1) I don't have access to repair info for this RoW vehicle to confirm or deny if G85 is part of the slip ring (AKA clockspring) -or- internal with #44 but I have to wonder if the slip ring (6C0 959 653) might communicate via diagnostics.
2) I would want to make sure the Raw value (118.4 in that example)
changes from 0.0 when straight to similar values with the steering held at each stop. Make sure you get 0.0 when straight and then something like +/- 460 in each direction when turning the wheel. Pictures at each position or text would be helpful so we can rule out a bad G85 reading.
Mind posting up a fresh scan so we people can see what changed?So the problem is solved. I gave up. I visited skoda tooday. Thay did not replace any part. It was the #44 bad coding problem. They did not tell me what they did but looking at WSC only the #44 was coded. Thank You all for support .
Friday,31,March,2017,20:04:51:10824
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
Workshop Code: 031 00031 073430
Chassis Type: NJ (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: TMBEA6NJ5GZ031323 Mileage: 44375km-27573miles
Address 01: Engine (J623-CHYA) Labels: 04C-906-020-CHY.clb
Part No SW: 04C 906 057 HW: 04C 907 309 J
Component: R3 1.0l MPI H24 8993
Revision: 31H24000
Coding: 01110052020405080000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM10MPI01104C906057 001016
ROD: EV_ECM10MPI01104C906057_SK26.rod
VCID: 629EA06454CD15975BD-8036
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08508679150618
Coding: 41F5247D492633C10917106B0054822492CC9008000DCA098F00
Shop #: WSC 73430 790 00000
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 37282130AFCF203FDC3-8062
Address 08: Auto HVAC (J301) Labels: 6C0-820-045.clb
Part No SW: 6V0 820 045 A HW: 6V0 820 045 A
Component: AC Manuell H01 0108
Serial number: 1506121B-0556
Coding: 100000001000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26_VW26.rod
VCID: 303A1A2C4AA1F7079D9-8064
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 6C0 937 087 C HW: 6C0 937 087
Component: BCM PQ26 Me4R H08 0084
Serial number: 001368003882
Coding: 0C0008404205497B43804000400703080000D80050013500000000000000
ASAM Dataset: EV_BCMA0 005005
ROD: EV_BCMA0_005_SK25.rod
VCID: 2E0604545095E1F78F5-807A
Address 15: Airbags (J234) Labels: 6C0-959-655.clb
Part No SW: 6C0 959 655 F HW: 6C0 959 655 F
Component: VW20Airbag733 001 0360
Revision: -------- Serial number: 003RJ003NK4D
Coding: 88CCC000000000005C5400CF000800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 36362C34A8C5D937C75-8062
Subsystem 1 - Part No SW: ----------- HW: 410 820 906 15
Component: SideSensor_Df 151 0800
Serial number: 3575H00B51AC0682F20N
Subsystem 2 - Part No SW: ----------- HW: 410 820 906 15
Component: SideSensor_Pf 151 0800
Serial number: 3585H00B31AC0683612F
Subsystem 3 - Part No SW: ----------- HW: 442 152 506 15
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00B91AC53B3919O
Subsystem 4 - Part No SW: ----------- HW: 442 152 506 15
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00BB1AC53B4419N
Part No SW: 6V0 920 730 A HW: 6V0 920 730 A
Component: KOMBI 105 1420
Coding: 0724010021000008010808001000000000000000
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 323E102444ADC517EBD-8066
Address 19: CAN Gateway (J533) Labels: 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 087
Component: GW MQB A0 H08 0084
Revision: -------- Serial number: 001368003882
Coding: 030000042F0A640000000000000000010001050000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_VW26.rod
VCID: 6594BB7845E362AFBEF-8030
Subsystem 1 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 22163633342821249920
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AJ HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3242
Serial number: CF6R0981
Coding: 000700
Shop #: WSC 57012 002 1048576
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW_SE26.rod
VCID: 70BADA2C8A21B707DD9-8024
Address 5F: Information Electr. (J794) Labels: 3V0-035-MIB-ENT2.clb
Part No SW: 6V0 035 867 C HW: 6V0 035 867 C
Component: MU-E--ER 852 6490
Serial number: 16061500012730
Coding: 036200003C0000005011000101000A00000000C40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_SK26.rod
VCID: 3C223E1C96E90367311-8068
End----------(Elapsed Time: 00:30, VBatt start/end: 14.9V/14.7V)-----------
Saturday,26,August,2017,12:31:16:36988
VCDS Version: 17.8.0.1
Workshop Code: 031 73430 000063
VIN: TMBEM6NJ0HZ102002 License Plate:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
VIN: TMBEM6NJ0HZ102002 Mileage: 10090km-6269miles
Address 01: Engine (J623-CJZC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 BB HW: 04E 907 309 AF
Component: R4 1.2l TFS H23 9085
Revision: R4H23---
Coding: 01110032230415080000
ASAM Dataset: EV_ECM12TFS01104E906027BB 001009
ROD: EV_ECM12TFS01104E906027BB.rod
VCID: 65CA5F4564F1BA6E19-8030
CAN Converter 01:
U0428 00 [039] - -
Mileage: 10090 km
Date: 2017.07.07
Time: 02:07:03
Engine speed: 0.00 /min
Coolant temperature: 23 °C
Intake air temperature: 24 °C
Voltage terminal 30: 13.853 V
CAN status - engine control module-Bit 0: 0
selected gear-Bit 0: 0
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 R HW: 6R0 907 379 BA
Component: ESP9.0i H04 0006
Serial number: 08505782161109
Coding: 41F5247D492333C2091410690053822492CC9008000DCA098F00
Shop #: WSC 73430 031 00063
VCID: 3E78D029A1E7C9B6B8-806A
0625 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Reset counter: 122
Mileage: 10090 km
Date: 2017.07.07
Time: 02:07:03
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
Reset counter: 122
Mileage: 10090 km
Date: 2017.07.07
Time: 02:07:03
1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
Reset counter: 122
Mileage: 10090 km
Date: 2017.07.07
Time: 02:07:03
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6V0 820 045 C HW: 6V0 820 045 C
Component: AC Manuell H01 0204
Serial number: 1611041B-0515
Coding: 100000001100100000
VCID: 3260F41965BF1DD64C-8066
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H10 0094
Serial number: 006308244111
Coding: 0C0008504205497B43804000400703080000D80050013500000000000000
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_SK25.rod
VCID: 3162FB1560B926CE35-8064
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 3K H10 0054
Revision: -------- Serial number: 39231633302445
Coding: 0001050001
ROD: EV_EPHVA14AU3700000_002_SK37.rod
VCID: 3C7CDA21B7FBDBA696-8068
13637426 - Databus
Reset counter: 122
Mileage: 10090 km
Date: 2017.07.07
Time: 02:07:03
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 K HW: 6C0 959 655 K
Component: VW20Airbag743 002 0380
Revision: -------- Serial number: 003TJ0090U15
VCID: 3B7ED93DB2F5DC9E9F-806E
Subsystem 1 - Part No SW: ----------- HW: 410 820 611 16
Serial number: 3575H00A7218C262307B
Subsystem 2 - Part No SW: ----------- HW: 410 820 711 16
Serial number: 3585H009F22AE861D19%
Subsystem 3 - Part No SW: ----------- HW: 442 152 910 16
Serial number: 3517A00C72182421536-
Subsystem 4 - Part No SW: ----------- HW: 442 152 910 16
Serial number: 3527A00C7218242371C2
B1000 1B [137] - Resistance Too High
Mileage: 10090 km
Date: 2017.07.07
Time: 02:07:05
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 6V0 920 740 B HW: 6V0 920 740 B
Component: KOMBI 202 2310
Coding: 072401002180000801082A001000000000000000
VCID: 346CF2019FAB13E65E-8060
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H10 0094
Revision: -------- Serial number: 006308244111
Coding: 030100042F0A640000000000000000010001050000000000000000000000
ROD: EV_GatewA0Lear_013_SK25.rod
VCID: 2648184959777176D0-8072
Subsystem 1 - Part No SW: 6C0 915 181 B HW: 6C0 915 181 B
Component: J367-BDM H08 0270
Serial number: 63321004145881883207
197169 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Reset counter: 122
Mileage: 10090 km
Date: 2017.07.07
Time: 02:07:03
Supply voltage: Terminal 30: 13.9 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Component: EPS_TRW_ALow 313 3242
Serial number: CGBT0578
Coding: 000700
ROD: EV_SteerAssisUDSTRW.rod
VCID: 70E43E11AB336FC67A-8024
1094656 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 122
Mileage: 10090 km
Date: 2017.07.07
Time: 02:07:03
1073664 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
Reset counter: 122
Mileage: 10090 km
Date: 2017.07.07
Time: 02:07:03
1073920 - Steering End Stops Not Learned
Reset counter: 122
Mileage: 10090 km
Date: 2017.07.07
Time: 02:07:03
Part No SW: 6V0 035 871 D HW: 6V0 035 871 D
Component: MU-E--ER 050 7080
Serial number: 15111600013194
Coding: 03620000BE0000001111000401000A002F0000C40000010000
VCID: 3874C63183C3F78672-806C
End-------------------------(Elapsed Time: 02:34)--------------------------
Let me try:Hmm, I dont know how to paste image...
It works, but raw value shows -142 degree at straight wheels. It is rather not possible to rotate steering column, as it fits only in one position.
It is entirely possible #44 needs information from other modules on the network that aren't installed in your bench setup. I would repeat the process after the rack is installed in a vehicle.I do note have a car, only EPS and CAN BusSimulation.
Tuesday,30,July,2019,18:26:35:60995
VCDS Version: 19.6.1.0 (x64)
VIN: VSSZZZKJZJR082375 License Plate: XXX-NNN
Mileage: Repair Order: arona
Chassis Type: KJ-SE27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 44 55 5F
08-Auto HVAC -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Cannot be reached 0100
Address 01: Engine (J623-DKJA) Labels: None
Part No SW: 04C 906 025 G HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 5178
Revision: D7H20000
Coding: 0125003223641D081000
Shop #: WSC 00049 770 00139
ASAM Dataset: EV_ECM10TFS01104C906025G 001003
ROD: N/A
VCID: 244C01B32F35BC6FDD-8070
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ECM10TFS01104C906025G" (SE27)
7150 - ROD - Unknown Error Code
- 00 [047]
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:22
4708 - ROD - Unknown Error Code
- 00 [047]
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:21
4709 - ROD - Unknown Error Code
- 00 [047]
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:21
Readiness: 0010 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 042 E HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1603
Revision: 00005008 Serial number: CU501710236571
ROD: N/A
VCID: 3874C5C383BDC88F61-806C
No ASAM data for: "EV_TCMDQ200021" (SE27)
21193 - ROD - Unknown Error Code
- 00 [047]
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:22
Part No SW: 2Q0 614 517 T HW: 2Q0 614 517 M
Component: ESC_high_vFGS H33 0322
Serial number: 08515614170912
Coding: 8A0D4C573D4951AF32FFBC1D12DF11A649344D26226A24484454625445488865922CB26444562412222A462AA269D64AFD966B52BF
Shop #: WSC 00049 770 00020
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
ROD: N/A
VCID: 3F86AEDFA693FFB7A0-806A
No ASAM data for: "EV_Brake1BOSCHESPMQBA0" (SE27)
1200 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:22
1152 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:22
1272 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 222
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:22
1141 - ROD - Unknown Error Code
- 00 [137]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:22
Address 05: Acc/Start Auth. (J518) Labels:. 5Q0-959-435.clb
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0459118184
Coding: 112E0E0703
Shop #: WSC 00049 770 00021
ROD: N/A
VCID: 3E78D3DBA199F6BFAB-806A
No ASAM data for: "EV_KessyHellaMQBAB" (SE27)
Part No SW: 2Q0 937 090 HW: 2Q0 937 090
Component: BCM A0 Std+ H97 0915
Serial number: 07001731100757
ASAM Dataset: EV_BCMA0 204001
ROD: N/A
VCID: 6FE63E9FB6734F3770-803A
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 047 0105
Serial number: S7Y17M10D25H21M17S46
Coding: 00194D
Subsystem 2 - Part No SW: 2Q1 959 881 B HW: 2Q1 959 881 B
Component: FHSG_DRV 001 0001
Serial number: 00000000000017364395
Coding: 13000F
Subsystem 3 - Part No SW: 2Q1 959 882 D HW: 2Q1 959 882 D
Component: FHSG_PSG 001 0002
Serial number: 00000000000017052411
Coding: 09000F
Subsystem 4 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000017048600
Subsystem 5 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000017285286
Coding: 190000
No ASAM data for: "EV_BCMA0" (SE27)
539157 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 182
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:27
590853 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 222
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:26
592133 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 222
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:26
Address 10: Park/Steer Assist (J791) Labels:. 5Q0-919-298.clb
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417617305
Coding: 0271161051
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: N/A
VCID: 50A49D630B0D70CF49-8004
No ASAM data for: "EV_EPHVA2CAU3700000" (SE27)
13679372 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:26
13637426 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:26
13679386 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:25
Address 13: Auto Dist. Reg
Address 15: Airbags (J234) Labels: None
Part No SW: 5QF 959 655 L HW: 5QF 959 655 L
Component: Airbag VW22 006 0520
Revision: -------- Serial number: 003XNPP0ZRQP
Coding: 88CCC0C000000000585400CF000C00000065
ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
ROD: N/A
VCID: 5FC64E5F46D3DFB7C0-800A
Subsystem 1 - Part No SW: ----------- HW: 454 001 310 17
Serial number: 35700000000EEBBCA92C
Subsystem 2 - Part No SW: ----------- HW: 454 001 410 17
Serial number: 358000000007839CA92X
Subsystem 3 - Part No SW: ----------- HW: 454 801 410 17
Serial number: 3510098002D120000001
Subsystem 4 - Part No SW: ----------- HW: 454 801 910 17
Serial number: 35200E8312C12000000A
Subsystem 5 - Part No SW: ----------- HW: 454 801 810 17
Component: FrontSensor_D 307 0189
Serial number: 3550052E66F10000000J
No ASAM data for: "EV_AirbaVW22TS6VW48X" (SE27)
1050117 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 182
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:23
1060608 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:25
Address 16: Steering wheel (J524) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 521 GE HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF035035 Serial number: 20171021400570
Coding: 6414
ROD: N/A
VCID: 7BFE1ACFF20B2397CC-802E
No ASAM data for: "EV_SMLSVALEOMQB" (SE27)
Address 17: Instruments (J285) Labels: None
Part No SW: 6F0 920 740 HW: 6F0 920 740
Component: KOMBI 206 0450
Coding: 04A4091A2D800008008822011001000080000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001020
ROD: N/A
VCID: 62C047AB75A1F25FEF-8036
No ASAM data for: "EV_DashBoardVDDMQBA0" (SE27)
16777028 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:26
16776960 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:23
16776961 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:23
Address 19: CAN Gateway (J533) Labels:. 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 436 4326
Revision: -------- Serial number: 0007032400
Coding: 030100046F085700E90002581C0F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: N/A
Subsystem 2 - Part No SW: 5F0 959 537 D HW: 5F0 959 537 D
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000H1749031017
Coding: 012000
Subsystem 3 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
Component: J367-BDMBOSCH H02 2011
Serial number: 100265D9
No ASAM data for: "EV_GatewNF" (SE27)
131654 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:23
131671 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:23
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 2Q0 905 861 HW: 2Q0 905 861
Component: ELV-MQBB H06 0020
Serial number: 17000189490014
Coding: 0800000000000000
ROD: N/A
VCID: 70E43DE3AB4D50CF69-8024
No ASAM data for: "EV_ELVMarqMQBA0" (SE27)
Address 44: Steering Assist (J792) Labels: None
Part No SW: 2Q1 909 144 J HW: 2Q1 909 144 F
Component: TRW_G4L_MQBA0 610 6030
Serial number: 0186381CB2H3032
Coding: 01000101000000010101020101000101000001
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
ROD: N/A
VCID: 3972C0C7B8B7D1879E-806C
No ASAM data for: "EV_SteerAssisTRWG4LMQBA0" (SE27)
15788544 - ROD - Unknown Error Code
- 00 [008]
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:23
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0070
Coding: 078A000001200003
ROD: N/A
VCID: 4182A827D0678947D6-8014
No ASAM data for: "EV_HeadlRegulAFSMQBMAX" (SE27)
13705992 - ROD - Unknown Error Code
- 00 [137]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:24
Address 5F: Information Electr. (J794) Labels:. 5F0-035-MIB-STD2.clb
Part No SW: 5QA 035 824 B HW: 5QA 035 824 B
Component: MU-S--ER H41 0468
Serial number: SEZAZ2T1259728
Coding: 04120600960A000011110001000808002F0101D40120050002
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: N/A
Subsystem 1 - Part No SW: 6F0 919 605 HW: 6F0 919 605
Component: ABT_Std-2 H50 8130
Serial number: SEZ6ZHT3151114
No ASAM data for: "EV_MUStd6C1TSAT" (SE27)
7173 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:25
7195 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 181
Mileage: 13726 km
Date: 2019.07.14
Time: 22:27:24
End-------------------------(Elapsed Time: 04:03)--------------------------
We use essential cookies to make this site work, and optional cookies to enhance your experience.
