- Apr 9, 2014
- 2,303
- 2,250
- Tartu, Estonia
- C?ID=195131
Hello
My friend has Passat 3C 2006. We installed 3c8 920 870 G cluster into it and he kept the old MFSW. Everything was working OK.
About month ago we tried 3C0 953 549 AH SW module, that i had repaired to another car to check if it works, it did. Then we refitted old 3C0 953 549 E SW module.
Now the menu button on old 8-button MFSW doesn't work anymore. It's in PHONE menu and NO WAY out of it. Gets to your nerves.... KINDA.
My another friend had EXACTLY THE SAME issue with his 3c8 920 880 G cluster, when he tried another SW module. But in his case, he needed to drive around with 3aa cluster for some time and there the button did work. After a week without power the cluster 3c8..880G started to work again. It's not logical that no power did some magical fix. So somehow something in another module had to get it stuff right.
Any idea how to speed up that process or what may be wrong?
I only have his old scan, but i could ask him to do another with his cable.
Friday,06,February,2015,18:43:11:01666
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WVWZZZ3CZ6Exxxxxx License Plate: STEN PASSAT
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 22 25 36 42 44 46 52 53 56 62 72 76
7D
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 CR HW: 03G 906 018 CR
Component: R4 2.0l PPD1.5 G 9674
Revision: --H15--- Serial number: VWZCZ000000000
Coding: 0000172
Shop #: WSC 05688 995 81466
VCID: 77FD199906CBC6A6AA7-8022
Readiness: N/A
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667482872
Coding: 0015662
Shop #: WSC 05311 000 00000
VCID: 326BE88DAD29E38E5D9-8067
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AC HW: 3C0 907 044 AC
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
VCID: 62CB58CDBD49330EED9-8037
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 01000009644687
Coding: ED088E070004100F5F000000000000008019BE455C00000C002000000000
Shop #: WSC 35110 377 08192
VCID: 3365ED895233EA8656F-8066
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 35110
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00338725
Shop #: WSC 35110
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
Component: 04 AIRBAG VW8 029 2521
Revision: 09029000 Serial number: 003A2P15SA86
Coding: 0012340
VCID: 2D51FBF1B417BC7600B-8078
Subsystem 1 - Serial number: 6332MSME0F1C005B
Subsystem 2 - Serial number: 6342MSME0F027E65
Subsystem 3 - Serial number: 6351HTS6QLLAMJB3
Subsystem 4 - Serial number: 6361HTS6TLLUMLA2
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C9953507P
Coding: 0000112
VCID: 2E53FCFDB911C76E391-807B
Component: E0221 002 0010
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 870 G HW: 3C8 920 870 G
Component: KOMBI H03 0305
Coding: 161F00
Shop #: WSC 05314 115 12345
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 2F6DE1F9761BCE66327-807A
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3690P118100240
Coding: F982FF1E000202002002
VCID: 2F6DE1F9BE1BCE66327-807A
Address 22: AWD Labels: None
VCID: 55A17311BC07D4B698B-8000
No Faults Found
Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
Component: IMMO 038 0367
Revision: 00038000 Serial number: VWZCZ000000000
Subsystem 1 - Part No: 3C0 905 861 D
Component: ELV 024 0370
3C0905861D ELV 024 0370
Part No SW: 3C0 959 760 C HW: 3C0 959 760 C
Component: Sitzverstellung 1001
Revision: 00004000 Serial number: 00000000000000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2801
Coding: 0000503
VCID: 377DD999464B06A66A7-8062
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 038 0455
Coding: 1891020851030E76380294157008CF0B603D00
Shop #: WSC 05688 995 66817
00123 - Outside Warning Light/Door exit Light; Rear Right
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 25
Mileage: 2391 km
Date: 2023.14.05
Time: 00:13:30
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Coding: 0000502
VCID: 387FDAA54B5509DE63D-806D
00121 - Outside Warning Light/Door exit Light Passenger Side
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 G HW: 3C0 907 801 G
Component: EPB VD8HC005 013 0005
Revision: 013
Coding: 0000012
Shop #: WSC 05688 995 100467
VCID: 264304DD91E18F2EC11-8073
Part No: 1K0 035 195 B
Component: Radio BVX 008 0015
Coding: 0040400
Shop #: WSC 05314 000 00000
VCID: 254103D1ECE78436C8B-8070
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703
Component: Tuer-SG 021 2507
Coding: 0000144
VCID: F0EFA285E3A5119EEBD-80A5
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704
Coding: 0000144
VCID: F1E9A781E8AF1896E43-80A4
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
Component: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Serial number: 82930611600055
Coding: 0000024
VCID: 285F0AE59BF5995EF3D-807D
Component: PTC-Element 0404
End ---------------------------------------------------------------------
