Check your PMs.I am with the following problem, my vcds does not show emergent balloon with security code to solve my problem.
[Access to security-16]
Enter the code that appears in the VCDS popup
What part doesn't work? Security Access not accepted? Or something else beyond that point?No work buddy
PS: You do have a rather different Steering Module.
"EV_SteerAssisNSKGen2" rather than "EV_SteerAssisUDSTRW".
Looks like a different supplier...
VIN: 9BWAG4121FT558704 License Plate: OLM553
Mileage: 23690km-14720mi Repair Order: 1122
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S1 909 144 P HW: 1S1 909 144 P
Component: EPS_ECU H51 1702
Coding: 0001000001010000
Shop #: WSC 03310 453 00217
ASAM Dataset: EV_SteerAssisNSK 014008
ROD: EV_SteerAssisNSK_VW12.rod
VCID: 4084F8FDDBDE7742EE-8014
0024 - Crash Shut-Down Activated
P1609 00 [137] - -
Reset counter: 35
Mileage: 23694 km
Date: 2017.01.19
Time: 00:32:30
Voltage terminal 15: 13.302 V
Voltage terminal 30: 13.903 V
Engine speed: 0.00 /min
Status: No enabling
Thursday,23,March,2017,18:55:09:10824
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
VIN: TMBEA6NJ5GZ031323 License Plate:
Chassis Type: NJ (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: TMBEA6NJ5GZ031323 Mileage: 44141km-27427miles
Address 01: Engine (J623-CHYA) Labels: 04C-906-020-CHY.clb
Part No SW: 04C 906 057 HW: 04C 907 309 J
Component: R3 1.0l MPI H24 8993
Revision: 31H24000
Coding: 01110052020405080000
Shop #: WSC 73430 031 00000
VCID: 629EA06454CD15975BD-8036
No ASAM data for: "Unknown" (SK26)
7150 - ROD - Unknown Error Code
- 00 [047]
Mileage: 44112 km
Date: 2017.03.04
Time: 01:52:39
4629 - ROD - Unknown Error Code
- 00 [032]
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08508679150618
Coding: 41F5247D492633C10917106B0054822492CC9008000DCA098F00
Shop #: WSC 13765 031 00000
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 37282130AFCF203FDC3-8062
0625 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Fault Frequency: 9
Reset counter: 80
Mileage: 44112 km
Date: 2017.03.04
Time: 00:20:18
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
Reset counter: 79
Mileage: 44112 km
Date: 2017.03.04
Time: 00:20:18
1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
Reset counter: 79
Mileage: 44112 km
Date: 2017.03.04
Time: 00:20:18
Address 08: Auto HVAC (J301) Labels: 6C0-820-045.clb
Part No SW: 6V0 820 045 A HW: 6V0 820 045 A
Component: AC Manuell H01 0108
Serial number: 1506121B-0556
Coding: 100000001000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26_VW26.rod
VCID: 303A1A2C4AA1F7079D9-8064
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 6C0 937 087 C HW: 6C0 937 087
Component: BCM PQ26 Me4R H08 0084
Serial number: 001368003882
Coding: 0C0008404205497B43804000400703080000D80050013500000000000000
Shop #: WSC 73430 790 00000
ASAM Dataset: EV_BCMA0 005005
ROD: EV_BCMA0_005_SK25.rod
VCID: 2E0604545095E1F78F5-807A
8202 - Bulb for Left DRL
B121D 15 [008] - Open or Short to Plus
Reset counter: 119
Mileage: 44112 km
Date: 2017.03.04
Time: 01:52:57
8458 - Bulb for Right DRL
B121E 15 [008] - Open or Short to Plus
Reset counter: 119
Mileage: 44112 km
Date: 2017.03.04
Time: 01:52:57
558100 - Databus
Reset counter: 119
Mileage: 44112 km
Date: 2017.03.04
Time: 01:52:48
Address 15: Airbags (J234) Labels: 6C0-959-655.clb
Part No SW: 6C0 959 655 F HW: 6C0 959 655 F
Component: VW20Airbag733 001 0360
Revision: -------- Serial number: 003RJ003NK4D
Coding: 88CCC000000000005C5400CF000800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 36362C34A8C5D937C75-8062
Subsystem 1 - Part No SW: ----------- HW: 410 820 906 15
Component: SideSensor_Df 151 0800
Serial number: 3575H00B51AC0682F20N
Subsystem 2 - Part No SW: ----------- HW: 410 820 906 15
Component: SideSensor_Pf 151 0800
Serial number: 3585H00B31AC0683612F
Subsystem 3 - Part No SW: ----------- HW: 442 152 506 15
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00B91AC53B3919O
Subsystem 4 - Part No SW: ----------- HW: 442 152 506 15
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00BB1AC53B4419N
Part No SW: 6V0 920 730 A HW: 6V0 920 730 A
Component: KOMBI 105 1420
Coding: 0724010021000008010808001000000000000000
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 323E102444ADC517EBD-8066
Address 19: CAN Gateway (J533) Labels: 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 087
Component: GW MQB A0 H08 0084
Revision: -------- Serial number: 001368003882
Coding: 030000042F0A640000000000000000010001050000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_VW26.rod
VCID: 6594BB7845E362AFBEF-8030
Subsystem 1 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 22163633342821249920
U1101 00 [008] - Active
Reset counter: 119
Mileage: 44112 km
Date: 2017.03.04
Time: 01:52:49
Supply voltage: Terminal 30: 11.7 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serial number: CF6R0981
Coding: 000300
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW_SE26.rod
VCID: 6D84C3589D135AEFF6F-8038
1094656 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 79
Mileage: 44112 km
Date: 2017.03.04
Time: 00:14:47
1073664 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
Reset counter: 79
Mileage: 44112 km
Date: 2017.03.04
Time: 00:14:47
1073920 - Steering End Stops Not Learned
Reset counter: 79
Mileage: 44112 km
Date: 2017.03.04
Time: 00:14:47
Address 5F: Information Electr. (J794) Labels: 3V0-035-MIB-ENT2.clb
Part No SW: 6V0 035 867 C HW: 6V0 035 867 C
Component: MU-E--ER 852 6490
Serial number: 16061500012730
Coding: 036200003C0000005011000101000A00000000C40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_SK26.rod
VCID: 3C223E1C96E90367311-8068
U1400 00 [008] - -
Reset counter: 114
Mileage: 43610 km
Date: 2017.01.03
Time: 08:35:45
Voltage terminal 30: 5.7 V
End----------(Elapsed Time: 00:46, VBatt start/end: 12.0V/11.9V)-----------
Address 44: Steering Assist Labels: 6RX-909-144-V2.clb
Control Module Part Number: 6C1 909 144 AG HW: 6C1 909 144 D
Component and/or Version: EPS_TRW_ALow 312 3232
Software Coding: 000300
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_SteerAssisUDSTRW 016026 (VW26)
Reset counter: 80
Mileage: 44141 km
Date: 2017.03.04
Time: 01:53:38
Reset counter: 80
Mileage: 44141 km
Date: 2017.03.04
Time: 01:53:38
Reset counter: 80
Mileage: 44141 km
Date: 2017.03.04
Time: 01:53:38
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP90.clb
Control Module Part Number: 6C0 907 379 K HW: 6R0 907 379 BA
Component and/or Version: ESP9.0i H03 0004
Software Coding: 41F5247D492633C10917106B0054822492CC9008000DCA098F00
Work Shop Code: WSC 13765 031 00000
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020 (VW26)
Reset counter: 80
Mileage: 44141 km
Date: 2017.03.04
Time: 01:54:28
U0428 00 [137] - -
Reset counter: 80
Mileage: 44141 km
Date: 2017.03.04
Time: 01:54:28
U0428 00 [137] - -
Reset counter: 80
Mileage: 44141 km
Date: 2017.03.04
Time: 01:54:28
Reset counter: 80
Mileage: 44141 km
Date: 2017.03.04
Time: 01:54:28
U0428 00 [137] - -
Reset counter: 80
Mileage: 44141 km
Date: 2017.03.04
Time: 01:54:28
U0428 00 [137] - -
Reset counter: 80
Mileage: 44141 km
Date: 2017.03.04
Time: 01:54:28
Please see: http://forums.ross-tech.com/showthread.php?1905-UDS-Vs-non-UDSOne update. On my vcds [meas blocks=08] is disabled
No, if I knew where to find a procedure for it in this car with ESP9.0i and EPS_TRW_ALow, I would have posted a link.Do You have any solution hou to calibrate tthis sensor?
6351360 - Crash Shut-Down Activated
P1609 00 [137] - -
Reset counter: 23
Mileage: 797 km
Date: 2015.09.12
Time: 01:48:31
Did you get this to clear Fabia3?
If not can you please recode the controller to match the WSC/Importer# and tester # of the 0x01 ( engine ) Shop #: WSC 73430 031 00063 In 0x15 ( airbag ) & 0x44 ( steering )
Make them all match please..........
We use essential cookies to make this site work, and optional cookies to enhance your experience.
