2012 Q7 TDI Virtual Modules, (Voltage Regulator) & Particulate Filter & P0299 Underboost error?
what2be
Eureka, CA, USA
C?ID=598147
Scan Attached. Starts and Idles fine, as soon as you drive it and it shifts from 1 to 2nd gear the engine stumbles a bit and a few seconds later the glow plug light starts flashing and it goes into limp mode.
1) If I understand this correctly, when the Particulate filter warning icon comes on in the dash, the car will always go into limp mode and the glow plug icon in the dash will blink, correct?
2) The can gateway error (J553, address 19), I looked at all the j numbers in a diagram and there is no physical voltage regulator other than the one thats bolted on the back of the alternator. Is this what the error message is referring to? This error only started showing after I hooked up a dumb charger to the car and was feeding it 40amps for about 3 hours. (I had loaned my smart charger to a friend) I have since purchased a voltage stabilizer and use it when running diagnostics on the car.
Any suggestions?
Monday,16,June,2025,03:18:21:32476
VCDS Version: 25.3.1.1 (x64)  HEX-V2 CB: 0.4671.5
Data version: 20250415 DS365.0
VIN: WA1VMAFE7CD003066   License Plate: Q7
Mileage: 297120km-184621mi   Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
          56 5F 62 69 6C 6D 6F 72 76
VIN: WA1VMAFE7CD003066   Mileage: 297120km-184621miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401     HW: 4L0 907 401 D
   Component: 3.0TDI FSA    H18 0009
   Revision: 54H18---    Serial number:                CVN: 5B6F114C5C3E0D04755A2113
   Coding: 2A2A4012253600050000
   Shop #: WSC 31796 005 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401 002008
   ROD: EV_ECM30TDI0114L2910401_002.rod
   VCID: 61987DF911CE47C2E04-8034
   VINID: 9D10667515951D35000030061896D2B1F1
5585 - Particulate Filter (Bank 1)
          P242F 00 [00100111] - Restricted/Clogged
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 03:06:42
                    Engine speed: 0.00 /min
                    Coolant temperature: 112 ∞C
                    Intake air temperature: 65 ∞C
                    Voltage terminal 30: 13.520 V
                    Crankshaft speed (RPM): 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Exhaust gas jet volume in particle filter: 0.0 m≥/h
                    Particul.filter diff.pressure: -1 hPa
                    Particle filter: oil ash volume: 0.73 l
                    Exh t Adap T Oxi Cat Ds: 212.0 ∞C
                    P Flt Ld fac Ash Cor: 0.4320
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 S    HW: 0C8 927 750 S
   Component: AL1000 AISIN  001 3408
   Serial number:                CVN: 44BD1086
   Coding: 001378
   Shop #: WSC 69905 136 139810
   ROD: EV_TCMAL991031_002.rod
   VCID: 3C26EC8DD6EC4A2A932-8068
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099473
   Shop #: WSC 31414 790 00001
   VCID: 3436C4ADF23C826A5B2-8060
                    Reset counter: 221
                    Mileage: 297126 km
                    Date: 2011.08.12
                    Time: 00:00:39
                    Count: 128
                    Count: 833
                    Count: 297
                    Count: 44800
                    Fault Status: 00101101
                    Reset counter: 221
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 02:48:15
                    Count: 8257
                    Count: 8196
                    Count: 50944
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603401893047
   Coding: 0000135
   VCID: 251029E949E6EBE2DCC-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Component: FBSAUDIC6 IDG   H01 0053
Address 08: Auto HVAC (J255)       Labels: 4L0-910-043.clb
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AJ
   Revision: 00---026    Serial number: 00000030208767
   Coding: 0004A036
   VCID: 251029E945E6EBE2DCC-8070
   Subsystem 1 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
   Component: SLR-B8  H05 0006
   Serial number:           0012461892
   Coding: 070000
   Subsystem 2 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
   Serial number:           0012461828
   Coding: 070000
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 221
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 03:06:51
                    Temperature: 30.0∞C
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0139123
   VCID: 6E8216C5DC90E8BA6D6-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 15: Airbags        Labels: 4L0-910-655.clb
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09VDZ9
   Coding: 0014131
   VCID: 2B04DFD12F02DD920A8-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME180D265AK
   Subsystem 3 - Serial number: 6342QSME180D2C78R
   Subsystem 4 - Serial number: 6352QSME195E225AP
   Subsystem 5 - Serial number: 6362QSME685C2972T
   Subsystem 6 - Serial number: 63734SME315C3C7CD
   Subsystem 7 - Serial number: 63834SME045B217E3
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
   Component: J0527               0830
   Revision: 00H07000    Serial number: 90025111660484
   Coding: 0012242
   VCID: 280E20DD3EF4F68AE7A-807C
   Component: E0221           H03 0030
Address 17: Instruments (J285)       Labels:. 4L0-920-KOM-V3.clb
   Part No SW: 4L0 920 984 R    HW: 4L0 920 984 R
   Component: KOMBIINSTR.   H22 0411
   Revision: 00000000    Serial number: LMZ04009C
   Coding: 8BD664040900CF05020205
   VCID: 42DA9275B4883CDAD9E-8016
                    Reset counter: 221
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 03:06:52
   Part No SW: 4F0 907 468 Q    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0047
   Revision: MB300033    Serial number: 3300M11819012B
   Coding: 00CF07
   VCID: 3D20E189CD764322A4C-8068
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790354551
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 221
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 03:06:51
                    Bin. Bits:    10111
                    Voltage: 13.30 V
                    Count: 7
                    Bin. Bits:    10011
                    Time: 25.40 s
03705 - Voltage Regulator
                    Reset counter: 221
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 03:07:46
                    Bin. Bits:    10111
                    Voltage: 13.30 V
                    Count: 7
                    Bin. Bits:    10011
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Revision: 00---010    Serial number: 00000000318817
   Coding: 0000006
   VCID: 688E60DDFE74368A27A-803C
                    Fault Status: 01101101
                    Reset counter: 221
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 03:06:56
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000013015459
   Coding: 00581B00000011110000
   VCID: 323AC2B504288C5A49E-8066
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E02D6C51C10A8BA2D6-807A
   Subsystem 3 - Serial number: 5F19.08.1100H010003C912704ˇ
   Subsystem 4 - Serial number: 912704ˇ
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000012886533
   Coding: 011F57205E40440004
   VCID: 48CE805D92B4168A07A-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H11 0120
   Revision: 0120 ---    Serial number: 01556943850000
   Coding: 3569693
   VCID: 382EF09DEE54660A77A-806C
                    Fault Status: 01101100
                    Fault Frequency: 150
                    Reset counter: 221
                    Mileage: 297094 km
                    Date: 2025.06.01
                    Time: 04:10:25
   Part No SW: 4L0 035 223 H    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H03 0130
   Revision: CH003000    Serial number: 00000000009532
   Coding: 030000
   VCID: 270C23E13FEAF9F2EE0-8072
Address 4C: Tire Pressure II
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000095857
   Coding: 0012001
   VCID: 5EE246052C30783ADD6-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000013387741
   VCID: 47CC83619FAA19F20E0-8012
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000031
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H52 0076
   Revision: AB001007    Serial number: 156I50B7547359
   Coding: 020007010000000000
   VCID: 1F1C3B0167BA3132960-804A
   Part No SW: 4L2 035 746 B    HW: 4L2 035 746
   Component: H-BNT-NA      H42 0422
   Revision: --------    Serial number: 097I.0B7503442
   Coding: 180200060004E3EF51002345EF632003140000000100000000
   VCID: 2D00D1C91D16D3A214C-8078
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H42 0094
   Serial number: 9466GT0A0034437
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000001906487
   Component: CD-Database  3371
                    Reset counter: 221
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 03:06:47
                    Bin. Bits: 00000000 10000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000013005192
   Coding: 010E57204040230004
   VCID: 46D28E6598A000FAF56-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000156551204
   Coding: 0200000000000000
   VCID: 3138CDB9012EB742304-8064
   Revision: --H08---    Serial number: 525PA8-J3442LQ
   Coding: 1021201
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C861CCDEA8C1AAA432-8038
   Subsystem 3 - Serial number: RD08.09.11--H57001001A0268ˇ
   Subsystem 4 - Serial number: 1A0268ˇ
   Component: ILM HINTEN 2    H07 0080
   Revision: AAH07080    Serial number: 118895293-----
   Coding: 0003595
   VCID: 26122EE534E0E0FAD56-8072
   Component: J_245_EE16_SKB10H11 0220
   Component: J_394_EE16_SKB10H11 0220
   Component: J_392_EE16_SKB10H11 0220
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000013005343
                    Fault Status: 01101000
                    Reset counter: 221
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 03:06:46
   Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
   Component: Parkhilfe 8-Kan H03 0500
   Revision: 00H03000    Serial number: 37361123701717
   Coding: 0231266
   VCID: 2A0ADAD520F8C49AF1E-807E
End----------(Elapsed Time: 02:19, VBatt start/end: 13.6V/13.6V)-----------
------------------------------11 Faults Found------------------------------
I would think so. There's likely a LIN bus connection between the Gateway and the Voltage Regulator that allows the Gateway to command the voltage produce by the alternator, and thus affect the load the alternator puts on the engine. The voltage the Gateway commands will depend on the battery's state-of-charge, as well as engine operating conditions.
I'm not sure. What I find interesting about that fault is the fact that the freeze-frame data shows it at 0 rpm, 0 road speed, and 0 load.
Let's do a very basic check. Tell us what you see in these measuring values, both with key on, engine off, and with the engine idling:
IDE00427 -- Particle filter: difference pressure (hPa)
IDE00428 -- DPF: offset for differential pressure (hPa)
what2be
Eureka, CA, USA
C?ID=598147
Key On Engine Off:
00427 actual 7 hPa
00428 actual -4 hPa
Key On Engine ON (idling)
00427 actual 8 hPa
00428 actual -4 hPa
what2be
Eureka, CA, USA
C?ID=598147
Also, I have a hard time believing the particulate filter is clogged. I found the paperwork from when the customer took the car to the dealer for the emission warranty (dieselgate) and the work was done on April 2022 and the mileage was 183,328. A few months after that she parked the car and it sat until sept of 2024 and I drove it from then until now. The current mileage is 184,625 (difference of 1,297 miles). The emissions are still under warranty until april 2025 but the nearest dealer is 300 miles away, which is why I would like to get it out of limp mode and drive it to them to have the DEF system looked at. When I first got the car it said the DEF was low and needed filled but the tank was full. And The lasts time I drove the car it said "150 miles until no start" or something like that. I might have drove it 50 miles and thats when it wouldnt start again.
Should I remove the particulate filter and take a look? I also replaced the ECU, do you think it is possible it still had def info from the last car the ECU was in? And I did do a reset of tank level and also a reset of learned values of particle filter but when I tried to do a service regeneration of particulate filter it failed after a few minutes.
Key On Engine Off:
00427 actual 7 hPa
00428 actual -4 hPa
00427 actual 8 hPa
00428 actual -4 hPa
That's not right. 00427 should be 0 with key on, engine off.
You can try this Basic Setting:
IDE00468 -- Resetting of learned values of difference pressure sensor
Engine must not be running when you do this.
But my sense is that you need a new differential pressure sensor. The fact that it only increases by 1 hPa with the engine idling is unrealistic. The other possibility is that the plumbing between the exhaust and that sensor is not up to snuff; either a leak or a clog in one of the two pipes.
what2be
Eureka, CA, USA
C?ID=598147
Well ill be honest, I took the differential sensor apart yesterday before I posted the scan and the bigger of the 2 hose barbs broke off so I epoxied it back on. I ordered a new one but it wont be here until later this week. I did try to put my air nozzle down each tube but it sure didnt feel like either one was flowing very well. I took the cap off the def tank and it *MAY HAVE* seemed like it blew easier through the line but im not 100% sure of that. I do know it did not flow easily like it was a open tube on the other end. I assume these 2 lines go to the def tank and def fluid runs through them? If thats the case there was nothing in either line that I would assume would be there if in fact the def fluid runs through that sensor. ALso, The tank is 100% full but I still think it should have flown better than it did.
I did do as you suggested and reset IDE00468 as well as a few other ones I noticed in there. and also tried to do a service particulate filter and the first tiime I tried it died as I put my foot on the accelerator and the second time it worked better, the rpms went to 3,000 and stayed there for a few minutes and then it aborted the test. The funny thing is now its showing 2% on the particulate filter and no errors when I scan. Howerever, I do have the old engine errors that I was getting previously (P0299) scan attached.
Monday,16,June,2025,18:09:11:32476
VCDS Version: 25.3.1.2 (x64)  HEX-V2 CB: 0.4671.5
Data version: 20250604 DS365.0
   VCID: 61987DF911CE47C2E07-8034
5171 - Boost Pressure Regulation
          P0299 00 [01100101] - Control Range Not Reached
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 18:00:58
                    Engine speed: 3002.50 /min
                    Normed load value: 83.5 %
                    Coolant temperature: 80 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 14.120 V
                    Charge Pressure Actuator: activation: 80.54 %
                    Charge air pressure actuator: acknowledgment: 80.55 %
                    Ambient temperature: 18.0 °C
                    Charge air pressure: specified value: 1676 hPa
                    Air mass: actual value (mg/stroke): 334.7 mg/stroke
                    Actual charge pressure: 1012 hPa
12896 - Boost Pressure Regulation
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 18:00:58
                    Charge Pressure Actuator: activation: 80.52 %
   Coding: 001378
   VCID: 3C26EC8DD6EC4A2A931-8068
   Revision: 00H02001
   Coding: 0099473
   VCID: 3436C4ADF23C826A5B1-8060
                    Reset counter: 222
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 17:54:51
                    Count: 321
                    Count: 297
                    Count: 43520
   Coding: 0000135
   VCID: 251029E949E6EBE2DCF-8070
   Coding: 0004A036
   VCID: 251029E945E6EBE2DCF-8070
   Coding: 070000
   Coding: 070000
                    Reset counter: 222
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 17:54:56
                    Temperature: 29.0°C
   Coding: 0139123
   VCID: 6E8216C5DC90E8BA6D5-803A
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0014131
   VCID: 2B04DFD12F02DD920AB-807E
   Coding: 0012242
   VCID: 280E20DD3EF4F68AE79-807C
   VCID: 42DA9275B4883CDAD9D-8016
                    Reset counter: 222
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 17:54:56
   Coding: 00CF07
   VCID: 3D20E189CD764322A4F-8068
                    Reset counter: 222
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 17:54:56
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 7
                    Bin. Bits:    10011
                    Time: 13.10 s
                    Reset counter: 222
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 17:56:04
                    Bin. Bits:    11111
                    Voltage: 13.50 V
                    Count: 7
                    Bin. Bits:    10011
   Coding: 0000006
   VCID: 688E60DDFE74368A279-803C
                    Reset counter: 222
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 17:55:01
   VCID: 323AC2B504288C5A49D-8066
   Coding: 0010001
   VCID: 2E02D6C51C10A8BA2D5-807A
   Subsystem 3 - Serial number: 5F19.08.1100H010003C912704ÿ
   Subsystem 4 - Serial number: 912704ÿ
   VCID: 48CE805D92B4168A079-801C
   Coding: 3569693
   VCID: 382EF09DEE54660A779-806C
                    Fault Frequency: 158
                    Reset counter: 222
                    Mileage: 297094 km
                    Date: 2025.06.01
                    Time: 04:10:25
   Coding: 030000
   VCID: 270C23E13FEAF9F2EE3-8072
   Coding: 0012001
   VCID: 5EE246052C30783ADD5-800A
   VCID: 47CC83619FAA19F20E3-8012
   Coding: 0000031
   VCID: 1F1C3B0167BA3132963-804A
   VCID: 2D00D1C91D16D3A214F-8078
                    Reset counter: 222
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 17:54:56
   VCID: 46D28E6598A000FAF55-8012
   VCID: 3138CDB9012EB742307-8064
   Coding: 1021201
                    Reset counter: 222
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 18:02:17
                        Reverse OFF
                    Count: 3
   VCID: 6C861CCDEA8C1AAA431-8038
   Subsystem 3 - Serial number: RD08.09.11--H57001001A0268ÿ
   Subsystem 4 - Serial number: 1A0268ÿ
   Coding: 0003595
   VCID: 26122EE534E0E0FAD55-8072
                    Reset counter: 222
                    Mileage: 297126 km
                    Date: 2025.06.16
                    Time: 17:54:51
   Coding: 0231266
   VCID: 2A0ADAD520F8C49AF1D-807E
End----------(Elapsed Time: 02:15, VBatt start/end: 13.1V/12.5V)-----------
------------------------------12 Faults Found------------------------------
Address 0x01,4L2 910 401 ,UDS Basic Settings,IDE02107-Resetting of learned values of turbocharger
Address 0x01,4L2 910 401 ,UDS Basic Settings,IDE07372-Particulate filter test
You have a massive boost leak.
Post your DPF loads... similar to this
                Address 01: Engine  (7P0 907 401 K)
  IDE00432   Particle filter: time since last regeneration 13407 s
  IDE00433   Particle filter: oil ash volume 0.31 l
  IDE00434   Particle filter: soot mass calculated 18.88 g
  IDE00435   Particle filter: soot mass measured 14.76 g
  IDE00436   Particle filter: kilometers since last regeneration 200547 m
  IDE01922   Vehicle distance driven 225339 km
  IDE03386   Long-term adaptation of reduction agent dosage 0.98
  IDE05857   DPF statistics: current measured charging rate 0.0735 g/km
  IDE06983-MAS05392   Diesel emissions re-treatment: status-Average distance between DPF regenerations 268 km
  IDE07197   Average reducing agent since lest filling 1.06 l/1000 km
what2be
Eureka, CA, USA
C?ID=598147
Ill post my DPF loads in the morning.i did find a hole in the big hose that goes to the differential pressure sensor. After replacing it my readings are 0 and zero idling for IDE00427 and IDE00428.
0 with key on, engine off is what it should be.
0 with engine idling is implausible.
what2be
Eureka, CA, USA
C?ID=598147
Ok, I replaced the DPF Pressure sensor, my readings are:
Engine off: 1 and 1
Engine On: (00427) initially 28-30 then settles at 19
(00428) 1
Now my scan looks like this:
Saturday,28,June,2025,11:22:29:32476
Mileage: 297140km-184634mi   Repair Order:
VIN: WA1VMAFE7CD003066   Mileage: 297140km-184634miles
                    Mileage: 297144 km
                    Date: 2011.08.12
                    Time: 00:17:48
                    Coolant temperature: 79 °C
                    Voltage terminal 30: 12.600 V
                    Exhaust gas jet volume in particle filter: 0.0 m³/h
                    Particul.filter diff.pressure: 2 hPa
                    Exh t Adap T Oxi Cat Ds: 327.2 °C
   Coding: 001378
   Revision: 00H02001
   Coding: 0099473
                    Reset counter: 225
                    Mileage: 297142 km
                    Date: 2011.08.12
                    Count: 128
                    Count: 837
                    Count: 297
                    Count: 43264
   Coding: 0000135
   Coding: 0004A036
   Coding: 070000
   Coding: 070000
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 226
                    Mileage: 297144 km
                    Date: 2011.08.12
                    Time: 00:18:09
                    Temperature: 24.0°C
   Coding: 0139123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0014131
   Coding: 0012242
                    Reset counter: 226
                    Mileage: 297144 km
                    Date: 2011.08.12
                    Time: 00:17:58
   Coding: 00CF07
                    Reset counter: 226
                    Mileage: 297144 km
                    Date: 2011.08.12
                    Time: 00:17:57
                    Bin. Bits:    10111
                    Voltage: 12.30 V
                    Count: 7
                    Bin. Bits:    10011
                    Time: 25.40 s
                    Reset counter: 226
                    Mileage: 297144 km
                    Date: 2011.08.12
                    Time: 00:18:52
                    Bin. Bits:    10111
                    Voltage: 12.00 V
                    Count: 7
                    Bin. Bits:    10011
   Coding: 0000006
                    Reset counter: 226
                    Mileage: 297144 km
                    Date: 2011.08.12
                    Time: 00:18:14
   Coding: 0010001
   Coding: 3569693
                    Fault Frequency: 236
                    Reset counter: 226
                    Mileage: 297094 km
                    Date: 2025.06.01
                    Time: 04:10:25
   Coding: 030000
   Coding: 0012001
   Coding: 0000031
                    Reset counter: 226
                    Mileage: 297144 km
                    Date: 2011.08.12
                    Time: 00:17:52
   Coding: 1021201
                    Reset counter: 226
                    Mileage: 297144 km
                    Date: 2011.08.12
                    Time: 00:20:07
                        Reverse OFF
                    Count: 3
   Coding: 0003595
                    Reset counter: 226
                    Mileage: 297144 km
                    Date: 2011.08.12
                    Time: 00:17:52
   Coding: 0231266
End----------(Elapsed Time: 02:24, VBatt start/end: 12.2V/12.2V)-----------
Address 0x01,4L2 910 401 ,UDS Basic Settings,IDE00471-Service regeneration of particle filter
Address 0x01,4L2 910 401 ,UDS Basic Settings,IDE01936-Resetting of learned values of exh.gas recirc. valve
                Address 01: Engine  (4L2 910 401 )
11:28:49
  IDE00347   Air mass: actual value: 19.55 g/s
  IDE00427   Particle filter: difference pressure 26 hPa
  IDE00428   DPF: offset for differential pressure 1 hPa
  IDE00432   Particle filter: time since last regeneration 1483 s
  IDE00433   Particle filter: oil ash volume 0.73 l
  IDE00434   Particle filter: soot mass calculated 13.37 g
  IDE00435   Particle filter: soot mass measured 16.34 g
11:28:51
  IDE00347   Air mass: actual value: 20.44 g/s
  IDE00427   Particle filter: difference pressure 28 hPa
  IDE00432   Particle filter: time since last regeneration 1486 s
  IDE00434   Particle filter: soot mass calculated 13.38 g
11:28:52
  IDE00427   Particle filter: difference pressure 27 hPa
  IDE00432   Particle filter: time since last regeneration 1487 s
You need to replace the DPF..... the capacity on a CATA DPF is .46L and you're so far past that, that it isn't even funny.
I'm actually shocked that the vehicle has managed to accumulate that much ash based on the ODO reading.... it must've been really abused and\or driven very poorly to have to regen so much.
I really wonder on what basis the ECU determines ash load.
I'd suspect is based on some model as a function of active regens.
what2be
Eureka, CA, USA
C?ID=598147
She used it mostly to run her kids to/from school, appts, etc. Very short trips (less than 5 miles) multiple times per day.
what2be
Eureka, CA, USA
C?ID=598147
Well after cleaning the particulate filter I put it back together and I must have strained the EGT sensor in the Particulate filter because now I get ERROR, EGT Sensor 1000 Celsius. So, ordered a EGT sensor. Hopefully that will do it. One thing Im concerned about is that if the particulate filter is within limits and I am able to drive to the dealer and have them address the emission issues still under warranty, what will happen if the particulate filter shows as working ok? Will the previous scans showing it plugged be sufficient or are they going to deny replacing it? I know from the records when it was serviced for the diesel gate fiasco they replaced everything except the particulate filter, and I think I know why... the bolts between the flext pipe flange and the particulate filter were rusted to the point they had all but dissolved and had to be cut off. Let me say that was not a fun job by any means. Also, I noticed they had missed the particulate pressure hose that had multiple holes in it from (im guessing) too much heat due to its location so close to the flex pipe. When I called the dealer you cant buy the hose (of course not) you have to buy the whole assembly which includes the hoses and metal lines and hoses again that run up to the DEF Pressure sensor on the firewall. Cost? $410. Since that will be convered under warranty I rigged up a temporary solution using a portion of the original rubber hose that didnt have a hole in it and then a metal tube with another portion of the original rubber hose to connect to the original metal tube. I figure since she already had to buy a DEF Pressure sensor (which would have been covered by warranty) I wasnt about to have her spend $410 for something covered under warranty. This Q7 has been a absolute pain in the ass. The only thing left is to address the TPMS issue which is another question I have. It doesent see the TMPS II module, which is the one that needs to be recoded. Can VCDS do coding for that module even if the old one cant be read?
Why would you have done "anything" if you're still under Dieselgate warranty? You've essentially just screwed yourself out of warranty!
Extended Emissions Warranty Information​
The vehicle has an Extended Emissions Warranty that runs for 10 years or 120,000 miles from the original in-service date. Please see your Audi dealership for additional information including the vehicle's in-service date.
In addition, and concurrently, the Extended Emissions Warranty runs for 4 years or 48,000 miles (whichever occurs first) from the date of modification or first dealer resale post-modification. Your vehicle was modified on Apr 28, 2022 and 183,328 miles. Please see your Audi dealership for additional information on the vehicle's post-modification dealer re-sale date.
:banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead:
