Wednesday,30,July,2025,19:23:23:01454
VCDS Version: 25.3.1.2 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250604 DS365.0
VIN: 1VWBN7A32DC076445 License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72
VIN: 1VWBN7A32DC076445 Mileage: 232180km-144269miles
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H23 9982
Revision: 71H23--- Serial number: CVN: D240C61F5C3E0D04
Coding: 001D0012042400000000
Shop #: WSC 22194 444 00000
ROD: EV_ECM20TDI01103L997009H.rod
VCID: 3B233CC303E5FA329AB-806E
VINID: 0669D27874430944C01C6104147C1ACF14
8863 - Particulate Filter
P2459 00 [11101101] - Regeneration Frequency
Mileage: 232077 km
Date: 2025.07.30.
Time: 14:03:26
Engine speed: 1924.50 /min
Normed load value: 80.0 %
Vehicle speed: 63 km/h
Coolant temperature: 87 C
Intake air temperature: 34 C
Voltage terminal 30: 14.420 V
Exhaust gas jet volume in particle filter: 263.6 m /h
Particle filter: difference pressure: 243 hPa
Particle filter: soot mass measured: 24.15 g
Particle filter: soot mass calculated: 24.13 g
Particle filter: differential pressure: dynamic offset: -4 hPa
Exhaust gas temperature sensor 3: 244.9 C
Exhaust gas temperature sensor 4: 247.5 C
Readiness: 1 1 0 0 0
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9436
Revision: 05551213 Serial number: 00001209182057
Shop #: WSC 09003 957 00200
VCID: 2411E7BF92DBA5CACB1-8070
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: C54BC0F549290000A30F03E8921E0042A71000
VCID: 7DA7F2DB5DF13402E4F-8028
Reset counter: 51
Mileage: 232053 km
Date: 2019.12.21.
Time: 00:06:59
Count: 2
Count: 14
Count: 20480
Count: 16390
Count: 44032
Count: 1
Count: 256
Part No SW: 561 907 426 A HW: 561 907 426 A
Component: AC Manuell H02 0101
Revision: 00001K07
Coding: 0010001002
ROD: EV_ACManuaElectGen2BHTC_VW41.rod
VCID: 196FC64BA919E822687-804C
9477489 - Motor for Air Distribution Flap
B109D 71 [00001000] - Actuator Stuck
Reset counter: 56
Mileage: 231032 km
Date: 2025.07.30.
Time: 08:40:36
Address 09: Cent. Elect.
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM056M09 Dataset Number: 560003v__A_ 0049
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FBBD893071D5692663-803A
Serial number: 6940000Y120000LZBM0G
Coding: 303044
Serial number: 3572MSME30653173ZZZL
Serial number: 3582MSME605A6273ZZZX
Serial number: 3516KSME166B2520ZZZM
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME323B0B20ZZZM
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME64056E1EZZZ1
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME261A761EZZZ%
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20121001302345
Coding: 088A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 76B5EDF77847675AA55-8022
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 E HW: 561 920 970 E
Component: KOMBI H07 0705
Coding: 231E01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 1C61DF5FA62B9D0A731-8048
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 10111203290546
Coding: 461000
VCID: 76B5EDF778C7675AA55-8022
Component: IMMO H07 0705
VCID: 6A8DC9873CFFB3BA31D-803E
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Revision: A1001003 Serial number: 7663363842
Coding: 020100
VCID: 2A0D0987FCFF73BAF1D-807E
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H35 0319
Serial number: VWZAZ2M4239743
Coding: 0400040104000B000000100A
ROD: EV_RNS315NARV2UDS_VW41.rod
VCID: 2517FABB95615CC2DCF-8070
Component: NAR_V3_(0037) 0037
B11CF 53 [00001000] - Deactivated
Reset counter: 51
Mileage: 228372 km
Date: 2025.07.30.
Time: 06:14:08
1048642 - Internal Control Module Memory Check Sum Error
B2000 42 [00001001] - General Memory Failure
[ECU defect data memory failure]
Mileage: 146115 km
Date: 2022.02.19.
Time: 22:27:47
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0005720211
Coding: 0404F5
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BE39C43E3A5DA32BAB-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Coding: 800000
B11EC 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 10
131584 - Motor for Rear Window Regulator
B11EE 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 10
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 290 3305
Revision: 00H22000
VCID: 372B20F3334DDE527E3-8062
Address 46: Central Conv.
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 01030108
VCID: 6FBBD893079D5692663-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011223200119
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0005690344
Coding: 0404F4
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CE19F5FE6ABDD0AB31-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
Reset counter: 10
End----------(Elapsed Time: 01:04, VBatt start/end: 13.5V/13.6V)-----------
------------------------------8 Faults Found-------------------------------
