- Jun 15, 2025
- 23
- 4
- Suffolk, VA, USA
- C?ID=533407
2008 (manufactured April 2008) VW Passat 2.0 TSI, automatic, 100k miles.
Newly acquired car that my wife bought for our 16 year old son. Said it didn't have a CEL when she bought it...but now it does!
P119A Fuel Pressure Sensor (G247)
P0171 Fuel Trim; Bank 1
The car seems to drive fine, decent performance for a 17 year old car with 100,000 miles on it. I have checked the crankcase breather (PCV) assembly and it seems to be in working order. I removed it, inspected the diaphragm, conducted a
suck/blow test on it(has suction, but restricts blowing). I sprayed starting fluid/ether around the intake manifold looking for any vacuum leaks, nothing apparent. I also sprayed ether into the transmission inspection port in attempts to check the rear main seal integrity. No change in RPM or idle(there is oil present at the inspection port, but the injection/HPFP pump is leaky so that could be the cause of that oil leak). Fuel pressures seem to be in range according to VCDS readings. From a sticker under the hood, it looks like the timing belt(chain?), water pump and tensioner were replaced in 2021 at 83k miles. Not sure where to start looking next. Any help is appreciated.
Saturday,07,June,2025,18:15:18:36368
VCDS Version: 25.3.1.1 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
VIN: WVWJK73C78P125111 License Plate: 123456
Mileage: 161210km-100171mi Repair Order: jetta4brady
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
VIN: WVWJK73C78P125111 Mileage: 161210km-100171miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 026 AG HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 3319
Revision: AAH03--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 00017 666 02302
VCID: 6FBBDF190B95ED72660-803A
VINID: 9E69DA6C70D31C880108504104196359E4
004506 - Fuel Pressure Sensor (G247)
P119A - 000 - Malfunction - Intermittent - MIL ON
Fault Status: 10100000
Fault Frequency: 8
Mileage: 161170 km
Date: 2025.06.06
Time: 17:00:20
RPM: 836 /min
Load: 25.9 %
Temperature: 64.0 C
Temperature: 42.0 C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
000369 - Fuel Trim; Bank 1
P0171 - 000 - System Too Lean - MIL ON
Fault Status: 11100000
Mileage: 161167 km
Date: 2025.06.06
Time: 11:09:53
RPM: 844 /min
Load: 34.5 %
Temperature: 99.0 C
Temperature: 53.0 C
Voltage: 13.335 V
Readiness: 0000 0101
Part No SW: 09G 927 750 HD HW: 09G 927 750 HD
Component: AQ 250 6F 1176
Revision: 00H76000 Serial number:
Coding: 0000840
Shop #: WSC 00028 028 00001
VCID: 7AADFE4D40D7B8DAC1E-802E
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 K HW: 3C0 614 109 K
Component: J104 C4 440 V2 0005
Revision: --020--- Serial number: 00000785529147
Coding: 0000348
VCID: 2615FA3DE4EFEC3AD56-8072
Part No SW: 1K0 820 047 HR HW: 1K0 820 047 HR
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 7BA3FB494FED81D2DA8-802E
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000005655567
Coding: 10840F0340041A00470000000F000000000859435C000100000000000000
VCID: 71BFD9611DA1FB82704-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 180308 003 0205
Coding: 00046997
Shop #: WSC 00028
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__01F VW10 HI 1815
Revision: 19013000 Serial number: 0039BP6Y446G
Coding: 0012614
Subsystem 1 - Part No: 3C0 959 339 D
Component: BF-Gewichtsens. 001 0002
Subsystem 2 - Serial number: 00000000000MZX
Subsystem 3 - Serial number: 0027.02.080000100000850002 63
Subsystem 4 - Serial number: 850002 6333FTS632770798 63
Subsystem 5 - Serial number: 70798 6343FTS631300668 63
Subsystem 6 - Serial number: 00668 6353ETS6CCPUSVNP 63
Subsystem 7 - Serial number: USVNP 6363ETS6OSRUSVNP 63
Subsystem 8 - Serial number: USVNP 6374CTS6ONPUSVNP 63
Subsystem 9 - Serial number: USVNP 6384CTS62VJUSVNP
Subsystem 10 - Serial number: USVNP
Reset counter: 22
Mileage: 156971 km
Date: 2024.03.19
Time: 14:23:28
03551 - Functional Restriction of Seat Occupied Recognition
000 - - - Intermittent - MIL ON
Fault Frequency: 9
Reset counter: 23
Mileage: 156971 km
Date: 2024.03.19
Time: 14:23:28
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AB HW: 3C0 953 549 AB
Component: J0527 0020
Revision: 00026000 Serial number: 3C5953507AP
Coding: 0001013
VCID: 6C81C8153A83166A432-8038
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 F HW: 3C0 920 971 F
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007205
VCID: 2809F405EEFBFA4AE7A-807C
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P0840702EC
Coding: FD807F070012021002
VCID: 2313E32997DD1912B28-8076
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1166279TSD6706
VCID: 6D87C51101991F6254C-8038
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 64397 004 1048576
VCID: 73B3D36967BDC992828-8026
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
01176 - Key
Fault Status: 01101000
Reset counter: 55
Mileage: 161170 km
Date: 2025.06.06
Time: 11:38:54
02861 - Electronic Steering Column Lock Check Sum Error
Fault Frequency: 23
Reset counter: 74
Mileage: 159581 km
Date: 2024.10.10
Time: 13:32:54
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1131
Revision: 32008001 Serial number: 00000109588330
Coding: 0001205
VCID: 3B233B490F6D41D29A8-806E
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
VCID: 35372D71294997A26CC-8060
Component: KSG PQ46 RDK 051 0221
Coding: 13910F8001862E521004141FF08A0F0E085801
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000532688322
Coding: 0001204
VCID: 3C2138550A6346EA932-8068
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000441589
Coding: 0000057
VCID: 290FF101F5F1C342F84-807C
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 D HW: 1K0 035 161 D
Component: Radio DE2 017 0021
Revision: 00017000 Serial number: VWZ4Z7H6340662
Coding: 0040401
VCID: 2019EC2586CB020AAFA-8074
Part No SW: 1K0 959 703 AD HW: 1K0 959 795 P
Component: J388 TUER-SG HL 0308
Revision: 42004101 Serial number: 00000000301152
Coding: 0001168
VCID: 72BDD66D18A7C09A89E-8026
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 AD HW: 1K0 959 794 P
Component: J389 TUER-SG HR 0308
Revision: 42004101 Serial number: 00000000297650
Coding: 0001168
End----------(Elapsed Time: 01:25, VBatt start/end: 13.9V/13.8V)-----------
------------------------------6 Faults Found-------------------------------
