). Can you try using the search box to filter as much as possible of those thousands of channels, and reduce the scrolling to a minimum?
PfauWeh
C?ID=265830
It worked! I finally figured out that the search box just limits the number of entries in the scroll box, and by specifying "Leuchte29", "Leuchte28", etc. I dramatically reduced the scrolling required and all my changes were accepted.
Thank you, sensei. This calls for a beer
:thanks:
