I have a 3 month old Audi 3.0 tdi Sport with Head Up Display, for some reason Audi have made the ACC/Active Lane Assist unavailable in the "content" menu.
I have raised with Audi as it is in the brochure and it is even featured in a video on their UK website.
I have managed a number of mods on my other Audi's using VCDS and took a scan (attached)
I thought I had cracked it after I discovered the comprehensive post on the ACC refit on this forum which provided some valuable coding information from module 4G0 919 604 which seems to have be similar coding to mine which is 4H0 919 617.
After some experimentation I can confirm the following coding testing on the first byte.
Bit 0 - Traffic sign recognition (works can select/deselect menu item)
Bit 1 - Navigation (works can select/deselect menu item)
Bit 2 - Lane Departure (no menu change when I set this bit)
Bit 3 - unknown
Bit 4 - Night Vision (works - can select/deselect menu item even thought I don't have it!)
Bit 5 - Cruise Control (works can select/deselect menu item - even though I have adaptive cruise)
Bit 6 - unknown but assume this is Automatic Distance Regulation (no menu change when I set this bit (with bit 5 set to 0)
Bit 7 - unknown but possibly something to do with seat memory.
My coding was originally C30000 and I have changed to C70000 but to no avail.
Below is a scan of my car, I do have a deep scan for the heads up module if need be.
Any help with coding would be much appreciated.
Mike
Bit 3 - unknown
Mike
VCDS Version: Release 15.7.3 Running on Windows XP x86
Data version: 20151216
Monday,04,January,2016,20:16:49:55272
Chassis Type: 4H (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 30 34 36 3B 3C 42 44
46 47 52 53 55 56 57 5F 62 69 6C 6D 6F 72 81 82 85 88 89 8B
8E 8F 90 AC
VIN: WAUZZZ4H6GN004288 Mileage: 7832km-4866miles
Address 01: Engine (J623-CTBA) Labels: None
Part No SW: 4H0 907 401 Q HW: 4G0 907 401 E
Component: 3.0TDI EDC17 H14 0002
Revision: 58H14---
Coding: 0A2A4032057601030800
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TDI0114H0907401Q 001002
ROD: N/A
VCID: 326BD6B765F889AEB7-8066
No ASAM data for: "EV_ECM30TDI0114H0907401Q" (AU64)
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4H1 927 158 CL HW: 0BK 927 156 AD
Component: 0BK 30TDIRdWH19 1005
Revision: --H19---
ROD: EV_TCMALX51011_AU64.rod
VCID: 7CF7388FF73C8FDE2D-8028
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 AA HW: 4H0 907 379 AA
Component: ESP PREMIUM H10 0665
Coding: 60E5AB8006A7D501E700
ASAM Dataset: EV_ESPPremi 005024
ROD: EV_ESPPremi_AU64.rod
VCID: 71E919BBA07EF2B68E-8024
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 GB HW: 4H0 907 064 GB
Component: BCM2 2.0 H37 0572
Coding: 05B76F4E000000000000
VCID: 6FED1FC3BE4AE44698-803A
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000153693047
Coding: 0038320000047201000001010101112131313333283333
VCID: 3467D0AF97EC879EA5-8060
Address 08: Auto HVAC (J255) Labels: 4H0-820-043.clb
Part No SW: 4H0 820 043 N HW: 4H0 820 043 N
Component: Klima 2 Zonen H20 0210
Coding: 36A10028340000
ASAM Dataset: EV_AirCondiFront 003001
ROD: EV_AirCondiFront_AU64.rod
VCID: 2B55CBD342D2D866F4-807E
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 DG HW: 4H0 907 063 AG
Component: BCM1 2.0 H20 0311
Revision: 14020001 Serial number: 00001082969301
Coding: 0105001440349FE2C9014087A0001800009DE30A2F080201800008946100170000400009090000
VCID: 70EF1CBFA374FBBE81-8024
Subsystem 1 - Part No SW: 4H2 955 119 C HW: 4H2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 140718 H36 0090
Coding: 0045F7
Component: G397_RLFS H06 0002
Coding: 02004E
Subsystem 3 - Part No SW: 4H0 941 531 F HW: 4H0 941 531 F
Component: E1 - LDS H01 0044
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Address 10: Park/Steer Assist (J791) Labels: None
Part No SW: 4G0 919 475 G HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0070
Revision: -------- Serial number: 56291513801670
Coding: BA3B01
ASAM Dataset: EV_EPHVA2CAU64X0000 001011
ROD: EV_EPHVA2CAU57X0000.rod
VCID: 3561EDAB94969E9692-8060
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4H0 907 561 C HW: 4H0 907 561
Component: ACC3 H21 0032
Coding: 7F04010201
ASAM Dataset: EV_AdaptCruisContrAU64X 002024
ROD: EV_AdaptCruisContrAU64X.rod
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Revision: -------- Serial number: 003P1005AW3-
Coding: 30333045313430303037554A305234483053
ROD: EV_AirbaAU10BPAAU64X_AU64.rod
VCID: 3B75FB93B2B248E664-806E
Serial number: 3575HRB404T3B2JID0BH
Serial number: 3585HRB405V3BA9U28GX
Serial number: 3515JRB400G54SDQ71FI
Serial number: 3525JRB400G54SDQ7HR4
Serial number: 3554VRB40593F0KQGHQC
Serial number: 3564VRB40593F0KQ59Q.
Address 16: Steering wheel
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4H0 920 950 T HW: 4H0 920 950 T
Component: TDieGBACC---- H53 0803
Revision: 38081205 Serial number: 658150615592029
Coding: 338F08001F552600010000
ASAM Dataset: EV_RBD4K 004050
ROD: EV_RBD4K.rod
VCID: 3979E19BB88E7AF676-806C
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 Q HW: 4H0 919 204 Q
Component: Analoguhr D4 H05 0225
Serial number: 2150520004825
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4H0 907 468 AG HW: 4H0 907 468 AC
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000001897436
Coding: C0CD077F08
ASAM Dataset: EV_GatewPkoUDS 001028
ROD: EV_GatewPkoUDS.rod
VCID: 76E32AA7C910D58E5B-8022
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J36™ H08 0181
Serial number: 52165113091911230579
Voltage stabilizer:
Address 30: Special Function II
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008003
ROD: EV_AirSuspe_AU64.rod
VCID: 2F6DDFC376CAA446D8-807A
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000153693046
Coding: 00383B0000057201000001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 K HW: 4H0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA7702S410
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_AU57.rod
VCID: 377DE7A38E9A6C8680-8062
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 4H0 907 566 F HW: 4H0 907 566 F
Component: SWA Master H06 0040
Serial number: 0369787405
Coding: 040322
ROD: EV_LaneChangAssis_AU37.rod
VCID: 3365D3B39AE280A6BC-8066
Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H07 0280
Revision: -------- Serial number: 0000154296752
Coding: 011F1E015E01628202083013
VCID: 489F945FFB64137EF9-801C
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 4G0 909 144 S HW: 4G0 909 144 G
Component: RCEPS H43 0012
Revision: 00001000 Serial number: 0004902163
Coding: 101101010001
ASAM Dataset: EV_RCEPS 009013
ROD: EV_RCEPS.rod
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0369248979
Coding: 011B0E2280B93881F320C7842C030C470000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H0 947 135 A HW: 4H0 947 135 A
Component: Dachelektroni H13 0080
Subsystem 4 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000173925
Coding: 030000
VCID: 1D31150B046626D67A-8048
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H07 0280
Revision: -------- Serial number: 0000153914842
Coding: 011F1E015E01628202083002
VCID: 3C77F88FBFBC4FDE6D-8068
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001511023
ROD: EV_ParkiBrake_AU48.rod
VCID: 2D51C5CB7CC6D656EA-8078
Address 55: Headlight Range (J745) Labels: 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 02F6022022130200
ROD: EV_HeadlRegulAUDIMXBAU64X_AU57.rod
VCID: 3467D0AF9FEC879EA5-8060
Coding: E00300
Coding: E00300
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
H03 0031
Coding: 4D7842204C65694D6F206C692E
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E00300
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109FY0F8044263
Coding: 010103010000000001
VCID: 2B55CBD34AD2D866F4-807E
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4G0 919 129 C HW: 4G0 919 129
Component: NGTV-DVB H04 0690
Revision: R0043000 Serial number: 06801302073001
Coding: 03000000
VCID: 2D51C5CB74C6D656EA-8078
Address 5F: Information Electr. Labels: None
Part No SW: 4H0 035 654 HW: 4H0 035 670 T
Component: H-BNT-EU H49 H-BNT-EU H49 09390939
Coding: 02010100000BFDEF7DB0EB1E00000003080001000000000000
VCID: 63C563F3628250260C-8036
Subsystem 1 - Part No: 8R0 060 884 CR
Component: EUR 2015 2102
Subsystem 2 - Part No SW: 4H0 919 604 H HW: 4H0 919 604 H
Component: DU8 D4 SV NB H63 0060
Subsystem 3 - Part No: 4H2 919 600 L
Component: E380 BDT D4
Component: CD-Database
No Faults Found
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H07 0280
Revision: -------- Serial number: 0000154304607
Coding: 010F1E014000628202083002
Address 69: Trailer (J345) Labels: None
Part No SW: 4H0 907 383 N HW: 4H0 907 383 L
Component: Anhaenger H20 0160
Revision: 7A001003 Serial number: 0368493636
Coding: 0100010202000000
ROD: EV_TrailFunctGener2Hella_AU37.rod
VCID: 387FE49F838463FE89-806C
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4H0 907 428 D HW: 7P6 907 441 F
Component: TopView H07 0330
Revision: 11001001 Serial number: 82330JF0236687
Coding: 020E000001000000010102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
VCID: 2E53C2C771C0AD4ED3-807A
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4H0 959 107 AC HW: 4H0 959 107 AC
Component: HDSG-Modul H12 0049
Revision: 10012001 Serial number: 162500992
Coding: 021004C021
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6FED1FC3B64AE44698-803A
Address 6F: Centr. Conv. II (J773) Labels: None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000187972
Coding: 220000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63C563F36A8250260C-8036
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H07 0280
Revision: -------- Serial number: 0000153941682
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4H2 927 731 A HW: 4H2 927 731 A
Component: GSM-RL H09 0083
Revision: 0R0D5015 Serial number: SN150512 0126
ROD: EV_GSM2x3Mono.rod
VCID: 2C57C8CF47DCDF5EFD-8078
Address 82: Heads Up Display (J898) Labels: None
Part No SW: 4H0 919 617 A HW: 4H0 919 617 A
Component: HeadUpDisplay H09 0021
Coding: C30000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7.rod
Address 85: On Board Cam. (J852) Labels: None
Component: DPC-SG H27 0081
Coding: EA160000
ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873) Labels: None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00021933035701
Coding: 672FF2
ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872) Labels: None
Serial number: 00021933063301
Coding: 272FF2
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4H0 907 541 C HW: 4H0 907 541
Coding: 7F04010201
ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
ROD: EV_AdaptCruisContr2AU57X.rod
VCID: 295931DB482ECA7606-807C
Address 8E: Image Processing (J851) Labels: None
Component: BV-SG H33 0090
Serial number: 005000621806157
Coding: 01C23B041111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H13 0080
Coding: 0066F609031F0376070308004240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3169D9BB60FEB2B6CE-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Address AC: Reductant Control (J880) Labels: None
Part No SW: 4H0 907 355 D HW: 4G0
Component: SCR-Stg-G2 H10 0019
Revision: 00000000 Serial number: 150991170
ROD: EV_RDCMA00100.rod
End-------------------------(Elapsed Time: 08:28)--------------------------
