DL382 Transmissions Basic Settings (7-speed dual-clutch automatic gearboxes)
DrPeter
16.4905° S, 151.7375° W
I have some new test plans here for the Basic Settings of the DL382 Transmissions, 7-speed dual-clutch automatic gearboxes ONLY.
To include the following:
0CK (DL382-7A)​
0CJ (DL382-7F)​
0HK/0HL (DL382+)​
0CL, 0DN, 0JN, 0CM​
Please try these at your own risk, we have not been able to test these yet, but if someone is willing to try, feed back would be greatly appreciated!
Selector Lever Calibration – DL382 (Gear Lever Basic Settings)
Use when:
- Selector lever mechanism or sensor replaced
- TCU or valve body replaced
- Gear positions (P, R, N, D, S) not correctly recognized
- Fault codes for selector lever or gear range sensors stored
- After wiring/connector repair to gear selector unit
Prerequisites:
- No active DTCs related to gear selector or CAN communication
- Gear selector in Park (P)
- Parking brake applied
- Engine at idle or ignition ON (as per prompt)
- Vehicle must be stationary
With VCDS, Select: [02 - Auto Trans], [Basic Settings - 04]
    IDE10912 - Selector lever position sensor: calibration
Then click [Show Measuring Data] and monitor:
    IDE10910 – Selector lever position
    IDE10911 – Selector lever position: raw value
    IDE10854 – Transm. calibration: calibration step
    IDE10853 – Transm. calibration: reason for abort (if needed)
Press [Start] and wait for Basic Setting to “Finished Correctly”
If Calibration Fails, observe messages:
    “Selector lever not in Park”
    “Calibration failed – invalid sensor range”
    “Routine aborted – safety reasons”
    Abort reason will be shown in IDE10853
Recheck selector position, verify no faults, and retry if needed.
If Successful:
    Selector lever positions will now be correctly registered
    No additional adaptation required for selector after this step
Press [Done, Go Back], then
Cycle ignition OFF for at least 6 seconds. This stores the calibration values in the controller.
Clutch Slip Point Adaptation – DL382 (Clutch Basic Settings)
Use when:
- Transmission, TCU, valve body, or software replaced
- Harsh shifts or clutch issues present
- After transmission fluid change
- After clutch service or replacement
- After clutch wear reset
- DTCs: P287B, P280A, P17EF
- Solenoids (N215/N216) replaced
Prerequisites:
- No DTCs except: P287B or P280A or P17EF (Cleared automatically after Basic Settings)
- Engine at idle, fully warmed up
- ATF temperature: ≥ 25°C
- No other transmission faults present
With VCDS, Select [02-Auto Trans], [Basic Settings - 04]
Select: IDE02298 - Adaptation of clutch kiss points - Calibration mode
Then click on [Show Measuring Data] and select the following:
  IDE06668 - Pressure control valve 1: act. current
  IDE06658 - Pressure control valve 2: act. current
  IDE06659 - Pressure control valve 3: act. current
  IDE10177 - Transmission Input Speed (RPM) Sensor 1
  IDE10178 - Transmission Input Speed (RPM) Sensor 2
  IDE10854 - Transm. calibration: calibration step
  IDE10853 - Transm. calibration: reason for abort
Press [Start] and wait for the Basic Setting to "Finished Correctly"
If Adaptation Fails watch for status messages:
- "Routine aborted - safety reasons"
- "Routine aborted - failure detected"
- Abort code will be displayed and logged
Re-check for proper conditions and retry if needed
If Successful, the New clutch pressure values will be shown:
Press [Done, Go Back],  [Close Controller, Go Back - 06]
Cycle ignition OFF for 6 seconds as this stores the learned adaptation values in the TCU
notes... expected pressures
E010 2.0 – 4.5 bar K1 PKP0 lower edge​
E011 2.0 – 4.5 bar K2 PKP0 lower edge​
E014 5.0 – 7.5 bar K1 PKP1 upper edge​
E015 5.0 – 7.5 bar K2 PKP1 upper edge​
E012 0.8 – 2.5 bar K1 fill start point​
E013 0.8 – 2.5 bar K2 fill start point​
E016 2.5 – 5.0 bar K1 fill end point​
E017 2.5 – 5.0 bar K2 fill end point​
ATF Drain, Fill and Level Check
 Use the Official Factory repair manuals! and follow ALL the "Test conditions" in the "ATF Pump, Deactivating and Draining the Hydraulic Pump Reservoir" section of the repair manual.
 There are three parts to this guide:
 1) Draining ATF
 2) Filling ATF
 3) Checking ATF
"WARNING - The system is under pressure"
Prerequisites:
 Ignition ON / Engine OFF
 Parking brake on
 Vehicle on flat level surface
1) Draining ATF
Prerequisites:
 Parking brake on
 Vehicle on absolutely flat level surface
With VCDS, select the [02-Auto Trans]
- Select [Adaptation-10]
- From the pull-down menu select [Oil pressure reservoir emptying]
 - [New Value] = "Activate", press [Do it!], then press [Go Back]
- Select [Adv.Meas.Values], then select the following for display:
 - "Oil pressure reservoir: status of emptying"
 - "Oil pressure reservoir: pressure - Data" (optional)
 - "Electrical pump 2 for trans. oil: actual speed" (optional)
 - "Oil pressure reservoir: status" (optional)
You should see the following information for "status of emptying":
   [Value]: "Leeren aktiv" or "Empty active" (briefly)
Then when complete you should see [Value]:
 "Druckspeicher entleert/ATF-Motor gesperrt" or "Pressure accumulator emptied/ATF motor disabled"
[Done, Go Back], [Close Controller, Go Back-06], switch ignition [Off].
The transmission is now ready for service and the following is true:
 - Auxiliary Hydraulic pump (V552 / ATF pump) is now disabled.
 - Pressure accumulator has been drained.
 - Vehicle MUST NOT be driven
 - P187E - Oil Pressure Reservoir, No Pressure (in memory)
 - Mechatronic can be removed for service
As per the Official Factory Repair manuals, Drain the ATF oil (T60 Torx), verify all the oil is drained.
2) Filling ATF
 Follow the the Official Factory repair manual to "Draining and filling ATF".
Important:
 It is possible to 'overfill' the AFT and mix the ATF and MTF(Manual Transmission Fluid)!!
 We strongly recommend to check and note the exact MTF level. If the level is to high, it could indicate mixing of ATF oil, due to a internal leak, between ATF and MTF.
 According to the manufacture, Audi, any mixing or operation with this condition WILL irreversibly damage the transmission!
Prerequisites:
 Ignition OFF / Engine OFF
 Parking brake on
 Remove the T30 Torx M10x1.0 - Filling AND Control plug.
Refill ATF* as per the Official Factory Repair manuals.
Tools needed:
 Oil hand pump VAS 6617, 6617/1, 6617/2 (aluminum pan)
 Oil hand pump VAS 6617, 6617/1, 6617/2, 7717/12 (plastic)
*Use ONLY Audi approved G 055 529 A2 dual clutch gearbox oil.
  (Max. filling volume is 3.5 liters)
Ignition [On], Engine [Off] - (Only after adding ATF)
 - [New Value] = "OFF", press [Do it!], then press [Go Back]
Verify the [Adv.Meas.Values]:
"Oil pressure reservoir: status of emptying" = [Not active]
[Done, Go Back], [Close Controller, Go Back-06], switch ignition [Off] for 30 seconds. Proceed to "Checking ATF" fluid level.
3) Checking ATF
Prerequisites:
 Ignition ON / Engine Idle
 Transmission is NOT in Emergency Running mode
 Parking brake on
 HVAC is [OFF]
Verify the [Adaptation-10] [Oil pressure reservoir emptying] is [OFF].
- If not set the [New Value] to [OFF].
(Optional)
 Supposedly you can increase the ATF fluid temperature by using this Basic Setting: [Set ATF-temperature]*
  Select [Basic Settings-04], [Set ATF-temperature]
  Specified temperature: 35°C > pre-set temperature: Yes > [Go!]
(*This is not yet tested with VCDS on a car).
(Recommended)
- Select [Adv.Meas.Values] = "Transmission fluid temperature"
Target temperature is [35°C], this is the minimum temp the ATF fluid level can be checked at. Wait till the correct temperature is achieved.
 Once the ATF temperature is at [35°C] it will be necessary to activate the ATF motor, see Adaptation steps below. Then follow the Official Factory repair manual "Checking ATF level".
- Select [Adaptation-10] - From the pull-down menu select
 [ATF_motor_speed_requirement - Activation]
 - [New Value] = "Vorgabe Aktiv", press [Do it!]
(Run the pump at this speed for 20 seconds)
[ATF_motor_speed_requirement - Motor Speed Requirement]
 - [New Value] = "3000", press [Do it!] (Default value = 0)
(Run the pump at this speed for 90 seconds)
 - [New Value] = "600", press [Do it!] (Default value = 0)
As per the manual:
"Note:
- The ATF level can be checked at the ATF inspection and filler hole.
- The ATF level is correct if a small amount of fluid comes out at the ATF inspection and filler hole when ATF temperature is between 35°C and 45°C (the fluid level rises due to expansion as it warms up)."
Tighten inspection/filler hole after the correct fluid level has been obtained.
(Shut down the ATF pump)
 - [New Value] = "keine Vorgab", press [Do it!]
 "Stop the Engine" and then turn the ignition back on, check /clear fault codes. Road test, check for leaks and fault codes.
Dinnyb
Ireland
C?ID=230450
Just did the Kiss point calibration on an 2015 A6, HW: OCK 927 156 transmission today worked perfectly. Have used the drain and fill procedures many times.
Have noticed engine stall on startup when trans first put into F or R when cold on cars that I have done a DSG oil change on, the kiss point procedure seems to resolve this.
Thanks for sharing!
jazda
Australia
C?ID=619908
Hi @DrPeter . Any idea what the security access code is for the auto trans module?
If there was a Security Access required to perform the Basic Settings in this thread, it would have been included in the procedure that DrPeter wrote above. ;)
jazda
Australia
C?ID=619908
Understand. Wasn't asking for the above procedure
Then why did you post your question here in this thread? ;)
magloman
Sweden
C?ID=2673
Hi everone! I am sorry if I post this in wrong area/thread.
Is there a way to see how worn the clutches are in a DL382 - 7A "0CJ 927 156" ? I have tried some things I found in other threads without any luck, it doesn't have same measurement adresses.
A friend of mine have an Audi Q5 -2018 (made 2017-09-ish) with DETA engine. Is now has 10.231 km on it. The gearbox DSG oil and filters was changed at 6.400 km by a common repair shop.
Its the wifey that use the car most of the time, but it seems it revs little high, like the clutch slips. They are second owner of the car and they owned it since about 4.500km.
Its unknown if the repair shop did the adaption after oil change.
We did "Clutch Slip Point Adaptation – DL382 (Clutch Basic Settings)" mentioned above and it went successfull.
We will see what the wifey says about. If it did any difference.
Monday,23,February,2026,16:47:11:45218
VCDS Version: 25.3.2.0 (x64)  HEX-NET CB: 0.4671.4
VIN: WAUZZZFY4J2032046   License Plate: YRR805
Mileage: 102313km-63574mi   Repair Order:
Chassis Type: FY-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 18 19 22 29 2B 39 42 44 46 47 52 5F
          69 6C 6D 81 A5 AC BB BC CA D6 D7
VIN: WAUZZZFY4J2032046   Mileage: 102313km-63574miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DETA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 CE    HW: 04L 907 309 L
   Component: R4 2.0l TDI   H35 6648
   Revision: B1H35---    CVN: FACB31A8E3F73227B866C2AD
   Coding: 2A65403A253605083408
   Shop #: WSC 16847 006 1048576
   ASAM Dataset: EV_ECM20TDI01104L906026CE 005007
   ROD: EV_ECM20TDI01104L906026CE_005.rod
   VCID: EFAEA059362D2EE3BA-80BA
   VINID: 9D196AAAA5A911A0800C200418ECCB5C0C
   Part No SW: 80A 927 155 BA    HW: 0CJ 927 156
   Component: 0CJ 20TDI RdW H04 0001
   Revision: --H04---    Serial number: 0000000392 CVN: BF920B2E
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_AU49.rod
   VCID: E99ACE4108C9C0D3E4-80BC
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  0C4 0572
   Serial number: 75117071170131000520
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-V1.clb
   Part No SW: 80A 907 379 B    HW: 80A 907 379
   Component: ESP9 Plus     H11 0766
   Dataset Number: 80B909504S  0001 CVN: C2A13B20
   Coding: 14AA48BE28A50A98D19E589520835292E4A5D2281214508B1A044A4927A54B
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: AE107D5DF1A767EBF1-80FA
   Part No SW: 80A 820 043 G    HW: 80A 820 043 G
   Component: Klima Zone 3  H32 0095
   Coding: 641848195544400D02000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: A10A9661B079C8937C-80F4
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J126 FLuftV  H08 0003
   Serial number: 00000000000001610171
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: ED6884A880PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
328019 - Motor for Rear Right Temperature Flap
          B10D6 07 [00001001] - Mechanical Failure
                    Reset counter: 51
                    Mileage: 101823 km
                    Date: 2026.01.28
                    Time: 17:10:06
                    Rear temp. door motor: specified value: 11545
                    Rear temperature flap motor: actual value: 11612
                    System run time-Engine running time: 188 s
                    System run time-Terminal 15 on: 190 s
                    Rear temperature flap motor: diagnosis-Last operating state: No routine started
                    Rear temperature flap motor: diagnosis-Operating condition: Blocking handling
                    Voltage terminal 30: 14.86 V
                    Outside temperature: -5.50 °C
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 80B909514E  0025
   Coding: 07501943E11800CD0505871594BF80F9110B3108000000000000000020001A810A450122025605
   Shop #: WSC 12345 123 61029
   VCID: 8248F9ED15BF338B45-80D6
   Subsystem 1 - Part No SW: 80B 955 119     HW: 80B 955 119
   Component: 426 LL 161214  040 0570
   Serial number: 00000001612102102191
   Coding: 5FC7F7
   Serial number: 20506311X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 19 07 2017  72000082
   Serial number: GX1CE123061723510315
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 80A 947 135 AE    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00009710
   Coding: 0D0101
   Subsystem 6 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000135574001
66308 - Reading Lamp; Rear Left
          B14EE 01 [00001000] - Electrical Failure
                    Reset counter: 102
                    Mileage: 101679 km
                    Date: 2026.01.25
                    Time: 09:22:25
                    average_Voltage_terminals: 12.20 V
                    Outside air temperature sensor-Outside air temperature on CAN: 7.50 °C
                    interior_temperature: 11.50 °C
                    Vehicle speed: 0.00 km/h
                    Terminal activation-Terminal 75 status: OFF
                    Terminal activation-Terminal 15 status signal: OFF
                    Terminal activation-Terminal 15 via CAN: OFF
   Part No SW: 80A 959 655 N    HW: 80A 959 655 N
   Component: AirbagVW30    031 0513
   Serial number: 003WBM01SU31 Dataset Number: 80A909602G  0013
   Coding: AACCF0C00C800000585400FFF00C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
   VCID: BE304D1D21C7976B61-80EA
   Subsystem 1 - Part No SW: -----------    HW: 480 001 305 17
   Serial number: 35700000000AD405242C
   Subsystem 2 - Part No SW: -----------    HW: 480 001 505 17
   Serial number: 358000000007F5A4F32Y
   Subsystem 3 - Part No SW: -----------    HW: 480 030 305 17
   Serial number: 351000C202857860394W
   Subsystem 4 - Part No SW: -----------    HW: 480 031 505 17
   Serial number: 352000C24CD94A00F97L
   Subsystem 5 - Part No SW: -----------    HW: 480 032 905 17
   Serial number: 355000C24ED619E14BBT
   Subsystem 6 - Part No SW: -----------    HW: 480 032 905 17
   Serial number: 356000C24EDDD830AE4
   Subsystem 7 - Part No SW: -----------    HW: 480 033 105 17
   Component: PedP_Sensor_C  002 0149
   Serial number: 230000C2443B16112E4R
   Subsystem 8 - Part No SW: -----------    HW: 480 000 404 17
   Serial number: I0M00000000B1A1C10A0
   Subsystem 9 - Part No SW: -----------    HW: 480 000 404 17
   Serial number: I0N0000000026A1C10A/
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 021 803 17
   Component: CentrSensorXY  000 0108
   Serial number: I0O00019F247F123F55/
   Part No SW: 80A 907 129 AJ    HW: 80A 907 129 AJ
   Component: Lenks.Modul   H02 0003
   VCID: F0ACA3252B13311BA3-80A4
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H18 0371
   Coding: 45A4A5D4A88000080B2369601000200000000000
   VCID: C3C63CE94A25FA830E-8096
Address 18: Aux. Heat (J364)       Labels:| 4M0-265-105.clb
   Part No SW: 4M0 265 105 E    HW: 4M0 265 105 E
   Component: HSG           H11 0090
   Dataset Number: 80B909858A  0008
   Coding: 0D0F01
   ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
   ROD: EV_AuxilParkHeateEBEAU736.rod
   VCID: A91A8E41C84900D324-80FC
360192 - Flame-Out
          B138A 00 [00001000] - -
          [flame interruption - control level Power: Flammenabbruch - Regelstufe Power]
                    Reset counter: 102
                    Mileage: 101710 km
                    Date: 2026.01.27
                    Time: 15:15:16
                    Coolant temperature of parking heater: 50 °C
                    Coolant temperature of auxiliary heater_Textual: numerical value: no text
                    Engine_coolant_temperature: 48.00 °C
                    Engine_coolant_temperature_Textual: numerical value: no text
                    Voltage terminal 30: 14.70 V
                    System condition: 190
                    Auxiliary heater operating status: full load
                    Outside_Temperature_Additional_Heating: -4.50 °C
                    Engine_Speed: 1430.00 /min
                    Fuel_Level_Input_Heater: 53 l
360194 - Flame-Out
          [flame interruption - control level medium: Flammenabbruch - Regelstufe Mittel]
                    Reset counter: 93
                    Mileage: 101867 km
                    Date: 2026.01.30
                    Time: 15:50:40
                    Coolant temperature of parking heater: 77 °C
                    Engine_coolant_temperature: 78.00 °C
                    Voltage terminal 30: 14.80 V
                    System condition: 80
                    Auxiliary heater operating status: Medium
                    Outside_Temperature_Additional_Heating: -4.00 °C
                    Engine_Speed: 1437.00 /min
                    Fuel_Level_Input_Heater: 37 l
   Part No SW: 8W5 907 468 E    HW: 8W5 907 468 E
   Component: Gateway       H42 0116
   Revision: 6A010002    Serial number: 0286A754017522 Dataset Number: 80B909515D  0043
   Coding: 03010001000006404107000000590032483A0007100000000175078F10000000
   GVL: 01D03C0008040200C08C08000006C80010080000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003092
   VCID: CBD614C9627532C3F6-809E
   Subsystem 1 - Part No SW: 80A 951 523 E    HW: 80A 951 523 E
   Component: J453 MFL  H06 0002
   Serial number: 20170609134134 00278
   Serial number: 9004395200
262659 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [BAP_Timeout_ParkHeater]
                    Reset counter: 108
                    Mileage: 101618 km
                    Date: 2026.01.20
                    Time: 19:48:00
Address 22: AWD (J492)       Labels:| 0CJ-927-749.clb
   Part No SW: 80A 927 755     HW: 0CJ 927 749
   Component: Q5_DL3_N_SD4  H18 0004
   Serial number: 1714234524
   Coding: 01070000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: EC94B755073BD5FB9F-80B8
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 80A 907 397 B    HW: 80A 907 397 B
   Component: LCM_MLBevo    H06 0017
   Dataset Number: 80B909519C  0009
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 17000119941014
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: B228692DE59F430B95-80E6
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Dataset Number: 80B909520C  0009
   Part No SW: 8W1 959 593     HW: 8W1 959 593
   Component: TSG FS001 0737
   Serial number: CLSM1QE6005UN Dataset Number: 80B909872A  0023
   Coding: 005F8B014000040000001080
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 885CEBC5338319DB1B-80DC
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0005
   Serial number: 0000826257 Dataset Number: 80B909852H  0020
   Coding: 90002001000100
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: B4246F351F8B4D3B87-80E0
   Part No SW: 8W0 907 064 DM    HW: 8W0 907 064 DM
   Component: BCM2 MLBevo   019 0366
   Dataset Number: 80B909501C  0027
   Coding: 01340000002000E06301A0006600D80233020000804306502F00000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 013013
   ROD: EV_BCM2HellaAU736_013_AU49.rod
   VCID: 8A58D1CD2D8F6BCB0D-80DE
640257 - Bulb for Right Brake Lamp / Tail Lamp
          B133C 13 [00001001] - Open Circuit
                    Reset counter: 45
                    Mileage: 101618 km
                    Date: 2026.01.21
                    Time: 05:40:20
                    Supply voltages-Terminal 30 power supply: 11.767 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 11.740 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 11.740 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 00 5B 12 04 98
                    light_freeze_frame: 11111111 11111111 11111111 11111111
131120 - Remote key 1
          B1479 18 [00001001] - Current Too Low
                    Reset counter: 65
                    Mileage: 101962 km
                    Date: 2026.02.04
                    Time: 16:33:46
                    Supply voltages-Terminal 30 power supply: 14.865 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 14.837 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 14.837 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 AA 98 06 E0
                    general_additional_freeze_frame-Vehicle speed: 3.19 km/h
                    key_error_freeze_frame: 01001001 11111111 11111111 11111111
   Part No SW: 80A 035 223 A    HW: 80A 035 223
   Component: MIB2_amp_P_Q5 H03 0420
   Revision: 00000001    Serial number: AUZ8ZAHTK00V6Q% Dataset Number: 80B909510B  0005
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   VCID: 997ABE8198299053B4-80CC
   Part No SW: 8W1 959 592     HW: 8W1 959 592
   Component: TSG BFS001 0737
   Serial number: CLSM1QFR00SFJ Dataset Number: 80B909873A  0023
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 875EE8F93E9D16A312-80D2
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 036 A    HW: 8W5 035 036
   Component: MU-P-LN-EU    034 1117
   Serial number: A795G0H9091152 Dataset Number: 80B909545K  0024
   Coding: 012406010000000053110002000A00102F00156501700100DE
   VCID: B620553D09F75F2BB9-80E2
   Subsystem 1 - Part No SW: V03 959 802 TH    HW: -----------
   Component: ECE 2020  --- 0184
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9HBL01HJP
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 20051700000000000167
   Compact disc data bank:
   Component: Gracenote2  --- 1016
3084 - GSM antenna 2
          B1533 13 [00001001] - Open Circuit
                    Reset counter: 45
                    Mileage: 101618 km
                    Date: 2026.01.20
                    Time: 19:37:28
                    Voltage terminal 30: 11.9 V
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: Anhaenger     H20 0216
   Revision: 9A001003    Serial number: 0441860027 Dataset Number: 80B909527A  0008
   Coding: 0110000202000000
   VCID: B3266C291A854A039E-80E6
   Component: RVC Compact   H12 0250
   Dataset Number: 80B909460F  0007
   Coding: 0224060103002005400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Dataset Number: 80B909541C  0009
   Coding: 0790
   Shop #: WSC 40870 222 00000
   VCID: C8DC2BC57303D9DBDB-809C
   Part No SW: 80B 713 041 L    HW: 80B 713 041 L
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170627000891
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: A600857DD9572FAB09-80F2
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217     HW: 80A 907 217
   Component: BVS           H14 0042
   Dataset Number: 80B909466C  0022
   Coding: 0404020600000403022023A1A50000FE00F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
   VCID: E386DC69EAE59A832E-80B6
1123671 - Fog mode active
          C118E 00 [00001000] - -
                    Reset counter: 100
                    Mileage: 102090 km
                    Date: 2026.02.12
                    Time: 05:50:37
                    Control Module temperature: 1 °C
                    Voltage terminal 15: 14.60 V
Address AC: Reductant Control (J880)       Labels: 80A-907-355.clb
   Part No SW: 80A 907 355 E    HW: 80A 907 355 D
   Component: SCR-Stg-G4H07 0003
   Dataset Number: 80B909571H  0002
   ASAM Dataset: EV_RDCMHelbaAU426 003010
   ROD: EV_RDCMHelbaAU426_003.rod
   VCID: AB167449C2B512C3D6-80FE
   Part No SW: 8W1 959 595     HW: 8W1 959 595
   Component: TSG HFS001 0737
   Serial number: CLSM1QG100OEJ Dataset Number: 80B909897A  0024
   Coding: 000F89000000040000001080
   Component: TSG HBFS001 0737
   Serial number: CLSM1QG100OKU Dataset Number: 80B909896A  0024
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Dataset Number: 80B909469C  0005
   Coding: 428000042602
   ROD: EV_SunRoofCONTIAU736_006_VW37.rod
   VCID: BD324A112CC18C7378-80E8
   Dataset Number: 80B909471B  0004
   VCID: 977EB8B96E3D862382-80C2
   Dataset Number: 80B909472B  0004
End----------(Elapsed Time: 02:14, VBatt start/end: 15.1V/15.0V)-----------
------------------------------9 Faults Found-------------------------------
leonardobdes
England
C?ID=661854
I just did the:
Feedback:
The first attempt complained that I could not do that in the current session.
I closed VCDS and tried again.
The second attempt was already running for around 40 min, it was showing " Running", but I had to stop it, as I could not wait any longer.
On the third attempt, I was expecting a long wait, and it just took 1 min or so.
Before:
  IDE06658   Pressure control valve 2: act. current 161.6 mA
  IDE06659   Pressure control valve 3: act. current 1.5 mA
  IDE06668   Pressure control valve 1: act. current 162.0 mA
  IDE10177   Transmission Input Speed (RPM) Sensor 1 0 /min
  IDE10178   Transmission Input Speed (RPM) Sensor 2 0 /min
  IDE10853-ENG98502   Transm. calibration: reason for abort-Data OK
  IDE10854-ENG98502   Transm. calibration: calibration step-Data Calibration off
After:
  IDE00024-ENG98502   ATF temperature-Data 39 °C
  IDE06658   Pressure control valve 2: act. current 141.9 mA
  IDE06659   Pressure control valve 3: act. current 1.7 mA
  IDE06668   Pressure control valve 1: act. current 141.8 mA
  IDE06669   Pressure control valve 1: spec. current 141.0 mA
I did check this before I started the second attempt: ATF temperature: ≥ 25°C
On the third attempt, I did see "Transm. calibration: calibration step-Data Calibration" changing.
On the second attempt, I just saw "Transmission Input Speed (RPM) Sensor 1" changing.
Info:
Audi A6 2014 2.0 Diesel Ultra.
Gearbox DL382-7F - 0CK - SJZ
