Differences in Audi Electromechanical Steering Racks for B8.5 S4
atbro199
Northern Virginia, USA
C?ID=594802
My original electromechanical steering rack died in my 2016 S4, non dynamic steering, and I bought an AEE remanufacturered rack because a new OEM is more than twice the price. The reman unit that was provided to me has different part numbers all over it, including the large embedded part number on the rack itself.
The large, raised part number on the AAE reman unit is 4G1423105F. On the other side, the part number on the electronic section is 8R0909144B. The number 4G1423105F when googled appears to be more related to the A6/A7.
On my broken unit, the large raised part number is 8K1423105A and the electronic section is 8K0909144B.
Are the part numbers for non-dynamic eletromechanical steering across the A4/A5/A6/A7/Q5 platforms the same? Or should I exchange it and roll the dice for another?
Do you have a Auto-Scan with the original rack installed; if so please post that complete and unedited auto scan so the forum can see all the relevant information on your S4.
I don't believe that reman rack is going to work out for you.
atbro199
C?ID=594802
Sunday,27,April,2025,17:14:47:42314
VCDS Version: 24.7.0.0 (x64)
VIN: WAUDGAFL1GA001177   License Plate:
Mileage: 65520km-40712mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56 5F
          62 6C 72 A9
VIN: WAUDGAFL1GA001177   Mileage: 65520km-40712miles
Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0007
   Revision: --H07---    CVN: 14D7E3E6
   Coding: 0A190034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
   ROD: EV_ECM30TFS021_AU48.rod
   VCID: 3A7B6DF4BDFAD346CD-806E
   VINID: 9D19545D159C0574400010471C90F2D3D5
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 281D1A01
   Shop #: WSC 06325 000 00000
   VCID: 0919C238A09C08DE94-805C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 8
                    Reset counter: 242
                    Mileage: 65420 km
                    Date: 2025.04.26
                    Time: 11:41:38
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x000C
                    Hex Value: 0xC09A
                    Hex Value: 0x0000
                    Reset counter: 242
                    Mileage: 65527 km
                    Date: 2025.04.27
                    Time: 16:21:58
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x001A
                    Hex Value: 0x0297
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 KM    HW: 8K0 907 064 KM
   Component: BCM2 2.0      H15 0711
   Coding: 0F814040000000000000
   VCID: 0501CE088C846CBEF0-8050
   Serial number: 3215000094137007
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01280520152946
   Coding: 6600228000
   VCID: 77FDB4C0C6680E2EF2-8022
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00001081873102
   Coding: 26000091863CAFE0240048C300003D0D0F9C9308A2090221000008004000030100000030000000
   VCID: 78FFB7FCCB760156FB-802C
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA270415  H19 0461
   Serial number: 1504230603924
   Coding: 004577
   Serial number: 20318862
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000805150514
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z0B99802C
   Serial number: 3CB8CBA7000000000001
   Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NDD138M88   Dataset Number: 8K0909602S  0001
   Coding: 303844354730383131304A55304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4B953830E2605ACE66-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R150000LNH0
   Serial number: 6334MSME510A055A9
   Serial number: 6344MSME511B6948J
   Serial number: 6352QSME16544F46M
   Serial number: 6362QSME39583866Q
   Serial number: 63732SME684C3678A
   Serial number: 63832SME684C3E5CL
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372OE5000E1
   Coding: 000016
   VCID: 4487130CC73E95B6A7-8010
   Part No SW: 8K0 920 983     HW: 8K0 920 983
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 63-664M5G
   Coding: 8BB509008301D705020000
   VCID: 72EB85D4AD0A6B06C5-8026
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z155150A11
   Coding: 80C303FF00
   VCID: 4C973B2CEF6E5DF66F-8018
   Serial number: 9159866403
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H15 0100
   Serial number: 002203150001031 Dataset Number: 8K0909104D  0025
   VCID: 2F6D4CA076B806EE6A-807A
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000145006518
   Coding: 00581B00000000000000
   VCID: 3B7568F0BAC0EA4ED6-806E
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0369752517 Dataset Number: 8K0909535J  0029
   Coding: 010211
   Shop #: WSC 06324 000 00000
   VCID: 3F8D1CE0A6D8F66EFA-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0369128828
   Coding: 010211
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H10 0305
   Coding: 011C13204E00410001
   VCID: 56A3D94421A21726C9-8002
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0012807362 Dataset Number: 8K0909852L  0026
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3E7361E4A1D2FF66F1-806A
7341600 - Position Sensor for Motor
          C10AD 29 [00001000] - Signal Implausible
                    Reset counter: 27
                    Mileage: 65527 km
                    Date: 2025.04.26
                    Time: 16:26:54
                    Write only channel
7341570 - Position Sensor for Motor
          C10AD 29 [10001001] - Signal Implausible
                    Mileage: 65418 km
                    Date: 2025.04.26
                    Time: 11:17:17
                    Write only channel
   Revision: 00002001    Serial number: 0368488565
   Coding: 0106023A00FA404580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000997965
   Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J245 PS051  H08 0043
   Revision: 00005001    Serial number: 94813044491806
   VCID: 2D5156A874B474FE58-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H10 0305
   VCID: 55A1DE483CA41C3EC0-8000
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 10000000545880
   ROD: EV_ParkiBrake_AU48.rod
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156E50F8269933
   Coding: 020007010000000001
   VCID: 2447B38C277EB5B687-8070
   Part No SW: 8R1 035 746 H    HW: 8R1 035 746 G
   Component: H-BNT-NA      H43 0937
   Revision: --------    Serial number: 523F00FB005776
   Coding: 110200000206A1EF55028B5E00000403140000000000000000
   VCID: 3C776BECBFCEED76DF-8068
   Subsystem 1 - Part No: 8R0 060 884 CS
   Component: NAR 2015  1201
   Component: DU7 High  H42 0104
   Serial number: A130EV0F3364870
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000002249970
   Component: CD-Database  6208
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H08 0305
   Coding: 010C13204000210001
   VCID: 59B9D27850BC385EE4-800C
   Revision: --H09---    Serial number: 525PA8-JA391UD
   Coding: 1000006
   VCID: 387F77FC4BF6C1563B-806C
   Component: TSG HR        H08 0305
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0006
   Serial number: 150514201908
   VCID: 72EB85D4A50A6B06C5-8026
End-------------------------(Elapsed Time: 04:12)--------------------------
Ziddywerks
Northern NJ USA
C?ID=208579
8K0909144B was the original. The only number that matters is the engraved number on the unit. None of the other ones matter, unless your rack was assembled from 2 or 3 different ones to make one good one. If the vehicle wasnt totaled it would be covered under the extension, but because its totaled it no longer applies. By the looks of the codes you have that rack is shot to shit.
atbro199
C?ID=594802
So the reman unit I have now isn’t correct for the S4, hence the numbers starting with a different set of characters? I’ll get another reman unit then with the correct numbers.
And yes. Unfortunately in my efforts to save my car after a minor accident resulted in this BS, so no extended warranty for me despite water intrusion into the rack.
Ziddywerks
Northern NJ USA
C?ID=208579
Yes agreed. 4G is a6 and a7, 8K is a4 s4.
PhilipCurrier
Northern VA, USA
C?ID=618315
i was wondering what you ended up doing. I have the part number 8k1423105a as a replacement but it was also a reman but it parts from different racks as there were different numbers throughout it. i have a 2014 s4 and the rack that came off of it was a 8k1423105 that was stamped with a 8k1423105xx from the people who also reman that one. Do you have a social you could help me out on? this is my first time using this forum.
PhilipCurrier
Northern VA, USA
C?ID=618315
Replacing my steering rack due to water getting in it and im over the 125k miles / 10 years warranty.
I have the part number 8k1423105a as a replacement but it was also a reman but it parts from different racks as there were different numbers throughout it. i have a 2014 s4 and the rack that came off of it was a 8k1423105 that was stamped with a 8k1423105xx from the people who also remanufactured that one. I have non dynamic steering and the one i bought came off of a low mileage 2015 a4. Dealership said i should have 8k1423055cg on the car but clearly i dont.
vin:
WAUDGAFL4EA018200
atbro199
C?ID=594802
I had bad luck with this process. In total, I went through three AEE reman racks because the first one was bad out of the box (made a grinding noise), so I obtained a second one that ended up being 4G1423105F that I was asking about in this thread because somebody swapped it and put it in the wrong box, so I exchanged it with AEE for third, a fresh reman that ended up being installed with zero issues.
There are many part numbers all over the rack so it's very confusing. One of the main things to know is if you need a rack for dynamic steering. My car didn't come with dynamic so it made things a little easier. From what I can tell, the only number that really matters is the ETCHED number in the body of the rack. This etched number should match the sticker (that has a QR code on it) for OEM racks. My renam racks didn't have this sticker but the etched part number still existed. I believe the part number of the reman rack I finally installed was 8K1423055AS. The original OEM from the broken unit was 8K1423055CA. But as somebody else said, these reman parts could be put together by Frankenstein, parts from multiple units into one. At the end of the day, I was screwed out of a several hunred due to installation labor costs from that first malfunctioning rack so as long as my new one works, I'm OK with it.
You'll need to code the part to your car for it to work.
Hope this helps.
PhilipCurrier
Northern VA, USA
C?ID=618315
Than you for the reply, so you were saying the new etched in part number is what i should be referring to as my part number insteadof the old etched in one? also how did you know to go with that part number in the end? also sorry i have some pictures of the new used one i ordered and the old one but couldnt figure out how to attach them to this thread so if youd like i could email those for better understanding. I ordered off of LKQ and got there 6 month warranty so if i had ti i could return i believe. what part number do you think i should be getting?
atbro199
C?ID=594802
Yes. The etched number represents the overall part. I found this out by using the Audi parts search and confirmed it. I don’t have a picture of any of my etched part numbers but here is an eBay ad with the etched number on picture #9. https://ebay.us/m/rgqyaG
If your part came from an A5 you’re probably good, as long as it matches your dynamic/non-dynamic option.
AudiZine might be a good place to ask this as well.
PhilipCurrier
Northern VA, USA
C?ID=618315
okay because i thought someone had said in a forum that the ratios between the A class racks were different and not made for the perfomance from S class cars so the s class ones were different. In the 9th pic it has 2 etched out part numbers are you referring to the newer looking etched out part number which is light grey or the darker older one
PhilipCurrier
Northern VA, USA
C?ID=618315
I also found out it was off a 2015 Audi A4 not A5 my mistake but id think it'd be the same.
atbro199
C?ID=594802
I have no clue about the ratios claim, but I would be interested in learning but only from a trusted source.
As for the pics, the part number in light gray matches the OEM QR code sticker. That sticker is normally not on reman units (not on any of mine) so the only information to go off of is that light gray etching.
If you take your vin, type it into the Audi parts page, search for steering rack, you’ll see what other cars that part number works on. You’ll also see the revision history with all of the superseded numbers.
PhilipCurrier
Northern VA, USA
C?ID=618315
Sorry im a little confused by what you meant by the part number in light grey matches the OEM QR code sticker. Also my reman part numbers have "xx" and "a_" at the end of them so they aren't on the this page https://audi.oempartsonline.com/oem...9MjAxNCZ0PXByZW1pdW0tcGx1cyZlPTMtMGwtdjYtZ2Fz
So im unsure if mine would even work i can try to email you pictures of both my new and old part numbers and what not and see if that'd help but i saw what u meant by the previous superseded part numbers. The part i bought used off the 2015 a4 Etching was " 8K1423105A_ " . The old one which seems to also be reman'd is this " 8k1423105xx " on the etching and because they are reman'd parts those part numbers dont exist in audi catalog. The Audi dealership told me that there was nothing he could tell me about either of the part numbers even tho that had been sitting on my vehicle except that they had both been reman'd parts.
I have posted on Audizine no replies related to my issue have come from it and reddit got 400 views and no replies and then i made a new thread on ross tech forums and it hasnt seen a reply either and also audi world came up dry so im really at a loss for words and feel like im in the middle of the ocean in a dinghy. You have been my only light at the end of the tunnel so i appreciate you trying to your best to help. I also wanted to say that were both from northern virginia so maybe that'd help except im stuck up near boston with this car trying to get it drivable to get back home to Alexandria Virginia haha. Been such a headache and after all of that i start school in under 3 weeks so im feeling helpless
Dr Sheldon
Windsor UK
C?ID=334979
WOW !!
After all that foolishness we have the realisation that the right part for the right car fitted the right way may be the answer to the conundrum ?
What a great idea !!
PhilipCurrier
Northern VA, USA
C?ID=618315
vin:
WAUDGAFL4EA018200
Haven't seen much activity on any audi forum groups so trying to push this to get more views
Threads merged. There's no reason to have two different threads for this saga.
