- Jan 16, 2023
- 28
- 3
- Orange, CA, USA
- C?ID=519030
Hello, I come to this forum with a pretty typical issue: Byte 18 bixenon coding.
I have a 2012 Volkswagen Jetta Sportwagen TDI (NAR), which originally came with halogens from the factory. Yesterday, I did an OEM bixenon w/ LED DRL retrofit, involving a 10 --> 14 pin adapter, new headlights, a new highline BCM out of a 2013 Golf GTI that came factory with xenons and LED DRLs, and the running of the two shutter wires to pins 48 and 49 on that BCM.
The new xenons plugged in fine, low beams and high beams work, etc- but I cannot for the life of me get the LED DRLs (the fancy dot ones) to light up.
Right now, using a mix of my old BCM coding and the new BCM's original Byte 18, all exterior lights work, except for some reason the car runs the marker lights as the DRLs.
Pardon the ugliness, I plan to polish them but I wanted to make sure they worked first.
Now to paste out all the relevant info.
Old, lowline BCM coding: 2F380E3F802F3EC4008800C1740000E449800086535D0560648000200040
New, highline BCM coding (untouched): 6F180A1A90272A04008800C170000D4448052086434D8D20E48420240040
New, highline BCM coding when combined with old, lowline BCM coding, while maintaining Byte 18 and the xenon shutter options: 2F380A3F802F3EC4008800C1740008E449842086535D0560E48400240040
The old, lowline BCM seemed to have the Byte 18 obfuscated, as it said "00". I have NOT touched the Byte 18 on my old BCM, but that BCM is no longer installed in the car. The new, highline BCM had the "20" coding from the GTI it came out of. With Byte 18 set to "20", the behavior of the side marker lights acting as DRLs happens as seen above. I also tried "09" in the VCDS dropdown (supposedly the coding for the wagon). That coding gave an error for the left and right DRLs in my MFI, and no side marker lights. Also, looking up a BCM Byte 18 values table (found here, row 79 VW362 XENON NAR), supposedly "4F" would be the appropriate code for the Mk6 wagon with xenons. I tried "4F", but that gave an error for the left and right "front side light". To recap, the only Byte 18s I have tried are "20", "09", and "4F". I have not tried more because I am afraid of breaking something.
Here are some photos of my 10 to 14 pin adapter in the engine bay, because I didn't think to grab a photo of them before I installed them (oops, my bad). I can try to get a better photo of the adapters when the headlights come out to get polished later. Could it be that my wiring is the issue, rather than the BCM coding?
Here is the 10 pin side of the adapter:
And here is the 14 pin side of that same adapter, going into the headlight:
Lastly, here is my VCDS autoscan (since I know providing a full, complete autoscan is the most important part of this whole dealio):
Please ignore the HVAC codes, they are due to me installing a dual zone Climatronic panel while having a single zone airbox behind the dash. The Instruments, Steering, and ABS codes are related to my Openpilot retrofit, those codes are only present because I did not have my Comma 3 installed at the time of the scan.
TL;DR: I need help getting LED DRLs to work, since I retrofitted them to my cheapo wagon using junkyard parts and an AliExpress adapter wiring harness. Everything else works except for the LED DRLs. I am unsure if this is a Byte 18 issue or a wiring issue.
Saturday,05,July,2025,12:08:44:25085
VCDS Version: 25.3.1.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
VIN: 3VWPL7AJ9CM666973 License Plate:
Mileage: 163910km-101848mi Repair Order: Xenon-BCM
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 13 15 16 17 19 25 42 44 46 4F 52 56 62 72 77
A5
VIN: 3VWPL7AJ9CM666973 Mileage: 163910km-101848miles
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI F000AG 9983
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 74291 008 00000
VCID: 30391E3356254C5A3FB-8064
VINID: 0E69E070745A2537461862470C854F941F
Readiness: 0 0 0 X X
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001111161278
Shop #: WSC 00066 000 00000
VCID: 1471B2A3C27D907A3B3-8040
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 114B600C49288000881406EB921C0142873A00
Shop #: WSC 00066 123 12345
VCID: 7DA7F707DDF77132E4D-8028
03197 - StopPing Distance Reduction 2 in ADR Control Module (J428)
Reset counter: 163
Mileage: 163913 km
Date: 2019.11.26.
Time: 12:04:53
Count: 3
Count: 14
Count: 12800
Count: 8244
Count: 48384
Count: 257
Part No SW: 3AA 907 044 AN HW: 3AA 907 044 AN
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0010001042
Shop #: WSC 00015 115 12345
VCID: 7CA1FA03C66D783AD33-8028
12 Faults Found:
9473394 - Motor for Right Temperature Flap
B108D 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 146
Mileage: 163038 km
Date: 2025.06.24.
Time: 15:22:59
9475349 - Position Sensor for Right Temperature Flap Motor
B1095 15 [00001001] - Open or Short to Plus
Reset counter: 146
Mileage: 163038 km
Date: 2025.06.24.
Time: 15:22:59
9474162 - Motor for Defroster Flap
B1090 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 146
Mileage: 163038 km
Date: 2025.06.24.
Time: 15:22:59
9476117 - Position Sensor for Defrost Flap Motor
B1098 15 [00001001] - Open or Short to Plus
Reset counter: 146
Mileage: 163038 km
Date: 2025.06.24.
Time: 15:22:59
9474418 - Motor for Front Air Distribution Flap
B1091 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 146
Mileage: 163038 km
Date: 2025.06.24.
Time: 15:22:59
9472882 - Motor for Fresh Air / Recirculated Air Flap
B108B 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 146
Mileage: 163038 km
Date: 2025.06.24.
Time: 15:23:00
9476885 - Position Sensor for Fresh/Recirculated Flap Motor
B109B 15 [00001001] - Open or Short to Plus
Reset counter: 146
Mileage: 163038 km
Date: 2025.06.24.
Time: 15:23:00
9470997 - Temperature Sensor for Right Footwell Vent
B1084 15 [00001001] - Open or Short to Plus
Reset counter: 146
Mileage: 163038 km
Date: 2025.06.24.
Time: 15:22:59
9472021 - Temperature Sensor for Right Vent
B1088 15 [00001001] - Open or Short to Plus
Reset counter: 146
Mileage: 163038 km
Date: 2025.06.24.
Time: 15:22:59
9496597 - Sunlight Photo Sensor
B10E8 15 [00001001] - Open or Short to Plus
Reset counter: 146
Mileage: 163038 km
Date: 2025.06.24.
Time: 15:22:59
9496613 - Sunlight Photo Sensor
Reset counter: 146
Mileage: 163038 km
Date: 2025.06.24.
Time: 15:22:59
9479189 - Signal Line for Air Quality Sensor
B10A4 15 [00001001] - Open or Short to Plus
Fault Frequency: 56
Reset counter: 163
Mileage: 163038 km
Date: 2025.06.24.
Time: 15:22:59
Part No SW: 1K0 937 086 P HW: 1K0 937 086 P
Component: BCM PQ35 M 110 0651
Revision: 00110 AC
Coding: 2F380A3F802F3EC4008800C1740008EC49842086535D0560E48400240040
VCID: 3D2737079D77B132A4D-8068
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 07021 26 0512
Coding: 009795
00061 - Footwell Lights
Fault Status: 00101010
Reset counter: 203
Mileage: 163913 km
Date: 2019.11.26.
Time: 12:03:48
Term 15 Off
Voltage: 12.60 V
Term 50 Off
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Serial number: 19121604382880 Dataset Number: V03935274UE 0001
Coding: 00001000FE073B
ROD: EV_ACCBEGVW361.rod
VCID: 3635282BB8C1626A657-8062
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA147W2 Dataset Number: 1KM003v__B_ 0035
Coding: 00003133
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FDB4D0F97FBA322B61-806A
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00002HRM00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME28091566ZZZU
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME072F5565ZZZ$
Serial number: 3511HSME0D506029ZZZG
Serial number: 3521HSME6A656029ZZZQ
Serial number: 35527SME206F4A29ZZZO
Serial number: 35627SME2E624A29ZZZQ
Part No SW: 5K0 953 521 GL HW: 5K0 953 569 BG
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20220525000106
Coding: 3012A40000
ROD: EV_SMLSNGVOLWSR8C_VW32.rod
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H08 0010
Serial number: 0012848
Coding: 830000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 981 B HW: 561 920 981 B
Component: KOMBI H03 1104
Coding: 151D010000
Shop #: WSC 06050 062 00200
ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
VCID: 1B63D99F2323DF027A9-804E
13648640 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Steuergerät für LaneDepartureWarning: keine Kommunikation]
Reset counter: 163
Mileage: 163913 km
Date: 2025.07.05.
Time: 12:05:37
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 21012200F10089
Coding: 352002
VCID: 7BA3F91FC3E37F02DA9-802E
Component: IMMO H03 1104
VCID: 6A8DCC5BBCF9F68A31F-803E
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0004022061
Coding: 0004B5
Shop #: WSC 01383 790 50316
VCID: 5BE3999F63A39F02BA9-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 007 1509
Serial number: 00000006161745
Coding: 000490
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 239 3501
Revision: 00H22000
Shop #: WSC 77101 662 01477
VCID: 392F2317855F8D12885-806C
02797 - Control Module for Directional Stabilization Assistance (J759)
Fault Frequency: 106
Reset counter: 160
Mileage: 163912 km
Date: 2019.11.24.
Time: 16:22:11
Voltage: 13.38 V
DU
Temperature: 33.0°C
RPM: 1018 /min
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1682
Coding: 05030100
VCID: 6FBBDD4F879B13A2661-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0003994126
Coding: 0004B4
VCID: 5CE19A8366AD983AB33-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 007 1509
Serial number: 00000006108319
Coding: 000490
B11EC 54 [00001000] - Missing Calibration / Basic Setting
Reset counter: 203
67589 - Turn Signal in Exterior Mirror
B11FD 01 [00001000] - Electrical Failure
Reset counter: 186
Address 56: Radio Labels:
VCID: 55F78FA70C0749728CD-FFFE
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661547966 Dataset Number: 5K0035730E 0001
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270BF56F6F6B0BE2EE1-8072
B104F 13 [00001001] - Short to GND
Reset counter: 113
Mileage: 161920 km
Date: 2025.05.24.
Time: 17:05:23
B104E 13 [00001001] - Short to GND
Reset counter: 113
Mileage: 161920 km
Date: 2025.05.24.
Time: 17:05:23
Address A5: Frt Sens. Drv. Assist
End----------(Elapsed Time: 01:29, VBatt start/end: 13.4V/13.4V)-----------
------------------------------22 Faults Found------------------------------
