And module improper code
jayhemrick
Virginia Beach, USA
C?ID=610701
Got a 2012 Tiguan with every light on the dash. I found some codes on an old forum and used them. The module accepted the codes but now it says improperly coded. The red brake light did go out and the abs light and staying on instead of blinking. Anyway here is the vin WVGAV7AX0CW590286 any help is greatly appreciated!
Dr Sheldon
Windsor UK
C?ID=334979
Your post is poorly written !!
It is not possible to gather what you are asking or telling !!
Start with Posting an Autoscan
Ziddywerks
Northern NJ USA
C?ID=208579
Post an auto scan. Also which module is imporperly coded? If you dont have a backup of old coding I can provide correct coding for a small fee if you're in a rush.
jayhemrick
Virginia Beach, USA
C?ID=610701
first time poster trying to figure out how to get it on here
jayhemrick
Virginia Beach, USA
C?ID=610701
Monday,16,June,2025,10:37:10:39586
VIN: WVGAV7AX0CW590286   License Plate: 1234
Mileage: 146040km-90745mi   Repair Order:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4C 52 53 56 62 72
          77
VIN: WVGAV7AX0CW590286   Mileage: 146040km-90745miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 997 029 N    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2    1518
   Revision: P3H07---    Serial number:
   Coding: 0423010A19070160
   Shop #: WSC 39807 001 1048576
   VCID: 42DDB67F68867B3A09F-8016
   VINID: 9E65D19874680139C5240088187C6A7DE1
               U1017 - 000 -
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 00:28:25
                    RPM: 812 /min
                    Load: 24.7 %
                    Temperature: 101.0°C
                    Temperature: 55.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.335 V
               U1017 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 00:28:28
                    RPM: 808 /min
                    Load: 24.3 %
                    Temperature: 55.0°C
                    Voltage: 13.335 V
               U1017 - 000 -
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:28:37
                    RPM: 948 /min
                    Load: 25.9 %
                    Temperature: 79.0°C
                    Temperature: 39.0°C
                    Voltage: 13.462 V
Readiness: 1010 0101
   Part No SW: 09G 927 750 LR    HW: 09G 927 750 LR
   Component: AQ 250 6F           1971
   Revision: 00H90000    Serial number:
   Coding: 0000840
   VCID: 0C4158471A42FD4A333-8058
01681 - ABS Wheel Speed Signal; Rear Left
            013 - Check DTC Memory
01682 - ABS Wheel Speed Signal; Rear Right
                    Fault Status: 01101101
                    Reset counter: 201
                    Mileage: 63744 km
                    Date: 2018.08.09.
                    Time: 04:50:00
   Part No SW: 5N0 614 109 AP    HW: 5N0 614 109 AP
   Component: J104   C6 450M VD55 0005
   Revision: --H07---    Serial number: 00000005638388
   Coding: 0054593
   Shop #: WSC 01357 551 00000
   VCID: 79AF119345D0F8E2185-802C
12 Faults Found:
                    Reset counter: 85
                    Speed: 252.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.00 V
                    Bin. Bits: 00000000
                    Count: 215
                    Hex Value: 0x0000
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Fault Status: 00101100
                    Reset counter: 125
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:34:37
                    Hex Value: 0x0000
                    Voltage: 13.25 V
                    Bin. Bits: 00011111
                    Count: 179
                    Hex Value: 0x0000
03842 - RPM Sensor Rear Right: Incorrect Signal
                    Reset counter: 125
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:34:37
                    Hex Value: 0x0000
                    Voltage: 13.25 V
                    Bin. Bits: 00011111
                    Count: 180
                    Hex Value: 0x0000
03201 - Adaptation Overboost
                    Reset counter: 125
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:34:37
                    Reset counter: 125
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:34:37
                    Reset counter: 125
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:34:37
                    Reset counter: 125
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:34:37
                    Reset counter: 125
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:34:37
                    Reset counter: 125
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:34:37
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 125
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:34:37
                    Reset counter: 125
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:34:37
                    Reset counter: 125
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:34:37
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001018
   Coding: 0000001002
   VCID: 00597C772A8AA92A5FB-8054
   Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
   Component: BCM PQ35 B    021 0064
   Revision: BG021001
   Coding: 6F180A1B80232EC4008800C11000044448010086524D8D60648000000040
   VCID: 392FD193095038E2585-806C
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 20031  013 0203
   Serial number: N1955119   °203!
   Coding: 009795
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 79
                    Mileage: 145806 km
                    Date: 2019.11.07.
                    Time: 00:08:53
                        Term 15 Off
                    Voltage: 12.70 V
   Part No SW: 5N0 959 655 S    HW: 5N0 959 655 S
   Component: J234__20G VW10 HI   2118
   Revision: 24017000    Serial number: 003L6P4N8PL7
   Coding: 0012359
   VCID: 4DC79543A1D8B442E4D-8018
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 00000000004UP6
   Subsystem 3 - Serial number: 0017.02.120000300000630063ÿ†63
   Subsystem 4 - Serial number: 630063ÿ†6332MTS666350672 ÿ†63
   Subsystem 5 - Serial number: 50672 ÿ†6342MTS694150672 ÿ†63
   Subsystem 6 - Serial number: 50672 ÿ†6351HTS6C9ND1AKR ÿ†63
   Subsystem 7 - Serial number: D1AKR ÿ†6361HTS6V3IANAKJ ÿ†63
   Subsystem 8 - Serial number: ANAKJ ÿ†63727TS61QNUMAKJ ÿ†63
   Subsystem 9 - Serial number: UMAKJ ÿ†63827TS6KGB81AKR ÿ
   Subsystem 10 - Serial number: 81AKR ÿ
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - MIL ON
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:34:56
   Part No SW: 5K0 953 501 AQ    HW: 5K0 953 569 F
   Revision: FF010040    Serial number: 20120319300667
   Coding: 5980140000
   VCID: 79AF11934950F8E2185-802C
1140738 - Steering angle sensor
          B1168 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 75
                    Mileage: 145653 km
                    Date: 2025.06.16.
                    Time: 00:09:47
                    UBat: 12.10 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
Address 17: Instruments
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 140312F2000576
   Coding: 356002
   VCID: 3A2DCE9F0C5633FA51F-806E
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 75
                    Mileage: 145653 km
                    Date: 2019.11.07.
                    Time: 00:09:51
   Component: IMMO          H04 0617
   VCID: 6A8D3EDF3CF6437AE1F-803E
   Revision: A1001003    Serial number: 7662175300
   VCID: 290F01D3F9F08862285-807C
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0004528356
   Coding: 0004B4
   VCID: 3829D49732DA21EAA7B-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1504
   Serial number: 00000006601004
   Coding: 000490
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.285 1002
   Revision: 1AH03836    Serial number: 00120680279701
   Coding: 0000258
   Shop #: WSC 01324 020 00200
   VCID: 3C21C8870A620DCA433-8068
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 85
                    (no units): 4.0
                    Voltage: 12.10 V
                    Reset counter: 85
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 01:36:16
                    (no units): 4.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 7
                    Fault Status: 11101101
                    Fault Frequency: 17
                    Reset counter: 85
                    Mileage: 146047 km
                    Date: 2019.11.07.
                    Time: 03:28:37
                    RPM: 947 /min
                    (no units): 7.0
                    Voltage: 13.50 V
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0004583700
   Coding: 0004B4
   VCID: 392FD19309D038E2585-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1504
   Serial number: 00000006602629
   Coding: 000490
   Revision:   H19       Serial number: 00000000062817
   Coding: 0026156
   VCID: 3635DAAF344ED79AB57-8062
                    Fault Status: 01110000
                    Reset counter: 85
                    Mileage: 229153 km
                    Date: 2019.11.07.
                    Time: 00:01:06
                    Voltage: 11.60 V
                    Count: 41
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 01110101
                    Reset counter: 85
                    Mileage: 229153 km
                    Date: 2019.11.07.
                    Time: 00:01:06
                    Voltage: 11.60 V
                    Count: 99
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 01111101
                    Fault Frequency: 14
                    Reset counter: 85
                    Mileage: 229153 km
                    Date: 2019.11.07.
                    Time: 00:01:07
                    Voltage: 11.60 V
                    Count: 69
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 5N0 035 164 D    HW: 5N0 035 164 D
   Component: LOW NAR Tig   H02 0004
   Revision: -----03S    Serial number: VWZ4Z6M3309964
   Coding: 0100040004000C
   VCID: 2A0DFEDFFCF6837A21F-807E
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007662140319 Dataset Number: 5K0035730E  0001
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270B07EBEF64BE123E1-8072
End----------(Elapsed Time: 01:24, VBatt start/end: 12.0V/12.1V)-----------
Address 03,5N0 614 109 AP,recoded (Short coding),from,0054593,to,0010530,(01357/551/00000),
Address 03,5N0 614 109 AP,recoded (Short coding),from,0054593,to,0000034,(01357/551/00000),
Address 03,5N0 614 109 AP,recoded (Short coding),from,0054593,to,0014636,(01357/551/00000),
Address 0x03,5N0 614 109 AP,Basic Settings,Group 040
Address 0x03,5N0 614 109 AP,Basic Settings,Group 042
Address 0x03,5N0 614 109 AP,Basic Settings,Group 060
Address 0x03,5N0 614 109 AP,Basic Settings,Group 061
Address 0x03,5N0 614 109 AP,Basic Settings,Group 066
Address 03: DTCs cleared
Address 03,5N0 614 109 AP,recoded (Short coding),from,0014636,to,0011554,(01357/551/00000),
Address 03,5N0 614 109 AP,recoded (Short coding),from,0014636,to,0002356,(01357/551/00000),
Address 03,5N0 614 109 AP,recoded (Short coding),from,0014636,to,0031023,(01357/551/00000),
Address 03,5N0 614 109 AP,recoded (Short coding),from,0031023,to,0011567,(01357/551/00000),
Address 03,5N0 614 109 AP,recoded (Short coding),from,0011567,to,0002356,(01357/551/00000),
Address 03,5N0 614 109 AP,recoded (Short coding),from,0011567,to,0014636,(01357/551/00000),
Address 16: DTCs cleared
Address 0x16,5K0 953 501 AQ,UDS Basic Settings,IDE02284-Steering angle sensor: carry out zero calibration
Address 0x16,5K0 953 501 AQ,UDS Basic Settings,IDE02285-Steering angle sensor: reset zero calibration
And assumed they would be appropriate for your car? ;)
Based on your CodingLog, it looks like 0054593 was the original coding for this ABS? That looks to be what's in there now as well.
Do you have a scan from when it was healthy?
jayhemrick
Virginia Beach, USA
C?ID=610701
No I bought it like this
Ziddywerks
Northern NJ USA
C?ID=208579
I can provide the correct coding for the ABS unit for a small fee if you don't have a backup as the coding is incorrect.
Ziddywerks
Northern NJ USA
C?ID=208579
Correct coding provided. Asked OP to update thread with findings after coding.
